[PATCH 2/2] libbsp/or1ksim: Fix warnings.
Hesham ALMatary
heshamelmatary at gmail.com
Fri Oct 10 16:45:13 UTC 2014
c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c | 2 +-
c/src/lib/libbsp/or1k/or1ksim/console/uart.c | 15 +++++++++++----
2 files changed, 12 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
index ad49d07..4169a11 100644
--- a/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
+++ b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
@@ -137,8 +137,8 @@ CPU_Counter_ticks _CPU_Counter_difference(
#define Clock_driver_support_install_isr(isr, old_isr) \
do { \
- or1ksim_clock_handler_install(isr, old_isr); \
old_isr = NULL; \
+ or1ksim_clock_handler_install(isr, old_isr); \
} while (0)
#define Clock_driver_support_shutdown_hardware() or1ksim_clock_cleanup()
diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
index 7ceca81..31cdce6 100644
--- a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
+++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
@@ -21,6 +21,14 @@
#include <bsp/uart.h>
#include <rtems/score/isr.h>
+static void uart_initialize(int minor);
+static int uart_first_open(int major, int minor, void *arg);
+static int uart_last_close(int major, int minor, void *arg);
+static int uart_read_polled(int minor);
+static ssize_t uart_write(int minor, const char *buf, size_t len);
+static void uart_write_polled(int minor, char c);
+static int uart_set_attributes(int minor, const struct termios *t);
static rtems_vector_number uart_get_irq_number(const console_tbl *ct)
return ct->ulIntVector;
@@ -86,10 +94,9 @@ static int uart_last_close(int major, int minor, void *arg)
return 0;
-static char uart_read_polled(int minor)
unsigned char lsr;
- char c;
/* Get a character when avaiable */
do {
@@ -120,7 +127,7 @@ static void uart_write_polled(int minor, char c)
} while ( (lsr & transmit_finished) != transmit_finished );
-static ssize_t uart_write_support_polled(
int minor,
const char *s,
size_t n
@@ -145,7 +152,7 @@ const console_fns or1ksim_uart_fns = {
.deviceFirstOpen = uart_first_open,
.deviceLastClose = uart_last_close,
.deviceRead = uart_read_polled,
- .deviceWrite = uart_write_support_polled,
+ .deviceWrite = uart_write,
.deviceInitialize = uart_initialize,
.deviceWritePolled = uart_write_polled,
.deviceSetAttributes = uart_set_attributes,
1.9.3
