[PATCH 1/2] libcpu/or1k: Fix warnings.
Hesham Moustafa heshamelmatary at gmail.com
Mon Oct 13 18:05:18 UTC 2014
On Mon, Oct 13, 2014 at 7:03 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 10/13/2014 11:45 AM, Hesham Moustafa wrote:
> Missed patch?
>  Yep. Committed now. This should address a bunch of the or1ksim
> build warnings. I fixed another in console/uart.c for an unused
> variable.
> Thanks. There is another patch I submitted earlier that fixes some uart.c
warnings, part of it this unused variable. I will reply to it.
> Starting another build of all BSPs to see if I fixed all
> "-Wunused-variables"
> cases.
> Thanks.
>  On Fri, Oct 10, 2014 at 7:23 PM, Hesham ALMatary <
> heshamelmatary at gmail.com> wrote:
>>  c/src/lib/libcpu/or1k/shared/cache/cache.c  | 16 ++++++++--------
>>  c/src/lib/libcpu/or1k/shared/cache/cache_.h |  1 +
>>  2 files changed, 9 insertions(+), 8 deletions(-)
>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c
>> b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>> index 039be36..afc8859 100644
>> --- a/c/src/lib/libcpu/or1k/shared/cache/cache.c
>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
>> @@ -71,7 +71,7 @@ static inline void
>> _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
>>    _ISR_Disable (level);
>> -  _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, d_addr);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, (uintptr_t) d_addr);
>>    _ISR_Enable(level);
>> @@ -81,7 +81,7 @@ static inline void
>> _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
>>     ISR_Level level;
>> -  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, d_addr);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, (uintptr_t) d_addr);
>>    _ISR_Enable(level);
>> @@ -91,7 +91,7 @@ static inline void
>> _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
>>     ISR_Level level;
>> -  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, d_addr);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, (uintptr_t) d_addr);
>>    _ISR_Enable(level);
>> @@ -101,7 +101,7 @@ static inline void
>> _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
>>     ISR_Level level;
>> -  _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, d_addr);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, (uintptr_t) d_addr);
>>    _ISR_Enable(level);
>> @@ -111,7 +111,7 @@ static inline void
>> _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
>>     ISR_Level level;
>> -  _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, d_addr);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, (uintptr_t) d_addr);
>>    _ISR_Enable(level);
>> @@ -122,7 +122,7 @@ static inline void
>> _CPU_OR1K_Cache_instruction_block_prefetch
>>     ISR_Level level;
>> -  _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, d_addr);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, (uintptr_t) d_addr);
>>    _ISR_Enable(level);
>> @@ -133,7 +133,7 @@ static inline void
>> _CPU_OR1K_Cache_instruction_block_invalidate
>>     ISR_Level level;
>> -  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, d_addr);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, (uintptr_t) d_addr);
>>    _ISR_Enable(level);
>> @@ -144,7 +144,7 @@ static inline void
>> _CPU_OR1K_Cache_instruction_block_lock
>>     ISR_Level level;
>> -  _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, d_addr);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, (uintptr_t) d_addr);
>>    _ISR_Enable(level);
>> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>> b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>> index 5f08410..0ea939f 100644
>> --- a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
>> @@ -6,6 +6,7 @@
>>  #define __OR1K_CACHE_H
>>  #include <bsp/cache_.h>
>> +#include <libcpu/cache.h>
>>  #endif
>>  /* end of include file */
>> 1.9.3
> Joel Sherrill, Ph.D.             Director of Research & Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141013/b55797d9/attachment-0002.html>
