rtems-rfs-rtems.c Warning
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Sun Oct 12 20:56:41 UTC 2014
Hi
With networking disabled and tests=samples, the arm/lpc2362
and 39 other ARM BSPs only have two warnings.  One of those
is the one in main_cp.c which I just pinged the list.
Let's see if these can be fixed and we get a nice set of BSPs to
build warning free in this configuration. :)
$ grep warning: log/arm-lpc2362.log
../../../../../../rtems/c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:19:
warning: assignment makes integer from pointer without a cast [enabled
by default]
../../../../../../rtems/c/src/../../cpukit/libmisc/shell/main_cp.c:108:1: warning:
'rtems_shell_cp_exit' defined but not used [-Wunused-function]
Don't worry if these turn out to be simple. Harder cases remain
but I wanted to see some 0's on the board. :)
