Batch of Patches from Joel
Mon Oct 13 15:18:45 UTC 2014
On 10/13/2014 9:48 AM, Gedare Bloom wrote:
> These 23 look good to me. -Gedare
Thanks. I know this many patches is a real pain but it
is unfortunately needed to get the warning count down.
The unique warning count has dropped from ~1750 to
~800 in the past week. Of those ~800, there are still
533 "no previous prototypes" left to look at.  I am
sticking to adding static or addressing .h files but we
still have to figure out what to do about C methods
that are only referenced from .S files. :)
NOTE: For defaults for weak symbols, I am just adding
a prototype to the C file.
Committing. Thanks.
--joel
> On Mon, Oct 13, 2014 at 10:13 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> It was rainy here over the weekend and I hacked at warnings.
>> I have a branch with 80 patches pending. That is obviously
>> too much to send to devel in one batch. This is the first
>> batch of 23 and these are the more unique patches and
>> a couple of cases of "apply a pattern"
>> + Clean up, then remove mips/clock because it was not even compiled
>> + delete unused rtems_shell_cp_exit()
>> + PowerPC bootloader patch round 2 to address Gedare's comments
>> + add <bsp/bootcard.h> to files where that fixed warnings
>> + eliminate odd and unused debug methods from some m68k consoles
>> Beyond this, the next patch of patches will be the same old warning
>> removal tricks and clean up. Make things static, correct types, etc.
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
