[PATCH 25/54] libcpu/m68k/mcf5206/clock/ckinit.c: Fix warnings
Mon Oct 13 15:37:09 UTC 2014
 c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c | 156 +++++++++------------------
 1 file changed, 48 insertions(+), 108 deletions(-)
diff --git a/c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c b/c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c
index e3ff932..c28c541 100644
--- a/c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c
+++ b/c/src/lib/libcpu/m68k/mcf5206/clock/ckinit.c
@@ -3,7 +3,9 @@
  *  This driver initailizes timer1 on the MCF5206E as the
  *  main system clock
  *  Author: Victor V. Vengerov <vvv at oktet.ru>
  *  Based on work:
@@ -29,27 +31,9 @@
 volatile uint32_t   Clock_driver_ticks;
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
 rtems_isr (*rtems_clock_hook)(rtems_vector_number) = NULL;
-/* Clock_isr --
- *     This handles the timer interrupt by clearing the timer's interrupt
- *     flag and announcing the clock tick to the system.
- * PARAMETERS:
- *     vector - timer interrupt vector number
- * RETURNS:
- *     none
-rtems_isr
+static rtems_isr
 Clock_isr (rtems_vector_number vector)
   /* Clear pending interrupt... */
@@ -62,111 +46,67 @@ Clock_isr (rtems_vector_number vector)
       rtems_clock_hook(vector);
-/* Clock_exit --
- *     This shuts down the timer if it was enabled and removes it
- *     from the MCF5206E interrupt mask.
- * PARAMETERS:
- *     none
- * RETURNS:
- *     none
 void
 Clock_exit(void)
-    if (rtems_configuration_get_ticks_per_timeslice())
-        /* disable all timer1 interrupts */
-        *MCF5206E_IMR(MBAR) |= MCF5206E_INTR_BIT(MCF5206E_INTR_TIMER_1);
+  /* disable all timer1 interrupts */
+  *MCF5206E_IMR(MBAR) |= MCF5206E_INTR_BIT(MCF5206E_INTR_TIMER_1);
-        /* reset timer1 */
-        *MCF5206E_TMR(MBAR,1) = MCF5206E_TMR_ICLK_STOP;
+  /* reset timer1 */
+  *MCF5206E_TMR(MBAR,1) = MCF5206E_TMR_ICLK_STOP;
-        /* clear pending */
-        *MCF5206E_TER(MBAR,1) = MCF5206E_TER_REF | MCF5206E_TER_CAP;
+  /* clear pending */
+  *MCF5206E_TER(MBAR,1) = MCF5206E_TER_REF | MCF5206E_TER_CAP;
-/* Install_clock --
- *     This initialises timer1 with the BSP timeslice config value
- *     as a reference and sets up the interrupt handler for clock ticks.
- * PARAMETERS:
- *     clock_isr - clock interrupt handler routine
- * RETURNS:
- *     none.
 static void
 Install_clock(rtems_isr_entry clock_isr)
-    Clock_driver_ticks = 0;
-        /* Configure timer1 interrupts */
-        *MCF5206E_ICR(MBAR,MCF5206E_INTR_TIMER_1) =
-            MCF5206E_ICR_AVEC |
-            ((BSP_INTLVL_TIMER1 << MCF5206E_ICR_IL_S) & MCF5206E_ICR_IL) |
-            ((BSP_INTPRIO_TIMER1 << MCF5206E_ICR_IP_S) & MCF5206E_ICR_IP);
-        /* Register the interrupt handler */
-        set_vector(clock_isr, BSP_INTVEC_TIMER1, 1);
-        /* Reset timer 1 */
-        *MCF5206E_TMR(MBAR, 1) = MCF5206E_TMR_RST;
-        *MCF5206E_TMR(MBAR, 1) = MCF5206E_TMR_ICLK_STOP;
-        *MCF5206E_TCN(MBAR, 1) = 0; /* Reset counter */
-        *MCF5206E_TER(MBAR, 1) = MCF5206E_TER_REF | MCF5206E_TER_CAP;
-        /* Set Timer 1 prescaler so that it counts in microseconds */
-            (((BSP_SYSTEM_FREQUENCY/1000000 - 1) << MCF5206E_TMR_PS_S) &
-             MCF5206E_TMR_PS) |
-            MCF5206E_TMR_CE_NONE | MCF5206E_TMR_ORI | MCF5206E_TMR_FRR |
-            MCF5206E_TMR_RST;
-        /* Set the timer timeout value from the BSP config */
-        *MCF5206E_TRR(MBAR, 1) = rtems_configuration_get_microseconds_per_tick() - 1;
-        /* Feed system frequency to the timer */
-        *MCF5206E_TMR(MBAR, 1) |= MCF5206E_TMR_ICLK_MSCLK;
-        /* Enable timer 1 interrupts */
-        *MCF5206E_IMR(MBAR) &= ~MCF5206E_INTR_BIT(MCF5206E_INTR_TIMER_1);
-        /* Register the driver exit procedure so we can shutdown */
-        atexit(Clock_exit);
+  Clock_driver_ticks = 0;
+  /* Configure timer1 interrupts */
+  *MCF5206E_ICR(MBAR,MCF5206E_INTR_TIMER_1) =
+      MCF5206E_ICR_AVEC |
+      ((BSP_INTLVL_TIMER1 << MCF5206E_ICR_IL_S) & MCF5206E_ICR_IL) |
+      ((BSP_INTPRIO_TIMER1 << MCF5206E_ICR_IP_S) & MCF5206E_ICR_IP);
+  /* Register the interrupt handler */
+  set_vector(clock_isr, BSP_INTVEC_TIMER1, 1);
+  /* Reset timer 1 */
+  *MCF5206E_TMR(MBAR, 1) = MCF5206E_TMR_RST;
+  *MCF5206E_TMR(MBAR, 1) = MCF5206E_TMR_ICLK_STOP;
+  *MCF5206E_TCN(MBAR, 1) = 0; /* Reset counter */
+  *MCF5206E_TER(MBAR, 1) = MCF5206E_TER_REF | MCF5206E_TER_CAP;
+  /* Set Timer 1 prescaler so that it counts in microseconds */
+      (((BSP_SYSTEM_FREQUENCY/1000000 - 1) << MCF5206E_TMR_PS_S) &
+       MCF5206E_TMR_PS) |
+      MCF5206E_TMR_CE_NONE | MCF5206E_TMR_ORI | MCF5206E_TMR_FRR |
+      MCF5206E_TMR_RST;
+  /* Set the timer timeout value from the BSP config */
+  *MCF5206E_TRR(MBAR, 1) = rtems_configuration_get_microseconds_per_tick() - 1;
+  /* Feed system frequency to the timer */
+  *MCF5206E_TMR(MBAR, 1) |= MCF5206E_TMR_ICLK_MSCLK;
+  /* Enable timer 1 interrupts */
+  *MCF5206E_IMR(MBAR) &= ~MCF5206E_INTR_BIT(MCF5206E_INTR_TIMER_1);
+  /* Register the driver exit procedure so we can shutdown */
+  atexit(Clock_exit);
-/* Clock_initialize --
- *     This is called to setup the clock driver. It calls the hardware
- *     setup function and make the driver major/minor values available
- *     for other.
- * PARAMETERS:
- *     major - clock device major number
- *     minor - clock device minor number
- *     pargp - device driver initialization argument (not used)
- * RETURNS:
- *     RTEMS status code
 rtems_device_driver
 Clock_initialize(rtems_device_major_number major,
                  rtems_device_minor_number minor,
                  void *pargp)
-    Install_clock (Clock_isr);
-    /* Make major/minor avail to others such as shared memory driver */
-    rtems_clock_major = major;
-    rtems_clock_minor = minor;
+  Install_clock (Clock_isr);
-    return RTEMS_SUCCESSFUL;
+  return RTEMS_SUCCESSFUL;
1.9.3
