[PATCH 26/54] libcpu/m68k/mcf5272/clock/ckinit.c: Fix warnings
Mon Oct 13 15:37:10 UTC 2014
 c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c | 192 ++++++++++-----------------
 1 file changed, 68 insertions(+), 124 deletions(-)
diff --git a/c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c b/c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c
index 0a81be7..26c5c90 100644
--- a/c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c
+++ b/c/src/lib/libcpu/m68k/mcf5272/clock/ckinit.c
@@ -3,7 +3,9 @@
  *  This driver initailizes timer1 on the MCF5272 as the
  *  main system clock
  *  Copyright 2004 Cogent Computer Systems
  *  Author: Jay Monkman <jtm at lopingdog.com>
@@ -33,148 +35,90 @@
 volatile uint32_t Clock_driver_ticks;
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
 rtems_isr (*rtems_clock_hook)(rtems_vector_number) = NULL;
-/* Clock_isr --
- *     This handles the timer interrupt by clearing the timer's interrupt
- *     flag and announcing the clock tick to the system.
- * PARAMETERS:
- *     vector - timer interrupt vector number
- * RETURNS:
- *     none
-rtems_isr
+static rtems_isr
 Clock_isr (rtems_vector_number vector)
-    /* Clear pending interrupt... */
-    g_timer_regs->ter1 = MCF5272_TER_REF | MCF5272_TER_CAP;
-    /* Announce the clock tick */
-    Clock_driver_ticks++;
-    rtems_clock_tick();
-    if (rtems_clock_hook != NULL) {
-        rtems_clock_hook(vector);
+  /* Clear pending interrupt... */
+  g_timer_regs->ter1 = MCF5272_TER_REF | MCF5272_TER_CAP;
+  /* Announce the clock tick */
+  Clock_driver_ticks++;
+  rtems_clock_tick();
+  if (rtems_clock_hook != NULL) {
+      rtems_clock_hook(vector);
-/* Clock_exit --
- *     This shuts down the timer if it was enabled and removes it
- *     from the MCF5206E interrupt mask.
- * PARAMETERS:
- *     none
- * RETURNS:
- *     none
 void
 Clock_exit(void)
-    if (rtems_configuration_get_ticks_per_timeslice()) {
-        uint32_t icr;
-        /* disable all timer1 interrupts */
-        icr = g_intctrl_regs->icr1;
-        icr = icr & ~(MCF5272_ICR1_TMR1_MASK | MCF5272_ICR1_TMR1_PI);
-        icr |= (MCF5272_ICR1_TMR1_IPL(0) | MCF5272_ICR1_TMR1_PI);
-        g_intctrl_regs->icr1 = icr;
-        /* reset timer1 */
-        g_timer_regs->tmr1 = MCF5272_TMR_CLK_STOP;
-        /* clear pending */
+  uint32_t icr;
+  /* disable all timer1 interrupts */
+  icr = g_intctrl_regs->icr1;
+  icr = icr & ~(MCF5272_ICR1_TMR1_MASK | MCF5272_ICR1_TMR1_PI);
+  icr |= (MCF5272_ICR1_TMR1_IPL(0) | MCF5272_ICR1_TMR1_PI);
+  g_intctrl_regs->icr1 = icr;
+  /* reset timer1 */
+  g_timer_regs->tmr1 = MCF5272_TMR_CLK_STOP;
+  /* clear pending */
-/* Install_clock --
- *     This initialises timer1 with the BSP timeslice config value
- *     as a reference and sets up the interrupt handler for clock ticks.
- * PARAMETERS:
- *     clock_isr - clock interrupt handler routine
- * RETURNS:
- *     none.
 static void
 Install_clock(rtems_isr_entry clock_isr)
   uint32_t icr;
   Clock_driver_ticks = 0;
-      /* Register the interrupt handler */
-      set_vector(clock_isr, BSP_INTVEC_TMR1, 1);
-      /* Reset timer 1 */
-      g_timer_regs->tmr1 = MCF5272_TMR_RST;
-      g_timer_regs->tcn1 = 0;  /* reset counter */
-      /* Set Timer 1 prescaler so that it counts in microseconds */
-      g_timer_regs->tmr1 = (
-          ((((BSP_SYSTEM_FREQUENCY / 1000000) - 1) << MCF5272_TMR_PS_SHIFT) |
-           MCF5272_TMR_CE_DISABLE                                      |
-           MCF5272_TMR_ORI                                             |
-           MCF5272_TMR_FRR                                             |
-           MCF5272_TMR_CLK_MSTR                                        |
-           MCF5272_TMR_RST));
-      /* Set the timer timeout value from the BSP config */
-      g_timer_regs->trr1 = rtems_configuration_get_microseconds_per_tick() - 1;
-      /* Feed system frequency to the timer */
-      g_timer_regs->tmr1 |= MCF5272_TMR_CLK_MSTR;
-      /* Configure timer1 interrupts */
-      icr |= (MCF5272_ICR1_TMR1_IPL(BSP_INTLVL_TMR1) | MCF5272_ICR1_TMR1_PI);
-      /* Register the driver exit procedure so we can shutdown */
-      atexit(Clock_exit);
+  /* Register the interrupt handler */
+  set_vector(clock_isr, BSP_INTVEC_TMR1, 1);
+  /* Reset timer 1 */
+  g_timer_regs->tmr1 = MCF5272_TMR_RST;
+  g_timer_regs->tcn1 = 0;  /* reset counter */
+  /* Set Timer 1 prescaler so that it counts in microseconds */
+  g_timer_regs->tmr1 = (
+      ((((BSP_SYSTEM_FREQUENCY / 1000000) - 1) << MCF5272_TMR_PS_SHIFT) |
+       MCF5272_TMR_CE_DISABLE                                      |
+       MCF5272_TMR_ORI                                             |
+       MCF5272_TMR_FRR                                             |
+       MCF5272_TMR_CLK_MSTR                                        |
+       MCF5272_TMR_RST));
+  /* Set the timer timeout value from the BSP config */
+  g_timer_regs->trr1 = rtems_configuration_get_microseconds_per_tick() - 1;
+  /* Feed system frequency to the timer */
+  g_timer_regs->tmr1 |= MCF5272_TMR_CLK_MSTR;
+  /* Configure timer1 interrupts */
+  icr |= (MCF5272_ICR1_TMR1_IPL(BSP_INTLVL_TMR1) | MCF5272_ICR1_TMR1_PI);
+  /* Register the driver exit procedure so we can shutdown */
+  atexit(Clock_exit);
-/* Clock_initialize --
- *     This is called to setup the clock driver. It calls the hardware
- *     setup function and make the driver major/minor values available
- *     for other.
- * PARAMETERS:
- *     major - clock device major number
- *     minor - clock device minor number
- *     pargp - device driver initialization argument (not used)
- * RETURNS:
- *     RTEMS status code
 rtems_device_driver
-Clock_initialize(rtems_device_major_number major,
-                 rtems_device_minor_number minor,
-                 void *pargp)
+Clock_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *pargp
-    Install_clock (Clock_isr);
-    /* Make major/minor avail to others such as shared memory driver */
-    rtems_clock_major = major;
-    rtems_clock_minor = minor;
+  Install_clock (Clock_isr);
-    return RTEMS_SUCCESSFUL;
+  return RTEMS_SUCCESSFUL;
1.9.3
