[PATCH 30/54] powerpc/score603e/include/bsp.h: Add prototypes to fix warnings
Mon Oct 13 15:37:14 UTC 2014
 c/src/lib/libbsp/powerpc/score603e/include/bsp.h | 6 ++++++
 1 file changed, 6 insertions(+)
diff --git a/c/src/lib/libbsp/powerpc/score603e/include/bsp.h b/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
index 95b89e4..f6e3c5a 100644
--- a/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
@@ -196,6 +196,12 @@ unsigned int SCORE603e_FLASH_Enable_writes(
 #define Convert_Endian_16( _data ) \
   ( ((_data&0x00ff)<<8) | ((_data&0xff00)>>8) )
+ *  Interfaces to required Clock Driver support methods
+int BSP_disconnect_clock_handler(void);
+int BSP_connect_clock_handler(void);
 #endif /* ASM */
 #ifdef __cplusplus
1.9.3
