[PATCH 31/54] powerpc/virtex5/include/bsp.h: Add prototypes to fix warnings
Mon Oct 13 15:37:15 UTC 2014
 c/src/lib/libbsp/powerpc/virtex5/include/bsp.h | 5 +++++
 1 file changed, 5 insertions(+)
diff --git a/c/src/lib/libbsp/powerpc/virtex5/include/bsp.h b/c/src/lib/libbsp/powerpc/virtex5/include/bsp.h
index 8558faa..c5d2dd9 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/virtex5/include/bsp.h
@@ -88,6 +88,11 @@ extern unsigned int BSP_time_base_divisor;
 #define BSP_Convert_decrementer( _value ) \
   ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))
+ *  Interfaces to required Clock Driver support methods
+int BSP_disconnect_clock_handler(void);
+int BSP_connect_clock_handler(void);
 #endif /* ASM */
1.9.3
