[PATCH 34/54] powerpc/shared/clock/clock.c: Remove clock major/minor and clean up
Mon Oct 13 15:37:18 UTC 2014
 c/src/lib/libbsp/powerpc/shared/clock/clock.c | 311 +++++++++++++-------------
 1 file changed, 158 insertions(+), 153 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/shared/clock/clock.c b/c/src/lib/libbsp/powerpc/shared/clock/clock.c
index ed482fa..e9b1d4d 100644
--- a/c/src/lib/libbsp/powerpc/shared/clock/clock.c
+++ b/c/src/lib/libbsp/powerpc/shared/clock/clock.c
@@ -42,10 +42,6 @@ extern uint32_t bsp_time_base_frequency;
 volatile uint32_t Clock_driver_ticks = 0;
-rtems_device_major_number rtems_clock_major = UINT32_MAX;
-rtems_device_minor_number rtems_clock_minor = UINT32_MAX;
 static uint32_t ppc_clock_decrementer_value = PPC_CLOCK_DECREMENTER_MAX;
 static uint32_t ppc_clock_next_time_base;
@@ -54,212 +50,221 @@ static uint64_t ppc_clock_factor;
 static void ppc_clock_no_tick(void)
-	/* Do nothing */
+  /* Do nothing */
 static void (*ppc_clock_tick)(void) = ppc_clock_no_tick;
-static int ppc_clock_exception_handler( BSP_Exception_frame *frame, unsigned number)
+static int ppc_clock_exception_handler(
+  BSP_Exception_frame *frame,
+  unsigned number
-	uint32_t delta = ppc_clock_decrementer_value;
-	uint32_t next = ppc_clock_next_time_base;
-	uint32_t dec = 0;
-	uint32_t now = 0;
-	uint32_t msr = 0;
+  uint32_t delta = ppc_clock_decrementer_value;
+  uint32_t next = ppc_clock_next_time_base;
+  uint32_t dec = 0;
+  uint32_t now = 0;
+  uint32_t msr = 0;
-	do {
-		/* Increment clock ticks */
-		Clock_driver_ticks += 1;
+  do {
+    /* Increment clock ticks */
+    Clock_driver_ticks += 1;
-		/* Enable external exceptions */
-		msr = ppc_external_exceptions_enable();
+    /* Enable external exceptions */
+    msr = ppc_external_exceptions_enable();
-		/* Call clock ticker  */
-		ppc_clock_tick();
+    /* Call clock ticker  */
+    ppc_clock_tick();
-		/* Restore machine state */
-		ppc_external_exceptions_disable( msr);
+    /* Restore machine state */
+    ppc_external_exceptions_disable( msr);
-		/* Next time base */
-		next += delta;
+    /* Next time base */
+    next += delta;
-		/* Current time */
-		now = ppc_time_base();
+    /* Current time */
+    now = ppc_time_base();
-		/* New decrementer value */
-		dec = next - now;
-	} while (dec > delta);
+    /* New decrementer value */
+    dec = next - now;
+  } while (dec > delta);
-	/* Set decrementer */
-	ppc_set_decrementer_register( dec);
+  /* Set decrementer */
+  ppc_set_decrementer_register( dec);
-	/* Expected next time base */
-	ppc_clock_next_time_base = next;
+  /* Expected next time base */
+  ppc_clock_next_time_base = next;
-	return 0;
+  return 0;
-static int ppc_clock_exception_handler_first( BSP_Exception_frame *frame, unsigned number)
+static int ppc_clock_exception_handler_first(
+  unsigned number
-	/* We have to clear the first pending decrementer exception this way */
+  /* We have to clear the first pending decrementer exception this way */
-	if (ppc_decrementer_register() >= 0x80000000) {
-		ppc_clock_exception_handler( frame, number);
+  if (ppc_decrementer_register() >= 0x80000000) {
+    ppc_clock_exception_handler( frame, number);
-	ppc_exc_set_handler( ASM_DEC_VECTOR, ppc_clock_exception_handler);
+  ppc_exc_set_handler( ASM_DEC_VECTOR, ppc_clock_exception_handler);
-	return 0;
+  return 0;
-static int ppc_clock_exception_handler_booke( BSP_Exception_frame *frame, unsigned number)
+static int ppc_clock_exception_handler_booke(
+  unsigned number
-	uint32_t msr;
+  uint32_t msr;
-	/* Acknowledge decrementer request */
-	PPC_SET_SPECIAL_PURPOSE_REGISTER( BOOKE_TSR, BOOKE_TSR_DIS);
+  /* Acknowledge decrementer request */
+  PPC_SET_SPECIAL_PURPOSE_REGISTER( BOOKE_TSR, BOOKE_TSR_DIS);
-	ppc_clock_tick();
+  ppc_clock_tick();
-	return 0;
+  return 0;
 static int ppc_clock_exception_handler_ppc405(BSP_Exception_frame *frame, unsigned number)
-	uint32_t msr;
+  uint32_t msr;
-	/* Acknowledge PIT request */
-	PPC_SET_SPECIAL_PURPOSE_REGISTER(PPC405_TSR, BOOKE_TSR_DIS);
+  /* Acknowledge PIT request */
+  PPC_SET_SPECIAL_PURPOSE_REGISTER(PPC405_TSR, BOOKE_TSR_DIS);
-	ppc_clock_tick();
+  ppc_clock_tick();
-	ppc_external_exceptions_disable(msr);
+  ppc_external_exceptions_disable(msr);
-	return 0;
+  return 0;
 static uint32_t ppc_clock_nanoseconds_since_last_tick(void)
-	uint64_t k = ppc_clock_factor;
-	uint32_t c = ppc_decrementer_register();
-	uint32_t i = ppc_clock_decrementer_value + 1;
+  uint64_t k = ppc_clock_factor;
+  uint32_t c = ppc_decrementer_register();
+  uint32_t i = ppc_clock_decrementer_value + 1;
-	return (uint32_t) (((i - c) * k) >> 32);
+  return (uint32_t) (((i - c) * k) >> 32);
 static uint32_t ppc_clock_nanoseconds_since_last_tick_ppc405(void)
-	uint32_t i = ppc_clock_decrementer_value;
-	uint32_t c = i - PPC_SPECIAL_PURPOSE_REGISTER(PPC405_PIT);
+  uint32_t i = ppc_clock_decrementer_value;
+  uint32_t c = i - PPC_SPECIAL_PURPOSE_REGISTER(PPC405_PIT);
-	if ((PPC_SPECIAL_PURPOSE_REGISTER(PPC405_TSR) & BOOKE_TSR_DIS) != 0) {
-		c = i - PPC_SPECIAL_PURPOSE_REGISTER(PPC405_PIT) + i;
+  if ((PPC_SPECIAL_PURPOSE_REGISTER(PPC405_TSR) & BOOKE_TSR_DIS) != 0) {
+    c = i - PPC_SPECIAL_PURPOSE_REGISTER(PPC405_PIT) + i;
-	return (uint32_t) ((c * k) >> 32);
+  return (uint32_t) ((c * k) >> 32);
 void Clock_exit(void)
-	/* Set the decrementer to the maximum value */
-	ppc_set_decrementer_register( PPC_CLOCK_DECREMENTER_MAX);
+  /* Set the decrementer to the maximum value */
+  ppc_set_decrementer_register( PPC_CLOCK_DECREMENTER_MAX);
-	/* Use default clock handler */
-	ppc_clock_tick = ppc_clock_no_tick;
+  /* Use default clock handler */
+  ppc_clock_tick = ppc_clock_no_tick;
-rtems_device_driver Clock_initialize( rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
+rtems_device_driver Clock_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *arg
-	uint64_t frequency = bsp_time_base_frequency;
-	uint64_t us_per_tick = rtems_configuration_get_microseconds_per_tick();
-	uint32_t interval = (uint32_t) ((frequency * us_per_tick) / 1000000);
-	/* Make major/minor available to others such as shared memory driver */
-	rtems_clock_major = major;
-	rtems_clock_minor = minor;
-	 * Set default ticker.
-	 * The function rtems_clock_tick() returns a status code.  This value
-	 * will be discarded since the RTEMS documentation claims that it is
-	 * always successful.
-	ppc_clock_tick = (void (*)(void)) rtems_clock_tick;
-	/* Factor for nano seconds extension */
-	ppc_clock_factor = (1000000000ULL << 32) / frequency;
-	if (ppc_cpu_is_bookE() != PPC_BOOKE_405) {
-		/* Decrementer value */
-		ppc_clock_decrementer_value = interval - 1;
-		/* Check decrementer value */
-		if (ppc_clock_decrementer_value == 0) {
-			ppc_clock_decrementer_value = PPC_CLOCK_DECREMENTER_MAX;
-			RTEMS_SYSLOG_ERROR( "decrementer value would be zero, will be set to maximum value instead\n");
-		/* Set the nanoseconds since last tick handler */
-		rtems_clock_set_nanoseconds_extension( ppc_clock_nanoseconds_since_last_tick);
-		if (ppc_cpu_is_bookE()) {
-			/* Set decrementer auto-reload value */
-			PPC_SET_SPECIAL_PURPOSE_REGISTER( BOOKE_DECAR, ppc_clock_decrementer_value);
-			/* Install exception handler */
-			ppc_exc_set_handler( ASM_BOOKE_DEC_VECTOR, ppc_clock_exception_handler_booke);
-			/* Enable decrementer and auto-reload */
-			PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS( BOOKE_TCR, BOOKE_TCR_DIE | BOOKE_TCR_ARE);
-		} else {
-			/* Here the decrementer value is actually the interval */
-			++ppc_clock_decrementer_value;
-			/* Initialize next time base */
-			ppc_clock_next_time_base = ppc_time_base() + ppc_clock_decrementer_value;
-			ppc_exc_set_handler( ASM_DEC_VECTOR, ppc_clock_exception_handler_first);
-		/* Set the decrementer value */
-		ppc_set_decrementer_register( ppc_clock_decrementer_value);
-	} else {
-		/* PIT interval value */
-		ppc_clock_decrementer_value = interval;
-		rtems_clock_set_nanoseconds_extension(ppc_clock_nanoseconds_since_last_tick_ppc405);
-		ppc_exc_set_handler(ASM_BOOKE_DEC_VECTOR, ppc_clock_exception_handler_ppc405);
-		/* Enable PIT and auto-reload */
-		PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS(PPC405_TCR, BOOKE_TCR_DIE | BOOKE_TCR_ARE);
-		/* Set PIT auto-reload and initial value */
-		PPC_SET_SPECIAL_PURPOSE_REGISTER(PPC405_PIT, interval);
-	return RTEMS_SUCCESSFUL;
+  uint64_t frequency = bsp_time_base_frequency;
+  uint64_t us_per_tick = rtems_configuration_get_microseconds_per_tick();
+  uint32_t interval = (uint32_t) ((frequency * us_per_tick) / 1000000);
+   * Set default ticker.
+   * The function rtems_clock_tick() returns a status code.  This value
+   * will be discarded since the RTEMS documentation claims that it is
+   * always successful.
+  ppc_clock_tick = (void (*)(void)) rtems_clock_tick;
+  /* Factor for nano seconds extension */
+  ppc_clock_factor = (1000000000ULL << 32) / frequency;
+  if (ppc_cpu_is_bookE() != PPC_BOOKE_405) {
+    /* Decrementer value */
+    ppc_clock_decrementer_value = interval - 1;
+    /* Check decrementer value */
+    if (ppc_clock_decrementer_value == 0) {
+      ppc_clock_decrementer_value = PPC_CLOCK_DECREMENTER_MAX;
+      RTEMS_SYSLOG_ERROR( "decrementer value would be zero, will be set to maximum value instead\n");
+    /* Set the nanoseconds since last tick handler */
+    rtems_clock_set_nanoseconds_extension( ppc_clock_nanoseconds_since_last_tick);
+    if (ppc_cpu_is_bookE()) {
+      /* Set decrementer auto-reload value */
+      PPC_SET_SPECIAL_PURPOSE_REGISTER( BOOKE_DECAR, ppc_clock_decrementer_value);
+      /* Install exception handler */
+      ppc_exc_set_handler( ASM_BOOKE_DEC_VECTOR, ppc_clock_exception_handler_booke);
+      /* Enable decrementer and auto-reload */
+      PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS( BOOKE_TCR, BOOKE_TCR_DIE | BOOKE_TCR_ARE);
+    } else {
+      /* Here the decrementer value is actually the interval */
+      ++ppc_clock_decrementer_value;
+      /* Initialize next time base */
+      ppc_clock_next_time_base = ppc_time_base() + ppc_clock_decrementer_value;
+      ppc_exc_set_handler( ASM_DEC_VECTOR, ppc_clock_exception_handler_first);
+    /* Set the decrementer value */
+    ppc_set_decrementer_register( ppc_clock_decrementer_value);
+  } else {
+    /* PIT interval value */
+    ppc_clock_decrementer_value = interval;
+    rtems_clock_set_nanoseconds_extension(ppc_clock_nanoseconds_since_last_tick_ppc405);
+    ppc_exc_set_handler(ASM_BOOKE_DEC_VECTOR, ppc_clock_exception_handler_ppc405);
+    /* Enable PIT and auto-reload */
+    PPC_SET_SPECIAL_PURPOSE_REGISTER_BITS(PPC405_TCR, BOOKE_TCR_DIE | BOOKE_TCR_ARE);
+    /* Set PIT auto-reload and initial value */
+    PPC_SET_SPECIAL_PURPOSE_REGISTER(PPC405_PIT, interval);
+  return RTEMS_SUCCESSFUL;
1.9.3
