[PATCH 35/54] arm/gba/console: Fix warnings and clean up
Mon Oct 13 15:37:19 UTC 2014
 c/src/lib/libbsp/arm/gba/console/conio.c   | 176 ++++++++++++++++-------------
 c/src/lib/libbsp/arm/gba/console/console.c |  75 ++++++------
 2 files changed, 140 insertions(+), 111 deletions(-)
diff --git a/c/src/lib/libbsp/arm/gba/console/conio.c b/c/src/lib/libbsp/arm/gba/console/conio.c
index 47cf6b4..1027b2a 100644
--- a/c/src/lib/libbsp/arm/gba/console/conio.c
+++ b/c/src/lib/libbsp/arm/gba/console/conio.c
@@ -3,6 +3,7 @@
  *  This file contains the GBA conio I/O package.
  *  RTEMS GBA BSP
@@ -118,21 +119,39 @@ void gba_gotoxy(int _x, int _y)
  *  @param  y screen y coordinate
  *  @return None
-void gba_putchar(char c, int textattr, int x, int y)
+static void gba_putchar(char c, int textattr, int x, int y)
-    int       f = textattr & 0x0F;
-    int       b = textattr >> 4;
-    uint32_t  fmask = f | f<<8 | f<<16 | f<<24;
-    uint32_t  bmask = b | b<<8 | b<<16 | b<<24;
-    uint32_t  *dest = (uint32_t *)&bg_bitmap4a[((y<<1) + y) << 1][x<<2];
-    const uint32_t  *src = (uint32_t *)&(font3x5[(int)c]);
-    uint32_t s;
-    s = *src++; *dest = (fmask&s) | (bmask&~s); dest += GBA_LCD_WIDTH/sizeof(uint32_t);
+  int       f = textattr & 0x0F;
+  int       b = textattr >> 4;
+  uint32_t  fmask = f | f<<8 | f<<16 | f<<24;
+  uint32_t  bmask = b | b<<8 | b<<16 | b<<24;
+  uint32_t  *dest = (uint32_t *)&bg_bitmap4a[((y<<1) + y) << 1][x<<2];
+  const uint32_t  *src = (uint32_t *)&(font3x5[(int)c]);
+  uint32_t s;
+  s = *src++;
+  *dest = (fmask&s) | (bmask&~s);
+  dest += GBA_LCD_WIDTH/sizeof(uint32_t);
+  s = *src++;
+  s = *src++;
+  s = *src++;
+  s = *src++;
+  s = *src++;
@@ -144,7 +163,7 @@ void gba_putchar(char c, int textattr, int x, int y)
 void gba_textattr(int _attr)
-    _textattr = _attr;
+  _textattr = _attr;
@@ -152,11 +171,11 @@ void gba_textattr(int _attr)
  *  @param  _color backround color
  *  @return None
 void gba_textbackground(int _color)
-    _textattr = (_textattr & 0x0F) | (_color << 4);
+  _textattr = (_textattr & 0x0F) | (_color << 4);
@@ -167,25 +186,25 @@ void gba_textbackground(int _color)
 void gba_textcolor(int _color)
-    _textattr = (_textattr & 0xF0) | (_color);
+  _textattr = (_textattr & 0xF0) | (_color);
- *  @brief gba_clearline function clear line nro y
+ *  @brief gba_clearline function clear line number y
  *  Line is filled with spaces
  *  @param  y line number
  *  @return None
-void gba_clearline(int y)
+static void gba_clearline(int y)
-    int x;
+  int x;
-    for (x=0 ; x<=W ; x++) {
-       gba_putchar(0, _textattr, x, y);
+  for (x=0 ; x<=W ; x++) {
+     gba_putchar(0, _textattr, x, y);
@@ -194,7 +213,7 @@ void gba_clearline(int y)
  *  @param  None
  *  @return None
-void gba_nextline(void)
+static void gba_nextline(void)
     _wherex = 0;
     if (++_wherey >= H) {
@@ -226,7 +245,7 @@ void gba_clrscr(void)
  *  @param  _c character code
  *  @return None
-void gba_put(char _c)
+static void gba_put(char _c)
   /* We have save some memory with reduced fonts */
   _c = _c & 0x7F;   /* no extened chars */
@@ -334,13 +353,12 @@ void gba_initconio(void)
 void gba_textmode(int _mode)
-    switch (_mode) {
-        case CO60:
-            gba_initconio();
-            break;
+  switch (_mode) {
+    case CO60: {
+      gba_initconio();
+      break;
@@ -350,17 +368,19 @@ void gba_textmode(int _mode)
  *  @param  count loop counter
  *  @return None
-void delay_loop(unsigned int count)
+static void delay_loop(unsigned int count)
-    int i;
-    for (i = 0; i<count; i++) i = i;
+  int i;
+  for (i = 0; i<count; i++) i = i;
 static unsigned char inputch = ASCII_CR;    /**< input character value */
  *  @brief gba_getch function read char from game pad keys
- *  Character input is done with GBA buttons, up-down-left-right/A/B/R/L/Select/Start
+ *  Character input is done with GBA buttons,
+ *      up-down-left-right/A/B/R/L/Select/Start
  *  - Select-key accept selected character
  *  - Start-key read CR (Enter)
  *  - A-key select 'A' character
@@ -380,47 +400,47 @@ int gba_getch(void)
   int  keyx, key  = 0;
   while(1) {
-      key = GBA_KEY();
-      while ( (keyx=GBA_KEY())==key );
-      switch (key)
-        case GBA_KEY_SELECT:
-            gba_put(inputch);
-            return inputch;
-            break;
-        case GBA_KEY_START:
-            gba_put(' ');
-            inputch = ASCII_CR;
-            return inputch;
-            break;
-        case GBA_KEY_A:
-            inputch = 'A';
-            break;
-        case GBA_KEY_B:
-            inputch = 'Z';
-            break;
-        case GBA_KEY_UP:
-            if ((inputch-1) >= 0x20) inputch--;
-            break;
-        case GBA_KEY_DOWN:
-            if ((inputch+1) <=  0x7E) inputch++;
-            break;
-        case GBA_KEY_LEFT:
-            if ((inputch - 0x20) >= 0x20) inputch -= 0x20;
-            break;
-        case GBA_KEY_RIGHT:
-            if ((inputch + 0x20) <= 0x7E) inputch += 0x20;
-            break;
-        case GBA_KEY_R:
-            inputch = '1';
-            break;
-        case GBA_KEY_L:
-            inputch = '9';
-            break;
-        default:
-            break;
-      gba_put(inputch);
-      delay_loop(1000);
+    key = GBA_KEY();
+    while ( (keyx=GBA_KEY())==key );
+    switch (key) {
+      case GBA_KEY_SELECT:
+	gba_put(inputch);
+	return inputch;
+	break;
+      case GBA_KEY_START:
+	gba_put(' ');
+	inputch = ASCII_CR;
+	return inputch;
+	break;
+      case GBA_KEY_A:
+	inputch = 'A';
+	break;
+      case GBA_KEY_B:
+	inputch = 'Z';
+	break;
+      case GBA_KEY_UP:
+	if ((inputch-1) >= 0x20) inputch--;
+	break;
+      case GBA_KEY_DOWN:
+	if ((inputch+1) <=  0x7E) inputch++;
+	break;
+      case GBA_KEY_LEFT:
+	if ((inputch - 0x20) >= 0x20) inputch -= 0x20;
+	break;
+      case GBA_KEY_RIGHT:
+	if ((inputch + 0x20) <= 0x7E) inputch += 0x20;
+	break;
+      case GBA_KEY_R:
+	inputch = '1';
+	break;
+      case GBA_KEY_L:
+	inputch = '9';
+	break;
+      default:
+	break;
+    gba_put(inputch);
+    delay_loop(1000);
diff --git a/c/src/lib/libbsp/arm/gba/console/console.c b/c/src/lib/libbsp/arm/gba/console/console.c
index 2647d59..35ec017 100644
--- a/c/src/lib/libbsp/arm/gba/console/console.c
+++ b/c/src/lib/libbsp/arm/gba/console/console.c
@@ -3,6 +3,7 @@
  *  This file contains the GBA console I/O package.
  *  RTEMS GBA BSP
@@ -34,7 +35,7 @@
 static int gba_pollRead(int minor)
-    return(gba_getch());
+  return (gba_getch());
@@ -52,7 +53,7 @@ static ssize_t gba_write(int minor, const char *buf, size_t len)
   int i;
   for (i=0;i<len;i++) {
-     gba_putch((unsigned short)buf[i]);
+    gba_putch((unsigned short)buf[i]);
   return len;
@@ -85,9 +86,11 @@ BSP_polling_getchar_function_type BSP_poll_char   = gba_getch;
  *  @return status code
 rtems_device_driver
-console_initialize(rtems_device_major_number  major,
-                   rtems_device_minor_number  minor,
-                   void                      *arg)
+console_initialize(
+  rtems_device_major_number  major,
+  rtems_device_minor_number  minor,
+  void                      *arg
   rtems_status_code status;
@@ -95,13 +98,13 @@ console_initialize(rtems_device_major_number  major,
   rtems_termios_initialize ();
   /* Do device-specific initialization  */
-  /* Allready done in bspstart.c -> gba_textmode(CO60); */
+  /* Already done in bspstart.c -> gba_textmode(CO60); */
   /* Register the device */
   status = rtems_io_register_name ("/dev/console", major, 0);
   if (status != RTEMS_SUCCESSFUL) {
-      printk("Error registering console device!\n");
-      rtems_fatal_error_occurred (status);
+    printk("Error registering console device!\n");
+    rtems_fatal_error_occurred (status);
   printk("Initialized GBA console\n\n");
@@ -119,7 +122,7 @@ console_initialize(rtems_device_major_number  major,
 static int console_first_open(int major, int minor, void *arg)
-    return 0;
+  return 0;
@@ -132,10 +135,9 @@ static int console_first_open(int major, int minor, void *arg)
 static int console_last_close(int major, int minor, void *arg)
-    return 0;
+  return 0;
  *  @brief Console device driver OPEN entry point
@@ -145,9 +147,11 @@ static int console_last_close(int major, int minor, void *arg)
 rtems_device_driver
-console_open(rtems_device_major_number major,
-             void                      *arg)
+console_open(
+  void                      *arg
   static rtems_termios_callbacks cb =
@@ -165,8 +169,8 @@ console_open(rtems_device_major_number major,
   status = rtems_termios_open (major, minor, arg, &cb);
-      printk("Error openning console device\n");
-      return status;
+    printk("Error openning console device\n");
+    return status;
   return RTEMS_SUCCESSFUL;
@@ -181,9 +185,11 @@ console_open(rtems_device_major_number major,
 rtems_device_driver
-console_close(rtems_device_major_number major,
-              void                      *arg)
+console_close(
+  void                      *arg
   rtems_device_driver res = RTEMS_SUCCESSFUL;
@@ -203,13 +209,13 @@ console_close(rtems_device_major_number major,
 rtems_device_driver
-console_read(rtems_device_major_number major,
-             void                      *arg)
+console_read(
+  void                      *arg
-    return rtems_termios_read (arg);
+  return rtems_termios_read (arg);
@@ -223,11 +229,13 @@ console_read(rtems_device_major_number major,
 rtems_device_driver
-console_write(rtems_device_major_number major,
-              void                      *arg)
+console_write(
+  void                      *arg
-    return rtems_termios_write (arg);
+  return rtems_termios_write (arg);
@@ -239,10 +247,11 @@ console_write(rtems_device_major_number major,
 rtems_device_driver
-console_control(rtems_device_major_number major,
-                void                      *arg
+console_control(
+  void                      *arg
-    return rtems_termios_ioctl (arg);
+  return rtems_termios_ioctl (arg);
1.9.3
