[PATCH 44/54] libcpu/sh/sh7045/clock/ckinit.c: Fix warnings
Mon Oct 13 15:37:28 UTC 2014
 c/src/lib/libcpu/sh/sh7045/clock/ckinit.c | 35 ++++++-------------------------
 1 file changed, 6 insertions(+), 29 deletions(-)
diff --git a/c/src/lib/libcpu/sh/sh7045/clock/ckinit.c b/c/src/lib/libcpu/sh/sh7045/clock/ckinit.c
index 3297238..5120b59 100644
--- a/c/src/lib/libcpu/sh/sh7045/clock/ckinit.c
+++ b/c/src/lib/libcpu/sh/sh7045/clock/ckinit.c
@@ -1,6 +1,8 @@
  *  This file contains the clock driver the Hitachi SH 704X
  *  Authors: Ralf Corsepius (corsepiu at faw.uni-ulm.de) and
  *           Bernd Becker (becker at faw.uni-ulm.de)
@@ -10,7 +12,6 @@
  *  but WITHOUT ANY WARRANTY; without even the implied warranty of
  *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
  *  COPYRIGHT (c) 1998.
  *  On-Line Applications Research Corporation (OAR).
@@ -35,7 +36,7 @@
-#include <rtems/libio.h>
+#include <rtems/clockdrv.h>
 #include <rtems/score/sh_io.h>
 #include <rtems/score/sh.h>
 #include <rtems/score/ispsh7045.h>
@@ -70,10 +71,8 @@ extern uint32_t bsp_clicks_per_second;
  *  Clock_driver_ticks is a monotonically increasing counter of the
  *  number of clock ticks since the driver was initialized.
 volatile uint32_t   Clock_driver_ticks;
-static void Clock_exit( void );
 static rtems_isr Clock_isr( rtems_vector_number vector );
 static uint32_t   Clock_MHZ ;
@@ -84,28 +83,18 @@ static uint32_t   Clock_MHZ ;
  *  length of time between the user configured microseconds per tick
  *  has passed.
 uint32_t   Clock_isrs;              /* ISRs until next tick */
 static uint32_t   Clock_isrs_const;        /* only calculated once */
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
  *  The previous ISR on this clock tick interrupt vector.
 rtems_isr_entry  Old_ticker;
  *  Isr Handler
-rtems_isr Clock_isr(
+static rtems_isr Clock_isr(
@@ -143,15 +132,13 @@ rtems_isr Clock_isr(
  *  Install a clock tick handler and reprograms the chip.  This
  *  is used to initially establish the clock tick.
-void Install_clock(
+static void Install_clock(
   rtems_isr_entry clock_isr
   uint8_t   temp8 = 0;
   uint32_t   factor = 1000000;
    *  Initialize the clock tick device driver variables
@@ -212,14 +199,12 @@ void Install_clock(
    *  Schedule the clock cleanup routine to execute if the application exits.
   atexit( Clock_exit );
  *  Clean up before the application exits
   uint8_t   temp8 = 0;
@@ -246,7 +231,6 @@ void Clock_exit( void )
  *  Device driver entry point for clock tick driver initialization.
 rtems_device_driver Clock_initialize(
   rtems_device_major_number major,
   rtems_device_minor_number minor,
@@ -255,12 +239,5 @@ rtems_device_driver Clock_initialize(
   Install_clock( Clock_isr );
-   * make major/minor avail to others such as shared memory driver
-  rtems_clock_major = major;
-  rtems_clock_minor = minor;
   return RTEMS_SUCCESSFUL;
1.9.3
