[PATCH 45/54] libcpu/sh/sh7750/clock/ckinit.c: Fix warnings
Mon Oct 13 15:37:29 UTC 2014
 c/src/lib/libcpu/sh/sh7750/clock/ckinit.c | 338 +++++++++++++-----------------
 1 file changed, 151 insertions(+), 187 deletions(-)
diff --git a/c/src/lib/libcpu/sh/sh7750/clock/ckinit.c b/c/src/lib/libcpu/sh/sh7750/clock/ckinit.c
index 5976e87..795203d 100644
--- a/c/src/lib/libcpu/sh/sh7750/clock/ckinit.c
+++ b/c/src/lib/libcpu/sh/sh7750/clock/ckinit.c
@@ -1,6 +1,8 @@
  * This file contains the generic RTEMS clock driver the Hitachi SH 7750
  * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
  * Author: Victor V. Vengerov <vvv at oktet.ru>
@@ -16,7 +18,7 @@
-#include <rtems/libio.h>
+#include <rtems/clockdrv.h>
 #include <rtems/score/sh_io.h>
 #include <rtems/score/sh.h>
 #include <rtems/score/ispsh7750.h>
@@ -36,198 +38,171 @@ extern uint32_t bsp_clicks_per_second;
  *  The interrupt vector number associated with the clock tick device
  *  driver.
 #define CLOCK_VECTOR SH7750_EVT_TO_NUM(SH7750_EVT_TUNI0)
  *  Clock_driver_ticks is a monotonically increasing counter of the
  *  number of clock ticks since the driver was initialized.
 volatile uint32_t   Clock_driver_ticks;
-static void Clock_exit( void );
 static rtems_isr Clock_isr( rtems_vector_number vector );
- * These are set by clock driver during its init
-rtems_device_major_number rtems_clock_major = ~0;
-rtems_device_minor_number rtems_clock_minor;
  *  The previous ISR on this clock tick interrupt vector.
 rtems_isr_entry  Old_ticker;
  *  Isr Handler
-/* Clock_isr --
- *     Clock interrupt handling routine.
- * PARAMETERS:
- *     vector - interrupt vector number
+ * Clock_isr
- * RETURNS:
- *     none
+ * Clock interrupt handling routine.
-rtems_isr
-Clock_isr(rtems_vector_number vector)
+static rtems_isr Clock_isr(rtems_vector_number vector)
-    uint16_t   tcr;
+  uint16_t   tcr;
-    /* reset the timer underflow flag */
-    tcr = read16(SH7750_TCR0);
-    write16(tcr & ~SH7750_TCR_UNF, SH7750_TCR0);
+  /* reset the timer underflow flag */
+  tcr = read16(SH7750_TCR0);
+  write16(tcr & ~SH7750_TCR_UNF, SH7750_TCR0);
-    /* Increment the clock interrupt counter */
-    Clock_driver_ticks++ ;
+  /* Increment the clock interrupt counter */
+  Clock_driver_ticks++ ;
-    /* Invoke rtems clock service routine */
+  /* Invoke rtems clock service routine */
     rtems_clock_tick();
-/* Install_clock --
- *     Install a clock tick handler and reprograms the chip.  This
- *     is used to initially establish the clock tick.
- * PARAMETERS:
- *     clock_isr - Clock interrupt stay routine
+ * Install_clock
- * RETURNS:
- *     none
+ * Install a clock tick handler and reprograms the chip.  This
+ * is used to initially establish the clock tick.
  * SIDE EFFECTS:
  *     Establish clock interrupt handler, configure Timer 0 hardware
-void
-Install_clock(rtems_isr_entry clock_isr)
+static void Install_clock(rtems_isr_entry clock_isr)
-    int cpudiv = 1; /* CPU frequency divider */
-    int tidiv = 1;  /* Timer input frequency divider */
-    uint32_t   timer_divider; /* Calculated Timer Divider value */
-    uint8_t   temp8;
-    uint16_t   temp16;
-     *  Initialize the clock tick device driver variables
-    Clock_driver_ticks = 0;
-    /* Get CPU frequency divider from clock unit */
-    switch (read16(SH7750_FRQCR) & SH7750_FRQCR_IFC)
-        case SH7750_FRQCR_IFCDIV1:
-            cpudiv = 1;
-            break;
-        case SH7750_FRQCR_IFCDIV2:
-            cpudiv = 2;
-            break;
-        case SH7750_FRQCR_IFCDIV3:
-            cpudiv = 3;
-            break;
-        case SH7750_FRQCR_IFCDIV4:
-            cpudiv = 4;
-            break;
-        case SH7750_FRQCR_IFCDIV6:
-            cpudiv = 6;
-            break;
-        case SH7750_FRQCR_IFCDIV8:
-            cpudiv = 8;
-            break;
-        default:
-            rtems_fatal_error_occurred( RTEMS_NOT_CONFIGURED);
-    /* Get peripheral module frequency divider from clock unit */
-    switch (read16(SH7750_FRQCR) & SH7750_FRQCR_PFC)
-        case SH7750_FRQCR_PFCDIV2:
-            tidiv = 2 * CLOCK_PRESCALER;
-            break;
-        case SH7750_FRQCR_PFCDIV3:
-            tidiv = 3 * CLOCK_PRESCALER;
-            break;
-        case SH7750_FRQCR_PFCDIV4:
-            tidiv = 4 * CLOCK_PRESCALER;
-            break;
-        case SH7750_FRQCR_PFCDIV6:
-            tidiv = 6 * CLOCK_PRESCALER;
-            break;
-        case SH7750_FRQCR_PFCDIV8:
-            tidiv = 8 * CLOCK_PRESCALER;
-            break;
-        default:
-    timer_divider =
-        (bsp_clicks_per_second * cpudiv / (tidiv*1000000)) *
-        rtems_configuration_get_microseconds_per_tick();
-     *  Hardware specific initialization
-    /* Stop the Timer 0 */
-    temp8 = read8(SH7750_TSTR);
-    temp8 &= ~SH7750_TSTR_STR0;
-    write8(temp8, SH7750_TSTR);
-    /* Establish interrupt handler */
-    rtems_interrupt_catch( Clock_isr, CLOCK_VECTOR, &Old_ticker );
-    /* Reset counter */
-    write32(timer_divider, SH7750_TCNT0);
-    /* Load divider */
-    write32(timer_divider, SH7750_TCOR0);
-    write16(
-        SH7750_TCR_UNIE |        /* Enable Underflow Interrupt */
-        SH7750_TCR_CKEG_RAISE |  /* Count on rising edge */
-        TCR0_TPSC,               /* Timer prescaler ratio */
-        SH7750_TCR0);
-    /* Set clock interrupt priority */
-    temp16 = read16(SH7750_IPRA);
-    temp16 = (temp16 & ~SH7750_IPRA_TMU0) | (CLOCKPRIO << SH7750_IPRA_TMU0_S);
-    write16(temp16, SH7750_IPRA);
-    /* Start the Timer 0 */
-    temp8 |= SH7750_TSTR_STR0;
-     *  Schedule the clock cleanup routine to execute if the application exits.
-    atexit( Clock_exit );
+  int cpudiv = 1; /* CPU frequency divider */
+  int tidiv = 1;  /* Timer input frequency divider */
+  uint32_t   timer_divider; /* Calculated Timer Divider value */
+  uint8_t   temp8;
+  uint16_t   temp16;
+   *  Initialize the clock tick device driver variables
+  Clock_driver_ticks = 0;
+  /* Get CPU frequency divider from clock unit */
+  switch (read16(SH7750_FRQCR) & SH7750_FRQCR_IFC) {
+    case SH7750_FRQCR_IFCDIV1:
+      cpudiv = 1;
+      break;
+    case SH7750_FRQCR_IFCDIV2:
+      cpudiv = 2;
+      break;
+    case SH7750_FRQCR_IFCDIV3:
+      cpudiv = 3;
+      break;
+    case SH7750_FRQCR_IFCDIV4:
+      cpudiv = 4;
+      break;
+    case SH7750_FRQCR_IFCDIV6:
+      cpudiv = 6;
+      break;
+    case SH7750_FRQCR_IFCDIV8:
+      cpudiv = 8;
+      break;
+      default:
+        rtems_fatal_error_occurred( RTEMS_NOT_CONFIGURED);
+  /* Get peripheral module frequency divider from clock unit */
+  switch (read16(SH7750_FRQCR) & SH7750_FRQCR_PFC) {
+    case SH7750_FRQCR_PFCDIV2:
+      tidiv = 2 * CLOCK_PRESCALER;
+      break;
+    case SH7750_FRQCR_PFCDIV3:
+      tidiv = 3 * CLOCK_PRESCALER;
+      break;
+    case SH7750_FRQCR_PFCDIV4:
+      tidiv = 4 * CLOCK_PRESCALER;
+      break;
+    case SH7750_FRQCR_PFCDIV6:
+      tidiv = 6 * CLOCK_PRESCALER;
+      break;
+    case SH7750_FRQCR_PFCDIV8:
+      tidiv = 8 * CLOCK_PRESCALER;
+      break;
+    default:
+  timer_divider =
+      (bsp_clicks_per_second * cpudiv / (tidiv*1000000)) *
+      rtems_configuration_get_microseconds_per_tick();
+   *  Hardware specific initialization
+  /* Stop the Timer 0 */
+  temp8 = read8(SH7750_TSTR);
+  temp8 &= ~SH7750_TSTR_STR0;
+  write8(temp8, SH7750_TSTR);
+  /* Establish interrupt handler */
+  rtems_interrupt_catch( Clock_isr, CLOCK_VECTOR, &Old_ticker );
+  /* Reset counter */
+  write32(timer_divider, SH7750_TCNT0);
+  /* Load divider */
+  write32(timer_divider, SH7750_TCOR0);
+  write16(
+      SH7750_TCR_UNIE |        /* Enable Underflow Interrupt */
+      SH7750_TCR_CKEG_RAISE |  /* Count on rising edge */
+      TCR0_TPSC,               /* Timer prescaler ratio */
+      SH7750_TCR0);
+  /* Set clock interrupt priority */
+  temp16 = read16(SH7750_IPRA);
+  temp16 = (temp16 & ~SH7750_IPRA_TMU0) | (CLOCKPRIO << SH7750_IPRA_TMU0_S);
+  write16(temp16, SH7750_IPRA);
+  /* Start the Timer 0 */
+  temp8 |= SH7750_TSTR_STR0;
+   *  Schedule the clock cleanup routine to execute if the application exits.
+  atexit( Clock_exit );
-/* Clock_exit --
- *     Clean up before the application exits
- * PARAMETERS:
- *     none
+ * Clock_exit
- * RETURNS:
- *     none
+ * Clean up before the application exits
  * SIDE EFFECTS:
  *     Stop Timer 0 counting, set timer 0 interrupt priority level to 0.
@@ -235,46 +210,35 @@ Install_clock(rtems_isr_entry clock_isr)
 void
 Clock_exit(void)
-    uint8_t   temp8 = 0;
-    uint16_t   temp16 = 0;
+  uint8_t   temp8 = 0;
+  uint16_t   temp16 = 0;
-    /* turn off the timer interrupts */
+  /* turn off the timer interrupts */
-    /* Lower timer interrupt priority to 0 */
-    temp16 = (temp16 & ~SH7750_IPRA_TMU0) | (0 << SH7750_IPRA_TMU0_S);
+  /* Lower timer interrupt priority to 0 */
+  temp16 = (temp16 & ~SH7750_IPRA_TMU0) | (0 << SH7750_IPRA_TMU0_S);
   /* old vector shall not be installed */
-/* Clock_initialize --
- *     Device driver entry point for clock tick driver initialization.
- * PARAMETERS:
- *     major - clock major device number
- *     minor - clock minor device number
- *     pargp - driver initialize primitive argument, not used
+ * Clock_initialize
- * RETURNS:
- *     RTEMS_SUCCESSFUL
+ * Device driver entry point for clock tick driver initialization.
-rtems_device_driver
-Clock_initialize(rtems_device_major_number major,
-                 rtems_device_minor_number minor,
-                 void *pargp)
+rtems_device_driver Clock_initialize(
+  rtems_device_major_number major,
+  rtems_device_minor_number minor,
+  void *pargp
     Install_clock( Clock_isr );
-     * make major/minor avail to others such as shared memory driver
-    rtems_clock_major = major;
-    rtems_clock_minor = minor;
     return RTEMS_SUCCESSFUL;
1.9.3
