Warnings Report 13 Oct
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Oct 13 16:50:26 UTC 2014
Hi
Attached is the set of unique warnings and list of warnings
count per BSP after committing all my patches. This is
with tests=samples and networking disabled.
On 6 Oct, there were 1737 unique warnings.
Today, there are 759 unique warnings.
The warnings break down in categories like this:
2 aggressive-loop-optimizations
2 comment <== I just pushed a
fix for this
5 cpp
3 deprecated-declarations
19 format=
17 implicit-function-declaration
5 int-to-pointer-cast
2 maybe-uninitialized
506 missing-prototypes
17 nested-externs
3 overflow
1 pointer-sign
6 pointer-to-int-cast
1 strict-prototypes
1 uninitialized
46 unused-but-set-variable
17 unused-function
13 unused-variable
If you are interested in helping, for many of the warnings, it is obvious
from the unique sorted list what BSP triggers the warning based on the
file name. If it isn't obvious, ask me for the BSPs triggering a warning.
Again, help running these down is appreciated.
200 c/src/../../cpukit/libmisc/shell/hexdump-conv.c:145:4: warning: format '%lc' expects argument of type 'wint_t', but argument 4 has type 'wchar_t' [-Wformat=]
179 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:19: warning: assignment makes integer from pointer without a cast [enabled by default]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:66:7: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:66:7: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:51:5: warning: format '%x' expects argument of type 'unsigned int', but argument 9 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:51:5: warning: format '%x' expects argument of type 'unsigned int', but argument 8 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/capture/capture-cli.c:1424:18: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:61:17: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:55:7: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c:72:13: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
56 c/src/lib/libcpu/powerpc/shared/src/cache_.h:203:2: warning: #warning Most cache functions are not implemented [-Wcpp]
34 c/src/../../cpukit/libfs/src/jffs2/src/os-rtems.h:47:3: warning: right shift count >= width of type [enabled by default]
34 c/src/../../cpukit/libfs/src/jffs2/src/nodelist.h:294:86: warning: integer overflow in expression [-Woverflow]
23 c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c:729:1: warning: no previous prototype for 'triv121PgTblConsistency' [-Wmissing-prototypes]
23 c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c:307:23: warning: variable 'api' set but not used [-Wunused-but-set-variable]
23 c/src/lib/libcpu/powerpc/mpc6xx/mmu/pte121.c:1082:1: warning: no previous prototype for 'triv121PgTblDump' [-Wmissing-prototypes]
20 c/src/../../cpukit/libfs/src/jffs2/include/linux/kernel.h:12:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
16 c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_alignment.c:28:29: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
10 c/src/../../testsuites/samples/nsecs/init.c:132:5: warning: format '%d' expects argument of type 'int', but argument 3 has type 'long int' [-Wformat=]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:870:5: warning: no previous prototype for 'm8xx_smc_isOn' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:854:6: warning: no previous prototype for 'm8xx_smc_disable' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:838:6: warning: no previous prototype for 'm8xx_smc_enable' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:625:5: warning: no previous prototype for 'm8xx_scc_isOn' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:601:6: warning: no previous prototype for 'm8xx_scc_disable' [-Wmissing-prototypes]
9 c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c:577:6: warning: no previous prototype for 'm8xx_scc_enable' [-Wmissing-prototypes]
8 c/src/../../cpukit/score/src/threadloadenv.c:28:8: warning: variable 'is_fp' set but not used [-Wunused-but-set-variable]
7 c/src/lib/libcpu/arm/shared/arm920/mmu.c:128:6: warning: no previous prototype for 'mmu_set_cpu_async_mode' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:47:19: warning: 'upmaTable' defined but not used [-Wunused-variable]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:159:6: warning: no previous prototype for '_InitMBX8xx' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c:86:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c:85:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:79:5: warning: no previous prototype for 'BSP_irq_disable_at_cpm' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:66:5: warning: no previous prototype for 'BSP_irq_enable_at_cpm' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:271:1: warning: no previous prototype for 'BSP_CPM_irq_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:252:6: warning: no previous prototype for 'BSP_SIU_irq_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:149:5: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:42:6: warning: no previous prototype for 'mbx8xx_pcmciaide_probe' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:351:19: warning: no previous prototype for 'mbx8xx_pcmciaide_config_io_speed' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:328:5: warning: no previous prototype for 'mbx8xx_pcmciaide_control' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:270:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_block' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:213:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_block' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:175:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_reg' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:137:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_reg' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:111:6: warning: no previous prototype for 'mbx8xx_pcmciaide_initialize' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:714:1: warning: no previous prototype for 'serial_tstc' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:693:1: warning: no previous prototype for 'serial_getc' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:529:1: warning: no previous prototype for 'serial_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:1102:5: warning: no previous prototype for 'mbx8xx_console_get_configuration' [-Wmissing-prototypes]
7 c/src/../../cpukit/score/cpu/sh/context.c:171:6: warning: no previous prototype for '__CPU_Context_switch' [-Wmissing-prototypes]
6 c/src/lib/libcpu/i386/displayCpu.c:185:6: warning: no previous prototype for 'printCpuInfo' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/bspstart.c:103:8: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/motorola/motorola.c:363:15: warning: no previous prototype for 'getMotorolaBoard' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/startup/bspstart.c:48:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/pci/pcibios.c:269:1: warning: no previous prototype for 'BSP_pciFindDevice' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/irq/irq_init.c:105:6: warning: no previous prototype for 'raw_idt_notify' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/irq/irq.c:35:1: warning: no previous prototype for 'BSP_irq_count_dump' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/irq/irq.c:237:6: warning: no previous prototype for 'C_dispatch_isr' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/uart.c:453:13: warning: 'uart_set_driver_handler' defined but not used [-Wunused-function]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:969:1: warning: no previous prototype for 'breakpoint' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:935:1: warning: no previous prototype for 'set_debug_traps' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:756:7: warning: variable 'newPC' set but not used [-Wunused-but-set-variable]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:585:1: warning: no previous prototype for 'set_mem_err' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:568:1: warning: no previous prototype for 'debug_error' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/i386-stub.c:450:1: warning: no previous prototype for '_returnFromException' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/../../i386/shared/comm/gdb_glue.c:25:6: warning: no previous prototype for 'init_remote_gdb' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/serial_mouse_config.c:29:6: warning: no previous prototype for 'bsp_get_serial_mouse_device' [-Wmissing-prototypes]
6 c/src/lib/libbsp/i386/pc386/console/keyboard.c:790:6: warning: no previous prototype for 'register_leds' [-Wmissing-prototypes]
6 c/src/../../cpukit/libfs/src/jffs2/src/fs-rtems.c:367:21: warning: unused variable 'sc' [-Wunused-variable]
6 c/src/../../cpukit/libfs/src/jffs2/src/fs-rtems.c:325:20: warning: unused variable 'sc' [-Wunused-variable]
6 c/src/../../cpukit/libfs/src/jffs2/src/fs-rtems.c:319:20: warning: unused variable 'sc' [-Wunused-variable]
6 c/src/../../cpukit/libfs/src/dosfs/msdos_conv_utf8.c:255:31: warning: variable 'rv' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libblock/src/media-server.c:47:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libblock/src/media.c:80:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
5 log/sparc64-usiii.log:../../cpukit/../../../usiii/lib/include/rtems/score/sparc64.h:324:25: warning: variable '_ignored' set but not used [-Wunused-but-set-variable]
5 log/sparc64-niagara.log:../../cpukit/../../../niagara/lib/include/rtems/score/sparc64.h:324:25: warning: variable '_ignored' set but not used [-Wunused-but-set-variable]
5 c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c:170:27: warning: iteration 474ul invokes undefined behavior [-Waggressive-loop-optimizations]
5 c/src/lib/libcpu/powerpc/e500/mmu/mmu.c:202:24: warning: variable 'mas0' set but not used [-Wunused-but-set-variable]
5 c/src/lib/libbsp/powerpc/gen83xx/startup/bsprestart.c:22:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
5 c/src/lib/libbsp/powerpc/gen83xx/../shared/uboot_getenv.c:40:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/../shared/startup/bspidle.c:25:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:563:5: warning: no previous prototype for 'mpc83xx_exception_handler' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:508:19: warning: no previous prototype for 'mpc83xx_ipic_initialize' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:495:19: warning: no previous prototype for 'mpc83xx_ipic_calc_prio2mask' [-Wmissing-prototypes]
5 c/src/../../cpukit/score/cpu/sparc/sparcv8-atomic.c:111:6: warning: conflicting types for built-in function '__atomic_compare_exchange_4' [enabled by default]
4 c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c:29:6: warning: no previous prototype for '__ISR_Handler' [-Wmissing-prototypes]
4 c/src/lib/libbsp/sh/shsim/../shared/bsphwinit.c:12:6: warning: no previous prototype for 'bsp_hw_init' [-Wmissing-prototypes]
4 c/src/lib/libbsp/sh/shsim/console/console-io.c:70:5: warning: no previous prototype for '_sys_exit' [-Wmissing-prototypes]
4 c/src/lib/libbsp/sh/shsim/console/console-debugio.c:30:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
4 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/irq/irq_init.c:167:6: warning: no previous prototype for 'VIA_isa_bridge_interrupts_setup' [-Wmissing-prototypes]
4 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c:299:21: warning: unused variable 'sc' [-Wunused-variable]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 5 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:105:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 6 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 5 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 4 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 3 has type 'uint32_t' [-Wformat=]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:356:1: warning: no previous prototype for 'spiInitialize' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:335:1: warning: no previous prototype for 'spiDeInit' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/ppc403/console/console405.c:194:1: warning: no previous prototype for 'spiBaudSet' [-Wmissing-prototypes]
3 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:79:3: warning: nested extern declaration of 'BSP_Convert_decrementer' [-Wnested-externs]
3 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:79:3: warning: implicit declaration of function 'BSP_Convert_decrementer' [-Wimplicit-function-declaration]
3 c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c:496:9: warning: passing argument 1 of 'rtems_cache_flush_multiple_data_lines' discards 'volatile' qualifier from pointer target type [enabled by default]
3 c/src/lib/libcpu/bfin/serial/uart.c:93:6: warning: no previous prototype for 'debug_write_byte' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:87:6: warning: no previous prototype for 'debug_write_nybble' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:81:6: warning: no previous prototype for 'debug_write_crlf' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:72:6: warning: no previous prototype for 'debug_write_string' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:68:6: warning: no previous prototype for 'debug_write_char' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:505:6: warning: no previous prototype for 'uart_exit' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:107:6: warning: no previous prototype for 'debug_write_word' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/serial/uart.c:100:6: warning: no previous prototype for 'debug_write_half' [-Wmissing-prototypes]
3 c/src/lib/libcpu/bfin/clock/rtc.c:33:6: warning: no previous prototype for 'Init_RTC' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/usart/usart.c:270:5: warning: no previous prototype for 'usart_poll_read' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c:220:5: warning: no previous prototype for '_BSP_poll_char' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c:201:5: warning: no previous prototype for 'dbgu_poll_read' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/uboot_getenv.c:40:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/startup/bspidle.c:25:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/clock/../../../shared/clockdrv_shell.h:154:21: warning: no previous prototype for 'Clock_initialize' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:77:1: warning: no previous prototype for '_IBMPC_scankey' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:275:1: warning: no previous prototype for '_IBMPC_inch_sleep' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:257:1: warning: no previous prototype for 'BSP_wait_polled_input' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:243:1: warning: no previous prototype for '_IBMPC_inch' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:221:1: warning: no previous prototype for '_IBMPC_chrdy' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:198:6: warning: no previous prototype for '_IBMPC_keyboard_isr' [-Wmissing-prototypes]
3 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c:43:6: warning: no previous prototype for '_Init68360' [-Wmissing-prototypes]
3 c/src/lib/libbsp/m68k/gen68360/console/console.c:200:20: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libbsp/arm/lpc176x/misc/restart.c:28:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libbsp/arm/csb337/startup/bspstart.c:40:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
3 c/src/lib/libbsp/arm/csb337/startup/bspreset.c:19:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
3 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:19: warning: assignment makes integer from pointer without a cast
3 c/src/../../cpukit/libcsupport/src/__assert.c:52:43: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/powerpc-virtex.log: #warning Most cache functions are not implemented
2 log/powerpc-virtex5.log: #warning Most cache functions are not implemented
2 log/powerpc-virtex4.log: #warning Most cache functions are not implemented
2 log/powerpc-t32mppc.log: #warning Most cache functions are not implemented
2 log/powerpc-ss555.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_p1020rdb.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_core_1.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_core_0.log: #warning Most cache functions are not implemented
2 log/powerpc-qemuprep.log: #warning Most cache functions are not implemented
2 log/powerpc-qemuprep-altivec.log: #warning Most cache functions are not implemented
2 log/powerpc-phycore_mpc5554.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme5500.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme3100.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme2307.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_rsm6.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674fevb_spe.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674fevb.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_ecu508_boot.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_ecu508_app.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5668g.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5643l_evb.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5643l_dpu.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5566evb_spe.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5566evb.log: #warning Most cache functions are not implemented
2 log/powerpc-mcp750.log: #warning Most cache functions are not implemented
2 log/powerpc-haleakala.log: #warning Most cache functions are not implemented
2 log/powerpc-gwlcfm.log: #warning Most cache functions are not implemented
2 log/powerpc-beatnik.log: #warning Most cache functions are not implemented
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:125:5: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:51: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:120:49: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 c/src/lib/libcpu/sparc64/shared/interrupts/installisrentries.c:18:6: warning: no previous prototype for 'sparc64_install_isr_entries' [-Wmissing-prototypes]
2 c/src/lib/libcpu/bfin/clock/clock.c:40:9: warning: comparison of distinct pointer types lacks a cast [enabled by default]
2 c/src/lib/libbsp/sparc/leon3/startup/bspdelay.c:18:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/leon3/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c:19:6: warning: no previous prototype for 'bsp_predriver_hook' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/startup/bspdelay.c:14:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:86:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:45:5: warning: no previous prototype for 'console_inbyte_nonblocking' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:24:6: warning: no previous prototype for 'console_outbyte_polled' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:22:6: warning: no previous prototype for '_InitTQM8xx' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:129:6: warning: no previous prototype for 'cpu_init' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:85:13: warning: no previous prototype for 'bsp_tqm_get_cib_string' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:74:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:61:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:134:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:133:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:115:20: warning: no previous prototype for 'bsp_tqm_get_cib_uint32' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:906:19: warning: no previous prototype for 'bsp_register_spi' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/../shared/startup/bspidle.c:25:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:59:19: warning: no previous prototype for 'bsp_irq_enable_at_CPM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:52:19: warning: no previous prototype for 'bsp_irq_disable_at_CPM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:45:19: warning: no previous prototype for 'bsp_irq_enable_at_SIU' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:38:19: warning: no previous prototype for 'bsp_irq_disable_at_SIU' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:217:5: warning: no previous prototype for 'mpc8xx_exception_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:207:19: warning: no previous prototype for 'mpc8xx_siu_int_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:187:19: warning: no previous prototype for 'mpc8xx_cpic_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:54:5: warning: no previous prototype for 'BSP_connect_clock_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:31:12: warning: 'BSP_get_clock_irq_level' defined but not used [-Wunused-function]
2 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: initialization from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/../../../powerpc/shared/bootloader/qemu_fakeres.c:146:1: warning: no previous prototype for 'res_copy' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/../../../powerpc/shared/bootloader/qemu_fakeres.c:123:1: warning: no previous prototype for 'nvram_rdl_be' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c:40:2: warning: #warning No SPI configuration available [-Wcpp]
2 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c:301:12: warning: variable 'spi_busno' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:420:24: warning: unused variable 'level' [-Wunused-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:419:11: warning: unused variable 'msr' [-Wunused-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:418:29: warning: unused variable 'mask_ptr' [-Wunused-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:417:22: warning: unused variable 'mask_save' [-Wunused-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c:102:7: warning: variable 'i2c_busno' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/gen5200/../shared/uboot_getenv.c:40:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c:21:6: warning: no previous prototype for 'bsp_spurious_handler_assistant' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/m68000spurious.c:34:9: warning: variable 's' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/m68000spurious.c:29:11: warning: no previous prototype for 'bsp_spurious_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/bspspuriousinit.c:29:6: warning: no previous prototype for 'bsp_spurious_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/console/debugio.c:20:6: warning: no previous prototype for 'debug_putc' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/timer/timer.c:34:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c:55:18: warning: assignment from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c:26:6: warning: no previous prototype for 'bsp_return_to_monitor_trap' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:87:5: warning: implicit declaration of function 'putchar' [-Wimplicit-function-declaration]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:39:11: warning: no previous prototype for 'C_Receive_ISR' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:184:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:171:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
2 c/src/lib/libbsp/h8300/h8sim/startup/__main.c:9:6: warning: no previous prototype for '__main' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c:33:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/console/uart.c:329:7: warning: no previous prototype for 'UART0_SendStr' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/console/uart.c:318:7: warning: no previous prototype for 'UART0_SendByte' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/console/uart.c:297:7: warning: no previous prototype for 'UART0_Ini' [-Wmissing-prototypes]
2 c/src/../../cpukit/score/src/threadloadenv.c:29:12: warning: variable 'isr_level' set but not used [-Wunused-but-set-variable]
2 c/src/../../cpukit/score/cpu/sparc64/cpu.c:74:18: warning: variable 'the_size' set but not used [-Wunused-but-set-variable]
2 c/src/../../cpukit/score/cpu/m68k/cpu_asm.S:75:2: warning: #warning "_CPU_Context_Restart_self restoring FPU context not implemented" [-Wcpp]
2 c/src/../../cpukit/score/cpu/lm32/irq.c:32:6: warning: no previous prototype for '__ISR_Handler' [-Wmissing-prototypes]
2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:80:16: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:33:12: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
1 tools/cpu/nios2/ptf.c:92:26: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:77:9: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:166:31: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:156:29: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 log/sh-gensh2.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
1 log/sh-gensh1.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
1 log/powerpc-ss555.log: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
1 log/powerpc-mpc8309som.log: #warning No SPI configuration available
1 log/powerpc-ep1a.log: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
1 log/powerpc-br_uid.log: #warning No SPI configuration available
1 log/or1k-or1ksim.log:/users/joel/rtems-4.11-work/tools/lib/gcc/or1k-rtems4.11/4.8.3/../../../../or1k-rtems4.11/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000000000
1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: (near initialization for 'Configuration.idle_task') [enabled by default]
1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: initialization from incompatible pointer type [enabled by default]
1 log/m68k-m5484FireEngine.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
1 log/m68k-COBRA5475.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
1 c/src/../../testsuites/samples/paranoia/paranoia.c:195:0: warning: "POW" redefined [enabled by default]
1 c/src/../../testsuites/samples/nsecs/init.c:125:12: warning: iteration 3u invokes undefined behavior [-Waggressive-loop-optimizations]
1 c/src/../../testsuites/samples/fileio/init.c:420:7: warning: large integer implicitly truncated to unsigned type [-Woverflow]
1 c/src/../../testsuites/samples/fileio/init.c:354:9: warning: left shift count >= width of type [enabled by default]
1 c/src/../../testsuites/samples/capture/system.h:49:41: warning: integer overflow in expression [-Woverflow]
1 c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c:81:1: warning: no previous prototype for 'sh4uart_get_Pph' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c:454:7: warning: variable 'error_occured' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c:422:1: warning: no previous prototype for 'sh4uart_handle_error' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c:154:11: warning: no previous prototype for 'sh_sci_tx_isr' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c:127:11: warning: no previous prototype for 'sh_sci_rx_isr' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:309:5: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../.././gensh2/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:266:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:254:6: warning: no previous prototype for 'sh_sci_inbyte_polled' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:228:6: warning: no previous prototype for 'rdSCI1' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:204:6: warning: no previous prototype for 'rdSCI0' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:197:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:184:6: warning: no previous prototype for 'sh_sci_outbyte_polled' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:167:6: warning: no previous prototype for 'wrtSCI1' [-Wmissing-prototypes]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:151:6: warning: no previous prototype for 'wrtSCI0' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/cpm/brg.c:59:3: warning: nested extern declaration of 'bsp_serial_per_sec' [-Wnested-externs]
1 c/src/lib/libcpu/powerpc/mpc8260/cpm/brg.c:157:6: warning: no previous prototype for 'm8xx_dump_brgs' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:877:17: warning: variable 'brg' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:868:5: warning: no previous prototype for 'm8xx_smc_isOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:852:6: warning: no previous prototype for 'm8xx_smc_disable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:836:6: warning: no previous prototype for 'm8xx_smc_enable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:655:5: warning: no previous prototype for 'm8xx_scc_isOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:633:6: warning: no previous prototype for 'm8xx_scc_disable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc8260/console-generic/console-generic.c:607:6: warning: no previous prototype for 'm8xx_scc_enable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c:96:11: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c:96:6: warning: no previous prototype for 'initialize_exceptions' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c:91:5: warning: no previous prototype for 'except_always_enabled' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c:87:6: warning: no previous prototype for 'nop_except_enable' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/vectors/vectors_init.c:30:6: warning: no previous prototype for 'C_default_exception_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c:92:6: warning: no previous prototype for 'CPU_USIU_irq_init' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq_init.c:110:1: warning: no previous prototype for 'CPU_UIMB_irq_init' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:410:6: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:400:5: warning: no previous prototype for 'CPU_rtems_irq_mngt_get' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:328:5: warning: no previous prototype for 'CPU_rtems_irq_mngt_set' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:271:5: warning: no previous prototype for 'CPU_remove_rtems_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:262:5: warning: no previous prototype for 'CPU_get_current_rtems_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:205:5: warning: no previous prototype for 'CPU_install_rtems_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:190:5: warning: no previous prototype for 'CPU_irq_enabled_at_usiu' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:176:5: warning: no previous prototype for 'CPU_irq_disable_at_usiu' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:162:5: warning: no previous prototype for 'CPU_irq_enable_at_usiu' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:155:5: warning: no previous prototype for 'CPU_irq_enabled_at_uimb' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:148:5: warning: no previous prototype for 'CPU_irq_disable_at_uimb' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/irq/irq.c:141:5: warning: no previous prototype for 'CPU_irq_enable_at_uimb' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c:273:5: warning: no previous prototype for 'm5xx_sci_isOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/console-generic/console-generic.c:269:6: warning: no previous prototype for 'm5xx_sci_nop' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:71:6: warning: no previous prototype for 'clockOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:61:11: warning: no previous prototype for 'Clock_isr' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:112:5: warning: no previous prototype for 'clockIsOn' [-Wmissing-prototypes]
1 c/src/lib/libcpu/powerpc/mpc5xx/clock/clock.c:104:6: warning: no previous prototype for 'clockOff' [-Wmissing-prototypes]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:586:3: warning: nested extern declaration of '_CPU_cache_disable_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:586:3: warning: implicit declaration of function '_CPU_cache_disable_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:576:3: warning: nested extern declaration of '_CPU_cache_enable_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:576:3: warning: implicit declaration of function '_CPU_cache_enable_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:566:3: warning: nested extern declaration of '_CPU_cache_unfreeze_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:566:3: warning: implicit declaration of function '_CPU_cache_unfreeze_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:555:3: warning: nested extern declaration of '_CPU_cache_freeze_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:555:3: warning: implicit declaration of function '_CPU_cache_freeze_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:516:2: warning: nested extern declaration of '_CPU_cache_invalidate_entire_instruction' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:516:2: warning: implicit declaration of function '_CPU_cache_invalidate_entire_instruction' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:461:5: warning: nested extern declaration of '_CPU_cache_invalidate_1_instruction_line' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:461:5: warning: implicit declaration of function '_CPU_cache_invalidate_1_instruction_line' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:420:3: warning: nested extern declaration of '_CPU_cache_disable_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:420:3: warning: implicit declaration of function '_CPU_cache_disable_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:410:3: warning: nested extern declaration of '_CPU_cache_enable_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:410:3: warning: implicit declaration of function '_CPU_cache_enable_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:400:3: warning: nested extern declaration of '_CPU_cache_unfreeze_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:400:3: warning: implicit declaration of function '_CPU_cache_unfreeze_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:389:3: warning: nested extern declaration of '_CPU_cache_freeze_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:389:3: warning: implicit declaration of function '_CPU_cache_freeze_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:352:2: warning: nested extern declaration of '_CPU_cache_invalidate_entire_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:352:2: warning: implicit declaration of function '_CPU_cache_invalidate_entire_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:335:4: warning: nested extern declaration of '_CPU_cache_flush_entire_data' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:335:4: warning: implicit declaration of function '_CPU_cache_flush_entire_data' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:316:5: warning: nested extern declaration of '_CPU_cache_invalidate_1_data_line' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:316:5: warning: implicit declaration of function '_CPU_cache_invalidate_1_data_line' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:280:5: warning: nested extern declaration of '_CPU_cache_flush_1_data_line' [-Wnested-externs]
1 c/src/lib/libcpu/or1k/../shared/src/cache_manager.c:280:5: warning: implicit declaration of function '_CPU_cache_flush_1_data_line' [-Wimplicit-function-declaration]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:94:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:84:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:74:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:147:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:136:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:125:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:114:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/or1k/shared/cache/cache.c:104:3: warning: passing argument 2 of '_OR1K_mtspr' makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:95:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:82:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:69:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:53:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:40:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:36:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:32:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:28:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:24:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:136:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:131:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:122:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:113:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf532x/cache/cachepd.c:100:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:91:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:86:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:76:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:66:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:57:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:52:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:42:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:32:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:30:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:29:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:24:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:23:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:22:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5235/cache/cachepd.c:21:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:35:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:34:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:33:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:32:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:30:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:29:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:28:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:27:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:25:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:24:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:19:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:18:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:17:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5223x/cache/cachepd.c:16:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:568:23: warning: assignment makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:417:1: warning: no previous prototype for 'mcfmbus_interrupt_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:190:25: warning: passing argument 1 of 'bus->done' makes pointer from integer without a cast [enabled by default]
1 c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c:524:22: warning: pointer targets in assignment differ in signedness [-Wpointer-sign]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:93:6: warning: no previous prototype for 'xscale_pmc_disable_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:86:6: warning: no previous prototype for 'xscale_pmc_enable_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:51:6: warning: no previous prototype for 'xscale_write_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:13:14: warning: no previous prototype for 'xscale_read_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:117:6: warning: no previous prototype for 'xscale_pmc_setevent' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:109:6: warning: no previous prototype for 'xscale_pmc_reset_ccnt' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/pmc/pmc.c:101:6: warning: no previous prototype for 'xscale_pmc_reset_pmc' [-Wmissing-prototypes]
1 c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c:207:5: warning: no previous prototype for 'ffuart_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:42:28: warning: no previous prototype for 'grcan_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:42:28: warning: no previous prototype for 'grcan_rasta_register_abs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/1553/b1553brm_rasta.c:84:5: warning: no previous prototype for 'b1553brm_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:246:5: warning: no previous prototype for 'cchip1_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/helenos/boot/genarch/ofw.c:217:6: warning: no previous prototype for 'ofw_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/console/conscfg.c:41:6: warning: no previous prototype for 'sun4v_console_deviceProbe' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/console/conscfg.c:32:5: warning: no previous prototype for 'sun4v_console_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/console/conscfg.c:27:6: warning: no previous prototype for 'sun4v_console_deviceInitialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/usiii/../shared/console/conscfg.c:16:5: warning: no previous prototype for 'sun4v_console_device_first_open' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/startup/m5op.h:46:1: warning: function declaration isn't a prototype [-Wstrict-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/helenos/boot/genarch/ofw.c:217:6: warning: no previous prototype for 'ofw_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/console/conscfg.c:41:6: warning: no previous prototype for 'sun4v_console_deviceProbe' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/console/conscfg.c:32:5: warning: no previous prototype for 'sun4v_console_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/console/conscfg.c:27:6: warning: no previous prototype for 'sun4v_console_deviceInitialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc64/niagara/../shared/console/conscfg.c:16:5: warning: no previous prototype for 'sun4v_console_device_first_open' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh4/../shared/bsphwinit.c:12:6: warning: no previous prototype for 'bsp_hw_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c:36:1: warning: no previous prototype for 'early_hw_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c:270:6: warning: no previous prototype for 'bsp_cache_on' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh2/../../sh/shared/console.c:68:3: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../../.././gensh2/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libbsp/sh/gensh2/../shared/bsphwinit.c:12:6: warning: no previous prototype for 'bsp_hw_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh1/../../sh/shared/console.c:68:3: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../../.././gensh1/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libbsp/sh/gensh1/../shared/bsphwinit.c:12:6: warning: no previous prototype for 'bsp_hw_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c:86:20: warning: unused variable 'c' [-Wunused-variable]
1 c/src/lib/libbsp/powerpc/virtex/irq/irq_init.c:86:17: warning: unused variable 'i' [-Wunused-variable]
1 c/src/lib/libbsp/powerpc/virtex5/../shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/virtex4/../shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:848:26: warning: 'bsp_dummy_spi_init' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:773:26: warning: 'bsp_pghplus_spi_init' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:743:26: warning: 'bsp_pghplus_spi_send_stop' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:694:26: warning: 'bsp_pghplus_spi_sel_addr' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:673:26: warning: 'bsp_dummy_spi_send_stop' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:629:26: warning: 'bsp_dummy_spi_sel_addr' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c:51:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c:38:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_write.c:36:21: warning: no previous prototype for 'console_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_read.c:36:21: warning: no previous prototype for 'console_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_control.c:37:21: warning: no previous prototype for 'console_control' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ss555/startup/iss555.c:34:6: warning: no previous prototype for '_InitSS555' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c:82:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c:81:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c:22:2: warning: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c). [-Wcpp]
1 c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c:86:6: warning: no previous prototype for 'init_PCI' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c:77:6: warning: no previous prototype for 'init_RTC' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c:129:6: warning: no previous prototype for 'data_cache_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c:114:6: warning: no previous prototype for 'instruction_cache_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:252:6: warning: no previous prototype for 'set_vme_slave_size' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:239:18: warning: no previous prototype for 'get_vme_slave_size' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:230:18: warning: no previous prototype for 'get_vme_base_address' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:197:6: warning: no previous prototype for 'set_vme_base_address' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c:157:6: warning: no previous prototype for 'initialize_universe' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:85:7: warning: no previous prototype for 'Write_pci_device_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:61:18: warning: no previous prototype for 'Read_pci_device_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:46:18: warning: no previous prototype for 'PCI_bus_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:37:6: warning: no previous prototype for 'PCI_bus_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c:28:6: warning: no previous prototype for 'PCI_bus_delay' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c:63:14: warning: no previous prototype for 'SCORE603e_FLASH_pci_reset_reg' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c:35:14: warning: no previous prototype for 'SCORE603e_FLASH_verify_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c:42:10: warning: no previous prototype for 'get_irq_mask' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c:24:6: warning: no previous prototype for 'initialize_PCI_bridge' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c:162:18: warning: no previous prototype for 'read_and_clear_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c:106:6: warning: no previous prototype for 'init_irq_data_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/console/console.c:46:5: warning: no previous prototype for 'console_inbyte_nonblocking' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/console/console.c:404:1: warning: no previous prototype for 'debug_putc_onlcr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/console/console.c:255:9: warning: no previous prototype for 'console_write_support' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/score603e/console/console.c:181:36: warning: variable 'chip' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: (near initialization for 'console_device_table[2].context') [enabled by default]
1 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: (near initialization for 'console_device_table[0].context') [enabled by default]
1 c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c:37:6: warning: no previous prototype for 'cmain' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c:10:1: warning: '__inb' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:49:19: warning: no previous prototype for 'bsp_interrupt_facility_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:43:19: warning: no previous prototype for 'bsp_interrupt_vector_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:37:19: warning: no previous prototype for 'bsp_interrupt_vector_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:28:5: warning: no previous prototype for 'qemuppc_exception_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:91:5: warning: no previous prototype for 'psim_exception_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:112:19: warning: no previous prototype for 'bsp_interrupt_facility_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:106:19: warning: no previous prototype for 'bsp_interrupt_vector_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:100:19: warning: no previous prototype for 'bsp_interrupt_vector_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/startup/pgtbl_activate.c:18:1: warning: no previous prototype for '__BSP_default_pgtbl_activate' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c:163:1: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/probeMemEnd.c:168:1: warning: no previous prototype for 'probeMemoryEnd' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/probeMemEnd.c:120:1: warning: no previous prototype for 'CPU_lockUnlockCaches' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci_interface.c:69:6: warning: no previous prototype for 'pci_interface' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c:22:7: warning: variable 'x' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c:19:5: warning: no previous prototype for 'BSP_pciFindDevicePrint' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c:219:18: warning: no previous prototype for 'BSP_getVMEchipType' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c:214:22: warning: no previous prototype for 'BSP_getDiscoveryChipVersion' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c:26:15: warning: no previous prototype for '_BSP_clear_hostbridge_errors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:482:6: warning: no previous prototype for 'BSP_printPicIsrTbl' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:357:6: warning: no previous prototype for 'BSP_disable_pic_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:322:6: warning: no previous prototype for 'BSP_enable_pic_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c:31:5: warning: no previous prototype for 'I2Cread_eeprom' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.c:61:5: warning: no previous prototype for 'GT64260TWSIintFlag' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c:125:1: warning: no previous prototype for 'BSP_eeprom_write_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c:116:1: warning: no previous prototype for 'BSP_eeprom_write_protect' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c:128:8: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:691:1: warning: no previous prototype for 'am2imode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:577:1: warning: no previous prototype for 'am2omode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1238:1: warning: no previous prototype for 'vmeTsi148InboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1184:1: warning: no previous prototype for 'vmeTsi148InboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1178:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1114:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c:71:6: warning: no previous prototype for 'BSP_motload_pci_fixup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c:109:1: warning: no previous prototype for 'BSP_pciConfigDump_early' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:430:1: warning: no previous prototype for 'i2c_write_bytes' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:424:1: warning: no previous prototype for 'i2c_read_bytes' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:381:1: warning: no previous prototype for 'i2c_send_addr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:365:1: warning: no previous prototype for 'i2c_stop' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:336:1: warning: no previous prototype for 'i2c_start' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:291:1: warning: no previous prototype for 'i2c_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:205:1: warning: no previous prototype for 'i2c_xfer' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/i2c_init.c:85:1: warning: no previous prototype for 'BSP_i2c_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/cpuinit.c:15:6: warning: no previous prototype for 'cpu_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:98:6: warning: no previous prototype for '_BSP_GPLED0_off' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:151:22: warning: variable 'myCpuRevision' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:150:16: warning: variable 'myCpu' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:140:6: warning: no previous prototype for '_BSP_Uart2_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:133:6: warning: no previous prototype for '_BSP_Uart2_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:126:6: warning: no previous prototype for '_BSP_Uart1_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:119:6: warning: no previous prototype for '_BSP_Uart1_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/startup/bspstart.c:112:6: warning: no previous prototype for '_BSP_GPLED1_off' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/../shared/startup/bspidle.c:25:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c:314:1: warning: no previous prototype for 'BSP_CPM_irq_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c:214:5: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mpc8260ads/console/console.c:455:5: warning: no previous prototype for 'mbx8xx_console_get_configuration' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/bspstart.c:125:14: warning: no previous prototype for 'get_eumbbar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:162:12: warning: unused variable 'i' [-Wunused-variable]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:411:26: warning: 'do_poll_write' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:347:26: warning: 'do_poll_read' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:219:16: warning: '_EPPCBug_pollWrite' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:114:12: warning: '_EPPCBug_pollRead' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c:14:2: warning: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c). [-Wcpp]
1 c/src/lib/libbsp/powerpc/beatnik/startup/i2c_init.c:60:1: warning: no previous prototype for 'BSP_i2c_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:162:1: warning: no previous prototype for 'BSP_getBoardType' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:147:1: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:691:1: warning: no previous prototype for 'am2imode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:577:1: warning: no previous prototype for 'am2omode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1238:1: warning: no previous prototype for 'vmeTsi148InboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1184:1: warning: no previous prototype for 'vmeTsi148InboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1178:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1114:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/zerobss.c:22:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/probeMemEnd.c:168:1: warning: no previous prototype for 'probeMemoryEnd' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/probeMemEnd.c:120:1: warning: no previous prototype for 'CPU_lockUnlockCaches' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/panic.c:31:17: warning: variable 'flags' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c:76:1: warning: no previous prototype for 'rtems_pci_io_remap' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c:72:6: warning: no previous prototype for 'BSP_motload_pci_fixup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c:170:1: warning: no previous prototype for 'BSP_pci_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c:258:6: warning: no previous prototype for 'BSP_timer_test_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c:212:1: warning: no previous prototype for 'BSP_timers_uninstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:971:1: warning: no previous prototype for 'discovery_pic_set_debug_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:924:1: warning: no previous prototype for 'discovery_pic_install_debug_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:199:6: warning: no previous prototype for 'discovery_dump_picregs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:92:8: warning: unused variable 'c' [-Wunused-variable]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:29:17: warning: 'uart_get_baud' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:24:28: warning: 'uart_get_irq_number' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:147:3: warning: (near initialization for 'or1ksim_uart_fns.deviceRead') [enabled by default]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:147:3: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c:140:34: warning: 'Old_ticker' is used uninitialized in this function [-Wuninitialized]
1 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c:45:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type
1 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c:33:6: warning: no previous prototype for 'timerisr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c:24:6: warning: no previous prototype for 'bsp_start' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/console/console.c:38:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/startup/moxiebdinstallirq.c:15:6: warning: no previous prototype for 'MOXIEBD_Install_IRQ' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/startup/__main.c:10:6: warning: no previous prototype for '__main' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/../../shared/bspclean.c:14:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c:9:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/start/start.S:24:1: warning: "/*" within comment [-Wcomment]
1 c/src/lib/libbsp/mips/rbtx4938/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:93:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:272:6: warning: no previous prototype for 'RBTX4938_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:138:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:113:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/startup/inittlb.c:9:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/start/start.S:24:1: warning: "/*" within comment [-Wcomment]
1 c/src/lib/libbsp/mips/rbtx4925/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:91:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:266:6: warning: no previous prototype for 'RBTX4925_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:134:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:111:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:145:5: warning: (near initialization for 'Console_Configuration_Ports[2].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:145:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:144:5: warning: (near initialization for 'Console_Configuration_Ports[2].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:144:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:126:5: warning: (near initialization for 'Console_Configuration_Ports[1].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:126:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:125:5: warning: (near initialization for 'Console_Configuration_Ports[1].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:125:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:107:5: warning: (near initialization for 'Console_Configuration_Ports[0].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:107:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:106:5: warning: (near initialization for 'Console_Configuration_Ports[0].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:106:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/hurricane/startup/inittlb.c:5:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:80:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:254:6: warning: no previous prototype for 'hurricane_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:123:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:100:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:1576:7: warning: nested extern declaration of 'rtems_interrupt_catch' [-Wnested-externs]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:1576:7: warning: implicit declaration of function 'rtems_interrupt_catch' [-Wimplicit-function-declaration]
1 c/src/lib/libbsp/mips/csb350/console/console-io.c:76:6: warning: no previous prototype for 'csb250_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:178:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:171:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:159:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:147:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:138:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:133:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:123:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:113:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:111:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:110:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:105:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:104:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:103:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/uC5282/startup/bspstart.c:102:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/trace.c:66:6: warning: no previous prototype for 'trace_exception' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c:29:1: warning: no previous prototype for 'partial_memory_test' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c:24:1: warning: no previous prototype for 'reset_partial_memory_test' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c:19:1: warning: no previous prototype for 'boot_memory_test' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c:14:1: warning: no previous prototype for 'production_memory_test' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c:540:6: warning: no previous prototype for '_returnFromException' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c:62:6: warning: no previous prototype for 'exceptionHandler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c:25:6: warning: no previous prototype for 'getDebugChar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c:14:6: warning: no previous prototype for 'putDebugChar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c:95:6: warning: no previous prototype for 'boot_phase_2' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c:51:6: warning: no previous prototype for 'boot_phase_1' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c:124:6: warning: no previous prototype for 'boot_phase_3' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/console/console.c:88:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/console/console.c:65:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/ods68302/console/console.c:108:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme167/timer/timer.c:78:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:585:52: warning: variable 'final_ier' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:585:39: warning: variable 'initial_ier' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:540:8: warning: variable 'buffer' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:539:42: warning: variable 'total' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:232:18: warning: variable 'ticks_per_second' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:1374:19: warning: no previous prototype for 'do_poll_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:1336:19: warning: no previous prototype for 'do_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/timer/timer.c:30:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c:43:18: warning: assignment from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c:21:6: warning: no previous prototype for 'bsp_return_to_monitor_trap' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/timer/timer.c:30:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:94:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:66:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:120:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:94:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:66:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:120:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c:31:11: warning: no previous prototype for 'Spurious_Isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mrm332/console/sci.c:1150:16: warning: variable 'unused' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mrm332/console/sci.c:1041:16: warning: variable 'length' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c:40:13: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c:25:6: warning: no previous prototype for 'Init5329' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5235/startup/init5235.c:29:6: warning: no previous prototype for 'Init5235' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c:30:6: warning: no previous prototype for 'Init5225x' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:43:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:42:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:41:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:40:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:38:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:37:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:36:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:35:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:33:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:32:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:27:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:26:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:25:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/bspstart.c:24:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf52235/startup/init52235.c:40:13: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libbsp/m68k/mcf52235/startup/init52235.c:25:6: warning: no previous prototype for 'Init52235' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:91:1: warning: no previous prototype for 'ds1307_get_time' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:47:1: warning: no previous prototype for 'ds1307_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:172:1: warning: no previous prototype for 'ds1307_set_time' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c:66:1: warning: no previous prototype for 'Init5206e' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/timer/timer.c:26:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/idp/console/mc68ec.c:12:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/console.c:86:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/console.c:157:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/console.c:132:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/console.c:110:6: warning: no previous prototype for 'quick_char_check' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c:48:26: warning: variable 'RamBase_p' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68340/timer/timer.c:88:6: warning: no previous prototype for '__Restart_Check_Timer' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/timer/timer.c:72:6: warning: no previous prototype for '__Restart_Fifo_Full_Timer' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/timer/timer.c:188:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68340/timer/timer.c:105:6: warning: no previous prototype for '__do_nothing' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/startup/init68340.c:21:6: warning: no previous prototype for '_Init68340' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c:129:6: warning: no previous prototype for '_dbug_dumpanic' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c:109:6: warning: no previous prototype for '_dbug_dump' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/m340uart.c:302:6: warning: no previous prototype for 'RAW_FMT' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/m340uart.c:288:6: warning: no previous prototype for 'RAW_GETC' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/m340uart.c:127:1: warning: no previous prototype for 'Find_Right_m340_UART_Channel_Config' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:382:23: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:298:23: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:232:5: warning: no previous prototype for 'dbug_char_present' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:214:5: warning: no previous prototype for 'dbug_in_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68340/console/console.c:196:6: warning: no previous prototype for 'dbug_out_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:166:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:134:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:105:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/csb360/startup/init5272.c:84:1: warning: no previous prototype for 'init5272' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/init5282.c:23:6: warning: no previous prototype for 'Init5282' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:95:6: warning: no previous prototype for '_CPU_cache_enable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:86:6: warning: no previous prototype for '_CPU_cache_invalidate_1_instruction_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:81:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:71:6: warning: no previous prototype for '_CPU_cache_disable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:61:6: warning: no previous prototype for '_CPU_cache_enable_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:59:6: warning: no previous prototype for '_CPU_cache_flush_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:58:6: warning: no previous prototype for '_CPU_cache_flush_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:53:6: warning: no previous prototype for '_CPU_cache_unfreeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:52:6: warning: no previous prototype for '_CPU_cache_freeze_instruction' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:51:6: warning: no previous prototype for '_CPU_cache_unfreeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:50:6: warning: no previous prototype for '_CPU_cache_freeze_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:121:6: warning: no previous prototype for '_CPU_cache_invalidate_1_data_line' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:116:6: warning: no previous prototype for '_CPU_cache_invalidate_entire_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/bspstart.c:105:6: warning: no previous prototype for '_CPU_cache_disable_data' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c:48:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:61:6: warning: no previous prototype for 'BSP_uart_is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:54:6: warning: no previous prototype for 'BSP_uart_polled_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:44:6: warning: no previous prototype for 'BSP_uart_polled_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c:173:6: warning: no previous prototype for 'initCPLB' [-Wmissing-prototypes]
1 c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c:225:9: warning: no previous prototype for 'getButtons' [-Wmissing-prototypes]
1 c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c:218:9: warning: no previous prototype for 'getLEDs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c:207:6: warning: no previous prototype for 'setLEDs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/startup/bspstart.c:24:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:355:5: warning: no previous prototype for 'sm_ECCEncode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:326:6: warning: no previous prototype for 'smc_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:291:6: warning: no previous prototype for 'smc_detect' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:242:6: warning: no previous prototype for 'smc_make_l2p' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:210:6: warning: no previous prototype for 'smc_read_spare' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:163:9: warning: no previous prototype for 'smc_read_page' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/smdk2410/../gp32/smc/smc.c:136:6: warning: no previous prototype for 'smc_read_id' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../../shared/bspclean.c:14:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/console/usart.c:37:17: warning: 'usart_get_baud' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/arm/raspberrypi/console/usart.c:32:28: warning: 'usart_get_irq_number' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c:124:20: warning: assignment from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/arm/gumstix/startup/bspstart.c:29:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/startup/bspstart.c:24:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:355:5: warning: no previous prototype for 'sm_ECCEncode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:326:6: warning: no previous prototype for 'smc_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:291:6: warning: no previous prototype for 'smc_detect' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:242:6: warning: no previous prototype for 'smc_make_l2p' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:210:6: warning: no previous prototype for 'smc_read_spare' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:163:9: warning: no previous prototype for 'smc_read_page' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gp32/smc/smc.c:136:6: warning: no previous prototype for 'smc_read_id' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/startup/bspstart.c:37:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/gba/console/conio.c:321:6: warning: no previous prototype for 'gba_initconio' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/edb7312/startup/bspstart.c:27:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/edb7312/irq/irq.c:23:6: warning: no previous prototype for 'edb7312_interrupt_dispatch' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/csb337/console/sed1356.c:362:6: warning: no previous prototype for 'sed_update_fb_offset' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/csb337/console/fbcons.c:135:5: warning: no previous prototype for 'fbcons_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/csb336/startup/bspstart.c:31:6: warning: no previous prototype for 'bsp_start_default' [-Wmissing-prototypes]
1 c/src/../../cpukit/score/src/threadstartmultitasking.c:82:1: warning: 'noreturn' function does return [enabled by default]
1 c/src/../../cpukit/score/src/objectextendinformation.c:159:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
1 c/src/../../cpukit/score/src/objectextendinformation.c:154:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
1 c/src/../../cpukit/libmisc/utf8proc/utf8proc.c:148:5: warning: left shift count >= width of type [enabled by default]
1 c/src/../../cpukit/libfs/src/dosfs/msdos_conv.c:452:48: warning: 'c' may be used uninitialized in this function [-Wmaybe-uninitialized]
1 c/src/../../cpukit/libcsupport/src/vprintk.c:199:41: warning: 'num' may be used uninitialized in this function [-Wmaybe-uninitialized]
1 arm-altcycv_devkit
1 arm-altcycv_devkit_smp
1 arm-arm1136jfs
1 arm-arm1136js
1 arm-arm7tdmi
1 arm-arm920
1 arm-armcortexa9
1 arm-lm3s3749
1 arm-lm3s6965
1 arm-lm3s6965_qemu
1 arm-lm4f120
1 arm-lpc17xx_ea_ram
1 arm-lpc17xx_ea_rom_int
1 arm-lpc17xx_plx800_ram
1 arm-lpc17xx_plx800_rom_int
1 arm-lpc2362
1 arm-lpc23xx_tli800
1 arm-lpc24xx_ea
1 arm-lpc24xx_ncs_ram
1 arm-lpc24xx_ncs_rom_ext
1 arm-lpc24xx_ncs_rom_int
1 arm-lpc24xx_plx800_ram
1 arm-lpc24xx_plx800_rom_int
1 arm-lpc32xx_mzx
1 arm-lpc32xx_mzx_stage_1
1 arm-lpc32xx_mzx_stage_2
1 arm-lpc32xx_phycore
1 arm-lpc40xx_ea_ram
1 arm-lpc40xx_ea_rom_int
1 arm-realview_pbx_a9_qemu
1 arm-realview_pbx_a9_qemu_smp
1 arm-stm32f105rc
1 arm-stm32f4
1 arm-tms570ls3137_hdk
1 arm-tms570ls3137_hdk_intram
1 arm-tms570ls3137_hdk_sdram
1 arm-xilinx_zynq_a9_qemu
1 arm-xilinx_zynq_zc702
1 arm-xilinx_zynq_zc706
1 arm-xilinx_zynq_zedboard
1 mips-jmr3904
2 arm-nds
2 mips-csb350
3 arm-csb336
3 arm-edb7312
3 arm-gba
3 avr-avrtest
3 mips-genmongoosev
3 v850-v850e1sim
3 v850-v850e2sim
3 v850-v850e2v3sim
3 v850-v850esim
3 v850-v850essim
3 v850-v850sim
5 lm32-milkymist
6 arm-raspberrypi
6 powerpc-dp2
6 powerpc-icecube
6 powerpc-mpc5643l_dpu
6 powerpc-mpc5643l_evb
6 powerpc-mpc5668g
6 powerpc-pm520_cr825
6 powerpc-pm520_ze30
6 sparc-leon3
6 sparc-ngmp
7 arm-csb337
7 arm-kit637_v6
7 lm32-lm32_evr
7 mips-hurricane
7 powerpc-brs5l
7 powerpc-brs6l
7 powerpc-ep1a
7 powerpc-gwlcfm
7 powerpc-mpc5674f_ecu508_app
7 powerpc-mpc5674f_ecu508_boot
7 powerpc-mpc5674fevb
7 powerpc-mpc5674fevb_spe
7 powerpc-mpc5674f_rsm6
7 powerpc-phycore_mpc5554
7 powerpc-virtex5
7 sh-gensh1
8 arm-lpc1768_mbed
8 arm-lpc1768_mbed_ahb_ram
8 arm-lpc1768_mbed_ahb_ram_eth
8 mips-rbtx4925
8 mips-rbtx4938
8 powerpc-mpc5566evb
8 powerpc-mpc5566evb_spe
8 sh-simsh1
8 sh-simsh2
8 sh-simsh2e
8 sh-simsh4
9 arm-csb637
9 nios2-nios2_iss
9 powerpc-haleakala
9 powerpc-virtex4
10 arm-gp32
10 arm-smdk2410
10 powerpc-virtex
10 sh-gensh4
10 sparc-leon2
11 arm-gumstix
11 powerpc-psim
11 powerpc-t32mppc
11 sparc-erc32
11 sparc-sis
12 powerpc-qemuppc
12 powerpc-qoriq_p1020rdb
13 arm-rtl22xx_t
13 mips-malta
13 powerpc-hsc_cm01
13 powerpc-mpc8349eamds
14 arm-rtl22xx
14 powerpc-mvme2100
14 powerpc-qoriq_core_0
14 powerpc-qoriq_core_1
16 powerpc-mpc8309som
16 powerpc-qemuprep
16 powerpc-qemuprep-altivec
17 m32r-m32rsim
17 powerpc-mpc8313erdb
18 h8300-h8sim
18 sh-gensh2
19 powerpc-br_uid
19 powerpc-mtx603e
20 m68k-COBRA5475
20 m68k-csb360
20 m68k-m5484FireEngine
20 moxie-moxiesim
21 m68k-gen68360
21 m68k-gen68360_040
21 powerpc-mcp750
21 powerpc-mvme2307
22 m68k-gen68302
22 m68k-pgh360
23 m68k-mrm332
23 m68k-mvme147s
24 m68k-sim68000
24 m68k-simcpu32
24 powerpc-mvme5500
25 m68k-idp
25 m68k-mvme136
25 m68k-mvme147
25 powerpc-mpc8260ads
26 bfin-TLL6527M
26 m68k-mvme162
26 m68k-mvme162lx
27 m68k-mcf5206elite
27 m68k-mvme167
28 bfin-eZKit533
28 powerpc-mvme3100
30 bfin-bf537Stamp
30 powerpc-mbx821_001
30 powerpc-mbx821_002
30 powerpc-mbx821_002b
30 powerpc-mbx860_001b
30 powerpc-mbx860_002
30 powerpc-score603e
31 powerpc-beatnik
31 powerpc-mbx860_1b
31 powerpc-pghplus
31 powerpc-tqm8xx_stk8xx
33 m68k-uC5282
33 powerpc-ss555
34 i386-pc386
34 i386-pc486
34 i386-pc586
34 i386-pc586-sse
34 i386-pc686
34 i386-pcp4
34 m68k-av5282
34 m68k-gen68340
34 m68k-mcf5225x
34 m68k-mcf5235
34 m68k-ods68302
35 m68k-mcf52235
35 m68k-mcf5329
35 powerpc-mbx860_005b
39 sparc64-usiii
40 sparc64-niagara
44 h8300-h8sxsim
52 m32c-m32csim
63 or1k-or1ksim
