Warnings Report 13 Oct
Hesham Moustafa heshamelmatary at gmail.com
Mon Oct 13 18:10:00 UTC 2014
Hi,
Thanks for providing these results. or1ksim related warnings should be
greatly decreased after the latest two patches I submitted.
Regards,
Hesham
On Mon, Oct 13, 2014 at 6:50 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> Hi
> Attached is the set of unique warnings and list of warnings
> count per BSP after committing all my patches.  This is
> with tests=samples and networking disabled.
> On 6 Oct, there were 1737 unique warnings.
> Today, there are 759 unique warnings.
> The warnings break down in categories like this:
>      2 aggressive-loop-optimizations
>       2 comment                                     <== I just pushed a
> fix for this
>       5 cpp
>       3 deprecated-declarations
>      19 format=
>      17 implicit-function-declaration
>       5 int-to-pointer-cast
>       2 maybe-uninitialized
>     506 missing-prototypes
>      17 nested-externs
>       3 overflow
>       1 pointer-sign
>       6 pointer-to-int-cast
>       1 strict-prototypes
>       1 uninitialized
>      46 unused-but-set-variable
>      17 unused-function
>      13 unused-variable
> If you are interested in helping, for many of the warnings, it is obvious
> from the unique sorted list what BSP triggers the warning based on the
> file name.  If it isn't obvious, ask me for the BSPs triggering a warning.
> Again, help running these down is appreciated.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141013/a5e60c65/attachment-0002.html>
