[PATCH 2/2] libbsp/or1ksim: Fix warnings.
Hesham Moustafa
heshamelmatary at gmail.com
Mon Oct 13 18:06:00 UTC 2014
Please have a look at this patch.
On Fri, Oct 10, 2014 at 6:45 PM, Hesham ALMatary <heshamelmatary at gmail.com>
wrote:
> c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c | 2 +-
> c/src/lib/libbsp/or1k/or1ksim/console/uart.c | 15 +++++++++++----
> 2 files changed, 12 insertions(+), 5 deletions(-)
> diff --git a/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
> b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
> index ad49d07..4169a11 100644
> --- a/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
> +++ b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
> @@ -137,8 +137,8 @@ CPU_Counter_ticks _CPU_Counter_difference(
> #define Clock_driver_support_install_isr(isr, old_isr) \
> do { \
> - or1ksim_clock_handler_install(isr, old_isr); \
> old_isr = NULL; \
> + or1ksim_clock_handler_install(isr, old_isr); \
> } while (0)
> #define Clock_driver_support_shutdown_hardware() or1ksim_clock_cleanup()
> diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> index 7ceca81..31cdce6 100644
> --- a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> +++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
> @@ -21,6 +21,14 @@
> #include <bsp/uart.h>
> #include <rtems/score/isr.h>
> +static void uart_initialize(int minor);
> +static int uart_first_open(int major, int minor, void *arg);
> +static int uart_last_close(int major, int minor, void *arg);
> +static int uart_read_polled(int minor);
> +static ssize_t uart_write(int minor, const char *buf, size_t len);
> +static void uart_write_polled(int minor, char c);
> +static int uart_set_attributes(int minor, const struct termios *t);
> static rtems_vector_number uart_get_irq_number(const console_tbl *ct)
> return ct->ulIntVector;
> @@ -86,10 +94,9 @@ static int uart_last_close(int major, int minor, void
> *arg)
> return 0;
> -static char uart_read_polled(int minor)
> unsigned char lsr;
> - char c;
> /* Get a character when avaiable */
> do {
> @@ -120,7 +127,7 @@ static void uart_write_polled(int minor, char c)
> } while ( (lsr & transmit_finished) != transmit_finished );
> -static ssize_t uart_write_support_polled(
> int minor,
> const char *s,
> size_t n
> @@ -145,7 +152,7 @@ const console_fns or1ksim_uart_fns = {
> .deviceFirstOpen = uart_first_open,
> .deviceLastClose = uart_last_close,
> .deviceRead = uart_read_polled,
> - .deviceWrite = uart_write_support_polled,
> + .deviceWrite = uart_write,
> .deviceInitialize = uart_initialize,
> .deviceWritePolled = uart_write_polled,
> .deviceSetAttributes = uart_set_attributes,
> 1.9.3
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141013/7c8f9bc4/attachment.html>
