[PATCH 03/62] m68k/idp: Fix warnings
Wed Oct 15 19:59:53 UTC 2014
 c/src/lib/libbsp/m68k/idp/console/console.c | 64 +++--------------------------
 c/src/lib/libbsp/m68k/idp/include/bsp.h     |  7 +++-
 c/src/lib/libbsp/m68k/idp/timer/timer.c     |  2 +-
 3 files changed, 12 insertions(+), 61 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/idp/console/console.c b/c/src/lib/libbsp/m68k/idp/console/console.c
index dd41e70..200d52e 100644
--- a/c/src/lib/libbsp/m68k/idp/console/console.c
+++ b/c/src/lib/libbsp/m68k/idp/console/console.c
@@ -1,6 +1,8 @@
  *  This file contains the Motorola IDP console IO package.
  *  Written by Doug McBride, Colorado Space Grant College
  *  Based off of the board support packages of RTEMS
@@ -21,14 +23,7 @@ rtems_isr C_Receive_ISR(rtems_vector_number vector);
 /*  console_initialize
  *  This routine initializes the console IO driver.
- *  Input parameters: NONE
- *  Output parameters:  NONE
- *  Return values:
 rtems_device_driver console_initialize(
   rtems_device_major_number  major,
   rtems_device_minor_number  minor,
@@ -75,15 +70,8 @@ rtems_device_driver console_initialize(
 /*  is_character_ready
  *  This routine returns TRUE if a character is available.
- *  Return values:
-bool is_character_ready(
+static bool is_character_ready(
   char *ch,
   int   port
@@ -95,41 +83,11 @@ bool is_character_ready(
   return true;
-/*  quick_char_check
- *  This routine returns TRUE if a character is available.
- *  It is different from above because it does not disturb the ring buffer
- *  Return values:
-bool quick_char_check(
-  int   port
-  if ( Ring_buffer_Is_empty( &Console_Buffer[ port ] ) )
-    return false;
-  return true;
 /*  inbyte
  *  This routine reads a character from the UART through a buffer.
- *  Return values:
- *    character read from UART
-char inbyte(
+static char inbyte(
   int port
@@ -147,14 +105,8 @@ char inbyte(
  *  This routine transmits a character out the M68681.  It supports
  *  XON/XOFF flow control.
- *    ch  - character to be transmitted
-void outbyte(
+static void outbyte(
   char ch,
   int  port
@@ -173,7 +125,6 @@ void outbyte(
  *  Open entry point
 rtems_device_driver console_open(
@@ -186,7 +137,6 @@ rtems_device_driver console_open(
  *  Close entry point
 rtems_device_driver console_close(
@@ -199,7 +149,6 @@ rtems_device_driver console_close(
  * read bytes from the serial port. We only have stdin.
 rtems_device_driver console_read(
@@ -234,7 +183,6 @@ rtems_device_driver console_read(
  * write bytes to the serial port. Stdout and stderr are the same.
 rtems_device_driver console_write(
diff --git a/c/src/lib/libbsp/m68k/idp/include/bsp.h b/c/src/lib/libbsp/m68k/idp/include/bsp.h
index 39d8c41..e3c6a0d 100644
--- a/c/src/lib/libbsp/m68k/idp/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/idp/include/bsp.h
@@ -44,10 +44,13 @@ rtems_isr_entry set_vector(
   int                 type
-void init_pit( void );
+void rtems_bsp_delay(int num);
+ * Prototypes for methods inside the BSP that cross file boundaries.
+void init_pit( void );
 void transmit_char( char ch );
 void transmit_char_portb( char ch );
 #endif
diff --git a/c/src/lib/libbsp/m68k/idp/timer/timer.c b/c/src/lib/libbsp/m68k/idp/timer/timer.c
index 23ffff7..4de71f2 100644
--- a/c/src/lib/libbsp/m68k/idp/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/idp/timer/timer.c
@@ -19,7 +19,7 @@
 int Ttimer_val;
 bool benchmark_timer_find_average_overhead;
-rtems_isr_entry timerisr(rtems_vector_number);
+rtems_isr timerisr(rtems_vector_number);
 void benchmark_timer_initialize(void)
1.9.3
