[PATCH 17/62] qemuppc/startup/cmain.c: Remove myCpu variables and clean up
Wed Oct 15 20:00:07 UTC 2014
 c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c b/c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c
index 0839db5..5b717e2 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c
+++ b/c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c
@@ -6,11 +6,15 @@ __outb(int port, unsigned char v)
   *((volatile unsigned char *)(0x80000000 + port)) = v;
+#if 0
+/* currently unused but keep just in case */
 static unsigned char
 __inb(int port)
   return *((volatile unsigned char *)(0x80000000 + port));
+#endif
 static void
 __memcpy (unsigned char *d, unsigned char *s, int len)
1.9.3
