[PATCH 18/62] shared/startup/bspstart.c: Remove myCpu variables and clean up
Wed Oct 15 20:00:08 UTC 2014
 c/src/lib/libbsp/powerpc/shared/startup/bspstart.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
index e1c0571..6d7696c 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/bspstart.c
@@ -141,8 +141,6 @@ void bsp_start( void )
 #endif
   uintptr_t intrStackStart;
   uintptr_t intrStackSize;
-/*  ppc_cpu_id_t myCpu; */
-/*  ppc_cpu_revision_t myCpuRevision; */
   prep_t boardManufacturer;
   motorolaBoard myBoard;
   Triv121PgTbl	pt=0;
@@ -152,8 +150,8 @@ void bsp_start( void )
    * function store the result in global variables so that it can be used
    * later...
-  /* myCpu 	= */ get_ppc_cpu_type();
-  /* myCpuRevision = */ get_ppc_cpu_revision();
+  get_ppc_cpu_type();
+  get_ppc_cpu_revision();
    * Init MMU block address translation to enable hardware access
1.9.3
