[PATCH 21/62] tqm8xx/clock/p_clock.c: Remove unused BSP_get_clock_irq_level() method
Wed Oct 15 20:00:11 UTC 2014
 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c | 9 ---------
 1 file changed, 9 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c b/c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c
index 2ea9f45..4ee201a 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c
@@ -28,15 +28,6 @@ static void BSP_clock_hdl(void * arg)
   Clock_isr(arg);
-static int BSP_get_clock_irq_level(void)
-   * Caution : if you change this, you must change the
-   * definition of BSP_PERIODIC_TIMER accordingly
-  return 6;
 int BSP_disconnect_clock_handler (void)
   rtems_status_code sc;
1.9.3
