[PATCH 22/62] i386/shared/comm/uart.c: Remove unused uart_set_driver_handler() method
Wed Oct 15 20:00:12 UTC 2014
 c/src/lib/libbsp/i386/shared/comm/uart.c | 21 ---------------------
 1 file changed, 21 deletions(-)
diff --git a/c/src/lib/libbsp/i386/shared/comm/uart.c b/c/src/lib/libbsp/i386/shared/comm/uart.c
index a211188..58421f4 100644
--- a/c/src/lib/libbsp/i386/shared/comm/uart.c
+++ b/c/src/lib/libbsp/i386/shared/comm/uart.c
@@ -447,27 +447,6 @@ static void ( *driver_input_handler_com1 )( void *,  char *, int ) = 0;
 static void ( *driver_input_handler_com2 )( void *,  char *, int ) = 0;
- * This routine sets the handler to handle the characters received
- * from the serial port.
-static void uart_set_driver_handler(
-  int port,
-  void ( *handler )( void *,  char *, int )
-  switch( port )
-    case BSP_UART_COM1:
-     driver_input_handler_com1 = handler;
-     break;
-    case BSP_UART_COM2:
-     driver_input_handler_com2 = handler;
-     break;
  * Set channel parameters
 void
1.9.3
