[PATCH 23/62] jffs2/src/fs-rtems.c: Eliminate set but not used warnings
Wed Oct 15 20:00:13 UTC 2014
 cpukit/libfs/src/jffs2/src/fs-rtems.c | 3 +++
 1 file changed, 3 insertions(+)
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 00a52bd..ceeb609 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -318,12 +318,14 @@ static void rtems_jffs2_do_lock(const struct super_block *sb)
 	rtems_status_code sc = rtems_semaphore_obtain(sb->s_mutex, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
 	assert(sc == RTEMS_SUCCESSFUL);
+	(void) sc; /* avoid unused variable warning */
 static void rtems_jffs2_do_unlock(const struct super_block *sb)
 	rtems_status_code sc = rtems_semaphore_release(sb->s_mutex);
 static void rtems_jffs2_free_directory_entries(struct _inode *inode)
@@ -366,6 +368,7 @@ static void rtems_jffs2_free_fs_info(rtems_jffs2_fs_info *fs_info, bool do_mount
 	if (sb->s_mutex != 0) {
 		rtems_status_code sc = rtems_semaphore_delete(sb->s_mutex);
 	rtems_jffs2_flash_control_destroy(fs_info->sb.s_flash_control);
1.9.3
