[PATCH 32/62] i386/pc386: Fix warnings
Wed Oct 15 20:00:22 UTC 2014
 c/src/lib/libbsp/i386/pc386/include/bsp.h      | 31 +++++++++++++++++++++++++-
 c/src/lib/libbsp/i386/pc386/startup/bspstart.c |  5 ++---
 2 files changed, 32 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/i386/pc386/include/bsp.h b/c/src/lib/libbsp/i386/pc386/include/bsp.h
index 62cf0f0..cefb726 100644
--- a/c/src/lib/libbsp/i386/pc386/include/bsp.h
+++ b/c/src/lib/libbsp/i386/pc386/include/bsp.h
@@ -47,6 +47,8 @@
 #ifndef _BSP_H
 #define _BSP_H
+#ifndef ASM
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -195,6 +197,18 @@ void Clock_driver_support_initialize_hardware(void); /* from 'ckinit.c'  */
 void kbd_reset_setup(char *str, int *ints);   /* from 'pc_keyb.c' */
 size_t read_aux(char * buffer, size_t count); /* from 'ps2_mouse.c'  */
+bool bsp_get_serial_mouse_device(             /* from 'serial_mouse.c' */
+  const char **name,
+  const char **type
+void register_leds(                           /* from 'keyboard.c' */
+  int console,
+  unsigned int led,
+  unsigned int *addr,
+  unsigned int mask
 /* Definitions for BSPConsolePort */
 #define BSP_CONSOLE_PORT_CONSOLE (-1)
 #define BSP_CONSOLE_PORT_COM1    (BSP_UART_COM1)
@@ -217,15 +231,30 @@ void bsp_ide_cmdline_init(void);
 #define RTEMS_BSP_HAS_IDE_DRIVER
 /* GDB stub stuff */
+void init_remote_gdb( void );
 void i386_stub_glue_init(int uart);
 void i386_stub_glue_init_breakin(void);
-void set_debug_traps(void);
 void breakpoint(void);
 #define BSP_MAXIMUM_DEVICES 6
+ * Debug helper methods
+typedef __FILE FILE;
+uint32_t BSP_irq_count_dump(FILE *f);
+ * Prototypes just called from .S files. This lets the .S file include
+ * bsp.h just to establish the dependency.
+void raw_idt_notify(void);
+void C_dispatch_isr(int vector);
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif /* _BSP_H */
diff --git a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
index ebe6b7c..4c81473 100644
--- a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
+++ b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
@@ -45,7 +45,7 @@ void Clock_driver_install_handler(void);
 |        Arguments: None.
 |          Returns: Nothing.
-void bsp_start_default( void )
+static void bsp_start_default( void )
   int pci_init_retval;
@@ -81,11 +81,10 @@ void bsp_start_default( void )
   bsp_ide_cmdline_init();
-} /* bsp_start */
+} /* bsp_start_default */
  *  By making this a weak alias for bsp_start_default, a brave soul
  *  can override the actual bsp_start routine used.
 void bsp_start (void) __attribute__ ((weak, alias("bsp_start_default")));
1.9.3
