[PATCH 33/62] m68k/gen68340: Fix warnings
Wed Oct 15 20:00:23 UTC 2014
 c/src/lib/libbsp/m68k/gen68340/console/console.c  |  10 +-
 c/src/lib/libbsp/m68k/gen68340/console/m340uart.c | 462 ++++++++++------------
 c/src/lib/libbsp/m68k/gen68340/include/bsp.h      |  17 +
 c/src/lib/libbsp/m68k/gen68340/start/start.S      |   9 +-
 c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c | 272 ++++++-------
 c/src/lib/libbsp/m68k/gen68340/timer/timer.c      | 365 +++++++++--------
 6 files changed, 544 insertions(+), 591 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/gen68340/console/console.c b/c/src/lib/libbsp/m68k/gen68340/console/console.c
index 710d9ec..2cd7fb2 100644
--- a/c/src/lib/libbsp/m68k/gen68340/console/console.c
+++ b/c/src/lib/libbsp/m68k/gen68340/console/console.c
@@ -1,6 +1,8 @@
  *  68340/68349 console serial I/O.
  *  Author:
  *  Geoffroy Montel
  *  France Telecom - CNET/DSM/TAM/CAT
@@ -295,9 +297,8 @@ dbugInitialise (void)
 	if (USE_INTERRUPTS_A) {
 	   rtems_isr_entry old_handler;
-	   rtems_status_code sc;
-	   sc = rtems_interrupt_catch (InterruptHandler,
+	   (void) rtems_interrupt_catch (InterruptHandler,
 	  			       CONSOLE_VECTOR,
 				       &old_handler);
@@ -379,9 +380,8 @@ dbugInitialise (void)
 	if ((USE_INTERRUPTS_B && !(CHANNEL_ENABLED_A))
 	   || (USE_INTERRUPTS_B && CHANNEL_ENABLED_A && !USE_INTERRUPTS_A)) {
 	  			       CONSOLE_VECTOR,
 				       &old_handler);
diff --git a/c/src/lib/libbsp/m68k/gen68340/console/m340uart.c b/c/src/lib/libbsp/m68k/gen68340/console/m340uart.c
index 178649e..8f65ffd 100644
--- a/c/src/lib/libbsp/m68k/gen68340/console/m340uart.c
+++ b/c/src/lib/libbsp/m68k/gen68340/console/m340uart.c
@@ -1,6 +1,8 @@
- *  M68340/349 uart management tools
+ *  M68340/349 UART management tools
  *  Author:
  *  Geoffroy Montel
@@ -32,23 +34,23 @@
    look at Motorola's MC68340 Integrated Processor User's Manual
    page 7-30 for more infos */
-float m340_Baud_Rates_Table[16][2] = {\
-      { 50,    75	},   \
-      { 110,   110	},   \
-      { 134.5, 134.5	},   \
-      { 200,   150	},   \
-      { 300,   300	},   \
-      { 600,   600	},   \
-      { 1200,  1200	},   \
-      { 1050,  2000	},   \
-      { 2400,  2400	},   \
-      { 4800,  4800	},   \
-      { 7200,  1800	},   \
-      { 9600,  9600	},   \
-      { 38400, 19200	},   \
-      { 76800, 38400	},   \
-      { SCLK/16, SCLK/16},   \
-      { SCLK,  SCLK	},   \
+float m340_Baud_Rates_Table[16][2] = {
+      { 50,    75 },
+      { 110,   110 },
+      { 134.5, 134.5 },
+      { 200,   150 },
+      { 300,   300 },
+      { 600,   600 },
+      { 1200,  1200 },
+      { 1050,  2000 },
+      { 2400,  2400 },
+      { 4800,  4800 },
+      { 7200,  1800 },
+      { 9600,  9600 },
+      { 38400, 19200 },
+      { 76800, 38400 },
+      { SCLK/16, SCLK/16},
+      { SCLK,  SCLK },
 /* config on both 340 channels */
@@ -65,110 +67,125 @@ uart_channel_config m340_uart_config[UART_NUMBER_OF_CHANNELS];
   Input parameters: -
   Output parameters: -
   Description: Init the m340_uart_config
-	       THIS SHOULD NOT BE HERE!
-	       Its aim was to let the user configure
-	       UARTs for each application.
-	       As we can't pass args to the console
-	       driver initialisation routine at the
-	       moment, this was not done.
+         THIS SHOULD NOT BE HERE!
+         Its aim was to let the user configure
+         UARTs for each application.
+         As we can't pass args to the console
+         driver initialisation routine at the
+         moment, this was not done.
   ATTENTION: TERMIOS init presupposes that the channel
-	     baud rates is 9600/9600.
-	     -> risks when using IOCTL
+       baud rates is 9600/9600.
+       -> risks when using IOCTL
 void Init_UART_Table(void)
- m340_uart_config[UART_CHANNEL_A].enable = TRUE;
- strcpy(m340_uart_config[UART_CHANNEL_A].name, UART_CONSOLE_NAME);
- m340_uart_config[UART_CHANNEL_A].parity_mode = m340_No_Parity;
- m340_uart_config[UART_CHANNEL_A].bits_per_char = m340_8bpc;
- m340_uart_config[UART_CHANNEL_A].rx_baudrate = 9600;
- m340_uart_config[UART_CHANNEL_A].tx_baudrate = 9600;
- m340_uart_config[UART_CHANNEL_A].rx_mode = UART_CRR;
- m340_uart_config[UART_CHANNEL_A].mode = UART_POLLING;
- m340_uart_config[UART_CHANNEL_A].termios.enable = TRUE;
- m340_uart_config[UART_CHANNEL_A].termios.rx_buffer_size = NOT_IMPLEMENTED_YET;
- m340_uart_config[UART_CHANNEL_A].termios.tx_buffer_size = NOT_IMPLEMENTED_YET;
- m340_uart_config[UART_CHANNEL_B].enable = FALSE;
- strcpy(m340_uart_config[UART_CHANNEL_B].name, UART_RAW_IO_NAME);
- m340_uart_config[UART_CHANNEL_B].parity_mode = m340_No_Parity;
- m340_uart_config[UART_CHANNEL_B].bits_per_char = m340_8bpc;
- m340_uart_config[UART_CHANNEL_B].rx_baudrate = 38400;
- m340_uart_config[UART_CHANNEL_B].tx_baudrate = 38400;
- m340_uart_config[UART_CHANNEL_B].rx_mode = UART_CRR;
- m340_uart_config[UART_CHANNEL_B].mode = UART_INTERRUPTS;
- m340_uart_config[UART_CHANNEL_B].termios.enable = TRUE;
- m340_uart_config[UART_CHANNEL_B].termios.rx_buffer_size = NOT_IMPLEMENTED_YET;
- m340_uart_config[UART_CHANNEL_B].termios.tx_buffer_size = NOT_IMPLEMENTED_YET;
+  m340_uart_config[UART_CHANNEL_A].enable = TRUE;
+  strcpy(m340_uart_config[UART_CHANNEL_A].name, UART_CONSOLE_NAME);
+  m340_uart_config[UART_CHANNEL_A].parity_mode = m340_No_Parity;
+  m340_uart_config[UART_CHANNEL_A].bits_per_char = m340_8bpc;
+  m340_uart_config[UART_CHANNEL_A].rx_baudrate = 9600;
+  m340_uart_config[UART_CHANNEL_A].tx_baudrate = 9600;
+  m340_uart_config[UART_CHANNEL_A].rx_mode = UART_CRR;
+  m340_uart_config[UART_CHANNEL_A].mode = UART_POLLING;
+  m340_uart_config[UART_CHANNEL_A].termios.enable = TRUE;
+  m340_uart_config[UART_CHANNEL_A].termios.rx_buffer_size = NOT_IMPLEMENTED_YET;
+  m340_uart_config[UART_CHANNEL_A].termios.tx_buffer_size = NOT_IMPLEMENTED_YET;
+  m340_uart_config[UART_CHANNEL_B].enable = FALSE;
+  strcpy(m340_uart_config[UART_CHANNEL_B].name, UART_RAW_IO_NAME);
+  m340_uart_config[UART_CHANNEL_B].parity_mode = m340_No_Parity;
+  m340_uart_config[UART_CHANNEL_B].bits_per_char = m340_8bpc;
+  m340_uart_config[UART_CHANNEL_B].rx_baudrate = 38400;
+  m340_uart_config[UART_CHANNEL_B].tx_baudrate = 38400;
+  m340_uart_config[UART_CHANNEL_B].rx_mode = UART_CRR;
+  m340_uart_config[UART_CHANNEL_B].mode = UART_INTERRUPTS;
+  m340_uart_config[UART_CHANNEL_B].termios.enable = TRUE;
+  m340_uart_config[UART_CHANNEL_B].termios.rx_buffer_size = NOT_IMPLEMENTED_YET;
+  m340_uart_config[UART_CHANNEL_B].termios.tx_buffer_size = NOT_IMPLEMENTED_YET;
   Input parameters: Send/Receive baud rates for a
-		    given channel
+        given channel
   Output parameters: UART compatible configs for this
-		    channel
+        channel
   Description: returns which uart configurations fit
-	       Receiver Baud Rate and Transmitter Baud
-	       Rate for a given channel
-	       For instance, according to the
-	       m340_Baud_Rates_Table:
+         Receiver Baud Rate and Transmitter Baud
+         Rate for a given channel
+         For instance, according to the
+         m340_Baud_Rates_Table:
                - Output Speed = 50, Input Speed = 75
-		 is not a correct config, because
-		 50 bauds implies set 1 and 75 bauds
-		 implies set 2
+     is not a correct config, because
+     50 bauds implies set 1 and 75 bauds
+     implies set 2
                - Output Speed = 9600, Input Speed = 9600
-		 two correct configs for this:
-		 RCS=11, TCS=11, Set=1 or 2
+     two correct configs for this:
+     RCS=11, TCS=11, Set=1 or 2
-t_baud_speed_table
-Find_Right_m340_UART_Channel_Config(float ReceiverBaudRate, float TransmitterBaudRate)
+static t_baud_speed_table
+Find_Right_m340_UART_Channel_Config(
+  float ReceiverBaudRate,
+  float TransmitterBaudRate
- t_baud_speed_table return_value;
- struct {
-	 int cs;
-	 int set;
-	} Receiver[2], Transmitter[2];
- int Receiver_nb_of_config = 0;
- int Transmitter_nb_of_config = 0;
- int i,j;
- /* Receiver and Transmitter baud rates must be compatible, ie in the same set */
- /* search for configurations for ReceiverBaudRate - there can't be more than two (only two sets) */
- for (i=0;i<16;i++)
-     for (j=0;j<2;j++)
-	 if (m340_Baud_Rates_Table[i][j]==ReceiverBaudRate) {
-	    Receiver[Receiver_nb_of_config].cs=i;
-	    Receiver[Receiver_nb_of_config].set=j;
-	    Receiver_nb_of_config++;
- /* search for configurations for TransmitterBaudRate - there can't be more than two (only two sets) */
-     for (j=0;j<2;j++)
-	 if (m340_Baud_Rates_Table[i][j]==TransmitterBaudRate) {
-	    Transmitter[Transmitter_nb_of_config].cs=i;
-	    Transmitter[Transmitter_nb_of_config].set=j;
-	    Transmitter_nb_of_config++;
- /* now check if there's a compatible config */
- return_value.nb=0;
- for (i=0; i<Receiver_nb_of_config; i++)
-     for (j=0;j<Transmitter_nb_of_config;j++)
-	 if (Receiver[i].set == Transmitter[j].set) {
-	    return_value.baud_speed_table[return_value.nb].set = Receiver[i].set + 1; /* we want set 1 or set 2, not 0 or 1 */
-	    return_value.baud_speed_table[return_value.nb].rcs = Receiver[i].cs;
-	    return_value.baud_speed_table[return_value.nb].tcs = Transmitter[j].cs;
-	    return_value.nb++;
+  t_baud_speed_table return_value;
+  int i,j;
+  struct {
+    int cs;
+    int set;
+  } Receiver[2], Transmitter[2];
+  int Receiver_nb_of_config = 0;
+  int Transmitter_nb_of_config = 0;
+  /* Receiver and Transmitter baud rates must be compatible, ie in the
+   * same set.
+  /* search for configurations for ReceiverBaudRate
+   * there can't be more than two (only two sets).
+  for (i=0;i<16;i++) {
+    for (j=0;j<2;j++) {
+      if (m340_Baud_Rates_Table[i][j]==ReceiverBaudRate) {
+        Receiver[Receiver_nb_of_config].cs=i;
+        Receiver[Receiver_nb_of_config].set=j;
+        Receiver_nb_of_config++;
+  /* search for configurations for TransmitterBaudRate
+      if (m340_Baud_Rates_Table[i][j]==TransmitterBaudRate) {
+        Transmitter[Transmitter_nb_of_config].cs=i;
+        Transmitter[Transmitter_nb_of_config].set=j;
+        Transmitter_nb_of_config++;
+  /* now check if there's a compatible config */
+  return_value.nb=0;
+ for (i=0; i<Receiver_nb_of_config; i++) {
+   for (j=0;j<Transmitter_nb_of_config;j++) {
+     if (Receiver[i].set == Transmitter[j].set) {
+       return_value.baud_speed_table[return_value.nb].set = Receiver[i].set + 1;
+       /* we want set 1 or set 2, not 0 or 1 */
+       return_value.baud_speed_table[return_value.nb].rcs = Receiver[i].cs;
+       return_value.baud_speed_table[return_value.nb].tcs = Transmitter[j].cs;
+       return_value.nb++;
  return return_value;
@@ -176,71 +193,87 @@ Find_Right_m340_UART_Channel_Config(float ReceiverBaudRate, float TransmitterBau
   Input parameters: Send/Receive baud rates for both
-		    channels
+        channels
-		     BOTH channels
+         BOTH channels
-	       Rate for both channels
-	       For instance, if we want 9600/38400 on
-	       channel A and 9600/19200 on channel B,
-	       this is not a good m340 uart config
-	       (channel A needs set 1 and channel B
-	       needs set 2)
+         Rate for both channels
+         For instance, if we want 9600/38400 on
+         channel A and 9600/19200 on channel B,
+         this is not a good m340 uart config
+         (channel A needs set 1 and channel B
+         needs set 2)
 t_baud_speed_table
-Find_Right_m340_UART_Config(float ChannelA_ReceiverBaudRate, float ChannelA_TransmitterBaudRate, uint8_t         enableA,
-			    float ChannelB_ReceiverBaudRate, float ChannelB_TransmitterBaudRate, uint8_t         enableB)
+Find_Right_m340_UART_Config(
+  float ChannelA_ReceiverBaudRate,
+  float ChannelA_TransmitterBaudRate,
+  uint8_t         enableA,
+  float ChannelB_ReceiverBaudRate,
+  float ChannelB_TransmitterBaudRate,
+  uint8_t         enableB
- t_baud_speed_table tableA, tableB;
- t_baud_speed_table return_value, tmp;
- int i,j;
- memset( &return_value, '\0', sizeof(return_value) );
- if (enableA && enableB) {
-  tableA = Find_Right_m340_UART_Channel_Config(ChannelA_ReceiverBaudRate, ChannelA_TransmitterBaudRate);
-  tableB = Find_Right_m340_UART_Channel_Config(ChannelB_ReceiverBaudRate, ChannelB_TransmitterBaudRate);
-  for (i=0;i<tableA.nb;i++)
-      for (j=0;j<tableB.nb;j++)
-          if (tableA.baud_speed_table[i].set==tableB.baud_speed_table[j].set) {
-	     return_value.baud_speed_table[UART_CHANNEL_A].set=tableA.baud_speed_table[i].set;
-	     return_value.baud_speed_table[UART_CHANNEL_A].rcs=tableA.baud_speed_table[i].rcs;
-	     return_value.baud_speed_table[UART_CHANNEL_A].tcs=tableA.baud_speed_table[i].tcs;
-	     return_value.baud_speed_table[UART_CHANNEL_B].set=tableB.baud_speed_table[j].set;
-	     return_value.baud_speed_table[UART_CHANNEL_B].rcs=tableB.baud_speed_table[j].rcs;
-	     return_value.baud_speed_table[UART_CHANNEL_B].tcs=tableB.baud_speed_table[j].tcs;
-	     return_value.nb=2;
-	     break;
-   return return_value;
+  t_baud_speed_table tableA, tableB;
+  t_baud_speed_table return_value, tmp;
+  int i,j;
+  memset( &return_value, '\0', sizeof(return_value) );
+  if (enableA && enableB) {
+    tableA = Find_Right_m340_UART_Channel_Config(
+               ChannelA_ReceiverBaudRate, ChannelA_TransmitterBaudRate);
+    tableB = Find_Right_m340_UART_Channel_Config(
+               ChannelB_ReceiverBaudRate, ChannelB_TransmitterBaudRate);
+    for (i=0;i<tableA.nb;i++) {
+      for (j=0;j<tableB.nb;j++) {
+        if (tableA.baud_speed_table[i].set==tableB.baud_speed_table[j].set) {
+          return_value.baud_speed_table[UART_CHANNEL_A].set =
+            tableA.baud_speed_table[i].set;
+          return_value.baud_speed_table[UART_CHANNEL_A].rcs =
+            tableA.baud_speed_table[i].rcs;
+          return_value.baud_speed_table[UART_CHANNEL_A].tcs =
+            tableA.baud_speed_table[i].tcs;
+          return_value.baud_speed_table[UART_CHANNEL_B].set =
+            tableB.baud_speed_table[j].set;
+          return_value.baud_speed_table[UART_CHANNEL_B].rcs =
+            tableB.baud_speed_table[j].rcs;
+          return_value.baud_speed_table[UART_CHANNEL_B].tcs =
+            tableB.baud_speed_table[j].tcs;
+          return_value.nb=2;
+          break;
+    return return_value;
- if (enableA) {
-    return_value = Find_Right_m340_UART_Channel_Config(ChannelA_ReceiverBaudRate, ChannelA_TransmitterBaudRate);
+  if (enableA) {
+    return_value = Find_Right_m340_UART_Channel_Config(
- if (enableB) {
-    tmp = Find_Right_m340_UART_Channel_Config(ChannelB_ReceiverBaudRate, ChannelB_TransmitterBaudRate);
+  if (enableB) {
+    tmp = Find_Right_m340_UART_Channel_Config(
     if (tmp.nb!=0) {
-       return_value.nb = 2;
-       return_value.baud_speed_table[1].set = tmp.baud_speed_table[0].set;
-       return_value.baud_speed_table[1].rcs = tmp.baud_speed_table[0].rcs;
-       return_value.baud_speed_table[1].tcs = tmp.baud_speed_table[0].tcs;
+      return_value.nb = 2;
+      return_value.baud_speed_table[1].set = tmp.baud_speed_table[0].set;
+      return_value.baud_speed_table[1].rcs = tmp.baud_speed_table[0].rcs;
+      return_value.baud_speed_table[1].tcs = tmp.baud_speed_table[0].tcs;
  * very low level fmted output
 extern void dbug_out_char( int minor, int ch );
 extern int dbug_in_char( int minor );
 extern int dbug_char_present( int minor );
@@ -253,9 +286,9 @@ extern int dbug_char_present( int minor );
 int dbugRead (int minor)
-	if (dbug_char_present(minor) == 0)
-		return -1;
-	return dbug_in_char(minor);
+  if (dbug_char_present(minor) == 0)
+    return -1;
+  return dbug_in_char(minor);
@@ -266,106 +299,13 @@ int dbugRead (int minor)
 ssize_t dbugWrite (int minor, const char *buf, size_t len)
-	static char txBuf;
-	size_t retval = len;
-	while (len--) {
- 		txBuf = *buf++;
-        	dbug_out_char( minor, (int)txBuf );
-	return retval;
-static void fmt_num( int minor, unsigned long, unsigned );
-static void fmt_str( int minor, const char* );
-  Name: RAW_GETC
-  Input parameters: channel, buffer and its length
-  Output parameters:
-  Description: a light blocking "getc"
-char RAW_GETC(int minor)
- while (!dbug_char_present(minor)) continue;
-  Name: RAW_FMT
-  Output parameters: always successfull
-  Description: a light polled "printf"
-	       useful when there's a serious pb and
-	       there are no more interrupts
-void RAW_FMT( int minor, const char* fmt, ... )
-   int ch;
-   va_list va;
-   va_start( va, fmt );
-   while( (ch = *fmt++) )
-      if( ch != '%' || (ch = *fmt++) == '%' )
-	 if( ch == '\n' )
-	    dbug_out_char( minor, '\r' );
-	 dbug_out_char( minor, ch );
-      else switch( ch )
-	 case 'c':
-	 dbug_out_char( minor, va_arg( va, int ) );
-	 continue;
-	 case 's':
-	 fmt_str( minor, va_arg( va, char* ) );
-	 continue;
-	 case 'd':
-	 ch = va_arg( va, int );
-	 if( ch >= 0 )
-	    fmt_num( minor, ch, 10 );
-	 else
-	    dbug_out_char( minor, '-' );
-	    fmt_num( minor, -ch, 10 );
-	 continue;
-	 case 'u':
-	 fmt_num( minor, va_arg( va, unsigned ), 10 );
-	 continue;
-	 case 'o':
-	 fmt_num( minor, va_arg( va, unsigned ), 8 );
-	 continue;
-	 case 'x':
-	 case 'p':
-	 fmt_num( minor, va_arg( va, unsigned ), 16 );
-	 continue;
-	 default: continue;
-	 return;
-   va_end( va );
+  static char txBuf;
+  size_t retval = len;
+  while (len--) {
+     txBuf = *buf++;
+          dbug_out_char( minor, (int)txBuf );
+  return retval;
-static void fmt_num( int minor, unsigned long num, unsigned base )
-   char buf[33];
-   int  ib = sizeof(buf);
-   buf[--ib] = 0;
-   do
-      buf[--ib] = "0123456789ABCDEF"[num%base];
-      num /= base;
-   while( num != 0 );
-   fmt_str( minor, buf+ib );
-static void fmt_str( int minor, const char* str )
-   if( str )
-      while( *str )
-	 dbug_out_char( minor, *str++ );
diff --git a/c/src/lib/libbsp/m68k/gen68340/include/bsp.h b/c/src/lib/libbsp/m68k/gen68340/include/bsp.h
index f4598b3..e89f445 100644
--- a/c/src/lib/libbsp/m68k/gen68340/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/gen68340/include/bsp.h
@@ -26,6 +26,8 @@
 #ifndef _BSP_H
 #define _BSP_H
+#ifndef ASM
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -60,8 +62,23 @@ rtems_isr_entry set_vector(
   int                 type
+ *  Methods used across files inside the BSP
+int dbug_in_char( int minor );
+void dbug_out_char( int minor, int ch );
+int dbug_char_present( int minor );
+void _dbug_dumpanic(void);
+ *  Only called from .S but prototyped here to capture the dependecy.
+void _Init68340 (void);
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif
diff --git a/c/src/lib/libbsp/m68k/gen68340/start/start.S b/c/src/lib/libbsp/m68k/gen68340/start/start.S
index 8be497f9..794c6d7 100644
--- a/c/src/lib/libbsp/m68k/gen68340/start/start.S
+++ b/c/src/lib/libbsp/m68k/gen68340/start/start.S
@@ -3,7 +3,9 @@
  *  The name of this entry point is compiler dependent.
  *  It jumps to the BSP which is responsible for performing
  *  all initialization.
  *  COPYRIGHT (c) 1989-1999.
  *  On-Line Applications Research Corporation (OAR).
@@ -26,7 +28,10 @@
 #include <rtems/asm.h>
 #include <m68349.inc>
-#define	_OLD_ASTECC 1 /* old addresses for AST68340 only, undefine for AST68349 */
+#include <bsp.h> /* to indicate dependencies */
+/* old addresses for AST68340 only, undefine for AST68349 */
+#define	_OLD_ASTECC 1
 BEGIN_CODE
diff --git a/c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c b/c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c
index 171838f..1341edb 100644
--- a/c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c
+++ b/c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c
@@ -1,6 +1,8 @@
  *  M68340/349 registers and stack dump if an exception is raised
  *  Author:
  *  Pascal Cadic
@@ -16,106 +18,108 @@
  *  http://www.rtems.org/license/LICENSE.
-#include <stdio.h>
+#include <bsp.h>
+#include <rtems/bspIo.h>
-const char *exceptionName[] =
-	"INITIAL STACK POINTER",
-	"INITIAL PROGRAM COUNTER",
-	"BUS ERROR",
-	"ADDRESS ERROR",
-	"ILLEGAL INSTRUCTION",
-	"DIVISION BY ZERO",
-	"CHK, CHK2",
-	"TRAPcc, TRAPv",
-	"PRIVILEGE VIOLATION",
-	"TRACE",
-	"LINE A EMULATOR",
-	"LINE F EMULATOR",
-	"HARDWARE BREAK",
-	"COPROCESSOR PROTOCOL VIOLATION",
-	"FORMAT ERROR",
-	"UNINITIALIZED INTERRUPT",
-	"RESERVED 16",
-	"RESERVED 17",
-	"RESERVED 18",
-	"RESERVED 19",
-	"RESERVED 20",
-	"RESERVED 21",
-	"RESERVED 22",
-	"RESERVED 23",
-	"SPURIOUS INTERRUPT",
-	"LEVEL 1 AUTOVECTOR",
-	"LEVEL 2 AUTOVECTOR",
-	"LEVEL 3 AUTOVECTOR",
-	"LEVEL 4 AUTOVECTOR",
-	"LEVEL 5 AUTOVECTOR",
-	"LEVEL 6 AUTOVECTOR",
-	"LEVEL 7 AUTOVECTOR",
-	"TRAP 1",
-	"TRAP 2",
-	"TRAP 3",
-	"TRAP 4",
-	"TRAP 5",
-	"TRAP 6",
-	"TRAP 7",
-	"TRAP 8",
-	"TRAP 9",
-	"TRAP 10",
-	"TRAP 11",
-	"TRAP 12",
-	"TRAP 13",
-	"TRAP 14",
-	"TRAP 15",
-	"VECTOR 48",
-	"VECTOR 49",
-	"VECTOR 50",
-	"VECTOR 51",
-	"VECTOR 52",
-	"VECTOR 53",
-	"VECTOR 54",
-	"VECTOR 55",
-	"VECTOR 56",
-	"VECTOR 57",
-	"VECTOR 58",
-	"VECTOR 59",
-	"VECTOR 60",
-	"VECTOR 61",
-	"VECTOR 62",
-	"VECTOR 63",
+const char *exceptionName[] = {
+  "INITIAL STACK POINTER",
+  "INITIAL PROGRAM COUNTER",
+  "BUS ERROR",
+  "ADDRESS ERROR",
+  "ILLEGAL INSTRUCTION",
+  "DIVISION BY ZERO",
+  "CHK, CHK2",
+  "TRAPcc, TRAPv",
+  "PRIVILEGE VIOLATION",
+  "TRACE",
+  "LINE A EMULATOR",
+  "LINE F EMULATOR",
+  "HARDWARE BREAK",
+  "COPROCESSOR PROTOCOL VIOLATION",
+  "FORMAT ERROR",
+  "UNINITIALIZED INTERRUPT",
+  "RESERVED 16",
+  "RESERVED 17",
+  "RESERVED 18",
+  "RESERVED 19",
+  "RESERVED 20",
+  "RESERVED 21",
+  "RESERVED 22",
+  "RESERVED 23",
+  "SPURIOUS INTERRUPT",
+  "LEVEL 1 AUTOVECTOR",
+  "LEVEL 2 AUTOVECTOR",
+  "LEVEL 3 AUTOVECTOR",
+  "LEVEL 4 AUTOVECTOR",
+  "LEVEL 5 AUTOVECTOR",
+  "LEVEL 6 AUTOVECTOR",
+  "LEVEL 7 AUTOVECTOR",
+  "TRAP 1",
+  "TRAP 2",
+  "TRAP 3",
+  "TRAP 4",
+  "TRAP 5",
+  "TRAP 6",
+  "TRAP 7",
+  "TRAP 8",
+  "TRAP 9",
+  "TRAP 10",
+  "TRAP 11",
+  "TRAP 12",
+  "TRAP 13",
+  "TRAP 14",
+  "TRAP 15",
+  "VECTOR 48",
+  "VECTOR 49",
+  "VECTOR 50",
+  "VECTOR 51",
+  "VECTOR 52",
+  "VECTOR 53",
+  "VECTOR 54",
+  "VECTOR 55",
+  "VECTOR 56",
+  "VECTOR 57",
+  "VECTOR 58",
+  "VECTOR 59",
+  "VECTOR 60",
+  "VECTOR 61",
+  "VECTOR 62",
+  "VECTOR 63",
 typedef struct {
-    unsigned long	pc;
-    unsigned short	sr;
-    unsigned short	format_id;
-    unsigned long	d0, d1, d2, d3, d4, d5, d6, d7;
-    unsigned long	a0, a1, a2, a3, a4, a5, a6, a7;
-    unsigned long	sfc, dfc, vbr;
+    unsigned long  pc;
+    unsigned short  sr;
+    unsigned short  format_id;
+    unsigned long  d0, d1, d2, d3, d4, d5, d6, d7;
+    unsigned long  a0, a1, a2, a3, a4, a5, a6, a7;
+    unsigned long  sfc, dfc, vbr;
 } boot_panic_registers_t;
 boot_panic_registers_t _boot_panic_registers;
-extern void RAW_FMT( int minor, const char* fmt, ... );
-extern char RAW_GETC(int minor);
   Input parameters: sr, pc, stack pointer,
-		    size to display
+        size to display
   Description: display the supervisor stack
-void _dbug_dump(unsigned short sr, void* pc, unsigned short *stack, int size)
+static void _dbug_dump(
+  unsigned short sr,
+  void* pc,
+  unsigned short *stack,
+  int size
-int i;
+  int i;
-	RAW_FMT(0,"%x : %x \t%x",0,sr,(unsigned short)(((unsigned)pc)>>16));
-	for (i=2; i<size; i++) {
-		if ((i%8)==0) RAW_FMT(0,"\n%x :",i/8);
-		RAW_FMT(0," %x\t",stack[i-2]);
-	RAW_FMT(0,"\n");
+  printk(0,"%x : %x \t%x",0,sr,(unsigned short)(((unsigned)pc)>>16));
+  for (i=2; i<size; i++) {
+    if ((i%8)==0) printk(0,"\n%x :",i/8);
+    printk(0," %x\t",stack[i-2]);
+  printk(0,"\n");
@@ -123,8 +127,8 @@ int i;
   Input parameters: -
   Description: display microcontroler state. Registers
-	       values are stored in _boot_panic_registers
-	       which is filled in _uhoh ASM routine
+         values are stored in _boot_panic_registers
+         which is filled in _uhoh ASM routine
@@ -134,53 +138,53 @@ void _dbug_dumpanic(void)
  unsigned char frametype, *stack;
  #define ESCAPE 27
-	stack = (unsigned char*)(_boot_panic_registers.a7);
-	do {
-		status = _boot_panic_registers.sr;
-		pc = (void*)_boot_panic_registers.pc;
-		faultedAddr = *(void**)(stack+4);
-		vector = (_boot_panic_registers.format_id&0x0FFF)>>2;
-		frametype = (_boot_panic_registers.format_id&0xF000)>>12;
+  stack = (unsigned char*)(_boot_panic_registers.a7);
+  do {
+    status = _boot_panic_registers.sr;
+    pc = (void*)_boot_panic_registers.pc;
+    faultedAddr = *(void**)(stack+4);
+    vector = (_boot_panic_registers.format_id&0x0FFF)>>2;
+    frametype = (_boot_panic_registers.format_id&0xF000)>>12;
-		RAW_FMT(0,"\n---------------------------------------------\n");
-		if (vector<64)
-			RAW_FMT(0,"%s",exceptionName[vector]);
-		else {
-			RAW_FMT(0,"RESERVED USER");
-		RAW_FMT(0," exception (vector %x, type %x)\n",vector,frametype);
-		RAW_FMT(0,"---------------------------------------------\n");
-		RAW_FMT(0,"PC : 0x%x  ",pc);
-		RAW_FMT(0,"A7 : 0x%x  ",_boot_panic_registers.a7);
-		RAW_FMT(0,"SR : 0x%x\n",status);
-		if (frametype==0x0c) {
-			RAW_FMT(0,"\nfaulted address = 0x%x\n",faultedAddr);
-		RAW_FMT(0,"               panic regs\n");
-		RAW_FMT(0,"D[0..3] : %x \t%x \t%x \t%x\n",
-				_boot_panic_registers.d0,_boot_panic_registers.d1,
-				_boot_panic_registers.d2,_boot_panic_registers.d3);
-		RAW_FMT(0,"D[4..7] : %x \t%x \t%x \t%x\n",
-				_boot_panic_registers.d4,_boot_panic_registers.d5,
-				_boot_panic_registers.d6,_boot_panic_registers.d7);
-		RAW_FMT(0,"A[0..3] : %x \t%x \t%x \t%x\n",
-				_boot_panic_registers.a0,_boot_panic_registers.a1,
-				_boot_panic_registers.a2,_boot_panic_registers.a3);
-		RAW_FMT(0,"A[4..7] : %x \t%x \t%x \t%x\n",
-				_boot_panic_registers.a4,_boot_panic_registers.a5,
-				_boot_panic_registers.a6,_boot_panic_registers.a7);
+    printk(0,"\n---------------------------------------------\n");
+    if (vector<64)
+      printk(0,"%s",exceptionName[vector]);
+    else {
+      printk(0,"RESERVED USER");
+    printk(0," exception (vector %x, type %x)\n",vector,frametype);
+    printk(0,"---------------------------------------------\n");
+    printk(0,"PC : 0x%x  ",pc);
+    printk(0,"A7 : 0x%x  ",_boot_panic_registers.a7);
+    printk(0,"SR : 0x%x\n",status);
+    if (frametype==0x0c) {
+      printk(0,"\nfaulted address = 0x%x\n",faultedAddr);
+    printk(0,"               panic regs\n");
+    printk(0,"D[0..3] : %x \t%x \t%x \t%x\n",
+        _boot_panic_registers.d0,_boot_panic_registers.d1,
+        _boot_panic_registers.d2,_boot_panic_registers.d3);
+    printk(0,"D[4..7] : %x \t%x \t%x \t%x\n",
+        _boot_panic_registers.d4,_boot_panic_registers.d5,
+        _boot_panic_registers.d6,_boot_panic_registers.d7);
+    printk(0,"A[0..3] : %x \t%x \t%x \t%x\n",
+        _boot_panic_registers.a0,_boot_panic_registers.a1,
+        _boot_panic_registers.a2,_boot_panic_registers.a3);
+    printk(0,"A[4..7] : %x \t%x \t%x \t%x\n",
+        _boot_panic_registers.a4,_boot_panic_registers.a5,
+        _boot_panic_registers.a6,_boot_panic_registers.a7);
-		RAW_FMT(0,"    SFC : %x",_boot_panic_registers.sfc);
-		RAW_FMT(0,"    DFC : %x\n",_boot_panic_registers.dfc);
-		RAW_FMT(0,"    VBR : %x\n",_boot_panic_registers.vbr);
-		RAW_FMT(0,"               panic stack\n");
-		_dbug_dump(status, pc, (unsigned short*)stack,64*2);
+    printk(0,"    SFC : %x",_boot_panic_registers.sfc);
+    printk(0,"    DFC : %x\n",_boot_panic_registers.dfc);
+    printk(0,"    VBR : %x\n",_boot_panic_registers.vbr);
+    printk(0,"               panic stack\n");
+    _dbug_dump(status, pc, (unsigned short*)stack,64*2);
-		RAW_FMT(0,"press escape to reboot\n");
-	} while ((c=RAW_GETC(0))!=ESCAPE);	/* cgets ne marche pas si les IT sont bloquées */
+    printk(0,"press escape to reboot\n");
+  } while ((c=getchark())!=ESCAPE);
diff --git a/c/src/lib/libbsp/m68k/gen68340/timer/timer.c b/c/src/lib/libbsp/m68k/gen68340/timer/timer.c
index 52dfc42..cfb58eb 100644
--- a/c/src/lib/libbsp/m68k/gen68340/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/gen68340/timer/timer.c
@@ -1,11 +1,16 @@
- * ATTENTION: AS MC68349 has no built-in Timer, the following code doesn't work
- * 	      in a MC68349. You can't use FIFO full mode for the moment, but
- *	      it should be easy to fix this by using an external timer
+ * ATTENTION: As MC68349 has no built-in Timer, the following code doesn't work
+ *            in a MC68349. You can't use FIFO full mode for the moment, but
+ *            it should be easy to fix this by using an external timer.
  * Use TIMER 1 for TIMEOUT when using FIFO FULL mode in UART driver
  * Use TIMER 2 for timing test suites
+ *  NOTE: It is important that the timer start/stop overhead be
+ *        determined when porting or modifying this code.
  * Geoffroy Montel
  * 4, rue du Clos Courtel
@@ -13,16 +18,6 @@
  * FRANCE
  * e-mail: g_montel at yahoo.com
- *  Input parameters:  NONE
- *  Output parameters:  NONE
- *  NOTE: It is important that the timer start/stop overhead be
- *        determined when porting or modifying this code.
@@ -47,7 +42,7 @@
 #define TIMER2_IRQ_LEVEL 4
 #define TIMER2_INTERRUPT_ARBITRATION 4
-#define CLOCK_SPEED 25		/* in Mhz */
+#define CLOCK_SPEED 25    /* in Mhz */
 #define max(a,b) (((a)>(b)) ? (a) : (b))
@@ -58,34 +53,28 @@ void (*Restart_Check_B_Timer)(void);
 int preload = 0;
-  Name: __Restart_Fifo_Full_Timer
-  Input parameters: -
-  Output parameters: -
-  Description: when a character is received, sets
-               the TIMER to raise an interrupt at
-	       TIMEOUT.
-	       It's necessary to prevent from not
-	       getting n-1 characters (with n the
-               Uart Fifo size)
-void __Restart_Fifo_Full_Timer (void)
+ * __Restart_Fifo_Full_Timer
+ * When a character is received, sets the TIMER to raise an interrupt at
+ * TIMEOUT.  It's necessary to prevent from not getting n-1 characters
+ * (with n the Uart Fifo size).
+static void __Restart_Fifo_Full_Timer (void)
- TSR1 |= m340_TO;
- TCR1 &= ~m340_CPE;
- WPREL11 = preload;
- TCR1 |= m340_CPE;
+  TSR1 |= m340_TO;
+  TCR1 &= ~m340_CPE;
+  WPREL11 = preload;
+  TCR1 |= m340_CPE;
-  Description: when no character has been received
-               recently, check now and then if whether
-	       a there's a character in the FIFO
-void __Restart_Check_Timer (void)
+ * __Restart_Check_Timer
+ * When no character has been received recently, check now and then if whether
+ * a there's a character in the FIFO
+static void __Restart_Check_Timer (void)
  TSR1 |= m340_TO;
  TCR1 &= ~m340_CPE;
@@ -93,177 +82,175 @@ void __Restart_Check_Timer (void)
  TCR1 |= m340_CPE;
-  Name: __do_nothing
-  Description: we always restart the fifo full timer
-	       with a call to Restart_*_Timer
-	       if we do not use FIFO full, Restart_*_Timer
-	       are set to do __do_nothing
-void __do_nothing (void)
+ * __do_nothing
+ * We always restart the fifo full timer with a call to Restart_*_Timer
+ * if we do not use FIFO full, Restart_X_Timer are set to do __do_nothing
+static void __do_nothing (void)
-#define Fifo_Full_on_A (m340_uart_config[UART_CHANNEL_A].rx_mode==UART_FIFO_FULL && m340_uart_config[UART_CHANNEL_A].enable && m340_uart_config[UART_CHANNEL_A].mode==UART_INTERRUPTS)
-#define Fifo_Full_on_B (m340_uart_config[UART_CHANNEL_B].rx_mode==UART_FIFO_FULL && m340_uart_config[UART_CHANNEL_B].enable && m340_uart_config[UART_CHANNEL_B].mode==UART_INTERRUPTS)
+#define Fifo_Full_on_A \
+   (m340_uart_config[UART_CHANNEL_A].rx_mode==UART_FIFO_FULL && \
+    m340_uart_config[UART_CHANNEL_A].enable && \
+    m340_uart_config[UART_CHANNEL_A].mode==UART_INTERRUPTS)
+#define Fifo_Full_on_B \
+    (m340_uart_config[UART_CHANNEL_B].rx_mode==UART_FIFO_FULL && \
+    m340_uart_config[UART_CHANNEL_B].enable && \
+    m340_uart_config[UART_CHANNEL_B].mode==UART_INTERRUPTS)
-  Name: Fifo_Full_benchmark_timer_initialize
-  Description: initialize Timer 1 for FIFO full mode
+ * Fifo_Full_benchmark_timer_initialize
+ * initialize Timer 1 for FIFO full mode
 void Fifo_Full_benchmark_timer_initialize (void)
-   float max_baud_rate;
-   int prescaler_output_tap = -1;
-   int nb_of_clock_ticks = 0;
-    *  USE TIMER 1 for UART FIFO FULL mode
-   if ( Fifo_Full_on_A || Fifo_Full_on_B )
-	/* Disable the timer */
-	TCR1 &= ~m340_SWR;
-	/* Reset the interrupts */
-	TSR1 &= ~(m340_TO | m340_TG | m340_TC);
-	/* Init the stop bit for normal operation, ignore FREEZE, user privileges,
-	   set interrupt arbitration */
-	TMCR1 = TIMER1_INTERRUPT_ARBITRATION;
-	/* interrupt priority level and interrupt vector */
-	TIR1 = TIMER1_VECTOR | (TIMER1_IRQ_LEVEL << 8);
-	/* compute prescaler */
-   	if ( Fifo_Full_on_A && Fifo_Full_on_B)
-		max_baud_rate = max(m340_uart_config[UART_CHANNEL_A].rx_baudrate, m340_uart_config[UART_CHANNEL_B].rx_baudrate);
-	else if ( Fifo_Full_on_A )
-		max_baud_rate = m340_uart_config[UART_CHANNEL_A].rx_baudrate;
-	     else max_baud_rate = m340_uart_config[UART_CHANNEL_B].rx_baudrate;
-	/* find out config */
-	nb_of_clock_ticks = (10/max_baud_rate)*(CLOCK_SPEED*1000000)*1.2;
-	if (nb_of_clock_ticks < 0xFFFF) {
-	   preload = nb_of_clock_ticks;
-	   prescaler_output_tap = -1;
-	} else if (nb_of_clock_ticks/2 < 0xFFFF) {
-	   preload = nb_of_clock_ticks/2;
-	   prescaler_output_tap = m340_Divide_by_2;
-	} else if (nb_of_clock_ticks/4 < 0xFFFF) {
-	   preload = nb_of_clock_ticks/4;
-	   prescaler_output_tap = m340_Divide_by_4;
-	} else if (nb_of_clock_ticks/8 < 0xFFFF) {
-	   preload = nb_of_clock_ticks/8;
-	   prescaler_output_tap = m340_Divide_by_16;
-	} else if (nb_of_clock_ticks/16 < 0xFFFF) {
-	   preload = nb_of_clock_ticks/16;
-	} else if (nb_of_clock_ticks/32 < 0xFFFF) {
-	   preload = nb_of_clock_ticks/32;
-	   prescaler_output_tap = m340_Divide_by_32;
-	} else if (nb_of_clock_ticks/64 < 0xFFFF) {
-	   preload = nb_of_clock_ticks/64;
-	   prescaler_output_tap = m340_Divide_by_64;
-	} else if (nb_of_clock_ticks/128 < 0xFFFF) {
-	   preload = nb_of_clock_ticks/128;
-	   prescaler_output_tap = m340_Divide_by_128;
-	} else if (nb_of_clock_ticks/256 < 0xFFFF) {
-	   preload = nb_of_clock_ticks/256;
-	   prescaler_output_tap = m340_Divide_by_256;
-	/* Input Capture/Output Compare (ICOC) */
-	TCR1 = m340_SWR | m340_TO_Enabled | m340_ICOC;
-	if (prescaler_output_tap!=-1) TCR1 |= prescaler_output_tap | m340_PSE;
-	/* install interrupt vector */
-         rtems_isr_entry old_handler;
-	  			     TIMER1_VECTOR,
-				     &old_handler);
-	 /* uncomment this if you want to pass control to your own ISR handler
-	    it may be usefull to do so to check for performances with an oscilloscope */
-	  proc_ptr ignored;
-	  _CPU_ISR_install_raw_handler( TIMER1_VECTOR, _Debug_ISR_Handler_Console, &ignored );
-       } /* fifo full mode on a uart */
-       /* install routines */
-       Restart_Check_A_Timer = Fifo_Full_on_A ? __Restart_Check_Timer : __do_nothing;
-       Restart_Fifo_Full_A_Timer = Fifo_Full_on_A ? __Restart_Fifo_Full_Timer : __do_nothing;
-       Restart_Check_B_Timer = Fifo_Full_on_B ? __Restart_Check_Timer : __do_nothing;
-       Restart_Fifo_Full_B_Timer = Fifo_Full_on_B ? __Restart_Fifo_Full_Timer : __do_nothing;
-       /* start checking timer */
-       Restart_Check_A_Timer();
-       Restart_Check_B_Timer();
+  float max_baud_rate;
+  int prescaler_output_tap = -1;
+  int nb_of_clock_ticks = 0;
+  rtems_isr_entry old_handler;
+   *  USE TIMER 1 for UART FIFO FULL mode
+  if ( Fifo_Full_on_A || Fifo_Full_on_B ) {
+    /* Disable the timer */
+    TCR1 &= ~m340_SWR;
+    /* Reset the interrupts */
+    TSR1 &= ~(m340_TO | m340_TG | m340_TC);
+    /* Init the stop bit for normal operation, ignore FREEZE, user privileges,
+     * set interrupt arbitration.
+    TMCR1 = TIMER1_INTERRUPT_ARBITRATION;
+    /* interrupt priority level and interrupt vector */
+    TIR1 = TIMER1_VECTOR | (TIMER1_IRQ_LEVEL << 8);
+    /* compute prescaler */
+    if ( Fifo_Full_on_A && Fifo_Full_on_B) {
+      max_baud_rate = max(
+        m340_uart_config[UART_CHANNEL_A].rx_baudrate,
+    } else if ( Fifo_Full_on_A ) {
+      max_baud_rate = m340_uart_config[UART_CHANNEL_A].rx_baudrate;
+    } else
+      max_baud_rate = m340_uart_config[UART_CHANNEL_B].rx_baudrate;
+    /* find out config */
+    nb_of_clock_ticks = (10/max_baud_rate)*(CLOCK_SPEED*1000000)*1.2;
+    if (nb_of_clock_ticks < 0xFFFF) {
+      preload = nb_of_clock_ticks;
+      prescaler_output_tap = -1;
+    } else if (nb_of_clock_ticks/2 < 0xFFFF) {
+      preload = nb_of_clock_ticks/2;
+      prescaler_output_tap = m340_Divide_by_2;
+    } else if (nb_of_clock_ticks/4 < 0xFFFF) {
+      preload = nb_of_clock_ticks/4;
+      prescaler_output_tap = m340_Divide_by_4;
+    } else if (nb_of_clock_ticks/8 < 0xFFFF) {
+      preload = nb_of_clock_ticks/8;
+      prescaler_output_tap = m340_Divide_by_16;
+    } else if (nb_of_clock_ticks/16 < 0xFFFF) {
+      preload = nb_of_clock_ticks/16;
+    } else if (nb_of_clock_ticks/32 < 0xFFFF) {
+      preload = nb_of_clock_ticks/32;
+      prescaler_output_tap = m340_Divide_by_32;
+    } else if (nb_of_clock_ticks/64 < 0xFFFF) {
+      preload = nb_of_clock_ticks/64;
+      prescaler_output_tap = m340_Divide_by_64;
+    } else if (nb_of_clock_ticks/128 < 0xFFFF) {
+      preload = nb_of_clock_ticks/128;
+      prescaler_output_tap = m340_Divide_by_128;
+    } else if (nb_of_clock_ticks/256 < 0xFFFF) {
+      preload = nb_of_clock_ticks/256;
+      prescaler_output_tap = m340_Divide_by_256;
+    /* Input Capture/Output Compare (ICOC) */
+    TCR1 = m340_SWR | m340_TO_Enabled | m340_ICOC;
+    if (prescaler_output_tap!=-1) TCR1 |= prescaler_output_tap | m340_PSE;
+    /* install interrupt vector */
+    rtems_interrupt_catch(InterruptHandler, TIMER1_VECTOR, &old_handler);
+  } /* fifo full mode on a uart */
+  /* install routines */
+  if ( Fifo_Full_on_A ) {
+    Restart_Check_A_Timer     = __Restart_Check_Timer;
+    Restart_Fifo_Full_A_Timer = __Restart_Fifo_Full_Timer;
+  } else {
+    Restart_Check_A_Timer     = __do_nothing;
+    Restart_Fifo_Full_A_Timer = __do_nothing;
+  if ( Fifo_Full_on_B ) {
+    Restart_Check_B_Timer     = __Restart_Check_Timer;
+    Restart_Fifo_Full_B_Timer = __Restart_Fifo_Full_Timer;
+  } else {
+    Restart_Check_B_Timer     = __do_nothing;
+    Restart_Fifo_Full_B_Timer = __do_nothing;
+  /* start checking timer */
+  Restart_Check_A_Timer();
+  Restart_Check_B_Timer();
-  Name: benchmark_timer_initialize
-  Description: init Timer for timing test suites
+ * benchmark_timer_initialize
+ * init Timer for timing test suites
 void benchmark_timer_initialize (void)
-	TCR2 &= ~m340_SWR;
+  TCR2 &= ~m340_SWR;
-	TSR2 &= ~(m340_TO | m340_TG | m340_TC);
+  TSR2 &= ~(m340_TO | m340_TG | m340_TC);
-	TMCR1 = TIMER2_INTERRUPT_ARBITRATION;
+     set interrupt arbitration */
+  TMCR1 = TIMER2_INTERRUPT_ARBITRATION;
-	TIR1 = TIMER2_VECTOR | (TIMER2_IRQ_LEVEL << 8);
+  TIR1 = TIMER2_VECTOR | (TIMER2_IRQ_LEVEL << 8);
-	TMCR2 = TIMER2_INTERRUPT_ARBITRATION;
+  TMCR2 = TIMER2_INTERRUPT_ARBITRATION;
-	/* Preload register 1 */
-	WPREL21 = 0xFFFF;
+  /* Preload register 1 */
+  WPREL21 = 0xFFFF;
-	TCR2 = m340_SWR | m340_ICOC | m340_PSE | m340_Divide_by_16 | m340_CPE;
+  TCR2 = m340_SWR | m340_ICOC | m340_PSE | m340_Divide_by_16 | m340_CPE;
-  Name: benchmark_timer_read
-  Description: Return timer value in microsecond units
-uint32_t
-benchmark_timer_read (void)
+ * benchmark_timer_read
+ * Return timer value in microsecond units
+uint32_t benchmark_timer_read (void)
- /* there's CLOCK_SPEED / 16 micro seconds between two timer register decrement */
+ /* there's CLOCK_SPEED / 16 micro seconds between two timer
+  * register decrements.
  return (((0xFFFF - TCNTR2) * CLOCK_SPEED) / 16);
-  Name: benchmark_timer_disable_subtracting_average_overhead
-  Description: -
-void
-benchmark_timer_disable_subtracting_average_overhead(bool find_flag)
+ * benchmark_timer_disable_subtracting_average_overhead
+void benchmark_timer_disable_subtracting_average_overhead(bool find_flag)
1.9.3
