[PATCH 48/62] arm/gba/startup/bspstart.c: Ensure bsp_start_default() is static
Wed Oct 15 20:00:38 UTC 2014
 c/src/lib/libbsp/arm/gba/startup/bspstart.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/gba/startup/bspstart.c b/c/src/lib/libbsp/arm/gba/startup/bspstart.c
index ec82f1c..b5e37d4 100644
--- a/c/src/lib/libbsp/arm/gba/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/gba/startup/bspstart.c
@@ -34,7 +34,7 @@ volatile unsigned int *Regs = (unsigned int *)GBA_IO_REGS_ADDR;
  *  @param  None
  *  @return None
-void bsp_start_default( void )
+static void bsp_start_default( void )
   /* Init conio  */
   gba_textmode(CO60);
1.9.3
