[PATCH 49/62] arm/gp32/startup/bspstart.c: Ensure bsp_start_default() is static
Wed Oct 15 20:00:39 UTC 2014
 c/src/lib/libbsp/arm/gp32/startup/bspstart.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/gp32/startup/bspstart.c b/c/src/lib/libbsp/arm/gp32/startup/bspstart.c
index 2dff6d4..5002e57 100644
--- a/c/src/lib/libbsp/arm/gp32/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/gp32/startup/bspstart.c
@@ -86,5 +86,4 @@ static void bsp_start_default( void )
  *  By making this a weak alias for bsp_start_default, a brave soul
  *  can override the actual bsp_start routine used.
 void bsp_start (void) __attribute__ ((weak, alias("bsp_start_default")));
1.9.3
