[PATCH 52/62] SH libcpu and libbsp: Fix warnings
Wed Oct 15 20:00:42 UTC 2014
 c/src/lib/libbsp/sh/gensh1/include/bsp.h           |   9 +-
 c/src/lib/libbsp/sh/gensh2/include/bsp.h           |  28 +-
 c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c       | 448 ++++++++++-----------
 c/src/lib/libbsp/sh/gensh4/include/bsp.h           |  17 +-
 c/src/lib/libbsp/sh/shared/bsphwinit.c             |   8 +-
 .../lib/libbsp/sh/shsim/console/console-debugio.c  |   5 +-
 c/src/lib/libbsp/sh/shsim/console/console-io.c     |  16 -
 c/src/lib/libbsp/sh/shsim/include/bsp.h            |  17 +-
 c/src/lib/libbsp/sh/shsim/start/start.S            |   1 +
 c/src/lib/libbsp/sh/shsim/startup/sysexit.c        |  21 +
 c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c         |   1 +
 c/src/lib/libcpu/sh/sh7045/sci/sci.c               |  89 ++--
 c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c       |   8 +-
 c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c           |   7 +-
 c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c          |   7 +-
 15 files changed, 350 insertions(+), 332 deletions(-)
 create mode 100644 c/src/lib/libbsp/sh/shsim/startup/sysexit.c
diff --git a/c/src/lib/libbsp/sh/gensh1/include/bsp.h b/c/src/lib/libbsp/sh/gensh1/include/bsp.h
index c25c6a2..6f7c77b 100644
--- a/c/src/lib/libbsp/sh/gensh1/include/bsp.h
+++ b/c/src/lib/libbsp/sh/gensh1/include/bsp.h
@@ -1,8 +1,10 @@
- *  This include file contains all board IO definitions.
  *  generic sh1
+ *  This include file contains all board IO definitions.
  *  Author: Ralf Corsepius (corsepiu at faw.uni-ulm.de)
  *  COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
@@ -68,8 +70,9 @@ extern void *CPU_Interrupt_stack_high;
       console_read, console_write, console_control }
- * NOTE: Use the standard Clock driver entry
+ * BSP methods that cross file boundaries.
+void bsp_hw_init(void);
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/sh/gensh2/include/bsp.h b/c/src/lib/libbsp/sh/gensh2/include/bsp.h
index be49e71..5ef882a 100644
--- a/c/src/lib/libbsp/sh/gensh2/include/bsp.h
+++ b/c/src/lib/libbsp/sh/gensh2/include/bsp.h
@@ -1,8 +1,10 @@
  *  generic sh2
@@ -45,12 +47,11 @@ extern "C" {
 #include <bspopts.h>
 #include <bsp/default-initial-extension.h>
-#if 0
-#include <rtems/devnull.h>
-#define BSP_CONSOLE_DEVNAME "/dev/null"
-#define BSP_CONSOLE_DRIVER_TABLE_ENTRY DEVNULL_DRIVER_TABLE_ENTRY
-#else
+#include <termios.h> /* for tcflag_t */
 #include <sh/sci.h>
+#if 1
 /* FIXME:
  *   These definitions will be no longer necessary if the old
  *   implementation of SCI driver will be droped
@@ -66,17 +67,18 @@ extern "C" {
  * Defined in the linker script 'linkcmds'
 extern void *CPU_Interrupt_stack_low;
- *  Device Driver Table Entries
+extern int _sci_get_brparms(
+  tcflag_t      cflag,
+  unsigned char *smr,
+  unsigned char *brr
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c b/c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c
index 20e3cde..4bf673e 100644
--- a/c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c
+++ b/c/src/lib/libbsp/sh/gensh4/hw_init/hw_init.c
@@ -1,9 +1,11 @@
  * SMFD board hardware initialization.
  * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
  * Author: Victor V. Vengerov <vvv at oktet.ru>
- *	   Alexandra Kossovsky <sasha at oktet.ru>
+ *         Alexandra Kossovsky <sasha at oktet.ru>
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
@@ -25,241 +27,234 @@
  *     This function should not access the memory! It should be compiled
  *     with -fomit-frame-pointer to avoid stack access.
- * PARAMETERS:
- *     none
- * RETURNS:
- *     none
-void
-early_hw_init(void)
+void early_hw_init(void)
-    /* Explicitly turn off the MMU */
-    write32(0, SH7750_MMUCR);
+  /* Explicitly turn off the MMU */
+  write32(0, SH7750_MMUCR);
-    /* Disable instruction and operand caches */
-    write32(0, SH7750_CCR);
+  /* Disable instruction and operand caches */
+  write32(0, SH7750_CCR);
-    /* Setup Clock Generator */
-     * Input clock frequency is 16 MHz, MD0=1,
-     * CPU clock frequency already selected to 96MHz.
-     * Bus clock frequency should be set to 48 MHz, therefore divider 2
-     * should be applied (bus frequency is 48 MHz, clock period is 20.84ns).
-     * Peripheral frequency should be set to 24 MHz, therefore divider 4
-     * should be used.
-    /* Prepare watchdog timer for frequency changing */
-    write16((read8(SH7750_WTCSR) & ~SH7750_WTCSR_TME) |
-            SH7750_WTCSR_KEY, SH7750_WTCSR);
-    write16(SH7750_WTCSR_MODE_IT | SH7750_WTCSR_CKS_DIV4096 |
+  /* Setup Clock Generator */
+   * Input clock frequency is 16 MHz, MD0=1,
+   * CPU clock frequency already selected to 96MHz.
+   * Bus clock frequency should be set to 48 MHz, therefore divider 2
+   * should be applied (bus frequency is 48 MHz, clock period is 20.84ns).
+   * Peripheral frequency should be set to 24 MHz, therefore divider 4
+   * should be used.
+  /* Prepare watchdog timer for frequency changing */
+  write16((read8(SH7750_WTCSR) & ~SH7750_WTCSR_TME) |
+          SH7750_WTCSR_KEY, SH7750_WTCSR);
+  write16(SH7750_WTCSR_MODE_IT | SH7750_WTCSR_CKS_DIV4096 |
-    /* Turn PLL1 on */
-    write16(0x40 | SH7750_WTCNT_KEY, SH7750_WTCNT);
-    write16(read16(SH7750_FRQCR) | SH7750_FRQCR_PLL1EN, SH7750_FRQCR);
+  /* Turn PLL1 on */
+  write16(0x40 | SH7750_WTCNT_KEY, SH7750_WTCNT);
+  write16(read16(SH7750_FRQCR) | SH7750_FRQCR_PLL1EN, SH7750_FRQCR);
-    /* Perform Frequency Selection */
-    write16(SH7750_FRQCR_CKOEN | SH7750_FRQCR_PLL1EN |
-            SH7750_FRQCR_IFCDIV1 | SH7750_FRQCR_BFCDIV2 | SH7750_FRQCR_PFCDIV4,
-            SH7750_FRQCR);
+  /* Perform Frequency Selection */
+  write16(SH7750_FRQCR_CKOEN | SH7750_FRQCR_PLL1EN |
+          SH7750_FRQCR_IFCDIV1 | SH7750_FRQCR_BFCDIV2 | SH7750_FRQCR_PFCDIV4,
+          SH7750_FRQCR);
-    /* Turn PLL2 on */
-    write16(read16(SH7750_FRQCR) | SH7750_FRQCR_PLL2EN, SH7750_FRQCR);
+  /* Turn PLL2 on */
+  write16(read16(SH7750_FRQCR) | SH7750_FRQCR_PLL2EN, SH7750_FRQCR);
-    /* Bus State Controller Initialization */
-     * Area assignments:
-     *     Area 0: Flash memory, SRAM interface
-     *     Area 1: GDC
-     *     Area 2: SDRAM
-     *     Area 3-6: unused
-    write32(
-        /* Pull-ups (IPUP, OPUP) enabled */
-        /* No Byte-Control SRAM mode for Area 1 and Area 3 */
-        SH7750_BCR1_BREQEN | /* Enable external bus requests */
-        /* No Partial Sharing Mode */
-        /* No MPX interface */
-        /* Memory and Control Signals are in HiZ */
-        SH7750_BCR1_A0BST_SRAM | /* No burst ROM in flash */
-        SH7750_BCR1_A5BST_SRAM | /* Area 5 is not in use */
-        SH7750_BCR1_A6BST_SRAM | /* Area 6 is not in use */
-        SH7750_BCR1_DRAMTP_2SDRAM_3SDRAM  /* Select Area 2 SDRAM type */
-        /* Area 5,6 programmed as a SRAM interface (not PCMCIA) */,
-        SH7750_BCR1);
+  /* Bus State Controller Initialization */
+   * Area assignments:
+   *     Area 0: Flash memory, SRAM interface
+   *     Area 1: GDC
+   *     Area 2: SDRAM
+   *     Area 3-6: unused
+  write32(
+      /* Pull-ups (IPUP, OPUP) enabled */
+      /* No Byte-Control SRAM mode for Area 1 and Area 3 */
+      SH7750_BCR1_BREQEN | /* Enable external bus requests */
+      /* No Partial Sharing Mode */
+      /* No MPX interface */
+      /* Memory and Control Signals are in HiZ */
+      SH7750_BCR1_A0BST_SRAM | /* No burst ROM in flash */
+      SH7750_BCR1_A5BST_SRAM | /* Area 5 is not in use */
+      SH7750_BCR1_A6BST_SRAM | /* Area 6 is not in use */
+      SH7750_BCR1_DRAMTP_2SDRAM_3SDRAM  /* Select Area 2 SDRAM type */
+      /* Area 5,6 programmed as a SRAM interface (not PCMCIA) */,
+      SH7750_BCR1);
-    write16(
-        (SH7750_BCR2_SZ_8 << SH7750_BCR2_A0SZ_S) |  /* These bits is read-only
-                                                       and set during reset */
-        (SH7750_BCR2_SZ_32 << SH7750_BCR2_A6SZ_S) | /* Area 6 not used */
-        (SH7750_BCR2_SZ_32 << SH7750_BCR2_A5SZ_S) | /* Area 5 not used */
-        (SH7750_BCR2_SZ_32 << SH7750_BCR2_A4SZ_S) | /* Area 4 not used */
-        (SH7750_BCR2_SZ_32 << SH7750_BCR2_A3SZ_S) | /* Area 3 not used */
-        (SH7750_BCR2_SZ_32 << SH7750_BCR2_A2SZ_S) | /* SDRAM is 32-bit width */
-        (SH7750_BCR2_SZ_32 << SH7750_BCR2_A1SZ_S) | /* GDC is 32-bit width */
-        SH7750_BCR2_PORTEN,                         /* Use D32-D51 as a port */
-        SH7750_BCR2);
+  write16(
+      (SH7750_BCR2_SZ_8 << SH7750_BCR2_A0SZ_S) |  /* These bits is read-only
+                                                     and set during reset */
+      (SH7750_BCR2_SZ_32 << SH7750_BCR2_A6SZ_S) | /* Area 6 not used */
+      (SH7750_BCR2_SZ_32 << SH7750_BCR2_A5SZ_S) | /* Area 5 not used */
+      (SH7750_BCR2_SZ_32 << SH7750_BCR2_A4SZ_S) | /* Area 4 not used */
+      (SH7750_BCR2_SZ_32 << SH7750_BCR2_A3SZ_S) | /* Area 3 not used */
+      (SH7750_BCR2_SZ_32 << SH7750_BCR2_A2SZ_S) | /* SDRAM is 32-bit width */
+      (SH7750_BCR2_SZ_32 << SH7750_BCR2_A1SZ_S) | /* GDC is 32-bit width */
+      SH7750_BCR2_PORTEN,                         /* Use D32-D51 as a port */
+      SH7750_BCR2);
-    write32(
-        (0 << SH7750_WCR1_DMAIW_S) |  /* 0 required for SDRAM RAS down mode */
-        (7 << SH7750_WCR1_A6IW_S) |   /* Area 6 not used */
-        (7 << SH7750_WCR1_A5IW_S) |   /* Area 5 not used */
-        (7 << SH7750_WCR1_A4IW_S) |   /* Area 4 not used */
-        (7 << SH7750_WCR1_A3IW_S) |   /* Area 3 not used */
-        (1 << SH7750_WCR1_A2IW_S) |   /* 1 idle cycles inserted between acc */
-        (7 << SH7750_WCR1_A1IW_S) |   /* Don't have GDC specs... Set safer. */
-        (1 << SH7750_WCR1_A0IW_S),    /* 1 idle cycles inserted between acc */
-        SH7750_WCR1);
+  write32(
+      (0 << SH7750_WCR1_DMAIW_S) |  /* 0 required for SDRAM RAS down mode */
+      (7 << SH7750_WCR1_A6IW_S) |   /* Area 6 not used */
+      (7 << SH7750_WCR1_A5IW_S) |   /* Area 5 not used */
+      (7 << SH7750_WCR1_A4IW_S) |   /* Area 4 not used */
+      (7 << SH7750_WCR1_A3IW_S) |   /* Area 3 not used */
+      (1 << SH7750_WCR1_A2IW_S) |   /* 1 idle cycles inserted between acc */
+      (7 << SH7750_WCR1_A1IW_S) |   /* Don't have GDC specs... Set safer. */
+      (1 << SH7750_WCR1_A0IW_S),    /* 1 idle cycles inserted between acc */
+      SH7750_WCR1);
-    write32(
-        (SH7750_WCR2_WS15   << SH7750_WCR2_A6W_S) | /* Area 6 not used */
-        (SH7750_WCR2_BPWS7  << SH7750_WCR2_A6B_S) |
-        (SH7750_WCR2_WS15   << SH7750_WCR2_A5W_S) | /* Area 5 not used */
-        (SH7750_WCR2_BPWS7  << SH7750_WCR2_A5B_S) |
-        (SH7750_WCR2_WS15   << SH7750_WCR2_A4W_S) | /* Area 4 not used */
-        (SH7750_WCR2_WS15   << SH7750_WCR2_A3W_S) | /*Area 3 not used*/
-        (SH7750_WCR2_SDRAM_CAS_LAT2 << SH7750_WCR2_A2W_S) | /* SDRAM CL = 2 */
-        (SH7750_WCR2_WS15   << SH7750_WCR2_A1W_S) | /* Area 1 (GDC)
-                                                       requirements not known*/
-        (SH7750_WCR2_WS6    << SH7750_WCR2_A0W_S) | /* 4 wait states required
-                                                       at 48MHz for 70ns mem.,
-                                                       set closest greater */
-        (SH7750_WCR2_BPWS7  << SH7750_WCR2_A0B_S),  /* burst mode disabled for
-                                                       Area 0 flash ROM */
-        SH7750_WCR2);
-    write32(
-        SH7750_WCR3_A6S |                           /* Area 6 not used */
-        (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A6H_S) |
-        SH7750_WCR3_A5S |                           /* Area 5 not used */
-        (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A5H_S) |
-        SH7750_WCR3_A4S |                           /* Area 4 not used */
-        (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A4H_S) |
-        SH7750_WCR3_A3S |                           /* Area 3 not used */
-        (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A3H_S) |
-        SH7750_WCR3_A2S |                           /* SDRAM - ignored */
-        (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A2H_S) |
-        SH7750_WCR3_A1S |                           /* GDC - unknown, set max*/
-        (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A1H_S) |
-        0 |               /* flash ROM - no write strobe setup time required */
-        (SH7750_WCR3_DHWS_0 << SH7750_WCR3_A0H_S),
-        SH7750_WCR3);
+  write32(
+      (SH7750_WCR2_WS15   << SH7750_WCR2_A6W_S) | /* Area 6 not used */
+      (SH7750_WCR2_BPWS7  << SH7750_WCR2_A6B_S) |
+      (SH7750_WCR2_WS15   << SH7750_WCR2_A5W_S) | /* Area 5 not used */
+      (SH7750_WCR2_BPWS7  << SH7750_WCR2_A5B_S) |
+      (SH7750_WCR2_WS15   << SH7750_WCR2_A4W_S) | /* Area 4 not used */
+      (SH7750_WCR2_WS15   << SH7750_WCR2_A3W_S) | /*Area 3 not used*/
+      (SH7750_WCR2_SDRAM_CAS_LAT2 << SH7750_WCR2_A2W_S) | /* SDRAM CL = 2 */
+      (SH7750_WCR2_WS15   << SH7750_WCR2_A1W_S) | /* Area 1 (GDC)
+                                                     requirements not known*/
+      (SH7750_WCR2_WS6    << SH7750_WCR2_A0W_S) | /* 4 wait states required
+                                                     at 48MHz for 70ns mem.,
+                                                     set closest greater */
+      (SH7750_WCR2_BPWS7  << SH7750_WCR2_A0B_S),  /* burst mode disabled for
+                                                     Area 0 flash ROM */
+      SH7750_WCR2);
+  write32(
+      SH7750_WCR3_A6S |                           /* Area 6 not used */
+      (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A6H_S) |
+      SH7750_WCR3_A5S |                           /* Area 5 not used */
+      (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A5H_S) |
+      SH7750_WCR3_A4S |                           /* Area 4 not used */
+      (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A4H_S) |
+      SH7750_WCR3_A3S |                           /* Area 3 not used */
+      (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A3H_S) |
+      SH7750_WCR3_A2S |                           /* SDRAM - ignored */
+      (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A2H_S) |
+      SH7750_WCR3_A1S |                           /* GDC - unknown, set max*/
+      (SH7750_WCR3_DHWS_3 << SH7750_WCR3_A1H_S) |
+      0 |               /* flash ROM - no write strobe setup time required */
+      (SH7750_WCR3_DHWS_0 << SH7750_WCR3_A0H_S),
+      SH7750_WCR3);
-    #define MCRDEF \
-        /* SH7750_MCR_RASD | */  /* Set RAS Down mode */                      \
-        (SH7750_MCR_TRC_0 | SH7750_MCR_TRAS_SDRAM_TRC_4 |                     \
-                 /* RAS precharge time is 63ns; it corresponds to 4 clocks */ \
-        /* TCAS valid only for DRAM interface */                              \
-        SH7750_MCR_TPC_SDRAM_1 | /* TPC = 20ns = 1 clock */                   \
-        SH7750_MCR_RCD_SDRAM_2 | /* RCD = 21ns = 2 clock */                   \
-        /* After write, next active command is not issued for a period of     \
-           TPC + TRWL. SDRAM specifies that it should be BL+Trp clocks when   \
-           CL=2. Trp = 20ns = 1clock; BL=8. Therefore we should wait 9        \
-           clocks. Don't know why, but 6 clocks (TRWL=5 and TPC=1) seems      \
-           working. May be, something wrong in documentation? */              \
-        SH7750_MCR_TRWL_5 |      /* TRWL = 5 clock        */                  \
-        SH7750_MCR_BE |          /* Always enabled for SDRAM */               \
-        SH7750_MCR_SZ_32 |       /* Memory data size is 32 bit */             \
-        (4 << SH7750_MCR_AMX_S) | /* Select memory device type */             \
-        SH7750_MCR_RFSH |        /* Refresh is performed */                   \
-        SH7750_MCR_RMODE_NORMAL) /* Auto-Refresh mode */
+  #define MCRDEF \
+      /* SH7750_MCR_RASD | */  /* Set RAS Down mode */                      \
+      (SH7750_MCR_TRC_0 | SH7750_MCR_TRAS_SDRAM_TRC_4 |                     \
+               /* RAS precharge time is 63ns; it corresponds to 4 clocks */ \
+      /* TCAS valid only for DRAM interface */                              \
+      SH7750_MCR_TPC_SDRAM_1 | /* TPC = 20ns = 1 clock */                   \
+      SH7750_MCR_RCD_SDRAM_2 | /* RCD = 21ns = 2 clock */                   \
+      /* After write, next active command is not issued for a period of     \
+         TPC + TRWL. SDRAM specifies that it should be BL+Trp clocks when   \
+         CL=2. Trp = 20ns = 1clock; BL=8. Therefore we should wait 9        \
+         clocks. Don't know why, but 6 clocks (TRWL=5 and TPC=1) seems      \
+         working. May be, something wrong in documentation? */              \
+      SH7750_MCR_TRWL_5 |      /* TRWL = 5 clock        */                  \
+      SH7750_MCR_BE |          /* Always enabled for SDRAM */               \
+      SH7750_MCR_SZ_32 |       /* Memory data size is 32 bit */             \
+      (4 << SH7750_MCR_AMX_S) | /* Select memory device type */             \
+      SH7750_MCR_RFSH |        /* Refresh is performed */                   \
+      SH7750_MCR_RMODE_NORMAL) /* Auto-Refresh mode */
-    /* Clear refresh timer counter */
-    write16(SH7750_RTCNT_KEY | 0, SH7750_RTCNT);
+  /* Clear refresh timer counter */
+  write16(SH7750_RTCNT_KEY | 0, SH7750_RTCNT);
-    /* Time between auto-refresh commands is 15.6 microseconds; refresh
-       timer counter frequency is 12 MHz; 1.56e-5*1.2e7= 187.2, therefore
-       program the refresh timer divider to 187 */
-    write16(SH7750_RTCOR_KEY | 187, SH7750_RTCOR);
+  /* Time between auto-refresh commands is 15.6 microseconds; refresh
+     timer counter frequency is 12 MHz; 1.56e-5*1.2e7= 187.2, therefore
+     program the refresh timer divider to 187 */
+  write16(SH7750_RTCOR_KEY | 187, SH7750_RTCOR);
-    /* Clear refresh counter */
-    write16(SH7750_RFCR_KEY | 0, SH7750_RFCR);
+  /* Clear refresh counter */
+  write16(SH7750_RFCR_KEY | 0, SH7750_RFCR);
-    /* Select refresh counter base frequency as bus frequency/4 = 12 MHz */
-    write16(SH7750_RTCSR_CKS_CKIO_DIV4 | SH7750_RTCSR_KEY, SH7750_RTCSR);
+  /* Select refresh counter base frequency as bus frequency/4 = 12 MHz */
+  write16(SH7750_RTCSR_CKS_CKIO_DIV4 | SH7750_RTCSR_KEY, SH7750_RTCSR);
-    /* Initialize Memory Control Register; disable refresh */
-    write32((MCRDEF & ~SH7750_MCR_RFSH) | SH7750_MCR_PALL, SH7750_MCR);
+  /* Initialize Memory Control Register; disable refresh */
+  write32((MCRDEF & ~SH7750_MCR_RFSH) | SH7750_MCR_PALL, SH7750_MCR);
-    /* SDRAM power-up initialization require 100 microseconds delay after
-       stable power and clock fed; 100 microseconds corresponds to 7 refresh
-       intervals */
-    while (read16(SH7750_RFCR) <= 7);
+  /* SDRAM power-up initialization require 100 microseconds delay after
+     stable power and clock fed; 100 microseconds corresponds to 7 refresh
+     intervals */
+  while (read16(SH7750_RFCR) <= 7);
-    /* Execute Precharge All command */
-    write32(0, SH7750_SDRAM_MODE_A2_32BIT(0));
+  /* Execute Precharge All command */
+  write32(0, SH7750_SDRAM_MODE_A2_32BIT(0));
-    /* Initialize Memory Control Register; enable refresh, prepare to
-       SDRAM mode register setting */
-    write32(MCRDEF | SH7750_MCR_MRSET, SH7750_MCR);
+  /* Initialize Memory Control Register; enable refresh, prepare to
+     SDRAM mode register setting */
+  write32(MCRDEF | SH7750_MCR_MRSET, SH7750_MCR);
-    /* Wait until at least 2 auto-refresh commands to be executed */
-    while (read16(SH7750_RFCR) <= 10);
+  /* Wait until at least 2 auto-refresh commands to be executed */
+  while (read16(SH7750_RFCR) <= 10);
-    /* SDRAM data width is 32 bit (4 bytes), cache line size is 32 bytes,
-       therefore burst length is 8 (32 / 4) */
-    write8(0,SH7750_SDRAM_MODE_A2_32BIT(
-        SDRAM_MODE_BL_8 |
-        SDRAM_MODE_BT_SEQ |    /* Only sequential burst mode supported
-                                  in SH7750 */
-        SDRAM_MODE_CL_2 |      /* CAS latency is 2 */
-        SDRAM_MODE_OPC_BRBW)   /* Burst read/burst write */
-    /* Bus State Controller initialized now */
+  /* SDRAM data width is 32 bit (4 bytes), cache line size is 32 bytes,
+     therefore burst length is 8 (32 / 4) */
+  write8(0,SH7750_SDRAM_MODE_A2_32BIT(
+      SDRAM_MODE_BL_8 |
+      SDRAM_MODE_BT_SEQ |    /* Only sequential burst mode supported
+                                in SH7750 */
+      SDRAM_MODE_CL_2 |      /* CAS latency is 2 */
+      SDRAM_MODE_OPC_BRBW)   /* Burst read/burst write */
+  /* Bus State Controller initialized now */
-    /* Disable DMA controller */
-    write32(0, SH7750_DMAOR);
+  /* Disable DMA controller */
+  write32(0, SH7750_DMAOR);
-    /* I/O port setup */
-    /* Configure all port bits as output - to fasciliate debugging */
-    write32(
-        SH7750_PCTRA_PBOUT(0)  | SH7750_PCTRA_PBOUT(1) |
-        SH7750_PCTRA_PBOUT(2)  | SH7750_PCTRA_PBOUT(3) |
-        SH7750_PCTRA_PBOUT(4)  | SH7750_PCTRA_PBOUT(5) |
-        SH7750_PCTRA_PBOUT(6)  | SH7750_PCTRA_PBOUT(7) |
-        SH7750_PCTRA_PBOUT(8)  | SH7750_PCTRA_PBOUT(9) |
-        SH7750_PCTRA_PBOUT(10) | SH7750_PCTRA_PBOUT(11) |
-        SH7750_PCTRA_PBOUT(12) | SH7750_PCTRA_PBOUT(13) |
-        SH7750_PCTRA_PBOUT(14) | SH7750_PCTRA_PBOUT(15),
-        SH7750_PCTRA);
-    write32(
-        SH7750_PCTRB_PBOUT(16) | SH7750_PCTRB_PBOUT(17) |
-        SH7750_PCTRB_PBOUT(18) | SH7750_PCTRB_PBOUT(19),
-        SH7750_PCTRB);
-    /* Clear data in port */
-    write32(0, SH7750_PDTRA);
-    write32(0, SH7750_PDTRB);
+  /* I/O port setup */
+  /* Configure all port bits as output - to fasciliate debugging */
+  write32(
+      SH7750_PCTRA_PBOUT(0)  | SH7750_PCTRA_PBOUT(1) |
+      SH7750_PCTRA_PBOUT(2)  | SH7750_PCTRA_PBOUT(3) |
+      SH7750_PCTRA_PBOUT(4)  | SH7750_PCTRA_PBOUT(5) |
+      SH7750_PCTRA_PBOUT(6)  | SH7750_PCTRA_PBOUT(7) |
+      SH7750_PCTRA_PBOUT(8)  | SH7750_PCTRA_PBOUT(9) |
+      SH7750_PCTRA_PBOUT(10) | SH7750_PCTRA_PBOUT(11) |
+      SH7750_PCTRA_PBOUT(12) | SH7750_PCTRA_PBOUT(13) |
+      SH7750_PCTRA_PBOUT(14) | SH7750_PCTRA_PBOUT(15),
+      SH7750_PCTRA);
+  write32(
+      SH7750_PCTRB_PBOUT(16) | SH7750_PCTRB_PBOUT(17) |
+      SH7750_PCTRB_PBOUT(18) | SH7750_PCTRB_PBOUT(19),
+      SH7750_PCTRB);
+  /* Clear data in port */
+  write32(0, SH7750_PDTRA);
+  write32(0, SH7750_PDTRB);
-    /* Interrupt Controller Initialization */
-    write16(SH7750_ICR_IRLM, SH7750_ICR); /* IRLs serves as an independent
-                                             interrupt request lines */
-    /* Mask all requests at this time */
-    write16(
-        (0 << SH7750_IPRA_TMU0_S) |
-        (0 << SH7750_IPRA_TMU1_S) |
-        (0 << SH7750_IPRA_TMU2_S) |
-        (0 << SH7750_IPRA_RTC_S),
-        SH7750_IPRA);
-    write16(
-        (0 << SH7750_IPRB_WDT_S) |
-        (0 << SH7750_IPRB_REF_S) |
-        (0 << SH7750_IPRB_SCI1_S),
-        SH7750_IPRB);
-    write16(
-        (0 << SH7750_IPRC_GPIO_S) |
-        (0 << SH7750_IPRC_DMAC_S) |
-        (0 << SH7750_IPRC_SCIF_S) |
-        (0 << SH7750_IPRC_HUDI_S),
-        SH7750_IPRC);
+  /* Interrupt Controller Initialization */
+  write16(SH7750_ICR_IRLM, SH7750_ICR); /* IRLs serves as an independent
+                                           interrupt request lines */
+  /* Mask all requests at this time */
+  write16(
+      (0 << SH7750_IPRA_TMU0_S) |
+      (0 << SH7750_IPRA_TMU1_S) |
+      (0 << SH7750_IPRA_TMU2_S) |
+      (0 << SH7750_IPRA_RTC_S),
+      SH7750_IPRA);
+  write16(
+      (0 << SH7750_IPRB_WDT_S) |
+      (0 << SH7750_IPRB_REF_S) |
+      (0 << SH7750_IPRB_SCI1_S),
+      SH7750_IPRB);
+  write16(
+      (0 << SH7750_IPRC_GPIO_S) |
+      (0 << SH7750_IPRC_DMAC_S) |
+      (0 << SH7750_IPRC_SCIF_S) |
+      (0 << SH7750_IPRC_HUDI_S),
+      SH7750_IPRC);
@@ -269,21 +264,20 @@ early_hw_init(void)
 void bsp_cache_on(void)
-    switch (boot_mode)
-        case SH4_BOOT_MODE_FLASH:
-            write32(SH7750_CCR_ICI | SH7750_CCR_ICE |
-                    SH7750_CCR_OCI | SH7750_CCR_CB | SH7750_CCR_OCE,
-                    SH7750_CCR);
-            break;
-        case SH4_BOOT_MODE_IPL:
-            __asm__ volatile (
-                "mov     #6, r0\n"
-                "xor     r4, r4\n"
-                "trapa   #0x3f\n"
-                : : : "r0", "r4");
-            break;
-        default: /* unreachable */
-            break;
+  switch (boot_mode) {
+    case SH4_BOOT_MODE_FLASH:
+      write32(SH7750_CCR_ICI | SH7750_CCR_ICE |
+              SH7750_CCR_OCI | SH7750_CCR_CB | SH7750_CCR_OCE,
+              SH7750_CCR);
+      break;
+    case SH4_BOOT_MODE_IPL:
+      __asm__ volatile (
+          "mov     #6, r0\n"
+          "xor     r4, r4\n"
+          "trapa   #0x3f\n"
+          : : : "r0", "r4");
+      break;
+    default: /* unreachable */
+      break;
diff --git a/c/src/lib/libbsp/sh/gensh4/include/bsp.h b/c/src/lib/libbsp/sh/gensh4/include/bsp.h
index 611c72e..a2b41d0 100644
--- a/c/src/lib/libbsp/sh/gensh4/include/bsp.h
+++ b/c/src/lib/libbsp/sh/gensh4/include/bsp.h
@@ -1,8 +1,10 @@
  *  generic sh4 BSP
@@ -47,6 +49,7 @@ extern "C" {
 #include <rtems/console.h>
 #include "rtems/score/sh7750_regs.h"
@@ -79,8 +82,16 @@ extern uint32_t   boot_mode;
+void early_hw_init(void);
+void bsp_cache_on(void);
+  tcflag_t      cflag,
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/sh/shared/bsphwinit.c b/c/src/lib/libbsp/sh/shared/bsphwinit.c
index 9211d9b..2e9bd2e 100644
--- a/c/src/lib/libbsp/sh/shared/bsphwinit.c
+++ b/c/src/lib/libbsp/sh/shared/bsphwinit.c
@@ -1,7 +1,9 @@
  *  This is a dummy bsp_hw_init routine.
- *  COPYRIGHT (c) 1989-2008.
+ *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
@@ -9,6 +11,8 @@
  *  http://www.rtems.org/license/LICENSE.
+#include <bsp.h>
 void bsp_hw_init( void )
diff --git a/c/src/lib/libbsp/sh/shsim/console/console-debugio.c b/c/src/lib/libbsp/sh/shsim/console/console-debugio.c
index 38b6c8f..0a81dbe 100644
--- a/c/src/lib/libbsp/sh/shsim/console/console-debugio.c
+++ b/c/src/lib/libbsp/sh/shsim/console/console-debugio.c
@@ -1,9 +1,6 @@
  *  @file
  *  @brief Stub printk() support
- *  This file contains a stub for the required printk() support.
- *  It is NOT functional!!!
@@ -27,7 +24,7 @@ void console_outbyte_polled(
   char ch
-void BSP_output_char_f(char c)
+static void BSP_output_char_f(char c)
   console_outbyte_polled( 0, c );
diff --git a/c/src/lib/libbsp/sh/shsim/console/console-io.c b/c/src/lib/libbsp/sh/shsim/console/console-io.c
index 7f5794e..71b089f 100644
--- a/c/src/lib/libbsp/sh/shsim/console/console-io.c
+++ b/c/src/lib/libbsp/sh/shsim/console/console-io.c
@@ -20,20 +20,13 @@
 #include <bsp/syscall.h>
-int errno;
-extern int __trap34(int, int, void*, int );
  *  console_initialize_hardware
  *  This routine initializes the console hardware.
 void console_initialize_hardware(void)
-  return;
@@ -41,14 +34,12 @@ void console_initialize_hardware(void)
  *  This routine transmits a character using polling.
   int  port,
   char ch
   __trap34 (SYS_write, 1, &ch, 1);
-  return;
@@ -56,7 +47,6 @@ void console_outbyte_polled(
  *  This routine polls for a character.
 int console_inbyte_nonblocking(
   int port
@@ -65,9 +55,3 @@ int console_inbyte_nonblocking(
   return __trap34 (SYS_read, 0, &c, 1);
-/* XXX wrong place for this */
-int _sys_exit (int n)
-  return __trap34 (SYS_exit, n, 0, 0);
diff --git a/c/src/lib/libbsp/sh/shsim/include/bsp.h b/c/src/lib/libbsp/sh/shsim/include/bsp.h
index 8b926dd..80ef2ce 100644
--- a/c/src/lib/libbsp/sh/shsim/include/bsp.h
+++ b/c/src/lib/libbsp/sh/shsim/include/bsp.h
@@ -1,8 +1,10 @@
  *  SH-gdb simulator BSP
  *  COPYRIGHT (c) 2001, Ralf Corsepius, Ulm, Germany
@@ -22,6 +24,8 @@
 #ifndef _BSP_H
 #define _BSP_H
+#ifndef ASM
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -46,12 +50,19 @@ Thread clock_driver_sim_idle_body(uintptr_t);
+int __trap34(int, int, void*, int );
+int _sys_exit (int n);
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif
diff --git a/c/src/lib/libbsp/sh/shsim/start/start.S b/c/src/lib/libbsp/sh/shsim/start/start.S
index 567af1f..cc4727b 100644
--- a/c/src/lib/libbsp/sh/shsim/start/start.S
+++ b/c/src/lib/libbsp/sh/shsim/start/start.S
@@ -18,6 +18,7 @@
 #include <rtems/asm.h>
+#include <bsp.h>
 	BEGIN_CODE
 	PUBLIC(start)
diff --git a/c/src/lib/libbsp/sh/shsim/startup/sysexit.c b/c/src/lib/libbsp/sh/shsim/startup/sysexit.c
new file mode 100644
index 0000000..4b540a2
--- /dev/null
+++ b/c/src/lib/libbsp/sh/shsim/startup/sysexit.c
@@ -0,0 +1,21 @@
+ *  This file contains the simulator specific exit trap.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#include <bsp.h>
+extern int __trap34(int, int, void*, int );
+  return __trap34 (SYS_exit, n, 0, 0);
diff --git a/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c b/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
index b121feb..dc1546e 100644
--- a/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c
@@ -35,6 +35,7 @@
 #include <rtems/score/isr.h>
 #include <rtems/score/sh.h>
+#include <rtems/score/ispsh7032.h>
 #include <rtems/score/iosh7032.h>
diff --git a/c/src/lib/libcpu/sh/sh7045/sci/sci.c b/c/src/lib/libcpu/sh/sh7045/sci/sci.c
index f48fef1..e6c54e2 100644
--- a/c/src/lib/libcpu/sh/sh7045/sci/sci.c
+++ b/c/src/lib/libcpu/sh/sh7045/sci/sci.c
@@ -8,7 +8,9 @@
  * This approach is similar to installing a sym-link from one device to
  * another device. If rtems once will support sym-links for devices files,
  * this implementation could be dropped.
@@ -75,11 +77,11 @@
 /*  #define SH_SCI_DEF_COMM_1   B9600 | CS8 */
 struct scidev_t {
-  char *			name;
-  uint32_t  			addr;
-  rtems_device_minor_number	minor;
-  unsigned short		opened;
-  tcflag_t			cflags;
+  char *                     name;
+  uint32_t                   addr;
+  rtems_device_minor_number  minor;
+  unsigned short             opened;
+  tcflag_t                   cflags;
 } sci_device[SCI_MINOR_DEVICES] =
   { "/dev/sci0", SH_SCI_BASE_0, 0, 0, SH_SCI_DEF_COMM_0 },
@@ -104,8 +106,8 @@ static int _sci_set_cflags(
   tcflag_t          c_cflag
-  uint8_t  	smr;
-  uint8_t  	brr;
+  uint8_t  smr;
+  uint8_t  brr;
   if ( c_cflag & CBAUD )
@@ -148,7 +150,7 @@ static int _sci_set_cflags(
  * local functions operate SCI ports 0 and 1
  * called from polling routines or ISRs
-bool wrtSCI0(unsigned char ch)
+static bool wrtSCI0(unsigned char ch)
   uint8_t   temp;
   bool result = false;
@@ -164,7 +166,7 @@ bool wrtSCI0(unsigned char ch)
   return result;
 } /* wrtSCI0 */
-bool wrtSCI1(unsigned char ch)
+static bool wrtSCI1(unsigned char ch)
   uint8_t   temp;
@@ -181,27 +183,27 @@ bool wrtSCI1(unsigned char ch)
 } /* wrtSCI1 */
 /* polled output steers byte to selected port */
-void sh_sci_outbyte_polled(
+static void sh_sci_outbyte_polled(
   rtems_device_minor_number  minor,
   char ch )
-	if (minor == 0) /* blocks until port ready */
-		while (wrtSCI0(ch) != true); /* SCI0*/
-	else
-		while (wrtSCI1(ch) != true); /* SCI1*/
+  if (minor == 0) /* blocks until port ready */
+    while (wrtSCI0(ch) != true); /* SCI0*/
+  else
+    while (wrtSCI1(ch) != true); /* SCI1*/
 } /* sh_sci_outbyte_polled */
  * Initial version calls polled output driver and blocks
-void outbyte(
+static void outbyte(
   char ch)
-	sh_sci_outbyte_polled(minor, (unsigned char)ch);
+  sh_sci_outbyte_polled(minor, (unsigned char)ch);
 } /* outbyte */
-bool rdSCI0(unsigned char *ch)
+static bool rdSCI0(unsigned char *ch)
   uint8_t   temp;
@@ -225,7 +227,7 @@ bool rdSCI0(unsigned char *ch)
   return result;
 } /* rdSCI0 */
-bool rdSCI1(unsigned char *ch)
+static bool rdSCI1(unsigned char *ch)
   uint8_t   temp;
@@ -249,9 +251,8 @@ bool rdSCI1(unsigned char *ch)
   return result;
 } /* rdSCI1 */
 /* initial version pulls byte from selected port */
-char sh_sci_inbyte_polled( rtems_device_minor_number  minor )
+static char sh_sci_inbyte_polled( rtems_device_minor_number  minor )
   uint8_t ch = 0;
@@ -263,7 +264,7 @@ char sh_sci_inbyte_polled( rtems_device_minor_number  minor )
 } /* sh_sci_inbyte_polled */
 /* Initial version calls polled input driver */
-char inbyte( rtems_device_minor_number  minor )
+static char inbyte( rtems_device_minor_number  minor )
   char ch;
@@ -271,7 +272,6 @@ char inbyte( rtems_device_minor_number  minor )
   return ch;
 } /* inbyte */
 /*  sh_sci_initialize
  *  This routine initializes (registers) the sh_sci IO drivers.
@@ -283,9 +283,7 @@ char inbyte( rtems_device_minor_number  minor )
  *  Return values: RTEMS_SUCCESSFUL
  *   if all sci[...] register, else calls
  *   rtems_fatal_error_occurred(status)
 rtems_device_driver sh_sci_initialize(
   rtems_device_major_number  major,
@@ -295,7 +293,6 @@ rtems_device_driver sh_sci_initialize(
   rtems_device_minor_number i;
   rtems_driver_name_t driver;
    * register all possible devices.
    * the initialization of the hardware is done by sci_open
@@ -303,19 +300,17 @@ rtems_device_driver sh_sci_initialize(
    * One of devices could be previously registered by console
    * initialization therefore we check it everytime
-  for ( i = 0 ; i < SCI_MINOR_DEVICES ; i++ )
+  for ( i = 0 ; i < SCI_MINOR_DEVICES ; i++ ) {
     status = rtems_io_lookup_name(
         sci_device[i].name,
         &driver);
-    if ( status != RTEMS_SUCCESSFUL )
+    if ( status != RTEMS_SUCCESSFUL ) {
         /* OK. We assume it is not registered yet. */
         status = rtems_io_register_name(
             sci_device[i].name,
             major,
-            sci_device[i].minor );
+            sci_device[i].minor
         if (status != RTEMS_SUCCESSFUL)
             rtems_fatal_error_occurred(status);
@@ -326,31 +321,27 @@ rtems_device_driver sh_sci_initialize(
   return RTEMS_SUCCESSFUL;
  *  Open entry point
  *   Sets up port and pins for selected sci.
 rtems_device_driver sh_sci_open(
   void                    * arg )
-  uint8_t   temp8;
+  uint8_t    temp8;
   uint16_t   temp16;
-  unsigned 	a;
+  unsigned   a;
  /* check for valid minor number */
-   if (( minor > ( SCI_MINOR_DEVICES -1 )) || ( minor < 0 ))
-     return RTEMS_INVALID_NUMBER;
+ if (( minor > ( SCI_MINOR_DEVICES -1 )) || ( minor < 0 )) {
+   return RTEMS_INVALID_NUMBER;
   /* device already opened */
-  if ( sci_device[minor].opened > 0 )
+  if ( sci_device[minor].opened > 0 ) {
     sci_device[minor].opened++;
@@ -372,7 +363,7 @@ rtems_device_driver sh_sci_open(
   } /* add other devices and pins as req'd. */
   /* set up SCI registers */
-      write8(0x00, sci_device[minor].addr + SCI_SCR);	 /* Clear SCR */
+      write8(0x00, sci_device[minor].addr + SCI_SCR);   /* Clear SCR */
                                                    /* set SMR and BRR */
     _sci_set_cflags( &sci_device[minor], sci_device[minor].cflags );
@@ -381,7 +372,7 @@ rtems_device_driver sh_sci_open(
     write8((SCI_RE | SCI_TE),              /* enable async. Tx and Rx */
-	   sci_device[minor].addr + SCI_SCR);
+     sci_device[minor].addr + SCI_SCR);
     /* clear error flags */
     temp8 = read8(sci_device[minor].addr + SCI_SSR);
@@ -409,7 +400,6 @@ rtems_device_driver sh_sci_open(
  *  Close entry point
 rtems_device_driver sh_sci_close(
@@ -428,7 +418,6 @@ rtems_device_driver sh_sci_close(
  * read bytes from the serial port. We only have stdin.
 rtems_device_driver sh_sci_read(
@@ -460,7 +449,6 @@ rtems_device_driver sh_sci_read(
  * write bytes to the serial port. Stdout and stderr are the same.
 rtems_device_driver sh_sci_write(
@@ -491,7 +479,6 @@ rtems_device_driver sh_sci_write(
  *  IO Control entry point
 rtems_device_driver sh_sci_control(
@@ -573,7 +560,7 @@ const rtems_termios_callbacks sci_interrupt_callbacks;
 const rtems_termios_callbacks* sh_sci_get_termios_handlers( bool poll )
-    return poll ?
-        &sci_poll_callbacks :
-        &sci_interrupt_callbacks;
+  return poll ?
+      &sci_poll_callbacks :
+      &sci_interrupt_callbacks;
diff --git a/c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c b/c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c
index f2a32c9..db9040e 100644
--- a/c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c
+++ b/c/src/lib/libcpu/sh/sh7045/sci/sci_termios.c
@@ -1,6 +1,8 @@
  * Termios console serial driver.
  * Based on SCI driver by Ralf Corsepius and John M. Mills
  * Author: Radzislaw Galler <rgaller at et.put.poznan.pl>
@@ -124,7 +126,7 @@ int sh_sci_set_attributes(
  * The same routine for all interrupt sources of the same type.
-rtems_isr sh_sci_rx_isr(rtems_vector_number vector)
+static rtems_isr sh_sci_rx_isr(rtems_vector_number vector)
     int minor;
@@ -151,7 +153,7 @@ rtems_isr sh_sci_rx_isr(rtems_vector_number vector)
-rtems_isr sh_sci_tx_isr(rtems_vector_number vector)
+static rtems_isr sh_sci_tx_isr(rtems_vector_number vector)
     int minor;
diff --git a/c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c b/c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c
index a4fefae..c64dac5 100644
--- a/c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c
+++ b/c/src/lib/libcpu/sh/sh7750/sci/sh4uart.c
@@ -77,7 +77,7 @@ sh4uart_init(sh4uart *uart, void *tty, int chn, int int_driven)
  * RETURNS:
  *    peripheral module clock in Hz.
-uint32_t
+static uint32_t
 sh4uart_get_Pph(void)
   uint16_t   frqcr = *(volatile uint16_t*)SH7750_FRQCR;
@@ -418,7 +418,7 @@ sh4uart_set_attributes(sh4uart *uart, const struct termios *t)
  * RETURNS:
  *     nothing
-void
+static void
 sh4uart_handle_error(sh4uart *uart)
   if (uart->chn == SH4_SCI) {
@@ -451,7 +451,6 @@ int
 sh4uart_poll_read(sh4uart *uart)
   int chn = uart->chn;
-  int error_occured = 0;
   int parity_error = 0;
   int break_occured = 0;
   int ch;
@@ -464,7 +463,6 @@ sh4uart_poll_read(sh4uart *uart)
   if (chn == SH4_SCI) {
     if ((SCSSR1 & (SH7750_SCSSR1_PER | SH7750_SCSSR1_FER |
                  SH7750_SCSSR1_ORER)) != 0) {
-      error_occured = 1;
       if (SCSSR1 & (SH7750_SCSSR1_PER | SH7750_SCSSR1_FER))
         parity_error = 1;
       sh4uart_handle_error(uart);
@@ -475,7 +473,6 @@ sh4uart_poll_read(sh4uart *uart)
     if ((SCSSR2 & (SH7750_SCSSR2_ER | SH7750_SCSSR2_DR |
                  SH7750_SCSSR2_BRK)) != 0 ||
             (SCLSR2 & SH7750_SCLSR2_ORER) != 0) {
       if (SCSSR2 & (SH7750_SCSSR1_PER | SH7750_SCSSR1_FER))
         parity_error = 1;
       if (SCSSR2 & SH7750_SCSSR2_BRK)
diff --git a/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c b/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
index 91c1a31..823f538 100644
--- a/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
+++ b/c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c
@@ -1,6 +1,8 @@
  *  Support for SuperH Simulator in GDB
@@ -22,10 +24,11 @@
 register unsigned long  *stack_ptr __asm__ ("r15");
+void __ISR_Handler(uint32_t vector);
  *  This routine provides the RTEMS interrupt management.
 void __ISR_Handler( uint32_t   vector)
   ISR_Level level;
1.9.3
