[PATCH 53/62] powerpc/score603e: Fix warnings
Wed Oct 15 20:00:43 UTC 2014
 c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c   |    14 +-
 c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c |     2 +
 .../libbsp/powerpc/score603e/PCI_bus/universe.c    |    23 +-
 .../lib/libbsp/powerpc/score603e/console/console.c |    40 +-
 c/src/lib/libbsp/powerpc/score603e/cscope.out      | 11129 +++++++++++++++++++
 c/src/lib/libbsp/powerpc/score603e/include/bsp.h   |    88 +-
 c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c      |    11 +-
 7 files changed, 11197 insertions(+), 110 deletions(-)
 create mode 100644 c/src/lib/libbsp/powerpc/score603e/cscope.out
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c
index 817037e..999ab93 100644
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c
@@ -1,6 +1,5 @@
- *  COPYRIGHT (c) 1989-2009.
+ *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
@@ -25,10 +24,10 @@
  * an UNIVERSE register, without sufficient delay, the second access will
  * not work correctly.
-void PCI_bus_delay (void)
+static void PCI_bus_delay (void)
-  __asm__ ("	nop");
-  __asm__ (" nop");
+  __asm__ volatile ("nop");
@@ -43,7 +42,7 @@ void PCI_bus_write(
   *_addr = _data;
-uint32_t         PCI_bus_read(
+uint32_t PCI_bus_read(
   volatile uint32_t         *  _addr                  /* IN */
@@ -57,8 +56,7 @@ uint32_t         PCI_bus_read(
  * PCI Configuration Cycle Read/Write Access which is used to access all of
  * devices registers on the PCI bus.  i.e.: Universe, Ethernet & PMC.
-uint32_t         Read_pci_device_register(
+uint32_t Read_pci_device_register(
   uint32_t         address
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
index c50c09b..a2e084a 100644
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c
@@ -60,6 +60,7 @@ unsigned int SCORE603e_FLASH_verify_enable( void )
   return RTEMS_SUCCESSFUL;
+#if 0
 unsigned int SCORE603e_FLASH_pci_reset_reg(
   uint8_t          reg,
   uint32_t         cmask,
@@ -79,6 +80,7 @@ unsigned int SCORE603e_FLASH_pci_reset_reg(
+#endif
  *  SCORE603e_FLASH_Enable_writes
diff --git a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
index a1011da..c373aa6 100644
--- a/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
+++ b/c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c
@@ -16,22 +16,6 @@
 #include <bsp.h>
 #include "PCI.h"
- *********                  Prototypes                      *********
 typedef struct {
   uint32_t         PCI_ID;                 /* 0x80030000 */
   uint32_t         PCI_CSR;                /* 0x80030004 */
@@ -153,7 +137,6 @@ volatile Universe_Memory *UNIVERSE =
  * by the boot code.  This routine should be called by user code only if
  * a complete SCORE603e VME initialization is required.
 void initialize_universe(void)
   uint32_t         jumper_selection;
@@ -227,7 +210,7 @@ void set_vme_base_address (
  * Gets the VME base address
-uint32_t         get_vme_base_address (void)
+static uint32_t get_vme_base_address (void)
   volatile uint32_t         temp;
@@ -236,7 +219,7 @@ uint32_t         get_vme_base_address (void)
   return (temp);
-uint32_t         get_vme_slave_size(void)
+uint32_t get_vme_slave_size(void)
   temp  =  PCI_bus_read( &UNIVERSE->VSI0_BD);
@@ -249,7 +232,7 @@ uint32_t         get_vme_slave_size(void)
  * Set the size of the VME slave image
  * Note: The maximum size is up to 24 M bytes. (00000000 - 017FFFFF)
-void set_vme_slave_size (uint32_t         size)
+void set_vme_slave_size (uint32_t size)
diff --git a/c/src/lib/libbsp/powerpc/score603e/console/console.c b/c/src/lib/libbsp/powerpc/score603e/console/console.c
index 5ae61ea..afbc5b4 100644
--- a/c/src/lib/libbsp/powerpc/score603e/console/console.c
+++ b/c/src/lib/libbsp/powerpc/score603e/console/console.c
@@ -4,8 +4,10 @@
  *  This driver uses the termios pseudo driver.
  *  Currently only polled mode is supported.
@@ -36,14 +38,12 @@ int USE_FOR_CONSOLE = USE_FOR_CONSOLE_DEF;
  *  Console Device Driver Entry Points
-/* PAGE
  *  console_inbyte_nonblocking
  *  Console Termios polling input entry point.
-int console_inbyte_nonblocking(
+static int console_inbyte_nonblocking(
   int minor
@@ -164,8 +164,7 @@ void console_outbyte_interrupts(
 #endif
-/* PAGE
  *  console_initialize
  *  Routine called to initialize the console device driver.
@@ -178,7 +177,7 @@ rtems_device_driver console_initialize(
   rtems_status_code          status;
   rtems_device_minor_number  console;
-  int                        port, chip, p0,p1;
+  int                        port, p0,p1;
    * initialize the termio interface.
@@ -234,7 +233,6 @@ rtems_device_driver console_initialize(
   for (port=1; port<NUM_Z85C30_PORTS; port++) {
-   chip = port >> 1;
     initialize_85c30_port( &Ports_85C30[port] );
@@ -245,14 +243,13 @@ rtems_device_driver console_initialize(
-/* PAGE
  *  console_write_support
  *  Console Termios output entry point.
-ssize_t console_write_support(
+static ssize_t console_write_support(
   int   minor,
   const char *buf,
   size_t   len)
@@ -289,12 +286,10 @@ ssize_t console_write_support(
   return nwrite;
-/* PAGE
  *  console_open
  *  open a port as a termios console.
 rtems_device_driver console_open(
   rtems_device_major_number major,
@@ -354,19 +349,10 @@ rtems_device_driver console_open(
 #if (CONSOLE_USE_INTERRUPTS)
  *  console_outbyte_interrupts
  *  This routine transmits a character out.
- *  Input parameters:
- *    port - port to transmit character to
- *    ch  - character to be transmitted
- *  Output parameters:  NONE
- *  Return values:      NONE
   const Port_85C30_info *Port,
@@ -396,12 +382,10 @@ void console_outbyte_interrupts(
   Ring_buffer_Add_character( &protocol->TX_Buffer, ch );
 #endif
 /* const char arg to be compatible with BSP_output_char decl. */
-void
-debug_putc_onlcr(const char c)
+static void debug_putc_onlcr(const char c)
   int                      console;
   volatile uint8_t         *csr;
diff --git a/c/src/lib/libbsp/powerpc/score603e/cscope.out b/c/src/lib/libbsp/powerpc/score603e/cscope.out
new file mode 100644
index 0000000..80b31bd
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/score603e/cscope.out
@@ -0,0 +1,11129 @@
+cscope 15 $HOME/rtems-4.11-work/rtems/c/src/lib/libbsp/powerpc/score603e               0000068551
+	@PCI_bus/PCI.c
+10
+	~<¹ems.h
+11
+	~<as£¹.h
+12
+	~<¡dio.h
+14
+	~<b¥.h
+27
+	$PCI_bus_d–ay
+29
+__asm__
+ volatile ("nop");
+30
+__asm__
+ volatile ("nop");
+31
+36
+	$PCI_bus_wr™e
+37 vÞ©ž
+ušt32_t
+_addr
+38
+ušt32_t
+_d©a
+41
+_d©a
+	`CÚv”t_EndŸn_32
+( _data );
+42 *
+_addr
+_d©a
+43
+45
+ušt32_t
+	$PCI_bus_»ad
+46 vÞ©ž
+ušt32_t
+_addr
+49
+ušt32_t
+d©a
+51
+d©a
+_addr
+52
+d©a
+	`CÚv”t_EndŸn_32
+( data );
+53
+d©a
+54
+59
+ušt32_t
+	$R—d_pci_deviû_»gi¡”
+60
+ušt32_t
+add»ss
+63
+ušt32_t
+d©a
+68
+	`PCI_bus_wr™e
+Ð(vÞ©ž
+ušt32_t
+SCORE603E_PCI_IO_CFG_ADDR
+add»ss
+73
+	`PCI_bus_d–ay
+78
+d©a
+	`PCI_bus_»ad
+Ð(vÞ©ž
+ušt32_t
+SCORE603E_PCI_IO_CFG_DATA
+80
+d©a
+81
+83
+	$Wr™e_pci_deviû_»gi¡”
+84
+ušt32_t
+add»ss
+85
+ušt32_t
+d©a
+91
+	`PCI_bus_wr™e
+Ð(vÞ©ž
+ušt32_t
+add»ss
+96
+	`PCI_bus_d–ay
+101
+	`PCI_bus_wr™e
+Ð(vÞ©ž
+ušt32_t
+d©a
+102
+	@PCI_bus/PCI.h
+17 #iâdeà
+__PCI_h
+18
+	#__PCI_h
+24
+PCI_bus_wr™e
+25 vÞ©ž
+ušt32_t
+_addr
+26
+ušt32_t
+_d©a
+29
+ušt32_t
+PCI_bus_»ad
+30 vÞ©ž
+ušt32_t
+_addr
+33
+ušt32_t
+R—d_pci_deviû_»gi¡”
+34
+ušt32_t
+add»ss
+37
+Wr™e_pci_deviû_»gi¡”
+38
+ušt32_t
+add»ss
+39
+ušt32_t
+d©a
+	@PCI_bus/flash.c
+10
+	~<¹ems.h
+11
+	~<as£¹.h
+12
+	~<¡dio.h
+13
+	~<š‰y³s.h
+15
+	~<b¥.h
+16
+	~<b¥/œq.h
+17
+	~"PCI.h
+22
+	$SCORE603e_FLASH_Di§bË
+23
+ušt32_t
+26
+ušt8_t
+v®ue
+28
+v®ue
+SCORE603E_BOARD_CTRL_REG
+29
+v®ue
+ = v®u| (~
+SCORE603E_BRD_FLASH_DISABLE_MASK
+30 *
+v®ue
+32
+RTEMS_SUCCESSFUL
+33
+35
+	$SCORE603e_FLASH_v”ify_’abË
+37 vÞ©ž
+ušt8_t
+CŒl_Stus_Regi¡”
+38 (*)
+39
+ušt8_t
+ù¾_v®ue
+40
+ušt32_t
+pci_v®ue
+42
+ù¾_v®ue
+CŒl_Stus_Regi¡”
+43 iàÐ
+ù¾_v®ue
+44
+	`´štf
+ ("Flash Writes Disabled by board control„egister %x\n",
+45
+ù¾_v®ue
+46
+	`as£¹
+( 0x0 );
+49
+pci_v®ue
+	`R—d_pci_deviû_»gi¡”
+( 0x800000A8 );
+50 ià(Ð
+pci_v®ue
+ & 0x00001000 ) == 0) {
+51
+	`´štf
+("Error PCI A8 \n");
+52
+	`as£¹
+( 0x0 );
+55
+pci_v®ue
+( 0x800000AC );
+56 iàÐ
+pci_v®ue
+ & 0x02000000) {
+57
+	`´štf
+("Error PCI AC \n");
+58
+	`as£¹
+( 0x0 );
+60
+RTEMS_SUCCESSFUL
+61
+64
+	$SCORE603e_FLASH_pci_»£t_»g
+65
+ušt8_t
+»g
+66
+ušt32_t
+cmask
+67
+ušt32_t
+mask
+70
+ušt32_t
+pci_v®ue
+71
+ušt32_t
+v®ue
+73
+pci_v®ue
+Ð
+»g
+74
+pci_v®ue
+ &ð
+cmask
+75
+pci_v®ue
+ |ð
+mask
+76
+	`Wr™e_pci_deviû_»gi¡”
+Ð
+»g
+pci_v®ue
+77
+v®ue
+Ð
+»g
+78 ià(
+v®ue
+ !ð
+pci_v®ue
+79
+	`´štf
+("E¼Ü PCI 0x%2"
+PRIX8
+" wrِ0x%8"
+PRIX32
+"„—d %8"PRIX32"\n",
+»g
+pci_v®ue
+v®ue
+81
+RTEMS_SUCCESSFUL
+82
+88
+	$SCORE603e_FLASH_EÇbË_wr™es
+89
+ušt32_t
+92
+ušt8_t
+ù¾_v®ue
+93
+ušt32_t
+pci_v®ue
+95
+ù¾_v®ue
+96
+ù¾_v®ue
+ = ctrl_value & 0xbf;
+97 *
+ù¾_v®ue
+99
+pci_v®ue
+( 0x800000A8 );
+100
+pci_v®ue
+ |= 0x00001000;
+101
+Ð0x800000A8,
+pci_v®ue
+103
+pci_v®ue
+( 0x800000AC );
+104
+pci_v®ue
+ &= (~0x02000000);
+105
+Ð0x000000AC,
+pci_v®ue
+107
+RTEMS_SUCCESSFUL
+108
+	@PCI_bus/universe.c
+10
+	~<¹ems.h
+11
+	~<as£¹.h
+12
+	~<¡dio.h
+13
+	~<š‰y³s.h
+14
+	~<¹ems/b¥Io.h
+16
+	~<b¥.h
+17
+	~"PCI.h
+20
+ušt32_t
+	mPCI_ID
+21
+ušt32_t
+	mPCI_CSR
+22
+ušt32_t
+	mPCI_CLASS
+23
+ušt32_t
+	mPCI_MISC0
+24
+ušt32_t
+	mPCI_BS
+25
+ušt32_t
+	mBuf_0x80030014
+[ 0x0A ];
+26
+ušt32_t
+	mPCI_MISC1
+27
+ušt32_t
+	mBuf_0x80030040
+[ 0x30 ];
+28
+ušt32_t
+	mLSI0_CTL
+29
+ušt32_t
+	mLSI0_BS
+30
+ušt32_t
+	mLSI0_BD
+31
+ušt32_t
+	mLSI0_TO
+32
+ušt32_t
+	mBuf_0x80030110
+33
+ušt32_t
+	mLSI1_CTL
+34
+ušt32_t
+	mLSI1_BS
+35
+ušt32_t
+	mLSI1_BD
+36
+ušt32_t
+	mLSI1_TO
+37
+ušt32_t
+	mBuf_0x80030124
+38
+ušt32_t
+	mLSI2_CTL
+39
+ušt32_t
+	mLSI2_BS
+40
+ušt32_t
+	mLSI2_BD
+41
+ušt32_t
+	mLSI2_TO
+42
+ušt32_t
+	mBuf_0x80030138
+43
+ušt32_t
+	mLSI3_CTL
+44
+ušt32_t
+	mLSI3_BS
+45
+ušt32_t
+	mLSI3_BD
+46
+ušt32_t
+	mLSI3_TO
+47
+ušt32_t
+	mBuf_0x8003014C
+[ 0x09 ];
+48
+ušt32_t
+	mSCYC_CTL
+49
+ušt32_t
+	mSCYC_ADDR
+50
+ušt32_t
+	mSCYC_EN
+51
+ušt32_t
+	mSCYC_CMP
+52
+ušt32_t
+	mSCYC_SWP
+53
+ušt32_t
+	mLMISC
+54
+ušt32_t
+	mSLSI
+55
+ušt32_t
+	mL_CMDERR
+56
+ušt32_t
+	mLAERR
+57
+ušt32_t
+	mBuf_0x80030194
+[ 0x1B ];
+58
+ušt32_t
+	mDCTL
+59
+ušt32_t
+	mDTBC
+60
+ušt32_t
+	mDLA
+61
+ušt32_t
+	mBuf_0x8003020C
+62
+ušt32_t
+	mDVA
+63
+ušt32_t
+	mBuf_0x80030214
+64
+ušt32_t
+	mDCPP
+65
+ušt32_t
+	mBuf_0x8003021C
+66
+ušt32_t
+	mDGCS
+67
+ušt32_t
+	mD_LLUE
+68
+ušt32_t
+	mBuf_0x80030228
+[ 0x36 ];
+69
+ušt32_t
+	mLINT_EN
+70
+ušt32_t
+	mLINT_STAT
+71
+ušt32_t
+	mLINT_MAP0
+72
+ušt32_t
+	mLINT_MAP1
+73
+ušt32_t
+	mVINT_EN
+74
+ušt32_t
+	mVINT_STAT
+75
+ušt32_t
+	mVINT_MAP0
+76
+ušt32_t
+	mVINT_MAP1
+77
+ušt32_t
+	mSTATID
+78
+ušt32_t
+	mV1_STATID
+79
+ušt32_t
+	mV2_STATID
+80
+ušt32_t
+	mV3_STATID
+81
+ušt32_t
+	mV4_STATID
+82
+ušt32_t
+	mV5_STATID
+83
+ušt32_t
+	mV6_STATID
+84
+ušt32_t
+	mV7_STATID
+85
+ušt32_t
+	mBuf_0x80030340
+[ 0x30 ];
+86
+ušt32_t
+	mMAST_CTL
+87
+ušt32_t
+	mMISC_CTL
+88
+ušt32_t
+	mMISC_STAT
+89
+ušt32_t
+	mUSER_AM
+90
+ušt32_t
+	mBuf_0x80030410
+[ 0x2bc ];
+91
+ušt32_t
+	mVSI0_CTL
+92
+ušt32_t
+	mVSI0_BS
+93
+ušt32_t
+	mVSI0_BD
+94
+ušt32_t
+	mVSI0_TO
+95
+ušt32_t
+	mBuf_0x80030f10
+96
+ušt32_t
+	mVSI1_CTL
+97
+ušt32_t
+	mVSI1_BS
+98
+ušt32_t
+	mVSI1_BD
+99
+ušt32_t
+	mVSI1_TO
+100
+ušt32_t
+	mBuf_0x80030F24
+101
+ušt32_t
+	mVSI2_CTL
+102
+ušt32_t
+	mVSI2_BS
+103
+ušt32_t
+	mVSI2_BD
+104
+ušt32_t
+	mVSI2_TO
+105
+ušt32_t
+	mBuf_0x80030F38
+106
+ušt32_t
+	mVSI3_CTL
+107
+ušt32_t
+	mVSI3_BS
+108
+ušt32_t
+	mVSI3_BD
+109
+ušt32_t
+	mVSI3_TO
+110
+ušt32_t
+	mBuf_0x80030F4C
+[ 0x9 ];
+111
+ušt32_t
+	mVRAI_CTL
+112
+ušt32_t
+	mVRAI_BS
+113
+ušt32_t
+	mBuf_0x80030F78
+[ 0x2 ];
+114
+ušt32_t
+	mVCSR_CTL
+115
+ušt32_t
+	mVCSR_TO
+116
+ušt32_t
+	mV_AMERR
+117
+ušt32_t
+	mVAERR
+118
+ušt32_t
+	mBuf_0x80030F90
+[ 0x19 ];
+119
+ušt32_t
+	mVCSR_CLR
+120
+ušt32_t
+	mVCSR_SET
+121
+ušt32_t
+	mVCSR_BS
+122 }
+	tUniv”£_MemÜy
+124 vÞ©ž
+Univ”£_MemÜy
+	gUNIVERSE
+125 (vÞ©ž
+Univ”£_MemÜy
+SCORE603E_UNIVERSE_BASE
+140
+	$š™Ÿlize_univ”£
+142
+ušt32_t
+jum³r_£ËùiÚ
+143
+ušt32_t
+pci_id
+148
+jum³r_£ËùiÚ
+	`PCI_bus_»ad
+149 (vÞ©ž
+ušt32_t
+SCORE603E_VME_JUMPER_ADDR
+150
+	`´štk
+("initialize_universe: Read 0x%x = 0x%x\n",
+151
+jum³r_£ËùiÚ
+152
+jum³r_£ËùiÚ
+ = (jumper_selection >> 3) & 0x1f;
+157
+pci_id
+Ð
+SCORE603E_IO_VME_UNIVERSE_BASE
+162 ià(
+pci_id
+ !ð
+SCORE603E_UNIVERSE_CHIP_ID
+163
+	`´štk
+ ("Inv®id SCORE603E_UNIVERSE_CHIP_ID: 0x08%"
+PRId32
+ "\n",
+pci_id
+164
+	`¹ems_çl_”rÜ_occu¼ed
+( 0x603e0bad );
+166
+	`´štk
+("initialize_universe: Reg 0x%x„ead 0x%x\n",
+167
+pci_id
+173
+180
+	$£t_vme_ba£_add»ss
+181
+ušt32_t
+ba£_add»ss
+184 vÞ©ž
+ušt32_t
+‹mp
+189
+‹mp
+	`PCI_bus_»ad
+Ð&
+UNIVERSE
+VSI0_BD
+) & 0xFFFFF000) -
+190 Ð
+	`PCI_bus_»ad
+Ð&
+UNIVERSE
+VSI0_BS
+) & 0xFFFFF000);
+196
+	`PCI_bus_wr™e
+Ð&
+UNIVERSE
+VSI0_BS
+ba£_add»ss
+ & 0xFFFFF000) );
+201
+	`PCI_bus_wr™e
+Ð&
+UNIVERSE
+VSI0_BD
+‹mp
+206
+‹mp
+ = 0xFFFFFFFF - (
+ba£_add»ss
+ & 0xFFFFF000) + 1 + 0x80000000;
+207
+	`PCI_bus_wr™e
+Ð&
+UNIVERSE
+VSI0_TO
+‹mp
+208
+213
+ušt32_t
+	$g‘_vme_ba£_add»ss
+215 vÞ©ž
+ušt32_t
+‹mp
+217
+‹mp
+	`PCI_bus_»ad
+Ð&
+UNIVERSE
+VSI0_BS
+218
+‹mp
+ &= 0xFFFFF000;
+219  (
+‹mp
+220
+222
+ušt32_t
+	$g‘_vme_¦ave_size
+224 vÞ©ž
+ušt32_t
+‹mp
+225
+‹mp
+	`PCI_bus_»ad
+Ð&
+UNIVERSE
+VSI0_BD
+226
+‹mp
+ &= 0xFFFFF000;
+227
+‹mp
+ =em°-
+	`g‘_vme_ba£_add»ss
+228
+‹mp
+229
+235
+	$£t_vme_¦ave_size
+ušt32_t
+size
+237 vÞ©ž
+ušt32_t
+‹mp
+239 ià(
+size
+<0)
+240
+size
+ = 0;
+242 ià(
+size
+ > 0x17FFFFF)
+243
+size
+ = 0x17FFFFF;
+248
+‹mp
+253
+‹mp
+ =em°+ (
+size
+ & 0xFFFFF000);
+254
+	`PCI_bus_wr™e
+Ð&
+UNIVERSE
+VSI0_BD
+‹mp
+255
+	@console/85c30.c
+17
+	~<¹ems.h
+18
+	~<b¥.h
+19
+	~<¹ems/libio.h
+20
+	~<as£¹.h
+22
+	~"85c30.h
+23
+	~"cÚsÞeb¥.h
+25
+	#STATUS_REGISTER
+ 0x00
+26
+	#DATA_REGISTER
+ 0x08
+28
+	#Z8530_Stus_Is_RX_ch¬aù”_avažabË
+Ð
+_¡©us
+29 Ð(
+_¡©us
+è& 0x01 )
+31
+	#Z8530_Stus_Is_TX_bufãr_em±y
+Ð
+_¡©us
+32 Ð(
+_¡©us
+è& 0x04 )
+34
+	#Z8530_Stus_Is_b»ak_abÜt
+Ð
+_¡©us
+35 Ð(
+_¡©us
+è& 0x80 )
+38
+	m»ad_£tup
+39
+	mwr™e_£tup
+40
+	mmask_v®ue
+41 }
+	tch¬_size_šfo
+43 cÚ¡
+ch¬_size_šfo
+	gCh¬_size_85c30
+44 {
+Z8530_READ_CHARACTER_BITS_8
+Z8530_WRITE_CHARACTER_BITS_8
+, 0xFF },
+45 {
+Z8530_READ_CHARACTER_BITS_7
+Z8530_WRITE_CHARACTER_BITS_7
+, 0x7F },
+46 {
+Z8530_READ_CHARACTER_BITS_6
+Z8530_WRITE_CHARACTER_BITS_6
+, 0x3F },
+47 {
+Z8530_READ_CHARACTER_BITS_5
+Z8530_WRITE_CHARACTER_BITS_5
+, 0x1F }
+50 cÚ¡
+	gClock_¥“d_85c30
+51
+Z8530_x1_CLOCK
+Z8530_x16_CLOCK
+Z8530_x32_CLOCK
+Z8530_x64_CLOCK
+53 cÚ¡
+	gStÝ_b™_85c30
+54
+Z8530_STOP_BITS_1
+Z8530_STOP_BITS_1_AND_A_HALF
+Z8530_STOP_BITS_2
+56 cÚ¡
+	gPªy_85c30
+57
+Z8530_PARITY_NONE
+Z8530_PARITY_ODD
+Z8530_PARITY_EVEN
+65
+	$R—d_85c30_»gi¡”
+66 vÞ©ž*
+c¤
+67
+»gi¡”_numb”
+70
+D©a
+72 *
+c¤
+»gi¡”_numb”
+74
+	`¹ems_b¥_d–ay_š_bus_cyþes
+( 40 );
+76
+D©a
+c¤
+78
+( 40 );
+80
+D©a
+81
+88
+	$Wr™e_85c30_»gi¡”
+89 vÞ©ž*
+c¤
+90
+»gi¡”_numb”
+91
+d©a
+94 *
+c¤
+»gi¡”_numb”
+96
+( 40 );
+97 *
+c¤
+d©a
+98
+( 40 );
+99
+108
+	$Re£t_85c30_ch
+109 vÞ©ž*
+ù¾_0
+110 vÞ©ž*
+ù¾_1
+113
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾_0
+, 0x09, 0x80 );
+114
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾_1
+, 0x09, 0x40 );
+115
+123
+	$š™Ÿlize_85c30_pÜt
+124 cÚ¡
+PÜt_85C30_šfo
+PÜt
+127
+ušt16_t
+v®ue
+128 vÞ©ž*
+ù¾
+129
+CÚsÞe_PrÙocÞ
+S‘up
+130
+ušt16_t
+baud_cÚ¡ªt
+132
+S‘up
+PÜt
+PrÙocÞ
+133
+ù¾
+PÜt
+->ctrl;
+135
+baud_cÚ¡ªt
+	`_ScÜe603e_Z8530_Baud
+Ð
+PÜt
+Ch
+þock_äequ’cy
+136
+PÜt
+Ch
+þock_x
+S‘up
+baud_¿‹
+142
+v®ue
+Clock_¥“d_85c30
+PÜt
+Ch
+þock_¥“d
+143
+StÝ_b™_85c30
+S‘up
+¡Ý_b™s
+144
+Pªy_85c30
+S‘up
+·r™y
+145
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x04,
+v®ue
+150
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 1, 0 );
+152 #ià
+CONSOLE_USE_INTERRUPTS
+156
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 2,
+PÜt
+Ch
+veùÜ
+162
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x03, 0x00 );
+167
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 5, 0x00 );
+176
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 9, 0x00 );
+181
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x0a, 0x00 );
+188
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x0b, 0x56 );
+190
+v®ue
+baud_cÚ¡ªt
+197
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x0c,
+v®ue
+ & 0xff );
+203
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x0d,
+v®ue
+>>8 );
+211
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x0e, 0x07 );
+223
+v®ue
+ = 0x01;
+224
+v®ue
+ = v®u|
+Ch¬_size_85c30
+S‘up
+»ad_ch¬_b™s
+»ad_£tup
+226
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x03,
+v®ue
+238
+v®ue
+ = 0x8a;
+239
+v®ue
+ = v®u|
+Ch¬_size_85c30
+S‘up
+wr™e_ch¬_b™s
+wr™e_£tup
+240
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x05,
+v®ue
+246
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x00, 0xf0 );
+248 #ià
+252
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 1, 0x10 );
+259
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 15, 0x00 );
+264
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 0x00, 0x10 );
+266 #ià
+274
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 1, 0x16 );
+280
+	`Wr™e_85c30_»gi¡”
+Ð
+ù¾
+, 9, 0x0A );
+287
+	`Wr™e_85c30_»gi¡”
+Ð
+PÜt
+ù¾
+STATUS_REGISTER
+, 0x38 );
+291
+300
+	$outby‹_pÞËd_85c30
+301 vÞ©ž*
+c¤
+302
+ch
+305
+z8530_¡©us
+306
+ušt32_t
+i¤Ëv–
+308
+	`¹ems_š‹¼u±_di§bË
+Ð
+i¤Ëv–
+314
+z8530_¡©us
+	`R—d_85c30_»gi¡”
+Ð
+c¤
+STATUS_REGISTER
+315 }  !
+	`Z8530_Stus_Is_TX_bufãr_em±y
+Ð
+z8530_¡©us
+320
+	`Wr™e_85c30_»gi¡”
+Ð
+c¤
+DATA_REGISTER
+, (è
+ch
+322
+	`¹ems_š‹¼u±_’abË
+Ð
+i¤Ëv–
+323
+332
+	$šby‹_nÚblockšg_85c30
+333 cÚ¡
+PÜt_85C30_šfo
+PÜt
+336 vÞ©ž*
+c¤
+337
+z8530_¡©us
+338
+ušt8_t
+d©a
+340
+c¤
+PÜt
+ù¾
+345
+z8530_¡©us
+	`R—d_85c30_»gi¡”
+Ð
+c¤
+STATUS_REGISTER
+346 iàÐ!
+	`Z8530_Stus_Is_RX_ch¬aù”_avažabË
+Ð
+z8530_¡©us
+352
+d©a
+	`R—d_85c30_»gi¡”
+Ð
+c¤
+DATA_REGISTER
+353
+d©a
+ &ð
+Ch¬_size_85c30
+PÜt
+PrÙocÞ
+»ad_ch¬_b™s
+mask_v®ue
+355
+d©a
+356
+362 #ià
+369
+¹ems_i¤
+	$ISR_85c30_Async
+370 cÚ¡
+PÜt_85C30_šfo
+PÜt
+373
+ušt16_t
+¡©us
+374 vÞ©ž
+CÚsÞe_PrÙocÞ
+PrÙocÞ
+375
+d©a
+376
+boÞ
+did_som‘hšg
+çl£
+378
+PrÙocÞ
+PÜt
+->Protocol;
+380
+¡©us
+	`R—d_85c30_»gi¡”
+Ð
+PÜt
+ù¾
+, 0x00 );
+386 iàÐ
+Ð
+¡©us
+387
+d©a
+	`R—d_85c30_»gi¡”
+Ð
+PÜt
+ù¾
+DATA_REGISTER
+388
+d©a
+ &ð
+Ch¬_size_85c30
+PÜt
+PrÙocÞ
+»ad_ch¬_b™s
+mask_v®ue
+390
+	`¹ems_‹rmios_’queue_¿w_ch¬aù”s
+Ð
+PÜt
+PrÙocÞ
+cÚsÞe_‹rmios_d©a
+391 &
+d©a
+, 1 );
+392
+did_som‘hšg
+Œue
+399 ià(
+Ð
+¡©us
+400 iàÐ!
+	`Ršg_bufãr_Is_em±y
+Ð&
+PrÙocÞ
+TX_Bufãr
+401
+	`Ršg_bufãr_Remove_ch¬aù”
+Ð&
+PrÙocÞ
+TX_Bufãr
+d©a
+402
+	`Wr™e_85c30_»gi¡”
+Ð
+PÜt
+ù¾
+DATA_REGISTER
+d©a
+405
+PrÙocÞ
+Is_TX_aùive
+çl£
+406
+	`Wr™e_85c30_»gi¡”
+Ð
+PÜt
+ù¾
+STATUS_REGISTER
+, 0x28 );
+409
+did_som‘hšg
+Œue
+419
+	`Wr™e_85c30_»gi¡”
+Ð
+PÜt
+ù¾
+STATUS_REGISTER
+, 0x38 );
+420
+	@console/85c30.h
+13 #iâdeà
+__85c30_H
+14
+	#__85c30_H
+20
+	#Z8530_x1_CLOCK
+ 0x00
+21
+	#Z8530_x16_CLOCK
+ 0x40
+22
+	#Z8530_x32_CLOCK
+ 0x80
+23
+	#Z8530_x64_CLOCK
+ 0xC0
+28
+	#Z8530_STOP_BITS_1
+ 0x04
+29
+	#Z8530_STOP_BITS_1_AND_A_HALF
+ 0x08
+30
+	#Z8530_STOP_BITS_2
+ 0x0C
+35
+	#Z8530_PARITY_NONE
+ 0x00
+36
+	#Z8530_PARITY_ODD
+ 0x01
+37
+	#Z8530_PARITY_EVEN
+ 0x03
+42
+	#Z8530_READ_CHARACTER_BITS_8
+ 0xC0
+43
+	#Z8530_READ_CHARACTER_BITS_7
+ 0x40
+44
+	#Z8530_READ_CHARACTER_BITS_6
+ 0x80
+45
+	#Z8530_READ_CHARACTER_BITS_5
+ 0x00
+47
+	#Z8530_WRITE_CHARACTER_BITS_8
+ 0x60
+48
+	#Z8530_WRITE_CHARACTER_BITS_7
+ 0x20
+49
+	#Z8530_WRITE_CHARACTER_BITS_6
+ 0x40
+50
+	#Z8530_WRITE_CHARACTER_BITS_5
+ 0x00
+	@console/console.c
+18
+	~<b¥.h
+19
+	~<¹ems/libio.h
+20
+	~<¡dlib.h
+21
+	~<as£¹.h
+23
+	~"cÚsÞeb¥.h
+24
+	~<¹ems/b¥Io.h
+33
+	#USE_FOR_CONSOLE_DEF
+ 0
+34
+	gUSE_FOR_CONSOLE
+USE_FOR_CONSOLE_DEF
+46
+	$cÚsÞe_šby‹_nÚblockšg
+47
+mšÜ
+50
+pÜt
+mšÜ
+55
+	`as£¹
+pÜt
+NUM_Z85C30_PORTS
+60
+	`šby‹_nÚblockšg_85c30
+Ð&
+PÜts_85C30
+pÜt
+61
+63
+¹ems_deviû_driv”
+	$cÚsÞe_þo£
+64
+¹ems_deviû_majÜ_numb”
+majÜ
+65
+¹ems_deviû_mšÜ_numb”
+mšÜ
+66 *
+¬g
+69
+	`¹ems_‹rmios_þo£
+¬g
+70
+72
+¹ems_deviû_driv”
+	$cÚsÞe_»ad
+73
+majÜ
+74
+mšÜ
+75 *
+¬g
+78
+	`¹ems_‹rmios_»ad
+¬g
+79
+81
+¹ems_deviû_driv”
+	$cÚsÞe_wr™e
+82
+majÜ
+83
+mšÜ
+84 *
+¬g
+87
+	`¹ems_‹rmios_wr™e
+¬g
+88
+90
+¹ems_deviû_driv”
+	$cÚsÞe_cÚŒÞ
+91
+majÜ
+92
+mšÜ
+93 *
+¬g
+96
+	`¹ems_‹rmios_ioùl
+¬g
+97
+103 #ià
+105
+¹ems_i¤
+	$cÚsÞe_i¤
+106
+¹ems_veùÜ_numb”
+veùÜ
+109
+i
+111
+i
+=0; i <
+NUM_Z85C30_PORTS
+; i++){
+112
+	`ISR_85c30_Async
+Ð&
+PÜts_85C30
+i
+114
+116
+	$cÚsÞe_ex™
+118
+i
+119 vÞ©ž
+Ršg_bufãr_t
+bufãr
+120
+ušt32_t
+ch
+122
+i
+=0 ; i <
+NUM_Z85C30_PORTS
+ ; i++ ) {
+124
+bufãr
+ = &Ð
+PÜts_85C30
+i
+PrÙocÞ
+TX_Bufãr
+126  !
+Ð
+bufãr
+127
+Ð
+bufãr
+ch
+128
+	`outby‹_pÞËd_85c30
+Ð
+PÜts_85C30
+i
+ù¾
+ch
+131
+133
+	$cÚsÞe_š™Ÿlize_š‹¼u±s
+135 vÞ©ž
+Ršg_bufãr_t
+bufãr
+136
+CÚsÞe_PrÙocÞ
+´ÙocÞ
+137
+i
+139
+i
+=0 ; i <
+NUM_Z85C30_PORTS
+ ; i++ ) {
+140
+´ÙocÞ
+PÜts_85C30
+i
+PrÙocÞ
+145
+bufãr
+´ÙocÞ
+TX_Bufãr
+146
+	`Ršg_bufãr_In™Ÿlize
+Ð
+bufãr
+147
+´ÙocÞ
+Is_TX_aùive
+çl£
+153
+i
+=0; i <
+NUM_Z85C30_CHIPS
+; i++)
+154
+	`£t_veùÜ
+Ð
+cÚsÞe_i¤
+Chs_85C30
+i
+veùÜ
+, 1 );
+157
+	`©ex™
+Ð
+cÚsÞe_ex™
+159
+160
+cÚsÞe_outby‹_š‹¼u±s
+161 cÚ¡
+PÜt_85C30_šfo
+PÜt
+162
+ch
+172
+¹ems_deviû_driv”
+	$cÚsÞe_š™Ÿlize
+173
+majÜ
+174
+mšÜ
+175 *
+¬g
+178
+¹ems_¡©us_code
+¡©us
+179
+cÚsÞe
+180
+pÜt
+p0
+p1
+185
+	`¹ems_‹rmios_š™Ÿlize
+190
+cÚsÞe
+USE_FOR_CONSOLE
+191
+¡©us
+	`¹ems_io_»gi¡”_Çme
+Ð"/dev/cÚsÞe",
+majÜ
+cÚsÞe
+192 ià(
+¡©us
+ !ð
+RTEMS_SUCCESSFUL
+193
+¡©us
+205 #iàÐ
+INITIALIZE_COM_PORTS
+211
+pÜt
+=0;…Üt<
+NUM_Z85C30_PORTS
+;…ort++){
+212
+p0
+pÜt
+213
+pÜt
+214
+p1
+pÜt
+215
+	`Re£t_85c30_ch
+Ð
+PÜts_85C30
+p0
+ù¾
+, PÜts_85C30[
+p1
+].ctrl );
+221
+pÜt
+=2;…Üt<
+NUM_Z85C30_PORTS
+;…ort++){
+222
+p0
+pÜt
+223
+pÜt
+224
+p1
+pÜt
+225
+	`Re£t_85c30_ch
+Ð
+PÜts_85C30
+p0
+ù¾
+, PÜts_85C30[
+p1
+].ctrl );
+235
+pÜt
+=1;…Üt<
+NUM_Z85C30_PORTS
+;…ort++) {
+236
+	`š™Ÿlize_85c30_pÜt
+Ð&
+PÜts_85C30
+pÜt
+239 #ià
+240
+	`cÚsÞe_š™Ÿlize_š‹¼u±s
+243
+RTEMS_SUCCESSFUL
+244
+252
+ssize_t
+	$cÚsÞe_wr™e_suµÜt
+253
+mšÜ
+254 cÚ¡ *
+buf
+255
+size_t
+Ën
+257
+nwr™e
+ = 0;
+258 vÞ©ž
+ušt8_t
+c¤
+259
+pÜt
+mšÜ
+264
+	`as£¹
+pÜt
+NUM_Z85C30_PORTS
+269
+c¤
+PÜts_85C30
+pÜt
+ù¾
+274
+nwr™e
+Ën
+275 #ià(
+276
+	`cÚsÞe_outby‹_š‹¼u±s
+Ð&
+PÜts_85C30
+pÜt
+buf
+278
+Ð
+c¤
+buf
+280
+nwr™e
+286
+nwr™e
+287
+294
+¹ems_deviû_driv”
+	$cÚsÞe_Ý’
+295
+majÜ
+296
+mšÜ
+297 *
+¬g
+300
+¹ems_¡©us_code
+sc
+301
+pÜt
+mšÜ
+302 #ià(
+303
+¹ems_libio_Ý’_þo£_¬gs_t
+¬gs
+¬g
+304 cÚ¡
+¹ems_‹rmios_ÿÎbacks
+šŒC®lbacks
+305
+NULL
+306
+NULL
+307
+NULL
+308
+cÚsÞe_wr™e_suµÜt
+309
+NULL
+310
+NULL
+311
+NULL
+315 cÚ¡
+pÞlC®lbacks
+316
+NULL
+317
+NULL
+318
+cÚsÞe_šby‹_nÚblockšg
+319
+cÚsÞe_wr™e_suµÜt
+320
+NULL
+321
+NULL
+322
+NULL
+330 ià(
+mšÜ
+ < 0)
+331
+RTEMS_INVALID_NUMBER
+333 iàÐ
+pÜt
+NUM_Z85C30_PORTS
+334
+340 #ià(
+341
+sc
+	`¹ems_‹rmios_Ý’
+Ð
+majÜ
+mšÜ
+¬g
+šŒC®lbacks
+343
+PÜts_85C30
+mšÜ
+PrÙocÞ
+cÚsÞe_‹rmios_d©a
+¬gs
+iÝ
+d©a1
+345
+sc
+	`¹ems_‹rmios_Ý’
+Ð
+majÜ
+mšÜ
+¬g
+pÞlC®lbacks
+348
+sc
+349
+351 #ià(
+357
+	$cÚsÞe_outby‹_š‹¼u±s
+358 cÚ¡
+PÜt_85C30_šfo
+PÜt
+359
+ch
+362
+CÚsÞe_PrÙocÞ
+´ÙocÞ
+363
+ušt32_t
+i¤Ëv–
+365
+´ÙocÞ
+PÜt
+PrÙocÞ
+371 iàÐ
+´ÙocÞ
+Is_TX_aùive
+ =ð
+çl£
+373
+	`¹ems_š‹¼u±_di§bË
+Ð
+i¤Ëv–
+374
+´ÙocÞ
+Is_TX_aùive
+Œue
+375
+Ð
+PÜt
+ù¾
+ch
+376
+	`¹ems_š‹¼u±_’abË
+Ð
+i¤Ëv–
+381
+	`Ršg_bufãr_Is_fuÎ
+Ð&
+´ÙocÞ
+TX_Bufãr
+383
+	`Ršg_bufãr_Add_ch¬aù”
+Ð&
+´ÙocÞ
+TX_Bufãr
+ch
+384
+388
+	$debug_putc_Úlü
+(cÚ¡
+c
+390
+cÚsÞe
+391 vÞ©ž
+ušt8_t
+c¤
+392
+ušt32_t
+i¤Ëv–
+394
+cÚsÞe
+USE_FOR_CONSOLE
+395
+c¤
+PÜts_85C30
+cÚsÞe
+ù¾
+397 ià('\n'==
+c
+398
+	`¹ems_š‹¼u±_di§bË
+Ð
+i¤Ëv–
+399
+Ð
+c¤
+, '\r' );
+400
+__asm__
+ volatile("isync");
+401
+	`¹ems_š‹¼u±_’abË
+Ð
+i¤Ëv–
+404
+	`¹ems_š‹¼u±_di§bË
+Ð
+i¤Ëv–
+405
+Ð
+c¤
+c
+406
+__asm__
+407
+	`¹ems_š‹¼u±_’abË
+Ð
+i¤Ëv–
+408
+410
+BSP_ouut_ch¬_funùiÚ_ty³
+	gBSP_ouut_ch¬
+debug_putc_Úlü
+411
+BSP_pÞlšg_g‘ch¬_funùiÚ_ty³
+	gBSP_pÞl_ch¬
+NULL
+	@console/consolebsp.h
+13 #iâdeà
+__CONSOLEBSP_H
+14
+	#__CONSOLEBSP_H
+16
+	~<¹ems.h
+17
+	~<¹ems/ršgbuf.h
+18
+	~<b¥.h
+20 #ifdeà
+__ýlu¥lus
+35 #ià(
+HAS_PMC_PSC8
+36
+	#NUM_Z85C30_CHIPS_ON_MEZZANINE
+ 4
+38
+ 0
+41
+	#NUM_Z85C30_CHIPS
+ (2 +
+NUM_Z85C30_CHIPS_ON_MEZZANINE
+42
+	#NUM_Z85C30_PORTS
+NUM_Z85C30_CHIPS
+ * 2)
+45
+CONSOLE_x1_CLOCK
+46
+CONSOLE_x16_CLOCK
+47
+CONSOLE_x32_CLOCK
+48
+CONSOLE_x64_CLOCK
+49 }
+	tCONSOLE_Clock_¥“d
+52
+CONSOLE_STOP_BITS_1
+53
+CONSOLE_STOP_BITS_1_AND_A_HALF
+54
+CONSOLE_STOP_BITS_2
+55 }
+	tCONSOLE_StÝ_b™s
+58
+CONSOLE_PARITY_NONE
+59
+CONSOLE_PARITY_ODD
+60
+CONSOLE_PARITY_EVEN
+61 }
+	tCONSOLE_Pªy
+64
+CONSOLE_CHARACTER_BITS_8
+65
+CONSOLE_CHARACTER_BITS_7
+66
+CONSOLE_CHARACTER_BITS_6
+67
+CONSOLE_CHARACTER_BITS_5
+68 }
+	tCONSOLE_Ch¬aù”_b™s
+71
+ušt32_t
+baud_¿‹
+72
+CONSOLE_StÝ_b™s
+¡Ý_b™s
+73
+CONSOLE_Pªy
+·r™y
+74
+CONSOLE_Ch¬aù”_b™s
+»ad_ch¬_b™s
+75
+CONSOLE_Ch¬aù”_b™s
+wr™e_ch¬_b™s
+77 #ià
+78 vÞ©ž
+Ršg_bufãr_t
+TX_Bufãr
+79 vÞ©ž
+boÞ
+Is_TX_aùive
+80 *
+cÚsÞe_‹rmios_d©a
+83 }
+	tCÚsÞe_PrÙocÞ
+89
+ušt32_t
+veùÜ
+90
+ušt32_t
+þock_äequ’cy
+91
+ušt16_t
+þock_x
+92
+CONSOLE_Clock_¥“d
+þock_¥“d
+93 }
+	tCh_85C30_šfo
+100 vÞ©ž*
+ù¾
+101 vÞ©ž*
+d©a
+103
+pÜt
+105
+CÚsÞe_PrÙocÞ
+PrÙocÞ
+106
+Ch_85C30_šfo
+Ch
+108 }
+	tPÜt_85C30_šfo
+113
+Ch_85C30_šfo
+Chs_85C30
+NUM_Z85C30_CHIPS
+114
cÚ¡
+PÜt_85C30_šfo
+PÜts_85C30
+NUM_Z85C30_PORTS
+119
+š™Ÿlize_85c30_pÜt
+120 cÚ¡
+PÜt_85C30_šfo
+PÜt
+123
+outby‹_pÞËd_85c30
+124 vÞ©ž*
+c¤
+125
+ch
+128
+šby‹_nÚblockšg_85c30
+129 cÚ¡
+PÜt_85C30_šfo
+PÜt
+132
+Re£t_85c30_ch
+133 vÞ©ž*
+ù¾_0
+134 vÞ©ž*
+ù¾_1
+137 #ià
+138
+¹ems_i¤
+ISR_85c30_Async
+139 cÚ¡
+PÜt_85C30_šfo
+PÜt
+142 #ifdeà
+__ýlu¥lus
+	@console/tbl85c30.c
+13
+	~"cÚsÞeb¥.h
+14
+	~<b¥.h
+15
+	~<b¥/œq.h
+17
+	#CONSOLE_DEFAULT_BAUD_RATE
+ 9600
+18
+	#CONSOLE_DEFAULT_BAUD_CONSTANT
+	`ScÜe603e_Z8530_Ch0_Baud
+(9600)
+20
+	#CONSOLE_DEFAULT_STOP_BITS
+21
+	#CONSOLE_DEFAULT_PARITY
+22
+	#CONSOLE_DEFAULT_READ_CHARACTER_BITS
+23
+	#CONSOLE_DEFAULT_WRITE_CHARACTER_BITS
+24
+	#CONSOLE_DEFAULT_CONSOLE_CLOCK
+CONSOLE_x16_CLOCK
+26
+	#DEFAULT_PROTOCOL
+CONSOLE_DEFAULT_BAUD_RATE
+27
+CONSOLE_DEFAULT_STOP_BITS
+28
+CONSOLE_DEFAULT_PARITY
+29
+CONSOLE_DEFAULT_READ_CHARACTER_BITS
+30
+CONSOLE_DEFAULT_WRITE_CHARACTER_BITS
+35
+CÚsÞe_PrÙocÞ
+	gPrÙocÞs_85c30
+NUM_Z85C30_PORTS
+37
+DEFAULT_PROTOCOL
+38
+DEFAULT_PROTOCOL
+39
+DEFAULT_PROTOCOL
+40
+DEFAULT_PROTOCOL
+42 #ià(
+HAS_PMC_PSC8
+43
+DEFAULT_PROTOCOL
+44
+DEFAULT_PROTOCOL
+45
+DEFAULT_PROTOCOL
+46
+DEFAULT_PROTOCOL
+47
+DEFAULT_PROTOCOL
+48
+DEFAULT_PROTOCOL
+49
+DEFAULT_PROTOCOL
+50
+DEFAULT_PROTOCOL
+58
+Ch_85C30_šfo
+	gChs_85C30
+NUM_Z85C30_CHIPS
+61
+SCORE603E_85C30_0_IRQ
+62
+SCORE603E_85C30_0_CLOCK
+63
+SCORE603E_85C30_0_CLOCK_X
+64
+CONSOLE_DEFAULT_CONSOLE_CLOCK
+67
+SCORE603E_85C30_1_IRQ
+68
+SCORE603E_85C30_1_CLOCK
+69
+SCORE603E_85C30_1_CLOCK_X
+70
+73 #ià(
+HAS_PMC_PSC8
+75
+SCORE603E_85C30_2_IRQ
+76
+SCORE603E_85C30_2_CLOCK
+77
+SCORE603E_85C30_2_CLOCK_X
+78
+81
+SCORE603E_85C30_3_IRQ
+82
+SCORE603E_85C30_3_CLOCK
+83
+SCORE603E_85C30_3_CLOCK_X
+84
+87
+SCORE603E_85C30_4_IRQ
+88
+SCORE603E_85C30_4_CLOCK
+89
+SCORE603E_85C30_4_CLOCK_X
+90
+93
+SCORE603E_85C30_5_IRQ
+94
+SCORE603E_85C30_5_CLOCK
+95
+SCORE603E_85C30_5_CLOCK_X
+96
+106 cÚ¡
+PÜt_85C30_šfo
+	gPÜts_85C30
+NUM_Z85C30_PORTS
+108 (vÞ©ž*è
+SCORE603E_85C30_CTRL_0
+109 (vÞ©ž*è
+SCORE603E_85C30_DATA_0
+111 &
+PrÙocÞs_85c30
+[0],
+112 &
+Chs_85C30
+[0],
+115 (vÞ©ž*è
+SCORE603E_85C30_CTRL_1
+116 (vÞ©ž*è
+SCORE603E_85C30_DATA_1
+118 &
+PrÙocÞs_85c30
+[1],
+119 &
+Chs_85C30
+[0],
+122 (vÞ©ž*è
+SCORE603E_85C30_CTRL_2
+123 (vÞ©ž*è
+SCORE603E_85C30_DATA_2
+125 &
+PrÙocÞs_85c30
+[2],
+126 &
+Chs_85C30
+[1],
+129 (vÞ©ž*è
+SCORE603E_85C30_CTRL_3
+130 (vÞ©ž*è
+SCORE603E_85C30_DATA_3
+132 &
+PrÙocÞs_85c30
+[3],
+133 &
+Chs_85C30
+[1],
+136 #ià(
+HAS_PMC_PSC8
+138 (vÞ©ž*è
+SCORE603E_85C30_CTRL_4
+139 (vÞ©ž*è
+SCORE603E_85C30_DATA_4
+141 &
+PrÙocÞs_85c30
+[4],
+142 &
+Chs_85C30
+[2],
+145 (vÞ©ž*è
+SCORE603E_85C30_CTRL_5
+146 (vÞ©ž*è
+SCORE603E_85C30_DATA_5
+148 &
+PrÙocÞs_85c30
+[5],
+149 &
+Chs_85C30
+[2],
+152 (vÞ©ž*è
+SCORE603E_85C30_CTRL_6
+153 (vÞ©ž*è
+SCORE603E_85C30_DATA_6
+155 &
+PrÙocÞs_85c30
+[6],
+156 &
+Chs_85C30
+[3],
+159 (vÞ©ž*è
+SCORE603E_85C30_CTRL_7
+160 (vÞ©ž*è
+SCORE603E_85C30_DATA_7
+162 &
+PrÙocÞs_85c30
+[7],
+163 &
+Chs_85C30
+[3],
+166 (vÞ©ž*è
+SCORE603E_85C30_CTRL_8
+167 (vÞ©ž*è
+SCORE603E_85C30_DATA_8
+169 &
+PrÙocÞs_85c30
+[8],
+170 &
+Chs_85C30
+[4],
+173 (vÞ©ž*è
+SCORE603E_85C30_CTRL_9
+174 (vÞ©ž*è
+SCORE603E_85C30_DATA_9
+176 &
+PrÙocÞs_85c30
+[9],
+177 &
+Chs_85C30
+[4],
+180 (vÞ©ž*è
+SCORE603E_85C30_CTRL_10
+181 (vÞ©ž*è
+SCORE603E_85C30_DATA_10
+183 &
+PrÙocÞs_85c30
+[10],
+184 &
+Chs_85C30
+[5],
+187 (vÞ©ž*è
+SCORE603E_85C30_CTRL_11
+188 (vÞ©ž*è
+SCORE603E_85C30_DATA_11
+190 &
+PrÙocÞs_85c30
+[11],
+191 &
+Chs_85C30
+[5],
+	@include/bsp.h
+14 #iâdeà
+_BSP_H
+15
+	#_BSP_H
+17 #ifdeà
+__ýlu¥lus
+21
+	#BSP_ZERO_WORKSPACE_AUTOMATICALLY
+TRUE
+23
+	~<b¥Ýts.h
+24
+	~<b¥/deçuÉ-š™Ÿl-ex‹nsiÚ.h
+25
+	~<¹ems.h
+26
+	~<¹ems/cÚsÞe.h
+27
+	~<libýu/io.h
+28
+	~<¹ems/þockdrv.h
+29
+	~<b¥/veùÜs.h
+31 #ifdeà
+ASM
+33
+	#ALIGN_REGS
+ 0x0140
+36
+	~<¹ems.h
+37
+	~<¹ems/cÚsÞe.h
+38
+	~<¹ems/þockdrv.h
+39
+	~<¹ems/iosuµ.h
+45
+	~<g’2.h
+46
+	~<b¥/œq.h
+54
+	#_ScÜe603e_Z8530_Baud
+Ð
+_äequ’cy
+_þock_by
+_baud_¿‹
+55 Ð(
+_äequ’cy
+ /Ð
+_þock_by
+ * 2 *
+_baud_¿‹
+)è- 2)
+57
+	#ScÜe603e_Z8530_Ch1_Baud
+Ð
+_v®ue
+58
+Ð
+59
+_v®ue
+61
+	#ScÜe603e_Z8530_Ch0_Baud
+Ð
+_v®ue
+62
+Ð
+63
+_v®ue
+65
+	#In™Ÿlize_Bßrd_ù¾_»gi¡”
+66 *
+ = (*SCORE603E_BOARD_CTRL_REG | \
+67
+69
+	#ProûssÜ_SynchrÚize
+70
+__asm__
+ vÞ©že("ƒ›iØ")
+91
+RAM_START
+92
+RAM_END
+93
+RAM_SIZE
+95
+PROM_START
+96
+PROM_END
+97
+PROM_SIZE
+99
+CLOCK_SPEED
+100
+CPU_PPC_CLICKS_PER_MS
+102
+’d
+107
+’d
+108
+RAM_END
+109
+ušt32_t
+BSP_mem_size
+116
+	#BSP_LIBIO_MAX_FDS
+ 20
+123
+¹ems_i¤_’Œy
+£t_EE_veùÜ
+124
+¹ems_i¤_’Œy
+hªdËr
+125
+¹ems_veùÜ_numb”
+veùÜ
+127
+š™Ÿlize_ex‹º®_exû±iÚ_veùÜ
+132
+š™_PCI
+133
+š™_RTC
+134
+š¡ruùiÚ_ÿche_’abË
+135
+d©a_ÿche_’abË
+137
+š™Ÿlize_PCI_bridge
+138
+ušt16_t
+»ad_ªd_þ—r_œq
+139
+£t_œq_mask
+ušt16_t
+v®ue
+140
+ušt16_t
+g‘_œq_mask
+145
+š™Ÿlize_univ”£
+146
+£t_œq_mask
+ušt16_t
+v®ue
+147
+ušt16_t
+g‘_œq_mask
+148
+unmask_œq
+ušt16_t
+œq_idx
+149
+mask_œq
+ušt16_t
+œq_idx
+150
+š™_œq_d©a_»gi¡”
+151
+ušt16_t
+»ad_ªd_þ—r_PMC_œq
+(ušt16_ˆ
+œq
+152
+boÞ
+Is_PMC_IRQ
+Ð
+ušt32_t
+pmc_œq
+ušt16_t
+¡©us_wÜd
+153
+ušt16_t
+»ad_ªd_þ—r_œq
+154
+£t_vme_ba£_add»ss
+ušt32_t
+ba£_add»ss
+155
+ušt32_t
+g‘_vme_¦ave_size
+156
+£t_vme_¦ave_size
+ušt32_t
+size
+161
+š™Ÿlize_PCI_bridge
+162
+š™_œq_d©a_»gi¡”
+163
+ušt32_t
+(ušt32_ˆ
+add»ss
+164
+ušt32_t
+add»ss
+, ušt32_ˆ
+d©a
+167
+SCORE603e_FLASH_Di§bË
+ušt32_t
+unu£d
+168
+SCORE603e_FLASH_v”ify_’abË
+169
+SCORE603e_FLASH_EÇbË_wr™es
+ušt32_t
+174
+ušt32_t
+PCI_bus_»ad
+(vÞ©žušt32_ˆ*
+_addr
+175
+PCI_bus_wr™e
+(vÞ©ž
+ušt32_t
+_addr
+, ušt32_ˆ
+_d©a
+177
+	#BSP_FLASH_ENABLE_WRITES
+Ð
+_¬—
+è
+	`SCORE603e_FLASH_EÇbË_wr™es
+Ð_¬— )
+178
+	#BSP_FLASH_DISABLE_WRITES
+_¬—
+è
+	`SCORE603e_FLASH_Di§bË
+Ð_¬— )
+180
+	#CÚv”t_EndŸn_32
+Ð
+_d©a
+181 Ð((
+_d©a
+&0x000000ff)<<24) | ((_data&0x0000ff00)<<8) | \
+182 ((
+_d©a
+&0x00ff0000)>>8è| ((_d©a&0xff000000)>>24è)
+184
+	#CÚv”t_EndŸn_16
+Ð
+_d©a
+185 Ð((
+_d©a
+&0x00ff)<<8è| ((_d©a&0xff00)>>8è)
+190
+BSP_discÚÃù_þock_hªdËr
+191
+BSP_cÚÃù_þock_hªdËr
+195 #ifdeà
+__ýlu¥lus
+	@include/gen2.h
+13 #iâdeà
+__SCORE_GENERATION_2_h
+14
+	#__SCORE_GENERATION_2_h
+16 #ifdeà
+__ýlu¥lus
+20
+	~<¹ems.h
+25
+	#SCORE603E_VME_JUMPER_ADDR
+ 0x00e20000
+26
+	#BSP_FLASH_BASE
+ 0x04000000
+27
+	#SCORE603E_ISA_PCI_IO_BASE
+ 0x80000000
+28
+	#SCORE603E_TIMER_PORT_C
+ 0xfd000000
+29
+	#SCORE603E_TIMER_INT_ACK
+ 0xfd000000
+30
+	#SCORE603E_TIMER_PORT_B
+ 0xfd000008
+31
+	#SCORE603E_TIMER_PORT_A
+ 0xfd000004
+33
+	#SCORE603E_BOARD_CTRL_REG
+ ((vÞ©ž
+ušt8_t
+*)0xfd00002c)
+34
+	#SCORE603E_BRD_FLASH_DISABLE_MASK
+ 0x40
+36
+	#SCORE603E_85C30_CTRL_0
+ ((vÞ©ž
+ušt8_t
+*)0xã200020)
+37
+	#SCORE603E_85C30_DATA_0
+ ((vÞ©ž
+ušt8_t
+*)0xã200024)
+38
+	#SCORE603E_85C30_CTRL_1
+ ((vÞ©ž
+ušt8_t
+*)0xã200028)
+39
+	#SCORE603E_85C30_DATA_1
+ ((vÞ©ž
+ušt8_t
+*)0xã20002c)
+40
+	#SCORE603E_85C30_CTRL_2
+ ((vÞ©ž
+ušt8_t
+*)0xã200000)
+41
+	#SCORE603E_85C30_DATA_2
+ ((vÞ©ž
+ušt8_t
+*)0xã200004)
+42
+	#SCORE603E_85C30_CTRL_3
+ ((vÞ©ž
+ušt8_t
+*)0xã200008)
+43
+	#SCORE603E_85C30_DATA_3
+ ((vÞ©ž
+ušt8_t
+*)0xã20000c)
+49
+	#PCI_DRAM_OFFSET
+PREP_PCI_DRAM_OFFSET
+50
+	#BSP_PCI_CONFIGURATION_BASE
+ 0x80800000
+51
+	#BSP_PMC_BASE
+BSP_PCI_CONFIGURATION_BASE
+52
+	#PCI_MEM_BASE_ADJUSTMENT
+ 0
+53
+	#BSP_PCI_PMC_DEVICE_BASE
+ 0x80808000
+54
+	#BSP_PCI_REGISTER_BASE
+ 0xfc000000
+56
+	#BSP_PCI_DEVICE_ADDRESS
+Ð
+_off£t
+57 ((vÞ©ž
+ušt32_t
+ *)Ð
+BSP_PCI_PMC_DEVICE_BASE
+_off£t
+60
+	#BSP_PMC_SERIAL_ADDRESS
+Ð
+_off£t
+61 ((vÞ©ž
+ušt8_t
+BSP_PCI_REGISTER_BASE
+_off£t
+66
+	#SCORE603E_85C30_CTRL_4
+	`BSP_PMC_SERIAL_ADDRESS
+(0x00200020)
+67
+	#SCORE603E_85C30_DATA_4
+(0x00200024)
+68
+	#SCORE603E_85C30_CTRL_5
+(0x00200028)
+69
+	#SCORE603E_85C30_DATA_5
+(0x0020002c)
+70
+	#SCORE603E_85C30_CTRL_6
+(0x00200030)
+71
+	#SCORE603E_85C30_DATA_6
+(0x00200034)
+72
+	#SCORE603E_85C30_CTRL_7
+(0x00200038)
+73
+	#SCORE603E_85C30_DATA_7
+(0x0020003c)
+74
+	#SCORE603E_85C30_CTRL_8
+(0x00200000)
+75
+	#SCORE603E_85C30_DATA_8
+(0x00200004)
+76
+	#SCORE603E_85C30_CTRL_9
+(0x00200008)
+77
+	#SCORE603E_85C30_DATA_9
+(0x0020000c)
+78
+	#SCORE603E_85C30_CTRL_10
+(0x00200010)
+79
+	#SCORE603E_85C30_DATA_10
+(0x00200014)
+80
+	#SCORE603E_85C30_CTRL_11
+(0x00200018)
+81
+	#SCORE603E_85C30_DATA_11
+(0x0020001c)
+83
+	#_IO_BASE
+PREP_ISA_IO_BASE
+84
+	#SCORE603E_PCI_IO_CFG_ADDR
+ 0x80000cf8
+85
+	#SCORE603E_PCI_IO_CFG_DATA
+ 0x80000cfc
+87
+	#SCORE603E_UNIVERSE_BASE
+ 0x80030000
+88
+	#SCORE603E_IO_VME_UNIVERSE_BASE
+ 0x80007000
+89
+	#PCI_MEM_BASE
+ 0xc0000000
+90
+	#BSP_PCI_MEM_BASE
+PCI_MEM_BASE
+91
+	#BSP_NVRAM_BASE
+ 0xfd100000
+92
+	#BSP_RTC_ADDRESS
+ ((vÞ©ž*)0xfd180000)
+93
+	#SCORE603E_JP1_JP2_PROM_BASE
+ 0xfff00000
+94
+	#SCORE603E_NOT_JP1_2_FLASH_BASE
+ 0xff800000
+96 #ià(
+SCORE603E_USE_SDS
+è| (
+SCORE603E_USE_OPEN_FIRMWARE
+è| (
+SCORE603E_USE_NONE
+97
+	#SCORE603E_VME_A16_OFFSET
+ 0x04000000
+98 #–ià(
+SCORE603E_USE_DINK
+99
+ 0x11000000
+100
+	#SCORE603E_VME_A24_OFFSET
+ 0x10000000
+101
+	#BSP_VME_A24_BASE
+BSP_PCI_MEM_BASE
+SCORE603E_VME_A24_OFFSET
+106
+	#BSP_VME_A16_BASE
+BSP_PCI_MEM_BASE
+SCORE603E_VME_A16_OFFSET
+114
+	#ICM1770_CRYSTAL_FREQ_32K
+ 0x00
+115
+	#ICM1770_CRYSTAL_FREQ_1M
+ 0x01
+116
+	#ICM1770_CRYSTAL_FREQ_2M
+ 0x02
+117
+	#ICM1770_CRYSTAL_FREQ_4M
+ 0x03
+119
+	#BSP_RTC_FREQUENCY
+ICM1770_CRYSTAL_FREQ_32K
+124
+	#SCORE603E_85C30_0_CLOCK
+ 14745600
+125
+	#SCORE603E_85C30_0_CLOCK_X
+ 16
+130
+	#SCORE603E_85C30_1_CLOCK
+ 16000000
+131
+	#SCORE603E_85C30_1_CLOCK_X
+ 16
+136
+	#SCORE603E_85C30_PMC_CLOCK
+ 16000000
+137
+	#SCORE603E_85C30_PMC_CLOCK_X
+ 16
+139
+	#SCORE603E_85C30_2_CLOCK
+SCORE603E_85C30_PMC_CLOCK
+140
+	#SCORE603E_85C30_3_CLOCK
+141
+	#SCORE603E_85C30_4_CLOCK
+142
+	#SCORE603E_85C30_5_CLOCK
+143
+	#SCORE603E_85C30_2_CLOCK_X
+SCORE603E_85C30_PMC_CLOCK_X
+144
+	#SCORE603E_85C30_3_CLOCK_X
+145
+	#SCORE603E_85C30_4_CLOCK_X
+146
+	#SCORE603E_85C30_5_CLOCK_X
+148
+	#SCORE603E_UNIVERSE_CHIP_ID
+ 0x000010E3
+153
+	#SCORE603E_FPGA_VECT_DATA
+ ((vÞ©ž
+ušt16_t
+*)0xfd000040)
+154
+	#SCORE603E_FPGA_BIT1_15_0
+ ((vÞ©ž
+ušt16_t
+*)0xfd000044)
+155
+	#SCORE603E_FPGA_MASK_DATA
+ ((vÞ©ž
+ušt16_t
+*)0xfd000048)
+156
+	#SCORE603E_FPGA_IRQ_INPUT
+ ((vÞ©ž
+ušt16_t
+*)0xfd00004c)
+161
+	#BSP_PMC_STATUS_ADDRESS
+ (0))
+162
+	#Is_PMC_85C30_4_IRQ
+Ð
+_¡©us
+ ) (_¡©u & 0x80è
+163
+	#Is_PMC_85C30_2_IRQ
+Ð
+_¡©us
+ ) (_¡©u & 0x40è
+164
+	#Is_PMC_85C30_5_IRQ
+Ð
+_¡©us
+ ) (_¡©u & 0x20è
+165
+	#Is_PMC_85C30_3_IRQ
+Ð
+_¡©us
+ ) (_¡©u & 0x08è
+167
+	#SCORE603E_PMC_CONTROL_ADDRESS
+(0x100000)
+168
+	#SCORE603E_PMC_SCC_232_LOOPBACK
+_wÜd
+è(_wÜd|0x20)
+170
+	#PMC_SET_232_LOOPBACK
+_wÜd
+è(_wÜd | 0x02)
+171
+	#PMC_CLEAR_232_LOOPBACK
+_wÜd
+è(_wÜd & 0xfd)
+172
+	#PMC_SET_422_LOOPBACK
+_wÜd
+è(_wÜd | 0x01)
+173
+	#PMC_CLEAR_422_LOOPBACK
+_wÜd
+è(_wÜd & 0xã)
+185
+	#BSP_TIMER_AVG_OVERHEAD
+ 4
+187
+	#BSP_TIMER_LEAST_VALID
+ 1
+201
+	#BSP_CÚv”t_deüem’‹r
+Ð
+_v®ue
+202 (è(((
+_v®ue
+è* 4000è/ 6667)
+204 #ifdeà
+__ýlu¥lus
+	@include/tm27.h
+16 #iâdeà
+_RTEMS_TMTEST27
+20 #iâdeà
+__tm27_h
+21
+	#__tm27_h
+23
+	~<b¥/œq.h
+29
+	#MUST_WAIT_FOR_INTERRUPT
+ 1
+31
+	$nuÎFunc
+(è{
+33
+¹ems_œq_cÚÃù_d©a
+	gþockIrqD©a
+BSP_DECREMENTER
+35 (
+¹ems_œq_’abË
+nuÎFunc
+36 (
+¹ems_œq_di§bË
+nuÎFunc
+37 (
+¹ems_œq_is_’abËd
+è
+nuÎFunc
+38
+In¡®l_tm27_veùÜ
+_hªdËr
+40
+þockIrqD©a
+hdl
+_hªdËr
+41 ià(!
+	`BSP_š¡®l_¹ems_œq_hªdËr
+þockIrqD©a
+42
+	`´štk
+("Error installing clock interrupt handler!\n");
+43
+(1);
+45
+47
+	#Cau£_tm27_šŒ
+49
+ušt32_t
+_þicks
+ = 8; \
+50
+__asm__
+ vÞ©žeÐ"mtdeø%0" : "ô" ((
+_þicks
+)) : "r" ((_clicks)) ); \
+51 } 0)
+53
+	#Cˬ_tm27_šŒ
+55
+ušt32_t
+_þicks
+ = 0xffffffff; \
+56
+__asm__
+_þicks
+57 } 0)
+59
+	#Low”_tm27_šŒ
+61
+ušt32_t
+_m¤
+ = 0; \
+62
+	`_ISR_S‘_Ëv–
+( 0 ); \
+63
+__asm__
+ vÞ©žeÐ"mfm¤ %0 ;" : "ô" (
+_m¤
+) : "r" (_msr) ); \
+64
+_m¤
+ |= 0x8002; \
+65
+__asm__
+ vÞ©žeÐ"mtm¤ %0 ;" : "ô" (
+_m¤
+66 } 0)
+	@irq/FPGA.c
+14
+	~<b¥.h
+15
+	~<b¥/œq.h
+16
+	~<¡ršg.h
+17
+	~<fúŽ.h
+18
+	~<as£¹.h
+20
+	~<¹ems/libio.h
+21
+	~<¹ems/libcsuµÜt.h
+22
+	~<¹ems/b¥Io.h
+27
+	$š™Ÿlize_PCI_bridge
+32
+34
+	$£t_œq_mask
+35
+ušt16_t
+v®ue
+38 vÞ©ž
+ušt16_t
+loc
+40
+loc
+ušt16_t
+SCORE603E_FPGA_MASK_DATA
+42 *
+loc
+v®ue
+43
+45
+ušt16_t
+	$g‘_œq_mask
+47 vÞ©ž
+ušt16_t
+loc
+48
+ušt16_t
+v®ue
+50
+loc
+ušt16_t
+52
+v®ue
+loc
+54
+v®ue
+55
+57
+	$mask_œq
+58
+ušt16_t
+œq_idx
+61
+ušt16_t
+v®ue
+62
+ušt32_t
+mask_idx
+œq_idx
+64
+v®ue
+	`g‘_œq_mask
+66 #ià(
+HAS_PMC_PSC8
+67
+œq_idx
+ScÜe_IRQ_Fœ¡
+68
+69
+70
+71
+72
+mask_idx
+SCORE603E_PCI_IRQ_0
+ScÜe_IRQ_Fœ¡
+79
+v®ue
+ |ð(0x1 <<
+mask_idx
+80
+	`£t_œq_mask
+Ð
+v®ue
+81
+83
+	$unmask_œq
+84
+ušt16_t
+œq_idx
+87
+ušt16_t
+v®ue
+88
+ušt32_t
+mask_idx
+œq_idx
+90
+v®ue
+	`g‘_œq_mask
+92 #ià(
+HAS_PMC_PSC8
+93
+œq_idx
+ScÜe_IRQ_Fœ¡
+94
+95
+96
+97
+98
+mask_idx
+ScÜe_IRQ_Fœ¡
+105
+v®ue
+ &ð(~(0x1 <<
+mask_idx
+106
+	`£t_œq_mask
+Ð
+v®ue
+107
+109
+	$š™_œq_d©a_»gi¡”
+111
+ušt32_t
+šdex
+112
+ušt32_t
+i
+114
+	`£t_œq_mask
+( 0xffff );
+119
+i
+=0; i<20; i++) {
+120
+šdex
+SCORE603E_FPGA_VECT_DATA
+121 iàÐ(
+šdex
+&0x10) != 0x10 )
+124
+126
+ušt16_t
+	$»ad_ªd_þ—r_PMC_œq
+127
+ušt16_t
+œq
+130
+ušt16_t
+¡©us_wÜd
+œq
+132
+¡©us_wÜd
+BSP_PMC_STATUS_ADDRESS
+134
+¡©us_wÜd
+135
+137
+boÞ
+	$Is_PMC_IRQ
+138
+ušt32_t
+pmc_œq
+139
+ušt16_t
+¡©us_wÜd
+142
+boÞ
+»suÉ
+çl£
+144
+pmc_œq
+145
+146
+»suÉ
+	`Is_PMC_85C30_4_IRQ
+Ð
+¡©us_wÜd
+Œue
+çl£
+148
+149
+»suÉ
+	`Is_PMC_85C30_2_IRQ
+Ð
+¡©us_wÜd
+Œue
+çl£
+151
+152
+»suÉ
+	`Is_PMC_85C30_5_IRQ
+Ð
+¡©us_wÜd
+Œue
+çl£
+154
+155
+»suÉ
+	`Is_PMC_85C30_3_IRQ
+Ð
+¡©us_wÜd
+Œue
+çl£
+158
+	`as£¹
+( 0 );
+162
+»suÉ
+163
+165
+ušt16_t
+	$»ad_ªd_þ—r_œq
+167
+ušt16_t
+œq
+170
+œq
+171
+	`ProûssÜ_SynchrÚize
+172 ià((
+œq
+ & 0xffff0) != 0x10) {
+173
+	`´štk
+Ð"»ad_ªd_þ—r_œq:: ERROR==>nØœq d©¨0x%x\n",
+œq
+174  (
+œq
+ | 0x80);
+177
+œq
+ &=0xf;
+178
+œq
+ +ð
+ScÜe_IRQ_Fœ¡
+179
+œq
+180
+	@irq/irq.c
+11
+	~<¡dlib.h
+13
+	~<b¥.h
+14
+	~<b¥/œq.h
+15
+	~<b¥/VME.h
+16
+	~<¹ems/scÜe/­›xt.h
+17
+	~<libýu/io.h
+18
+	~<b¥/veùÜs.h
+19
+	~<¡dlib.h
+20
+	~<¹ems/b¥Io.h
+25
+¹ems_œq_cÚÃù_d©a
+	gdeçuÉ_¹ems_’Œy
+31
+¹ems_œq_glob®_£‰šgs
+	gš‹º®_cÚfig
+32
+¹ems_œq_cÚÃù_d©a
+	g¹ems_hdl_tbl
+37
+šlše
+	$is_i§_œq
+(cÚ¡
+¹ems_œq_numb”
+œqLše
+39  (((è
+œqLše
+ <ð
+BSP_ISA_IRQ_MAX_OFFSET
+40 ((è
+œqLše
+ >ð
+BSP_ISA_IRQ_LOWEST_OFFSET
+42
+47
+šlše
+	$is_pci_œq
+(cÚ¡
+¹ems_œq_numb”
+œqLše
+49  (((è
+œqLše
+ <ð
+BSP_PCI_IRQ_MAX_OFFSET
+50 ((è
+œqLše
+ >ð
+BSP_PCI_IRQ_LOWEST_OFFSET
+52
+57
+šlše
+	$is_´oûssÜ_œq
+(cÚ¡
+¹ems_œq_numb”
+œqLše
+59  (((è
+œqLše
+ <ð
+BSP_PROCESSOR_IRQ_MAX_OFFSET
+60 ((è
+œqLše
+ >ð
+BSP_PROCESSOR_IRQ_LOWEST_OFFSET
+62
+73
+	$isV®idIÁ”ru±
+œq
+75 iàÐ(
+œq
+BSP_LOWEST_OFFSET
+è|| (œq >
+BSP_MAX_OFFSET
+78
+83
+	$BSP_š¡®l_¹ems_sh¬ed_œq_hªdËr
+ (cÚ¡
+¹ems_œq_cÚÃù_d©a
+œq
+85
+¹ems_š‹¼u±_Ëv–
+Ëv–
+86
+¹ems_œq_cÚÃù_d©a
+vchaš
+88
+	`´štk
+(" BSP_š¡®l_¹ems_sh¬ed_œq_hªd˸%d\n",
+œq
+Çme
+90 ià(!
+	`isV®idIÁ”ru±
+œq
+Çme
+91
+	`´štk
+("Inv®id iÁ”ru± veùÜ %d\n",
+œq
+Çme
+95
+	`¹ems_š‹¼u±_di§bË
+Ëv–
+97 iàÐ()
+¹ems_hdl_tbl
+œq
+Çme
+Ãxt_hªdËr
+ == -1 ) {
+98
+	`¹ems_š‹¼u±_’abË
+Ëv–
+99
+	`´štk
+("IRQ veùÜ %d‡Ì—dy cÚÃùedØª unsh¬ed hªdËr\n",
+œq
+Çme
+103
+vchaš
+¹ems_œq_cÚÃù_d©a
+	`m®loc
+((rtems_irq_connect_data));
+106
+vchaš
+[0]ð
+¹ems_hdl_tbl
+œq
+Çme
+111
+¹ems_hdl_tbl
+œq
+Çme
+] = *irq;
+114
+¹ems_hdl_tbl
+œq
+Çme
+Ãxt_hªdËr
+vchaš
+119 ià(
+	`is_pci_œq
+œq
+Çme
+122 ià(
+	`is_´oûssÜ_œq
+œq
+Çme
+130 ià(
+œq
+Ú
+131
+œq
+	`Ú
+(irq);
+133
+	`¹ems_š‹¼u±_’abË
+Ëv–
+136
+141
+¹ems_¡©us_code
+	$b¥_š‹¼u±_veùÜ_di§bË
+Ð
+¹ems_veùÜ_numb”
+œqLše
+145
+	`´štk
+("b¥_š‹¼u±_veùÜ_di§bË: 0x%x\n",
+œqLše
+146
+RTEMS_SUCCESSFUL
+147
+149
+¹ems_¡©us_code
+	$b¥_š‹¼u±_veùÜ_’abË
+Ð
+¹ems_veùÜ_numb”
+œqLše
+152
+	`´štk
+("b¥_š‹¼u±_veùÜ_’abË: 0x%x\n",
+œqLše
+154
+RTEMS_SUCCESSFUL
+155
+163
+	$BSP_š¡®l_¹ems_œq_hªdËr
+ (cÚ¡
+¹ems_œq_cÚÃù_d©a
+œq
+165
+¹ems_š‹¼u±_Ëv–
+Ëv–
+167
+	`´štk
+(" BSP_š¡®l_¹ems_œq_hªd˸%d\n",
+œq
+Çme
+169 ià(!
+	`isV®idIÁ”ru±
+œq
+Çme
+170
+	`´štk
+œq
+Çme
+180
+	`¹ems_š‹¼u±_di§bË
+Ëv–
+181 ià(
+¹ems_hdl_tbl
+œq
+Çme
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl) {
+182
+	`¹ems_š‹¼u±_’abË
+Ëv–
+183
+	`´štk
+("IRQ veùÜ %d‡Ì—dy cÚÃùed\n",
+œq
+Çme
+190
+¹ems_hdl_tbl
+œq
+Çme
+] = *irq;
+191
+¹ems_hdl_tbl
+œq
+Çme
+Ãxt_hªdËr
+ = (*)-1;
+194 ià(
+	`is_pci_œq
+œq
+Çme
+198
+	`´štk
+("is_pci_irq = TRUE - FIX THIS!\n");
+201 ià(
+	`is_´oûssÜ_œq
+œq
+Çme
+205
+	`´štk
+("is_processor_irq = TRUE : Fix This\n");
+211 ià(
+œq
+Ú
+212
+	`´štk
+("C®È0x%x\n",
+œq
+Ú
+213
+œq
+	`Ú
+(irq);
+216
+	`¹ems_š‹¼u±_’abË
+Ëv–
+219
+221
+	$BSP_g‘_cu¼’t_¹ems_œq_hªdËr
+¹ems_œq_cÚÃù_d©a
+œq
+223
+¹ems_š‹¼u±_Ëv–
+Ëv–
+225
+	`´štk
+(" BSP_g‘_cu¼’t_¹ems_œq_hªd˸%d\n",
+œq
+Çme
+226 ià(!
+	`isV®idIÁ”ru±
+œq
+Çme
+229
+	`¹ems_š‹¼u±_di§bË
+Ëv–
+230 *
+œq
+¹ems_hdl_tbl
+[œq->
+Çme
+231
+	`¹ems_š‹¼u±_’abË
+Ëv–
+233
+235
+	$BSP_»move_¹ems_œq_hªdËr
+ (cÚ¡
+¹ems_œq_cÚÃù_d©a
+œq
+237
+¹ems_œq_cÚÃù_d©a
+pchaš
+ð
+NULL
+vchaš
+ = NULL;
+238
+¹ems_š‹¼u±_Ëv–
+Ëv–
+240
+	`´štk
+(" BSP_»move_¹ems_œq_hªd˸%d\n",
+œq
+Çme
+241 ià(!
+	`isV®idIÁ”ru±
+œq
+Çme
+251
+	`¹ems_š‹¼u±_di§bË
+Ëv–
+252 ià(
+¹ems_hdl_tbl
+œq
+Çme
+hdl
+ != irq->hdl) {
+253
+	`¹ems_š‹¼u±_’abË
+Ëv–
+257 ifÐ()
+¹ems_hdl_tbl
+œq
+Çme
+Ãxt_hªdËr
+ != -1 )
+259
+found
+ = 0;
+261  (
+pchaš
+ð
+NULL
+vchaš
+¹ems_hdl_tbl
+œq
+Çme
+262 (
+vchaš
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl);
+263 (
+pchaš
+ð
+vchaš
+, vchaš = (
+¹ems_œq_cÚÃù_d©a
+*)vchaš->
+Ãxt_hªdËr
+265 ifÐ
+vchaš
+hdl
+ =ð
+œq
+->hdl )
+267
+found
+= -1; ;
+271 ifÐ!
+found
+273
+	`¹ems_š‹¼u±_’abË
+Ëv–
+279 ià(
+¹ems_hdl_tbl
+œq
+Çme
+hdl
+ != irq->hdl)
+281
+	`¹ems_š‹¼u±_’abË
+Ëv–
+287 ià(
+	`is_pci_œq
+œq
+Çme
+292 ià(
+	`is_´oûssÜ_œq
+œq
+Çme
+301 ià(
+œq
+off
+302
+œq
+	`off
+(irq);
+307 ifÐ!
+vchaš
+310
+¹ems_hdl_tbl
+œq
+Çme
+deçuÉ_¹ems_’Œy
+314 ifÐ
+pchaš
+317
+pchaš
+Ãxt_hªdËr
+vchaš
+->next_handler;
+324
+¹ems_hdl_tbl
+œq
+Çme
+]ð*
+vchaš
+326
+	`ä“
+vchaš
+329
+	`¹ems_š‹¼u±_’abË
+Ëv–
+332
+338
+	$BSP_¹ems_œq_mngt_£t
+cÚfig
+340
+i
+341
+¹ems_š‹¼u±_Ëv–
+Ëv–
+346
+š‹º®_cÚfig
+cÚfig
+347
+deçuÉ_¹ems_’Œy
+cÚfig
+deçuÉEÁry
+348
+¹ems_hdl_tbl
+cÚfig
+œqHdlTbl
+350
+	`´štk
+(" BSP_rtems_irq_mngt_set\n");
+352
+	`¹ems_š‹¼u±_di§bË
+Ëv–
+360
+i
+; i < BSP_PCI_IRQ_LOWEST_OFFSET +
+BSP_PCI_IRQ_NUMBER
+ ; i++) {
+361 ià(
+¹ems_hdl_tbl
+i
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl) {
+363
+¹ems_œq_cÚÃù_d©a
+vchaš
+364
+vchaš
+¹ems_hdl_tbl
+i
+365 (()
+vchaš
+ !ð-1 && vchaš->
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl);
+366
+vchaš
+¹ems_œq_cÚÃù_d©a
+*)vchaš->
+Ãxt_hªdËr
+368 ià(
+vchaš
+Ú
+369
+vchaš
+	`Ú
+(vchain);
+377
+¹ems_œq_cÚÃù_d©a
+vchaš
+378
+vchaš
+¹ems_hdl_tbl
+i
+379 (()
+vchaš
+ !ð-1 && vchaš->
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl);
+380
+vchaš
+¹ems_œq_cÚÃù_d©a
+*)vchaš->
+Ãxt_hªdËr
+382 ià(
+vchaš
+off
+383
+vchaš
+	`off
+(vchain);
+391
+i
+; i < BSP_PROCESSOR_IRQ_LOWEST_OFFSET+
+BSP_PROCESSOR_IRQ_NUMBER
+; i++){
+392 ià(
+¹ems_hdl_tbl
+i
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl) {
+394
+¹ems_œq_cÚÃù_d©a
+vchaš
+395
+vchaš
+¹ems_hdl_tbl
+i
+396 (()
+vchaš
+ !ð-1 && vchaš->
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl);
+397
+vchaš
+¹ems_œq_cÚÃù_d©a
+*)vchaš->
+Ãxt_hªdËr
+399 ià(
+vchaš
+Ú
+400
+vchaš
+	`Ú
+(vchain);
+407
+¹ems_œq_cÚÃù_d©a
+vchaš
+408
+vchaš
+¹ems_hdl_tbl
+i
+409 (()
+vchaš
+ !ð-1 && vchaš->
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl);
+410
+vchaš
+¹ems_œq_cÚÃù_d©a
+*)vchaš->
+Ãxt_hªdËr
+412 ià(
+vchaš
+off
+413
+vchaš
+	`off
+(vchain);
+419
+	`¹ems_š‹¼u±_’abË
+Ëv–
+421
+423
+	$BSP_¹ems_œq_mngt_g‘
+cÚfig
+425 *
+cÚfig
+š‹º®_cÚfig
+427
+429
+	gBSP_¥uriousIÁr
+ = 0;
+434
+	$C_di¥©ch_œq_hªdËr
+CPU_IÁ”ru±_äame
+äame
+excNum
+436
+œq
+437
+m¤
+438
+Ãw_m¤
+440 ià(
+excNum
+ =ð
+ASM_DEC_VECTOR
+441
+	`_CPU_MSR_GET
+m¤
+442
+Ãw_m¤
+m¤
+MSR_EE
+443
+	`_CPU_MSR_SET
+Ãw_m¤
+445
+¹ems_hdl_tbl
+BSP_DECREMENTER
+	`hdl
+Ô‹ms_hdl_tbl[BSP_DECREMENTER].
+hªdË
+447
+	`_CPU_MSR_SET
+m¤
+452
+œq
+	`»ad_ªd_þ—r_œq
+453
+	`_CPU_MSR_GET
+m¤
+454
+Ãw_m¤
+m¤
+MSR_EE
+455
+	`_CPU_MSR_SET
+Ãw_m¤
+459
+¹ems_œq_cÚÃù_d©a
+vchaš
+460
+vchaš
+¹ems_hdl_tbl
+œq
+461 (()
+vchaš
+ !ð-1 && vchaš->
+hdl
+ !ð
+deçuÉ_¹ems_’Œy
+.hdl);
+462
+vchaš
+¹ems_œq_cÚÃù_d©a
+*)vchaš->
+Ãxt_hªdËr
+464
+vchaš
+	`hdl
+(vchaš->
+hªdË
+468
+	`_CPU_MSR_SET
+m¤
+471
+473
+¹ems_¡©us_code
+	$b¥_š‹¼u±_çcž™y_š™Ÿlize
+476 ià(
+	`µc_exc_£t_hªdËr
+Ð
+ASM_EXT_VECTOR
+C_di¥©ch_œq_hªdËr
+477
+RTEMS_IO_ERROR
+479 ià(
+	`µc_exc_£t_hªdËr
+Ð
+ASM_DEC_VECTOR
+C_di¥©ch_œq_hªdËr
+480
+RTEMS_IO_ERROR
+482 ià(
+	`µc_exc_£t_hªdËr
+Ð
+ASM_E300_SYSMGMT_VECTOR
+C_di¥©ch_œq_hªdËr
+483
+RTEMS_IO_ERROR
+486
+RTEMS_SUCCESSFUL
+487
+489
+	$b¥_š‹¼u±_hªdËr_deçuÉ
+Ð
+¹ems_veùÜ_numb”
+veùÜ
+491 ià(
+veùÜ
+ !ð
+BSP_DECREMENTER
+492
+	`´štk
+Ð"Spuriou š‹¼u±: 0x%08x\n",
+veùÜ
+494
+	@irq/irq.h
+20 #iâdeà
+BSP_POWERPC_IRQ_H
+21
+	#BSP_POWERPC_IRQ_H
+23
+	#BSP_SHARED_HANDLER_SUPPORT
+ 1
+24
+	~<¹ems/œq.h
+26 #iâdeà
+ASM
+28 #ifdeà
+__ýlu¥lus
+40
+	#BSP_ISA_IRQ_NUMBER
+ (16)
+41
+	#BSP_ISA_IRQ_LOWEST_OFFSET
+ (0)
+42
+	#BSP_ISA_IRQ_MAX_OFFSET
+BSP_ISA_IRQ_NUMBER
+ - 1)
+47
+	#BSP_PCI_IRQ_NUMBER
+ (16)
+48
+	#BSP_PCI_IRQ_LOWEST_OFFSET
+BSP_ISA_IRQ_NUMBER
+49
+	#BSP_PCI_IRQ_MAX_OFFSET
+BSP_PCI_IRQ_NUMBER
+ - 1)
+54
+	#BSP_PMC_IRQ_NUMBER
+ (4)
+55
+	#BSP_PMC_IRQ_LOWEST_OFFSET
+ + 1)
+56
+	#BSP_PMC_IRQ_MAX_OFFSET
+BSP_PMC_IRQ_LOWEST_OFFSET
+BSP_PMC_IRQ_NUMBER
+ - 1)
+63
+	#BSP_PROCESSOR_IRQ_NUMBER
+ (1)
+64
+	#BSP_PROCESSOR_IRQ_LOWEST_OFFSET
+BSP_PMC_IRQ_MAX_OFFSET
+ + 1)
+65
+	#BSP_PROCESSOR_IRQ_MAX_OFFSET
+ - 1)
+69
+	#BSP_MISC_IRQ_NUMBER
+ (8)
+70
+	#BSP_MISC_IRQ_LOWEST_OFFSET
+ + 1)
+71
+	#BSP_MISC_IRQ_MAX_OFFSET
+BSP_MISC_IRQ_LOWEST_OFFSET
+BSP_MISC_IRQ_NUMBER
+ - 1)
+75
+	#BSP_IRQ_NUMBER
+BSP_MISC_IRQ_MAX_OFFSET
+ + 1)
+76
+	#BSP_LOWEST_OFFSET
+77
+	#BSP_MAX_OFFSET
+82
+	#BSP_DECREMENTER
+87
+	#ScÜe_IRQ_Fœ¡
+92
+	#SCORE603E_IRQ00
+ScÜe_IRQ_Fœ¡
+ + 0 )
+93
+	#SCORE603E_IRQ01
+ScÜe_IRQ_Fœ¡
+ + 1 )
+94
+	#SCORE603E_IRQ02
+ScÜe_IRQ_Fœ¡
+ + 2 )
+95
+	#SCORE603E_IRQ03
+ScÜe_IRQ_Fœ¡
+ + 3 )
+96
+	#SCORE603E_IRQ04
+ScÜe_IRQ_Fœ¡
+ + 4 )
+97
+	#SCORE603E_IRQ05
+ScÜe_IRQ_Fœ¡
+ + 5 )
+98
+	#SCORE603E_IRQ06
+ScÜe_IRQ_Fœ¡
+ + 6 )
+99
+	#SCORE603E_IRQ07
+ScÜe_IRQ_Fœ¡
+ + 7 )
+100
+	#SCORE603E_IRQ08
+ScÜe_IRQ_Fœ¡
+ + 8 )
+101
+	#SCORE603E_IRQ09
+ScÜe_IRQ_Fœ¡
+ + 9 )
+102
+	#SCORE603E_IRQ10
+ScÜe_IRQ_Fœ¡
+ + 10 )
+103
+	#SCORE603E_IRQ11
+ScÜe_IRQ_Fœ¡
+ + 11 )
+104
+	#SCORE603E_IRQ12
+ScÜe_IRQ_Fœ¡
+ + 12 )
+105
+	#SCORE603E_IRQ13
+ScÜe_IRQ_Fœ¡
+ + 13 )
+106
+	#SCORE603E_IRQ14
+ScÜe_IRQ_Fœ¡
+ + 14 )
+107
+	#SCORE603E_IRQ15
+ScÜe_IRQ_Fœ¡
+ + 15 )
+109
+	#SCORE603E_TIMER1_IRQ
+SCORE603E_IRQ00
+110
+	#SCORE603E_TIMER2_IRQ
+SCORE603E_IRQ01
+111
+	#SCORE603E_TIMER3_IRQ
+SCORE603E_IRQ02
+112
+	#SCORE603E_85C30_1_IRQ
+SCORE603E_IRQ03
+113
+	#SCORE603E_85C30_0_IRQ
+SCORE603E_IRQ04
+114
+	#SCORE603E_RTC_IRQ
+SCORE603E_IRQ05
+115
+	#SCORE603E_PCI_IRQ_0
+SCORE603E_IRQ06
+116
+	#SCORE603E_PCI_IRQ_1
+SCORE603E_IRQ07
+117
+	#SCORE603E_PCI_IRQ_2
+SCORE603E_IRQ08
+118
+	#SCORE603E_PCI_IRQ_3
+SCORE603E_IRQ09
+119
+	#SCORE603E_UNIVERSE_IRQ
+SCORE603E_IRQ10
+120
+	#SCORE603E_1553_IRQ
+SCORE603E_IRQ11
+121
+	#SCORE603E_MAIL_BOX_IRQ_0
+SCORE603E_IRQ12
+122
+	#SCORE603E_MAIL_BOX_IRQ_1
+SCORE603E_IRQ13
+123
+	#SCORE603E_MAIL_BOX_IRQ_2
+SCORE603E_IRQ14
+124
+	#SCORE603E_MAIL_BOX_IRQ_3
+SCORE603E_IRQ15
+131
+	#SCORE603E_IRQ16
+ScÜe_IRQ_Fœ¡
+ + 16 )
+132
+	#SCORE603E_IRQ17
+ScÜe_IRQ_Fœ¡
+ + 17 )
+133
+	#SCORE603E_IRQ18
+ScÜe_IRQ_Fœ¡
+ + 18 )
+134
+	#SCORE603E_IRQ19
+ScÜe_IRQ_Fœ¡
+ + 19 )
+139
+	#SCORE603E_85C30_4_IRQ
+SCORE603E_IRQ16
+140
+	#SCORE603E_85C30_2_IRQ
+SCORE603E_IRQ17
+141
+	#SCORE603E_85C30_5_IRQ
+SCORE603E_IRQ18
+142
+	#SCORE603E_85C30_3_IRQ
+SCORE603E_IRQ19
+144
+	#MAX_BOARD_IRQS
+SCORE603E_IRQ19
+146
+BSP_¹ems_œq_mng_š™
+ýuId
+148 #ifdeà
+__ýlu¥lus
+	@irq/irq_init.c
+19
+	~<libýu/io.h
+20
+	~<libýu/¥r.h
+21
+	~<b¥/pci.h
+22
+	~<b¥/»sidu®.h
+23
+	~<b¥/œq.h
+24
+	~<b¥.h
+25
+	~<b¥/veùÜs.h
+26
+	~<¹ems/b¥Io.h
+28
+	#SHOW_ISA_PCI_BRIDGE_SETTINGS
+ 1
+29
+	#SCAN_PCI_PRINT
+ 1
+30
+	#TRACE_IRQ_INIT
+ 0
+33
+	mbus
+34
+	mdeviû
+35
+	mfunùiÚ
+36 }
+	tpci_i§_bridge_deviû
+38
+pci_i§_bridge_deviû
+	gvŸ_82c586
+ = 0;
+40
+ex‹º®_exû±iÚ_veùÜ_´Þog_code_size
+41
+42
+deüem’‹r_exû±iÚ_veùÜ_´Þog_code_size
+43
+45
+	$IRQ_DeçuÉ_¹ems_œq_hdl
+46
+¹ems_œq_hdl_·¿m
+±r
+49
+51
+	$IRQ_DeçuÉ_¹ems_œq_’abË
+52 cÚ¡
+__¹ems_œq_cÚÃù_d©a__
+±r
+55
+57
+	$IRQ_DeçuÉ_¹ems_œq_di§bË
+58 cÚ¡
+±r
+61
+63
+	$IRQ_DeçuÉ_¹ems_œq_is_’abËd
+64 cÚ¡
+±r
+67
+69
+¹ems_œq_cÚÃù_d©a
+	g¹emsIrq
+BSP_IRQ_NUMBER
+70
+	gš™Ÿl_cÚfig
+72
+¹ems_œq_cÚÃù_d©a
+	gdeçuÉIrq
+73 .
+Çme
+ = 0,
+74 .
+	ghdl
+IRQ_DeçuÉ_¹ems_œq_hdl
+75 .
+	ghªdË
+NULL
+76 .
+	gÚ
+IRQ_DeçuÉ_¹ems_œq_’abË
+77 .
+	gÚ
+IRQ_DeçuÉ_¹ems_œq_di§bË
+78 .
+	gisOn
+IRQ_DeçuÉ_¹ems_œq_is_’abËd
+81
+¹ems_œq_´io
+	gœqPrioTabË
+BSP_IRQ_NUMBER
+89
+	$BSP_¹ems_œq_mng_š™
+ýuId
+91
+i
+103
+i
+ = 0; i <
+BSP_IRQ_NUMBER
+; i++) {
+104
+œqPrioTabË
+i
+] = 8;
+105
+¹emsIrq
+i
+deçuÉIrq
+106
+¹emsIrq
+i
+Çme
+ = i;
+107 #ifdeà
+BSP_SHARED_HANDLER_SUPPORT
+108
+¹emsIrq
+i
+Ãxt_hªdËr
+NULL
+115
+š™Ÿl_cÚfig
+œqNb
+BSP_IRQ_NUMBER
+116
+š™Ÿl_cÚfig
+deçuÉEÁry
+deçuÉIrq
+117
+š™Ÿl_cÚfig
+œqHdlTbl
+¹emsIrq
+118
+š™Ÿl_cÚfig
+œqBa£
+BSP_LOWEST_OFFSET
+119
+š™Ÿl_cÚfig
+œqPrioTbl
+œqPrioTabË
+121 ià(!
+	`BSP_¹ems_œq_mngt_£t
+š™Ÿl_cÚfig
+125
+	`BSP_·nic
+("Unableo initialize RTEMS interrupt Management!!! System†ocked\n");
+128 #ifdeà
+TRACE_IRQ_INIT
+129
+	`´štk
+("RTEMS IRQ management is‚ow operational\n");
+131
+	@irq/no_pic.c
+13
+	~<¹ems.h
+14
+	~<b¥.h
+15
+	~<b¥/œq.h
+16
+	~<b¥/œq_suµ.h
+17
+	~<b¥/veùÜs.h
+19
+¹ems_œq_cÚÃù_d©a
+	g¹ems_hdl_tbl
+20
+¹ems_œq_cÚÃù_d©a
+	gdæt_’Œy
+25
+26
+BSP_Exû±iÚ_äame
+äame
+27
+excNum
+30
+œq
+31 #ià(
+HAS_PMC_PSC8
+32
+ušt16_t
+check_œq
+33
+ušt16_t
+¡©us_wÜd
+36 ià(
+excNum
+ =ð
+ASM_DEC_VECTOR
+37
+	`b¥_œq_di¥©ch_li¡
+¹ems_hdl_tbl
+BSP_DECREMENTER
+dæt_’Œy
+hdl
+41
+œq
+	`»ad_ªd_þ—r_œq
+43 #ià(
+HAS_PMC_PSC8
+44 ià(
+œq
+ =ð
+45
+¡©us_wÜd
+	`»ad_ªd_þ—r_PMC_œq
+Ð
+œq
+46
+check_œq
+SCORE603E_IRQ16
+; check_œq<=
+SCORE603E_IRQ19
+; check_irq++) {
+47 iàÐ
+	`Is_PMC_IRQ
+Ð
+check_œq
+¡©us_wÜd
+48
+	`b¥_œq_di¥©ch_li¡_ba£
+¹ems_hdl_tbl
+check_œq
+dæt_’Œy
+hdl
+54
+¹ems_hdl_tbl
+œq
+dæt_’Œy
+hdl
+58
+61
+	$BSP_’abË_œq_©_pic
+(cÚ¡
+¹ems_œq_numb”
+œq
+63
+ušt16_t
+vec_idx
+œq
+ScÜe_IRQ_Fœ¡
+64
+	`unmask_œq
+Ð
+vec_idx
+65
+68
+	$BSP_di§bË_œq_©_pic
+(cÚ¡
+¹ems_œq_numb”
+œq
+70
+ušt16_t
+vec_idx
+œq
+ScÜe_IRQ_Fœ¡
+71
+	`unmask_œq
+Ð
+vec_idx
+73
+76
+	$BSP_£tup_the_pic
+cÚfig
+78
+dæt_’Œy
+cÚfig
+deçuÉEÁry
+79
+¹ems_hdl_tbl
+cÚfig
+œqHdlTbl
+80
+	`š™_œq_d©a_»gi¡”
+82
+	@startup/Hwr_init.c
+11
+	~<b¥.h
+13
+	#PPC603e_SPR_HID0
+ 1008
+14
+	#PPC603e_SPR_HID1
+ 1009
+15
+	#PPC603e_SPR_IBAT0U
+ 528
+16
+	#PPC603e_SPR_IBAT0L
+ 529
+17
+	#PPC603e_SPR_DBAT0U
+ 536
+18
+	#PPC603e_SPR_DBAT0L
+ 537
+19
+	#PPC603e_SPR_IBAT1U
+ 530
+20
+	#PPC603e_SPR_IBAT1L
+ 531
+21
+	#PPC603e_SPR_DBAT1U
+ 538
+22
+	#PPC603e_SPR_DBAT1L
+ 539
+23
+	#PPC603e_SPR_IBAT2U
+ 532
+24
+	#PPC603e_SPR_IBAT2L
+ 533
+25
+	#PPC603e_SPR_DBAT2U
+ 540
+26
+	#PPC603e_SPR_DBAT2L
+ 541
+27
+	#PPC603e_SPR_IBAT3U
+ 534
+28
+	#PPC603e_SPR_IBAT3L
+ 535
+29
+	#PPC603e_SPR_DBAT3U
+ 542
+30
+	#PPC603e_SPR_DBAT3L
+ 543
+31
+	#PPC603e_SPR_DMISS
+ 976
+32
+	#PPC603e_SPR_DCMP
+ 977
+33
+	#PPC603e_SPR_HASH1
+ 978
+34
+	#PPC603e_SPR_HASH2
+ 979
+35
+	#PPC603e_SPR_IMISS
+ 980
+36
+	#PPC603e_SPR_ICMP
+ 981
+37
+	#PPC603e_SPR_RPA
+ 982
+38
+	#PPC603e_SPR_SDR1
+ 25
+39
+	#PPC603e_SPR_PVR
+ 287
+40
+	#PPC603e_SPR_DAR
+ 19
+41
+	#PPC603e_SPR_SPRG0
+ 272
+42
+	#PPC603e_SPR_SPRG1
+ 273
+43
+	#PPC603e_SPR_SPRG2
+ 274
+44
+	#PPC603e_SPR_SPRG3
+ 275
+45
+	#PPC603e_SPR_DSISR
+ 18
+46
+	#PPC603e_SPR_SRR0
+ 26
+47
+	#PPC603e_SPR_SRR1
+ 27
+48
+	#PPC603e_SPR_TBL_WRITE
+ 284
+49
+	#PPC603e_SPR_TBU_WRITE
+ 285
+50
+	#PPC603e_SPR_DEC
+ 22
+51
+	#PPC603e_SPR_IABR
+ 1010
+52
+	#PPC603e_SPR_EAR
+ 282
+54
+	#PCI_MEM_CMD
+SCORE603E_PCI_MEM_BASE
+ >> 16)
+57
+ušt32_t
+	mcouÁ”_1_100
+58
+ušt32_t
+	mcouÁ”_hours
+59
+ušt32_t
+	mcouÁ”_mš
+60
+ušt32_t
+	mcouÁ”_£c
+61
+ušt32_t
+	mcouÁ”_mÚth
+62
+ušt32_t
+	mcouÁ”_d©e
+63
+ušt32_t
+	mcouÁ”_y—r
+64
+ušt32_t
+	mcouÁ”_day_of_w“k
+66
+ušt32_t
+	mRAM_1_100
+67
+ušt32_t
+	mRAM_hours
+68
+ušt32_t
+	mRAM_mÚth
+69
+ušt32_t
+	mRAM_d©e
+70
+ušt32_t
+	mRAM_y—r
+71
+ušt32_t
+	mRAM_day_of_w“k
+73
+ušt32_t
+	mš‹ru±_¡©us_mask
+74
+ušt32_t
+	mcommªd_»gi¡”
+75 }
+	tH¬ris_RTC
+77
+	$š™_RTC
+79 vÞ©ž
+H¬ris_RTC
+the_RTC
+81
+the_RTC
+ = (vÞ©ž
+H¬ris_RTC
+BSP_RTC_ADDRESS
+83
+the_RTC
+commªd_»gi¡”
+ = 0x0;
+84
+86
+	$š™_PCI
+90
+92
+	#PPC_G‘_HID0
+Ð
+_v®ue
+94
+_v®ue
+ = 0; \
+95
+__asm__
+ volatile( \
+98 : "ô" (
+_v®ue
+99 : "0" (
+_v®ue
+101 } 0)
+103
+	#PPC_S‘_HID0
+Ð
+_v®ue
+105
+__asm__
+ volatile( \
+109 : "ô" (
+_v®ue
+110 : "0" (
+_v®ue
+112 } 0)
+114
+	$š¡ruùiÚ_ÿche_’abË
+116
+ušt32_t
+v®ue
+122
+	`PPC_G‘_HID0
+Ð
+v®ue
+124
+v®ue
+ |= 0x00008000;
+126
+	`PPC_S‘_HID0
+Ð
+v®ue
+127
+129
+	$d©a_ÿche_’abË
+131
+ušt32_t
+v®ue
+137
+	`PPC_G‘_HID0
+Ð
+v®ue
+139
+v®ue
+ |= 0x00004000;
+141
+	`PPC_S‘_HID0
+Ð
+v®ue
+142
+	@startup/bspstart.c
+14
+	~<¡ršg.h
+16
+	~<b¥.h
+17
+	~<b¥/boÙÿrd.h
+18
+	~<¹ems/libio.h
+19
+20
+	~<¹ems/b¥Io.h
+21
+	~<¹ems/couÁ”.h
+22
+	~<libýu/ýuId’t.h
+23
+	~<b¥/œq.h
+25
+	#DEBUG
+ 0
+30
+	gBSP_h—p_¡¬t
+35
+	gBSP_bus_äequ’cy
+40
+	gBSP_´oûssÜ_äequ’cy
+47
+	gBSP_time_ba£_divisÜ
+ = 3960;
+52
+ušt32_t
+	gb¥_þicks_³r_u£c
+57
+RamSize
+58
+ušt32_t
+	gBSP_mem_size
+60
+__¹ems_’d
+62
+	$BSP_·nic
+s
+64
+	`´štk
+("% PANIC %s\n",
+_RTEMS_v”siÚ
+s
+65
+__asm__
+	`__vÞ©že
+ ("sc");
+66
+68
+	$_BSP_F©®_”rÜ
+v
+70
+	`´štk
+("% PANIC ERROR %x\n",
+_RTEMS_v”siÚ
+v
+71
+__asm__
+	`__vÞ©že
+ ("sc");
+72
+79
+š™_RTC
+80
+š™Ÿlize_PMC
+82
+	$b¥_´edriv”_hook
+84
+	`š™_PCI
+85
+	`š™Ÿlize_univ”£
+87 #ià
+DEBUG
+88
+	`´štk
+("bsp_predriver_hook: initialize_PCI_bridge\n");
+90
+	`š™Ÿlize_PCI_bridge
+92 #ià(
+HAS_PMC_PSC8
+93 #ià
+DEBUG
+94
+	`´štk
+("bsp_predriver_hook: initialize_PMC\n");
+96
+	`š™Ÿlize_PMC
+99 #ià
+DEBUG
+100
+	`´štk
+("bsp_predriver_hook: End of„outine\n");
+103
+110
+	$š™Ÿlize_PMC
+111 vÞ©ž
+ušt32_t
+PMC_addr
+112
+ušt32_t
+d©a
+117
+PMC_addr
+	`BSP_PCI_DEVICE_ADDRESS
+( 0x4 );
+118 *
+PMC_addr
+ = 0x020080cc;
+119 #ià
+DEBUG
+120
+	`´štk
+("š™Ÿlize_PMC: 0x%x = 0x%x\n",
+PMC_addr
+, 0x020080cc);
+126
+PMC_addr
+( 0x14 );
+127 *
+PMC_addr
+ >> 24) & 0x3f;
+128 #ià
+DEBUG
+129
+	`´štk
+PMC_addr
+ >> 24) & 0x3f));
+132
+PMC_addr
+ = (vÞ©ž
+ušt32_t
+133
+( 0x100000 );
+134
+d©a
+PMC_addr
+135 #ià
+DEBUG
+136
+	`´štk
+("š™Ÿlize_PMC: R—d 0x%x (0x%x)\n",
+PMC_addr
+d©a
+137
+	`´štk
+PMC_addr
+d©a
+ & 0xfc );
+139 *
+PMC_addr
+d©a
+ & 0xfc;
+140
+149
+	$b¥_¡¬t
+151
+m¤_v®ue
+ = 0x0000;
+152
+ušŒ_t
+šŒSckS¹
+153
+ušŒ_t
+šŒSckSize
+154
+µc_ýu_id_t
+myCpu
+155
+µc_ýu_»visiÚ_t
+myCpuRevisiÚ
+157
+	`¹ems_b¥_d–ay
+( 1000 );
+162 #ià
+DEBUG
+163
+	`´štk
+("bsp_start: Zero out†ots of memory\n");
+166
+BSP_´oûssÜ_äequ’cy
+ = 266000000;
+167
+BSP_bus_äequ’cy
+ = 66000000;
+174
+myCpu
+	`g‘_µc_ýu_ty³
+175
+myCpuRevisiÚ
+	`g‘_µc_ýu_»visiÚ
+176
+	`´štk
+("Cpu: 0x%x RevisiÚ: %d\n",
+myCpu
+myCpuRevisiÚ
+177
+	`´štk
+("Cpu %s\n",
+	`g‘_µc_ýu_ty³_Çme
+myCpu
+182
+šŒSckS¹
+ušŒ_t
+è
+__¹ems_’d
+183
+šŒSckSize
+	`¹ems_cÚfigu¿tiÚ_g‘_š‹¼u±_¡ack_size
+184
+	`´štk
+("Interrupt Stack Start: 0x%x Size: 0x%x Heap Start: 0x%x\n",
+185
+šŒSckS¹
+šŒSckSize
+BSP_h—p_¡¬t
+188
+BSP_mem_size
+ušt32_t
+è
+RamSize
+189
+	`´štk
+("BSP_mem_size: %p\n",
+RamSize
+194
+	`µc_exc_š™Ÿlize
+šŒSckS¹
+šŒSckSize
+196
+m¤_v®ue
+ = 0x2030;
+197
+	`_CPU_MSR_SET
+Ð
+m¤_v®ue
+198
+__asm__
+ volatile("sync; isync");
+203 #ià
+DEBUG
+204
+	`´štk
+("bsp_start: set clicks…oer usec\n");
+206
+b¥_þicks_³r_u£c
+ = 66 / 4;
+207
+	`¹ems_couÁ”_š™Ÿlize_cÚv”‹r
+b¥_þicks_³r_u£c
+ * 1000000);
+209 #ià
+BSP_DATA_CACHE_ENABLED
+210 #ià
+DEBUG
+211
+	`´štk
+("bsp_start: cache_enable\n");
+213
+	`š¡ruùiÚ_ÿche_’abË
+214
+	`d©a_ÿche_’abË
+215 #ià
+DEBUG
+216
+	`´štk
+("bsp_start: END BSP_DATA_CACHE_ENABLED\n");
+223 #ià
+DEBUG
+224
+	`´štk
+("bspstart: Call BSP_rtems_irq_mng_init\n");
+226
+	`BSP_¹ems_œq_mng_š™
+(0);
+228 #ià
+DEBUG
+229
+	`´štk
+("bsp_start:ƒnd BSPSTART\n");
+230
+	`ShowBATS
+232
+	@startup/genpvec.c
+13
+	~<b¥.h
+14
+	~<¹ems/chaš.h
+15
+	~<¹ems/b¥Io.h
+16
+	~<as£¹.h
+18
+	~<¡dio.h
+24
+¹ems_i¤
+ex‹º®_exû±iÚ_ISR
+25
+¹ems_veùÜ_numb”
+veùÜ
+28
+	#NUM_LIRQ_HANDLERS
+ 20
+29
+	#NUM_LIRQ
+MAX_BOARD_IRQS
+PPC_IRQ_LAST
+37
+¹ems_chaš_node
+	mNode
+38
+¹ems_i¤_’Œy
+	mhªdËr
+39
+¹ems_veùÜ_numb”
+	mveùÜ
+40 }
+	tEE_ISR_Ty³
+45
+EE_ISR_Ty³
+	gISR_Nodes
+NUM_LIRQ_HANDLERS
+46
+ušt16_t
+	gNodes_U£d
+47
+¹ems_chaš_cÚŒÞ
+	gISR_A¼ay
+NUM_LIRQ
+50
+š™_œq_d©a_»gi¡”
+52
+	$In™_EE_mask_š™
+54
+60
+¹ems_i¤_’Œy
+	$£t_EE_veùÜ
+61
+¹ems_i¤_’Œy
+hªdËr
+62
+¹ems_veùÜ_numb”
+veùÜ
+65
+ušt16_t
+vec_idx
+veùÜ
+ScÜe_IRQ_Fœ¡
+66
+ušt32_t
+šdex
+68
+	`as£¹
+Nodes_U£d
+NUM_LIRQ_HANDLERS
+75
+šdex
+=0 ; index <ð
+Nodes_U£d
+ ; index++ ) {
+76 iàÐ
+ISR_Nodes
+šdex
+veùÜ
+ == vector &&
+77
+ISR_Nodes
+šdex
+hªdËr
+ == handler )
+78
+NULL
+85
+Nodes_U£d
+87
+šdex
+Nodes_U£d
+ - 1;
+89
+ISR_Nodes
+šdex
+hªdËr
+ = handler;
+90
+ISR_Nodes
+šdex
+veùÜ
+ = vector;
+95
+	`¹ems_chaš_­³nd
+Ð&
+ISR_A¼ay
+vec_idx
+ISR_Nodes
+šdex
+Node
+100
+	`unmask_œq
+Ð
+vec_idx
+102
+NULL
+103
+108
+¹ems_i¤
+	$ex‹º®_exû±iÚ_ISR
+109
+¹ems_veùÜ_numb”
+veùÜ
+112
+ušt16_t
+šdex
+113
+EE_ISR_Ty³
+node
+114
+ušt16_t
+v®ue
+115 #ià(
+HAS_PMC_PSC8
+116
+ušt16_t
+PMC_œq
+117
+ušt16_t
+check_œq
+118
+ušt16_t
+¡©us_wÜd
+121
+šdex
+	`»ad_ªd_þ—r_œq
+122 iàÐ
+šdex
+ >ð
+NUM_LIRQ
+123
+	`´štk
+Ð"ERROR:: Inv®id iÁ”ru±‚umb” (%02x)\n",
+šdex
+127 #ià(
+HAS_PMC_PSC8
+128
+PMC_œq
+SCORE603E_IRQ00
+130 ià(
+šdex
+ =ð
+PMC_œq
+131
+¡©us_wÜd
+Ð
+šdex
+133
+check_œq
+SCORE603E_IRQ16
+; check_œq<=
+SCORE603E_IRQ19
+; check_irq++) {
+134 iàÐ
+	`Is_PMC_IRQ
+Ð
+check_œq
+¡©us_wÜd
+135
+šdex
+check_œq
+SCORE603E_IRQ00
+136
+node
+EE_ISR_Ty³
+ISR_A¼ay
+šdex
+fœ¡
+138 iàÐ
+	`¹ems_chaš_is_ž
+Ð&
+ISR_A¼ay
+šdex
+node
+139
+	`´štk
+ ("ERROR:: check %d iÁ”ru± %02d ha nØi¤\n",
+check_œq
+šdex
+140
+v®ue
+	`g‘_œq_mask
+141
+	`´štk
+(" Mask = %02x\n",
+v®ue
+143  !
+	`¹ems_chaš_is_ž
+Ð&
+ISR_A¼ay
+šdex
+node
+144 (*
+node
+hªdËr
+)Ðnode->
+veùÜ
+145
+node
+EE_ISR_Ty³
+ *ènode->
+Node
+Ãxt
+153
+node
+EE_ISR_Ty³
+ISR_A¼ay
+šdex
+fœ¡
+154 iàÐ
+	`¹ems_chaš_is_ž
+Ð&
+ISR_A¼ay
+šdex
+node
+155
+	`´štk
+Ð"ERROR:: iÁ”ru± %02x ha nØi¤\n",
+šdex
+156
+v®ue
+	`g‘_œq_mask
+157
+	`´štk
+(" Mask = %02x\n",
+v®ue
+160  !
+	`¹ems_chaš_is_ž
+Ð&
+ISR_A¼ay
+šdex
+node
+161 (*
+node
+hªdËr
+)Ðnode->
+veùÜ
+162
+node
+EE_ISR_Ty³
+ *ènode->
+Node
+Ãxt
+166
+	@startup/vmeintr.c
+14
+	~<¹ems.h
+15
+	~<b¥.h
+16
+	~<¹ems/vmešŒ.h
+21
+	$VME_š‹¼u±_Di§bË
+22
+VME_š‹¼u±_Mask
+mask
+25 vÞ©ž
+ušt8_t
+VME_š‹¼u±_’abË
+26
+ušt8_t
+v®ue
+28
+VME_š‹¼u±_’abË
+ = 0;
+29
+v®ue
+VME_š‹¼u±_’abË
+30
+v®ue
+ &ð~
+mask
+31 *
+VME_š‹¼u±_’abË
+v®ue
+32
+37
+	$VME_š‹¼u±_EÇbË
+38
+VME_š‹¼u±_Mask
+mask
+41 vÞ©ž
+ušt8_t
+VME_š‹¼u±_’abË
+42
+ušt8_t
+v®ue
+44
+VME_š‹¼u±_’abË
+ = 0;
+45
+v®ue
+VME_š‹¼u±_’abË
+46
+v®ue
+ |ð
+mask
+47 *
+VME_š‹¼u±_’abË
+v®ue
+48
+	@timer/timer.c
+18
+	~<as£¹.h
+20
+	~<b¥.h
+21
+	~<¹ems/btim”.h
+23
+ušt64_t
+	gTim”_driv”_S¹_time
+25
+boÞ
+	gb’chm¬k_tim”_fšd_av”age_ov”h—d
+31
+	$b’chm¬k_tim”_š™Ÿlize
+38
+Tim”_driv”_S¹_time
+	`PPC_G‘_timeba£_»gi¡”
+39
+45
+b’chm¬k_tim”_t
+	$b’chm¬k_tim”_»ad
+47
+ušt64_t
+þicks
+48
+ušt64_t
+tÙ®64
+49
+ušt32_t
+tÙ®
+53
+þicks
+55
+	`as£¹
+Ð
+þicks
+57
+tÙ®64
+þicks
+59
+	`as£¹
+Ð
+tÙ®64
+ <= 0xffffffff );
+61
+tÙ®
+ušt32_t
+è
+tÙ®64
+63 iàÐ
+b’chm¬k_tim”_fšd_av”age_ov”h—d
+ =ð
+Œue
+64
+tÙ®
+66 iàÐ
+tÙ®
+BSP_TIMER_LEAST_VALID
+69
+	`BSP_CÚv”t_deüem’‹r
+tÙ®
+BSP_TIMER_AVG_OVERHEAD
+70
+72
+	$b’chm¬k_tim”_di§bË_subŒaùšg_av”age_ov”h—d
+73
+boÞ
+fšd_æag
+76
+fšd_æag
+77
+	@tod/tod.c
+14
+	~<¹ems.h
+15
+	~<tod.h
+16
+	~<b¥.h
+22
+ 0x00
+23
+ 0x01
+24
+ 0x02
+25
+ 0x03
+27
+ICM7170_G‘TOD
+28 vÞ©ž*
+imc1770_»gs
+29
+ušt8_t
+icm1770_äeq
+30
+¹ems_time_of_day
+¹c_tod
+32
+ICM7170_S‘TOD
+33 vÞ©ž*
+imc1770_»gs
+34
+ušt8_t
+icm1770_äeq
+35
+¹ems_time_of_day
+¹c_tod
+43
+	$£tR—lTimeToRTEMS
+45
+¹ems_time_of_day
+¹c_tod
+47
+	`ICM7170_G‘TOD
+Ð
+BSP_RTC_ADDRESS
+BSP_RTC_FREQUENCY
+¹c_tod
+48
+	`¹ems_þock_£t
+Ð&
+¹c_tod
+49
+51
+	$£tR—lTimeFromRTEMS
+53
+¹ems_time_of_day
+¹ems_tod
+55
+	`¹ems_þock_g‘
+Ð
+RTEMS_CLOCK_GET_TOD
+¹ems_tod
+56
+	`ICM7170_S‘TOD
+Ð
+BSP_RTC_ADDRESS
+BSP_RTC_FREQUENCY
+¹ems_tod
+57
+59
+	$checkR—lTime
+61
+¹ems_time_of_day
+¹ems_tod
+62
+¹ems_time_of_day
+¹c_tod
+64
+	`ICM7170_G‘TOD
+Ð
+BSP_RTC_ADDRESS
+BSP_RTC_FREQUENCY
+¹c_tod
+65
+	`¹ems_þock_g‘
+Ð
+¹ems_tod
+67 ifÐ
+¹ems_tod
+y—r
+ =ð
+¹c_tod
+.year &&
+68
+¹ems_tod
+mÚth
+ =ð
+¹c_tod
+.month &&
+69
+¹ems_tod
+day
+ =ð
+¹c_tod
+.day ) {
+70  ((
+¹ems_tod
+hour
+¹c_tod
+.hour) * 3600) +
+71 ((
+¹ems_tod
+mšu‹
+¹c_tod
+.minute) * 60) +
+72 (
+¹ems_tod
+£cÚd
+¹c_tod
+.second);
+75
+82
+	$ICM7170_G‘F›ld
+83 vÞ©ž*
+imc1770_»gs
+84
+»g
+87
+x
+89
+x
+imc1770_»gs
+»g
+*4];
+91
+x
+92
+94
+	$ICM7170_S‘F›ld
+95 vÞ©ž*
+imc1770_»gs
+96
+»g
+97
+d
+100
+imc1770_»gs
+»g
+*4] =
+d
+101
+103
+	$ICM7170_G‘TOD
+104 vÞ©ž*
+imc1770_»gs
+105
+ušt8_t
+icm1770_äeq
+106
+¹ems_time_of_day
+¹c_tod
+109
+y—r
+110
+u£c
+111
+boÞ
+š™
+Œue
+114 ià(
+š™
+115
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x11, (0x0ø|
+icm1770_äeq
+116
+š™
+çl£
+122
+u£c
+	`ICM7170_G‘F›ld
+Ð
+imc1770_»gs
+, 0x00 );
+124
+y—r
+	`ICM7170_G‘F›ld
+Ð
+imc1770_»gs
+, 0x06 );
+125 iàÐ
+y—r
+ >= 88 )
+126
+y—r
+ += 1900;
+128
+y—r
+ += 2000;
+130
+¹c_tod
+y—r
+ = year;
+131
+¹c_tod
+mÚth
+	`ICM7170_G‘F›ld
+Ð
+imc1770_»gs
+, 0x04 );
+132
+¹c_tod
+day
+	`ICM7170_G‘F›ld
+Ð
+imc1770_»gs
+, 0x05 );
+133
+¹c_tod
+hour
+	`ICM7170_G‘F›ld
+Ð
+imc1770_»gs
+, 0x01 );
+134
+¹c_tod
+mšu‹
+	`ICM7170_G‘F›ld
+Ð
+imc1770_»gs
+, 0x02 );
+135
+¹c_tod
+£cÚd
+	`ICM7170_G‘F›ld
+Ð
+imc1770_»gs
+, 0x03 );
+136
+¹c_tod
+ticks
+	`ICM7170_G‘F›ld
+Ð
+imc1770_»gs
+, 0x00 );
+137
+139
+	$ICM7170_S‘TOD
+140 vÞ©ž*
+imc1770_»gs
+141
+ušt8_t
+icm1770_äeq
+142
+¹ems_time_of_day
+¹c_tod
+145
+y—r
+147
+y—r
+¹c_tod
+->year;
+148 iàÐ
+y—r
+ >= 2088 )
+149
+( 0xBAD0BAD0 );
+151 iàÐ
+y—r
+ >= 2000 )
+152
+y—r
+ -= 2000;
+154
+y—r
+ -= 1900;
+156
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x11, (0x04 |
+icm1770_äeq
+158
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x06,
+y—r
+159
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x04,
+¹c_tod
+mÚth
+160
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x05,
+¹c_tod
+day
+161
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x01,
+¹c_tod
+hour
+162
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x02,
+¹c_tod
+mšu‹
+163
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x03,
+¹c_tod
+£cÚd
+169
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x07, 1 );
+171
+	`ICM7170_S‘F›ld
+Ð
+imc1770_»gs
+, 0x11, (0x0ø|
+icm1770_äeq
+172
+	@vme/VMEConfig.h
+1 #iâdeà
+RTEMS_BSP_VME_CONFIG_H
+2
+	#RTEMS_BSP_VME_CONFIG_H
+63 #undeà
+BSP_VME_BAT_IDX
+65
+	#_VME_A32_WIN0_ON_PCI
+ 0x10000000
+66
+	#_VME_A24_ON_PCI
+ 0x1f000000
+67
+	#_VME_A16_ON_PCI
+ 0x1fff0000
+72
+	#_VME_A32_WIN0_ON_VME
+ 0x20000000
+78 #undeà
+_VME_DRAM_OFFSET
+85 #undeà
+_VME_CSR_ON_PCI
+87 #undeà
+BSP_PCI_VME_DRIVER_DOES_EOI
+89
+BSP_VMEIn™
+90
+BSP_VMEIrqMgrIn¡®l
+92
+	#BSP_VME_UNIVERSE_INSTALL_IRQ_MGR
+”r
+94
+”r
+	`vmeUniv”£In¡®lIrqMgr
+(0,5,1,6); \
+95 } 0)
+1
+0
+24
+370
+PCI_bus/PCI.c
+PCI_bus/PCI.h
+PCI_bus/flash.c
+PCI_bus/universe.c
+console/85c30.c
+console/85c30.h
+console/console.c
+console/consolebsp.h
+console/tbl85c30.c
+include/bsp.h
+include/gen2.h
+include/tm27.h
+irq/FPGA.c
+irq/irq.c
+irq/irq.h
+irq/irq_init.c
+irq/no_pic.c
+startup/Hwr_init.c
+startup/bspstart.c
+startup/genpvec.c
+startup/vmeintr.c
+timer/timer.c
+tod/tod.c
+vme/VMEConfig.h
diff --git a/c/src/lib/libbsp/powerpc/score603e/include/bsp.h b/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
index f6e3c5a..dc78498 100644
--- a/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/score603e/include/bsp.h
@@ -1,8 +1,9 @@
-/*  bsp.h
  *  This include file contains all board IO definitions.
- *  COPYRIGHT (c) 1989-2009.
+ *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
@@ -123,68 +124,55 @@ rtems_isr_entry  set_EE_vector(
   rtems_isr_entry     handler,                  /* isr routine        */
   rtems_vector_number vector                    /* vector number      */
-void initialize_external_exception_vector ();
+void initialize_external_exception_vector(void);
  * Hwr_init.c
-void init_PCI();
-void instruction_cache_enable ();
-void data_cache_enable ();
+void init_PCI(void);
+void init_RTC(void);
+void instruction_cache_enable(void);
+void data_cache_enable(void);
-void initialize_PCI_bridge ();
-uint16_t         read_and_clear_irq ();
-void set_irq_mask(
-  uint16_t         value
-uint16_t         get_irq_mask();
+void     initialize_PCI_bridge(void);
+uint16_t read_and_clear_irq(void);
+void     set_irq_mask(uint16_t value);
+uint16_t get_irq_mask(void);
  * universe.c
-void initialize_universe();
-void set_irq_mask(
-  uint16_t         value
-void unmask_irq(
-  uint16_t         irq_idx
-void mask_irq(
-  uint16_t         irq_idx
-void init_irq_data_register();
-uint16_t         read_and_clear_PMC_irq(
-  uint16_t            irq
-bool Is_PMC_IRQ(
-  uint32_t           pmc_irq,
-  uint16_t           status_word
-uint16_t         read_and_clear_irq();
+void     initialize_universe(void);
+void     unmask_irq(uint16_t irq_idx);
+void     mask_irq(uint16_t irq_idx);
+void     init_irq_data_register(void);
+uint16_t read_and_clear_PMC_irq(uint16_t irq);
+bool     Is_PMC_IRQ( uint32_t pmc_irq, uint16_t status_word);
+void set_vme_base_address(uint32_t base_address);
+uint32_t get_vme_slave_size(void);
+void set_vme_slave_size (uint32_t size);
  * FPGA.c
+uint32_t Read_pci_device_register(uint32_t address);
+void  Write_pci_device_register(uint32_t address, uint32_t data);
 /* flash.c */
+unsigned int SCORE603e_FLASH_Disable(uint32_t unused);
+unsigned int SCORE603e_FLASH_verify_enable(void);
+unsigned int SCORE603e_FLASH_Enable_writes(uint32_t area);
-unsigned int SCORE603e_FLASH_Disable(
-  uint32_t                       unused
-unsigned int SCORE603e_FLASH_verify_enable();
-unsigned int SCORE603e_FLASH_Enable_writes(
-  uint32_t                       area        /* Unused  */
+ * PCI.c
+uint32_t PCI_bus_read(volatile uint32_t *_addr);
+void PCI_bus_write(volatile uint32_t *_addr, uint32_t _data);
 #define BSP_FLASH_ENABLE_WRITES( _area) SCORE603e_FLASH_Enable_writes( _area )
 #define BSP_FLASH_DISABLE_WRITES(_area) SCORE603e_FLASH_Disable( _area )
diff --git a/c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c b/c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c
index 33e22de..9c08d1d 100644
--- a/c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c
+++ b/c/src/lib/libbsp/powerpc/score603e/irq/FPGA.c
@@ -1,6 +1,9 @@
-/*  FPGA.c -- Bridge for second and subsequent generations
+ * FPGA.c -- Bridge for second and subsequent generations
@@ -120,7 +123,7 @@ void init_irq_data_register(void)
   uint16_t            irq
1.9.3
