[PATCH 54/62] libcpu/powerpc/e500/mmu/mmu.c: Fix warnings
Wed Oct 15 20:00:44 UTC 2014
 c/src/lib/libcpu/powerpc/e500/mmu/mmu.c | 662 ++++++++++++++++----------------
 1 file changed, 331 insertions(+), 331 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/e500/mmu/mmu.c b/c/src/lib/libcpu/powerpc/e500/mmu/mmu.c
index a972a65..c93a660 100644
--- a/c/src/lib/libcpu/powerpc/e500/mmu/mmu.c
+++ b/c/src/lib/libcpu/powerpc/e500/mmu/mmu.c
@@ -22,13 +22,13 @@
  * This software was created by
  *     Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
- * 	   Stanford Linear Accelerator Center, Stanford University.
+ *      Stanford Linear Accelerator Center, Stanford University.
  * Acknowledgement of sponsorship
  * This software was produced by
  *     the Stanford Linear Accelerator Center, Stanford University,
- * 	   under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ *      under Contract DE-AC03-76SFO0515 with the Department of Energy.
  * Government disclaimer of liability
@@ -76,13 +76,13 @@
 #include "e500_mmu.h"
-#define TLBIVAX_TLBSEL	(1<<(63-60))
-#define TLBIVAX_INV_ALL	(1<<(63-61))
+#define TLBIVAX_TLBSEL  (1<<(63-60))
+#define TLBIVAX_INV_ALL  (1<<(63-61))
-#define E500_TLB_ATTR_WIMGE(x)      ((x)&0x7f)				/* includes user bits */
+#define E500_TLB_ATTR_WIMGE(x)      ((x)&0x7f)        /* includes user bits */
 #define E500_TLB_ATTR_WIMGE_GET(x)  ((x)&0x7f)
 #define E500_TLB_ATTR_TS            (1<<7)
-#define E500_TLB_ATTR_PERM(x)   	(((x)&0x3ff)<<8)
+#define E500_TLB_ATTR_PERM(x)     (((x)&0x3ff)<<8)
 #define E500_TLB_ATTR_PERM_GET(x)   (((x)>>8)&0x3ff)
 #define E500_TLB_ATTR_TID(x)        (((x)&0xfff)<<20)
 #define E500_TLB_ATTR_TID_GET(x)    (((x)>>20)&0xfff)
@@ -95,11 +95,11 @@
 #endif
 /* Factory to generate inline macros for accessing the MAS registers */
-#define __RDWRMAS(mas,rmas)	\
-	static inline uint32_t _read_MAS##mas(void)	                                 \
-	{ uint32_t x; __asm__ volatile("mfspr %0, %1": "=r"(x):"i"(rmas)); return x; } \
-	static inline void _write_MAS##mas(uint32_t x)                             \
-	{             __asm__ volatile("mtspr %1, %0":: "r"(x),"i"(rmas)); }
+#define __RDWRMAS(mas,rmas)  \
+  static inline uint32_t _read_MAS##mas(void)                                   \
+  { uint32_t x; __asm__ volatile("mfspr %0, %1": "=r"(x):"i"(rmas)); return x; } \
+  static inline void _write_MAS##mas(uint32_t x)                             \
+  {             __asm__ volatile("mtspr %1, %0":: "r"(x),"i"(rmas)); }
 __RDWRMAS(0,FSL_EIS_MAS0)
 __RDWRMAS(1,FSL_EIS_MAS1)
@@ -121,19 +121,19 @@ E500_tlb_va_cache_t rtems_e500_tlb_va_cache[16];
 static void
 myprintf(FILE *f, char *fmt, ...)
-va_list ap;
-    va_start(ap, fmt);
-    if (!f || !_impure_ptr->__sdidinit) {
-		 * Might be called at an early stage when
-         * stdio is not yet initialized.
-        vprintk(fmt,ap);
-    } else {
-        vfprintf(f,fmt,ap);
-    va_end(ap);
+  va_list ap;
+  va_start(ap, fmt);
+  if (!f || !_impure_ptr->__sdidinit) {
+       * Might be called at an early stage when
+       * stdio is not yet initialized.
+      vprintk(fmt,ap);
+  } else {
+      vfprintf(f,fmt,ap);
+  va_end(ap);
@@ -141,38 +141,38 @@ void
 rtems_e500_dmptlbc(FILE *f)
 int i;
-	if ( !initialized ) {
-		myprintf(stderr,"TLB cache not initialized\n");
-		return;
-	for ( i=0; i<16; i++ ) {
-		if ( !rtems_e500_tlb_va_cache[i].att.v )
-			continue;
-		myprintf(f,"#%2i: TID 0x%03x, TS %i, ea 0x%08x .. 0x%08x\n",
-			i,
-			rtems_e500_tlb_va_cache[i].va.va_tid,
-			rtems_e500_tlb_va_cache[i].att.ts,
-			rtems_e500_tlb_va_cache[i].va.va_epn<<12,
-			(rtems_e500_tlb_va_cache[i].va.va_epn<<12) + (1024<<(2*rtems_e500_tlb_va_cache[i].att.sz))-1);
-		myprintf(f,"PA 0x%08"PRIx32", PERM 0x%03x, WIMGE 0x%02x\n",
-			rtems_e500_tlb_va_cache[i].rpn<<12,
-			rtems_e500_tlb_va_cache[i].att.perm,
-			rtems_e500_tlb_va_cache[i].att.wimge);
+  if ( !initialized ) {
+    myprintf(stderr,"TLB cache not initialized\n");
+    return;
+  for ( i=0; i<16; i++ ) {
+    if ( !rtems_e500_tlb_va_cache[i].att.v )
+      continue;
+    myprintf(f,"#%2i: TID 0x%03x, TS %i, ea 0x%08x .. 0x%08x\n",
+      i,
+      rtems_e500_tlb_va_cache[i].va.va_tid,
+      rtems_e500_tlb_va_cache[i].att.ts,
+      rtems_e500_tlb_va_cache[i].va.va_epn<<12,
+      (rtems_e500_tlb_va_cache[i].va.va_epn<<12) + (1024<<(2*rtems_e500_tlb_va_cache[i].att.sz))-1);
+    myprintf(f,"PA 0x%08"PRIx32", PERM 0x%03x, WIMGE 0x%02x\n",
+      rtems_e500_tlb_va_cache[i].rpn<<12,
+      rtems_e500_tlb_va_cache[i].att.perm,
+      rtems_e500_tlb_va_cache[i].att.wimge);
-#define E500_SELTLB_1	0x1000
+#define E500_SELTLB_1  0x1000
 static void seltlb(rtems_e500_tlb_idx key)
 int idx = key & ~E500_SELTLB_1;
-	if ( key & E500_SELTLB_1 ) {
-		_write_MAS0( FSL_EIS_MAS0_TLBSEL | FSL_EIS_MAS0_ESEL(idx) );
-	} else {
-		_write_MAS0( (idx & 128) ? FSL_EIS_MAS0_ESEL(1) : FSL_EIS_MAS0_ESEL(0) );
-		_write_MAS2( FSL_EIS_MAS2_EPN( idx & 127 ) );
+  if ( key & E500_SELTLB_1 ) {
+    _write_MAS0( FSL_EIS_MAS0_TLBSEL | FSL_EIS_MAS0_ESEL(idx) );
+  } else {
+    _write_MAS0( (idx & 128) ? FSL_EIS_MAS0_ESEL(1) : FSL_EIS_MAS0_ESEL(0) );
+    _write_MAS2( FSL_EIS_MAS2_EPN( idx & 127 ) );
@@ -199,84 +199,84 @@ int idx = key & ~E500_SELTLB_1;
 int
 rtems_e500_prtlb(rtems_e500_tlb_idx key, int quiet, FILE *f)
-uint32_t               mas0, mas1, mas2, mas3;
-rtems_interrupt_level  lvl;
-E500_tlb_va_cache_t   *tlb;
-E500_tlb_va_cache_t    buf;
-int                    sel, idx;
+  uint32_t               mas1, mas2, mas3;
+  rtems_interrupt_level  lvl;
+  E500_tlb_va_cache_t   *tlb;
+  E500_tlb_va_cache_t    buf;
+  int                    sel, idx;
-	sel = (key &  E500_SELTLB_1) ? 1 : 0;
-	idx = key & ~E500_SELTLB_1;
+  sel = (key &  E500_SELTLB_1) ? 1 : 0;
+  idx = key & ~E500_SELTLB_1;
-	if ( idx < 0 || idx > 255 || ( idx > 15 && sel ) )
-		return -1;
+  if ( idx < 0 || idx > 255 || ( idx > 15 && sel ) )
+    return -1;
-	rtems_interrupt_disable(lvl);
+  rtems_interrupt_disable(lvl);
-	seltlb( key );
+  seltlb( key );
-	asm volatile("tlbre");
+  asm volatile("tlbre");
-	mas0 = _read_MAS0();
-	mas1 = _read_MAS1();
-	mas2 = _read_MAS2();
-	mas3 = _read_MAS3();
+  /* not manipulating MAS0, skip reading it */
+  mas1 = _read_MAS1();
+  mas2 = _read_MAS2();
+  mas3 = _read_MAS3();
-	rtems_interrupt_enable(lvl);
+  rtems_interrupt_enable(lvl);
-	tlb = sel ? rtems_e500_tlb_va_cache + idx : &buf;
+  tlb = sel ? rtems_e500_tlb_va_cache + idx : &buf;
-	if ( (tlb->att.v  = (FSL_EIS_MAS1_V & mas1) ? 1 : 0) ) {
-		tlb->va.va_epn = FSL_EIS_MAS2_EPN_GET(mas2);
-		tlb->rpn       = FSL_EIS_MAS3_RPN_GET(mas3);
-		tlb->va.va_tid = FSL_EIS_MAS1_TID_GET(mas1);
-		tlb->att.ts    = (FSL_EIS_MAS1_TS & mas1) ? 1 : 0;
-		tlb->att.sz    = sel ? FSL_EIS_MAS1_TSIZE_GET(mas1) : 1 /* 4k size */;
-		tlb->att.wimge = FSL_EIS_MAS2_ATTR_GET(mas2);
-		tlb->att.perm  = FSL_EIS_MAS3_PERM_GET(mas3);
+  if ( (tlb->att.v  = (FSL_EIS_MAS1_V & mas1) ? 1 : 0) ) {
+    tlb->va.va_epn = FSL_EIS_MAS2_EPN_GET(mas2);
+    tlb->rpn       = FSL_EIS_MAS3_RPN_GET(mas3);
+    tlb->va.va_tid = FSL_EIS_MAS1_TID_GET(mas1);
+    tlb->att.ts    = (FSL_EIS_MAS1_TS & mas1) ? 1 : 0;
+    tlb->att.sz    = sel ? FSL_EIS_MAS1_TSIZE_GET(mas1) : 1 /* 4k size */;
+    tlb->att.wimge = FSL_EIS_MAS2_ATTR_GET(mas2);
+    tlb->att.perm  = FSL_EIS_MAS3_PERM_GET(mas3);
-	if ( tlb->att.v ) {
-		if ( !quiet ) {
+  if ( tlb->att.v ) {
+    if ( !quiet ) {
-			"TLB[1] Entry # 0 spans EA range     0x00000000 .. 0x00000000
-			"Mapping:    VA     [TS 0/TID 0x00/EPN 0x00000] -> RPN 0x00000"
-			"Size:       TSIZE  0x0 ( 4^ts KiB = 000000 KiB = 0x00000000 B)
-			"Attributes: PERM 0x000 (ux/sx/uw/sw/ur/sr) WIMGE 0x00 IPROT 0"
+      "TLB[1] Entry # 0 spans EA range     0x00000000 .. 0x00000000
+      "Mapping:    VA     [TS 0/TID 0x00/EPN 0x00000] -> RPN 0x00000"
+      "Size:       TSIZE  0x0 ( 4^ts KiB = 000000 KiB = 0x00000000 B)
+      "Attributes: PERM 0x000 (ux/sx/uw/sw/ur/sr) WIMGE 0x00 IPROT 0"
-			myprintf(f,
-				"TLB[%i] Entry # %d spans EA range     0x%08x .. 0x%08x\r\n",
-				sel,
-				idx,
-				(tlb->va.va_epn << 12),
-				(tlb->va.va_epn << 12) + (1024<<(2*tlb->att.sz)) - 1
-			myprintf(f,
-				"Mapping:    VA     [TS %d/TID 0x%02x/EPN 0x%05x] -> RPN 0x%05"PRIx32"\r\n",
-				tlb->att.ts, tlb->va.va_tid, tlb->va.va_epn, tlb->rpn
-			myprintf(f,
-				"Size:       TSIZE  0x%x ( 4^ts KiB = %6d KiB = 0x%08x B)\r\n",
-				tlb->att.sz, (1<<(2*tlb->att.sz)), (1024<<(2*tlb->att.sz))
-			myprintf(f,
-				"Attributes: PERM 0x%03x (ux/sx/uw/sw/ur/sr) WIMGE 0x%02x IPROT %i\r\n",
-				tlb->att.perm, tlb->att.wimge, (sel && (mas1 & FSL_EIS_MAS1_IPROT) ? 1 : 0)
-			myprintf(f,
-				"EA range 0x%08x .. 0x%08x\r\n",
-	} else {
-		if ( !quiet ) {
-			myprintf(f, "TLB[%i] Entry #%i <OFF> (size 0x%x = 0x%xb)\n", sel, idx, tlb->att.sz, (1024<<(2*tlb->att.sz)));
-		return 1;
-	return 0;
+      myprintf(f,
+        "TLB[%i] Entry # %d spans EA range     0x%08x .. 0x%08x\r\n",
+        sel,
+        idx,
+        (tlb->va.va_epn << 12),
+        (tlb->va.va_epn << 12) + (1024<<(2*tlb->att.sz)) - 1
+      myprintf(f,
+        "Mapping:    VA     [TS %d/TID 0x%02x/EPN 0x%05x] -> RPN 0x%05"PRIx32"\r\n",
+        tlb->att.ts, tlb->va.va_tid, tlb->va.va_epn, tlb->rpn
+      myprintf(f,
+        "Size:       TSIZE  0x%x ( 4^ts KiB = %6d KiB = 0x%08x B)\r\n",
+        tlb->att.sz, (1<<(2*tlb->att.sz)), (1024<<(2*tlb->att.sz))
+      myprintf(f,
+        "Attributes: PERM 0x%03x (ux/sx/uw/sw/ur/sr) WIMGE 0x%02x IPROT %i\r\n",
+        tlb->att.perm, tlb->att.wimge, (sel && (mas1 & FSL_EIS_MAS1_IPROT) ? 1 : 0)
+      myprintf(f,
+        "EA range 0x%08x .. 0x%08x\r\n",
+  } else {
+    if ( !quiet ) {
+      myprintf(f, "TLB[%i] Entry #%i <OFF> (size 0x%x = 0x%xb)\n", sel, idx, tlb->att.sz, (1024<<(2*tlb->att.sz)));
+    return 1;
+  return 0;
 /* Initialize cache; verify that TLB0 is unused;
@@ -290,22 +290,22 @@ int rtems_e500_initlb()
 int i;
 int rval = 0;
-	for (i=0; i<16; i++)
-		rtems_e500_prtlb(E500_SELTLB_1 | i, 1, 0);
-	for (i=0; i<256; i++) {
-		/* refuse to enable operations that change TLB entries
+  for (i=0; i<16; i++)
+    rtems_e500_prtlb(E500_SELTLB_1 | i, 1, 0);
+  for (i=0; i<256; i++) {
+    /* refuse to enable operations that change TLB entries
          * if anything in TLB[0] is valid (because we currently
-		 * don't check against overlap with TLB[0] when we
-		 * write a new entry).
-		if ( rtems_e500_prtlb(E500_SELTLB_0 | i, 1, 0) <=0 ) {
-			myprintf(stderr,"WARNING: 4k TLB #%i seems to be valid; UNSUPPORTED configuration\n", i);
-			rval = -1;
-	if ( !rval )
-		initialized = 1;
-	return rval;
+     * don't check against overlap with TLB[0] when we
+     * write a new entry).
+    if ( rtems_e500_prtlb(E500_SELTLB_0 | i, 1, 0) <=0 ) {
+      myprintf(stderr,"WARNING: 4k TLB #%i seems to be valid; UNSUPPORTED configuration\n", i);
+      rval = -1;
+  if ( !rval )
+    initialized = 1;
+  return rval;
@@ -343,10 +343,10 @@ int rval = 0;
  *         <0: other error
@@ -359,94 +359,94 @@ uint32_t              tid, msk;
 int                   lkup;
-	if ( sz >= 1024 ) {
-		/* Assume they literally specify a size */
-		msk = sz;
-		sz  = 0;
-		while ( msk != (1024<<(2*sz)) ) {
-			if ( ++sz > 15 ) {
-				return -1;
-		/* OK, acceptable */
-	msk = sz > 0 ? (1024<<(2*sz)) - 1 : 0;
-	if ( !initialized && sz > 0 ) {
-		myprintf(stderr,"TLB driver not initialized; refuse to enable any entry\n");
-		return -3;
-	if ( (ea & msk) || (pa & msk) ) {
-		myprintf(stderr,"Misaligned ea or pa\n");
-		return -1;
-	if ( idx < 0 || idx > 15 )
-		return -1;
-	if ( sz > 15 ) {
-		/* but e500v1 doesn't support all 16 sizes!! */
-		/* FIXME: we should inquire about this CPU's
-		 *        capabilities...
-		return -1;
-	tid = E500_TLB_ATTR_TID_GET(attr);
-	mas1 = (attr & E500_TLB_ATTR_TS) ? FSL_EIS_MAS1_TS : 0;
-	if ( sz >=0 ) {
-		lkup = rtems_e500_matchtlb(ea, tid, mas1, sz);
-		if ( lkup < -1 ) {
-			/* some error */
-			return lkup;
-		if ( lkup >= 0 && lkup != idx ) {
-			myprintf(stderr,"TLB[1] #%i overlaps with requested mapping\n", lkup);
-			rtems_e500_prtlb( E500_SELTLB_1 | lkup, 0, stderr);
-			return lkup+1;
-	/* OK to proceed */
-	mas1 |= FSL_EIS_MAS1_IPROT | FSL_EIS_MAS1_TID(tid);
-	if ( sz >= 0 )
-		mas1 |= FSL_EIS_MAS1_V | FSL_EIS_MAS1_TSIZE(sz);
-	mas2 = FSL_EIS_MAS2_EPN( ea>>12 ) | E500_TLB_ATTR_WIMGE(attr);
-	mas3 = FSL_EIS_MAS3_RPN( pa>>12 ) | E500_TLB_ATTR_PERM_GET(attr);
-	/* mas4 is not really relevant; we don't use TLB replacement */
-	mas4 = FSL_EIS_MAS4_TLBSELD | FSL_EIS_MAS4_TIDSELD(0) | FSL_EIS_MAS4_TSIZED(9) | FSL_EIS_MAS4_ID | FSL_EIS_MAS4_GD;
-	seltlb(idx | E500_SELTLB_1);
-	_write_MAS1(mas1);
-	_write_MAS2(mas2);
-	_write_MAS3(mas3);
-	_write_MAS4(mas4);
-	asm volatile(
-		"	sync		\n"
-		"	isync		\n"
-		"	tlbwe       \n"
-		"	sync        \n"
-		"	isync		\n"
-	/* update cache */
-	rtems_e500_prtlb( E500_SELTLB_1 | idx, 1, 0);
-	return 0;
+  if ( sz >= 1024 ) {
+    /* Assume they literally specify a size */
+    msk = sz;
+    sz  = 0;
+    while ( msk != (1024<<(2*sz)) ) {
+      if ( ++sz > 15 ) {
+        return -1;
+    /* OK, acceptable */
+  msk = sz > 0 ? (1024<<(2*sz)) - 1 : 0;
+  if ( !initialized && sz > 0 ) {
+    myprintf(stderr,"TLB driver not initialized; refuse to enable any entry\n");
+    return -3;
+  if ( (ea & msk) || (pa & msk) ) {
+    myprintf(stderr,"Misaligned ea or pa\n");
+    return -1;
+  if ( idx < 0 || idx > 15 )
+    return -1;
+  if ( sz > 15 ) {
+    /* but e500v1 doesn't support all 16 sizes!! */
+    /* FIXME: we should inquire about this CPU's
+     *        capabilities...
+    return -1;
+  tid = E500_TLB_ATTR_TID_GET(attr);
+  mas1 = (attr & E500_TLB_ATTR_TS) ? FSL_EIS_MAS1_TS : 0;
+  if ( sz >=0 ) {
+    lkup = rtems_e500_matchtlb(ea, tid, mas1, sz);
+    if ( lkup < -1 ) {
+      /* some error */
+      return lkup;
+    if ( lkup >= 0 && lkup != idx ) {
+      myprintf(stderr,"TLB[1] #%i overlaps with requested mapping\n", lkup);
+      rtems_e500_prtlb( E500_SELTLB_1 | lkup, 0, stderr);
+      return lkup+1;
+  /* OK to proceed */
+  mas1 |= FSL_EIS_MAS1_IPROT | FSL_EIS_MAS1_TID(tid);
+  if ( sz >= 0 )
+    mas1 |= FSL_EIS_MAS1_V | FSL_EIS_MAS1_TSIZE(sz);
+  mas2 = FSL_EIS_MAS2_EPN( ea>>12 ) | E500_TLB_ATTR_WIMGE(attr);
+  mas3 = FSL_EIS_MAS3_RPN( pa>>12 ) | E500_TLB_ATTR_PERM_GET(attr);
+  /* mas4 is not really relevant; we don't use TLB replacement */
+  mas4 = FSL_EIS_MAS4_TLBSELD | FSL_EIS_MAS4_TIDSELD(0) | FSL_EIS_MAS4_TSIZED(9) | FSL_EIS_MAS4_ID | FSL_EIS_MAS4_GD;
+  seltlb(idx | E500_SELTLB_1);
+  _write_MAS1(mas1);
+  _write_MAS2(mas2);
+  _write_MAS3(mas3);
+  _write_MAS4(mas4);
+  asm volatile(
+    "  sync\n"
+    "  isync\n"
+    "  tlbwe\n"
+    "  sync\n"
+    "  isync\n"
+  /* update cache */
+  rtems_e500_prtlb( E500_SELTLB_1 | idx, 1, 0);
+  return 0;
@@ -470,41 +470,41 @@ int                  i;
 uint32_t             m,a;
-	if ( sz < 0 || sz > 15 )
-		return -4;
-	sz = (1024<<(2*sz));
-		/* cache not initialized */
-		return -3;
-	if ( ea & (sz-1) ) {
-		/* misaligned ea */
-		return -2;
-	if ( ts )
-		ts = 1;
-	for ( i=0, tlb=rtems_e500_tlb_va_cache; i<16; i++, tlb++ ) {
-		if ( ! tlb->att.v )
-			continue;
-		if ( tlb->att.ts != ts )
-			continue;
-		if ( tlb->va.va_tid && tlb->va.va_tid != tid )
-			continue;
-		/* TID and TS match a valid entry */
-		m  = (1024<<(2*tlb->att.sz)) - 1;
-		/* calculate starting address of this entry */
-		a  = tlb->va.va_epn<<12;
-		if ( ea <= a + m && ea + sz -1 >= a ) {
-			/* overlap */
-			return i;
-	return -1;
+  if ( sz < 0 || sz > 15 )
+    return -4;
+  sz = (1024<<(2*sz));
+    /* cache not initialized */
+    return -3;
+  if ( ea & (sz-1) ) {
+    /* misaligned ea */
+    return -2;
+  if ( ts )
+    ts = 1;
+  for ( i=0, tlb=rtems_e500_tlb_va_cache; i<16; i++, tlb++ ) {
+    if ( ! tlb->att.v )
+      continue;
+    if ( tlb->att.ts != ts )
+      continue;
+    if ( tlb->va.va_tid && tlb->va.va_tid != tid )
+      continue;
+    /* TID and TS match a valid entry */
+    m  = (1024<<(2*tlb->att.sz)) - 1;
+    /* calculate starting address of this entry */
+    a  = tlb->va.va_epn<<12;
+    if ( ea <= a + m && ea + sz -1 >= a ) {
+      /* overlap */
+      return i;
+  return -1;
 /* Find TLB index that maps 'ea/as' combination
@@ -523,38 +523,38 @@ uint32_t              pid, mas0, mas1;
 int                   i, rval = -1;
-	for ( i=0; i<3; i++ ) {
-		switch (i) {
-			case 0:	asm volatile("mfspr %0, %1":"=r"(pid):"i"(FSL_EIS_PID0)); break;
-			case 1:	asm volatile("mfspr %0, %1":"=r"(pid):"i"(FSL_EIS_PID1)); break;
-			case 2:	asm volatile("mfspr %0, %1":"=r"(pid):"i"(FSL_EIS_PID2)); break;
-			default:
-				goto bail;
+  for ( i=0; i<3; i++ ) {
+    switch (i) {
+      case 0:  asm volatile("mfspr %0, %1":"=r"(pid):"i"(FSL_EIS_PID0)); break;
+      case 1:  asm volatile("mfspr %0, %1":"=r"(pid):"i"(FSL_EIS_PID1)); break;
+      case 2:  asm volatile("mfspr %0, %1":"=r"(pid):"i"(FSL_EIS_PID2)); break;
+      default:
+        goto bail;
-		_write_MAS6( FSL_EIS_MAS6_SPID0(pid) | (as ? FSL_EIS_MAS6_SAS : 0 ) );
+    _write_MAS6( FSL_EIS_MAS6_SPID0(pid) | (as ? FSL_EIS_MAS6_SAS : 0 ) );
-		asm volatile("tlbsx 0, %0"::"r"(ea));
+    asm volatile("tlbsx 0, %0"::"r"(ea));
-		if ( (FSL_EIS_MAS1_V & mas1) ) {
-			if ( FSL_EIS_MAS0_TLBSEL & mas0 ) {
-				/* TLB1 */
-				rval = FSL_EIS_MAS0_ESEL_GET(mas0) | E500_SELTLB_1;
-			} else {
-				rval = (ea >> (63-51)) | (( FSL_EIS_MAS0_NV & mas0 ) ? 180 : 0 ) ;
-			break;
+    if ( (FSL_EIS_MAS1_V & mas1) ) {
+      mas0 = _read_MAS0();
+      if ( FSL_EIS_MAS0_TLBSEL & mas0 ) {
+        /* TLB1 */
+        rval = FSL_EIS_MAS0_ESEL_GET(mas0) | E500_SELTLB_1;
+      } else {
+        rval = (ea >> (63-51)) | (( FSL_EIS_MAS0_NV & mas0 ) ? 180 : 0 ) ;
+      break;
 bail:
-	return rval;
+  return rval;
 /* Mark TLB entry as invalid ('disabled'). Unlike
@@ -577,55 +577,55 @@ rtems_e500_clrtlb(rtems_e500_tlb_idx key)
 rtems_e500_tlb_idx    k0;
-	/* minimal guard against bad key */
-	if ( key < 0 )
-		return -1;
-	if ( (key & E500_SELTLB_1) ) {
-		if ( (key & ~E500_SELTLB_1) > 15 ) {
-			myprintf(stderr,"Invalid TLB index; TLB1 index must be < 16\n");
-			return -1;
-	} else if ( key > 255 ) {
-			myprintf(stderr,"Invalid TLB index; TLB0 index must be < 256\n");
-			return -1;
-	/* Must not invalidate page 0 which holds vectors, text etc...  */
-	k0 = rtems_e500_ftlb(0, 0);
-	if ( -1 == k0 ) {
-		myprintf(stderr,"tlbivax; something's fishy - I don't find mapping for addr. 0\n");
-		return -1;
-	/* NOTE: we assume PID is ignored, and AS is 0 */
-	if ( k0 == key ) {
-		myprintf(stderr,"Refuse to invalidate page holding addr 0 (always needed)\n");
-		return -1;
-	seltlb(key);
-	/* read old entries */
-	_write_MAS1( _read_MAS1() & ~FSL_EIS_MAS1_V );
-	asm volatile(
-		"	sync		\n"
-		"	isync		\n"
-		"	tlbwe       \n"
-		"	sync        \n"
-		"	isync		\n"
-	if ( E500_SELTLB_1 & key )
-		rtems_e500_tlb_va_cache[ (~E500_SELTLB_1 & key) ].att.v = 0;
-	return 0;
+  /* minimal guard against bad key */
+  if ( key < 0 )
+    return -1;
+  if ( (key & E500_SELTLB_1) ) {
+    if ( (key & ~E500_SELTLB_1) > 15 ) {
+      myprintf(stderr,"Invalid TLB index; TLB1 index must be < 16\n");
+      return -1;
+  } else if ( key > 255 ) {
+      myprintf(stderr,"Invalid TLB index; TLB0 index must be < 256\n");
+      return -1;
+  /* Must not invalidate page 0 which holds vectors, text etc...  */
+  k0 = rtems_e500_ftlb(0, 0);
+  if ( -1 == k0 ) {
+    myprintf(stderr,"tlbivax; something's fishy - I don't find mapping for addr. 0\n");
+    return -1;
+  /* NOTE: we assume PID is ignored, and AS is 0 */
+  if ( k0 == key ) {
+    myprintf(stderr,"Refuse to invalidate page holding addr 0 (always needed)\n");
+    return -1;
+  seltlb(key);
+  /* read old entries */
+  _write_MAS1( _read_MAS1() & ~FSL_EIS_MAS1_V );
+  asm volatile(
+    "  sync\n"
+    "  isync\n"
+    "  tlbwe\n"
+    "  sync\n"
+    "  isync\n"
+  if ( E500_SELTLB_1 & key )
+    rtems_e500_tlb_va_cache[ (~E500_SELTLB_1 & key) ].att.v = 0;
+  return 0;
1.9.3
