[PATCH 59/62] libcpu/powerpc/mpc8xx/console-generic/console-generic.c: Fix warnings
Wed Oct 15 20:00:49 UTC 2014
 .../libcpu/powerpc/mpc8xx/console-generic/console-generic.c  | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c b/c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c
index 5df8a5f..ba33619 100644
--- a/c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c
+++ b/c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c
@@ -574,7 +574,7 @@ m8xx_smc2_interrupt_handler (void *unused)
-void m8xx_scc_enable(const rtems_irq_connect_data* ptr)
+static void m8xx_scc_enable(const rtems_irq_connect_data* ptr)
   volatile m8xxSCCRegisters_t *sccregs = 0;
   switch (ptr->name) {
@@ -598,7 +598,7 @@ void m8xx_scc_enable(const rtems_irq_connect_data* ptr)
   sccregs->sccm = 3;
-void m8xx_scc_disable(const rtems_irq_connect_data* ptr)
+static void m8xx_scc_disable(const rtems_irq_connect_data* ptr)
@@ -622,7 +622,7 @@ void m8xx_scc_disable(const rtems_irq_connect_data* ptr)
   sccregs->sccm &= (~3);
-int m8xx_scc_isOn(const rtems_irq_connect_data* ptr)
+static int m8xx_scc_isOn(const rtems_irq_connect_data* ptr)
  return BSP_irq_enabled_at_cpm (ptr->name);
@@ -835,7 +835,7 @@ m8xx_uart_scc_initialize (int minor)
-void m8xx_smc_enable(const rtems_irq_connect_data* ptr)
+static void m8xx_smc_enable(const rtems_irq_connect_data* ptr)
   volatile m8xxSMCRegisters_t *smcregs = 0;
@@ -851,7 +851,7 @@ void m8xx_smc_enable(const rtems_irq_connect_data* ptr)
   smcregs->smcm = 3;
-void m8xx_smc_disable(const rtems_irq_connect_data* ptr)
+static void m8xx_smc_disable(const rtems_irq_connect_data* ptr)
@@ -867,7 +867,7 @@ void m8xx_smc_disable(const rtems_irq_connect_data* ptr)
   smcregs->smcm &= (~3);
-int m8xx_smc_isOn(const rtems_irq_connect_data* ptr)
+static int m8xx_smc_isOn(const rtems_irq_connect_data* ptr)
1.9.3
