[PATCH 60/62] libcpu/powerpc/ppc403/console/console405.c: Fix warnings
Wed Oct 15 20:00:50 UTC 2014
 .../lib/libcpu/powerpc/ppc403/console/console405.c | 24 ++++++----------------
 1 file changed, 6 insertions(+), 18 deletions(-)
diff --git a/c/src/lib/libcpu/powerpc/ppc403/console/console405.c b/c/src/lib/libcpu/powerpc/ppc403/console/console405.c
index ac7a66d..cf93658 100644
--- a/c/src/lib/libcpu/powerpc/ppc403/console/console405.c
+++ b/c/src/lib/libcpu/powerpc/ppc403/console/console405.c
@@ -1,6 +1,8 @@
  *  This file contains the PowerPC 405GP console IO package.
  *  Author:	Thomas Doerfler <td at imd.m.isar.de>
  *              IMD Ingenieurbuero fuer Microcomputertechnik
@@ -190,7 +192,7 @@ static int spiBaudRound(double x)
   return (int)((int)((x-(int)x)*1000)>500 ? x+1 : x);
-void
+static void
 spiBaudSet(uint32_t   baudrate)
   uint32_t   tmp;
@@ -252,7 +254,6 @@ spiPollRead (int minor)
   return port->RBR;
 static ssize_t
 spiPollWrite(int minor, const char *buf, size_t len)
@@ -325,13 +326,10 @@ static rtems_isr serial_ISR(rtems_vector_number v)
  * deinit SPI
-void
+static void
 spiDeInit(void)
@@ -339,20 +337,16 @@ spiDeInit(void)
    * set it to state to work with polling boot monitor, if any...
   /* set up baud rate to original state */
   spiBaudSet(bsp_serial_rate);
   port->IER = 0;
  * init SPI
-rtems_status_code
+static rtems_status_code
 spiInitialize(void)
   register unsigned tmp;
@@ -453,11 +447,9 @@ rtems_device_driver console_initialize(
   return RTEMS_SUCCESSFUL;
  *  Open entry point
 rtems_device_driver console_open(
   rtems_device_major_number major,
   rtems_device_minor_number minor,
@@ -501,7 +493,6 @@ rtems_device_driver console_open(
  *  Close entry point
 rtems_device_driver console_close(
@@ -514,7 +505,6 @@ rtems_device_driver console_close(
  * read bytes from the serial port. We only have stdin.
 rtems_device_driver console_read(
@@ -527,7 +517,6 @@ rtems_device_driver console_read(
  * write bytes to the serial port. Stdout and stderr are the same.
 rtems_device_driver console_write(
@@ -540,7 +529,6 @@ rtems_device_driver console_write(
  *  IO Control entry point
 rtems_device_driver console_control(
1.9.3
