Warnings Report 15 Oct 2014
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Oct 15 20:08:50 UTC 2014
Hi
The warnings count is slowly going down. This report reflects
the next batch of 62 patches that I just sent to devel@
I have once again attached reports on the unique warnings
and warnings per BSP. On 6 Oct, there were 1737 unique warnings.
Today, there are 381 unique warnings.
Of those 381, 279 are in BSP specific code and 11 are
in libcpu code (by grep).
The warnings by class are:
5 cpp
3 deprecated-declarations
18 format=
3 implicit-function-declaration
4 int-to-pointer-cast
2 maybe-uninitialized
306 missing-prototypes
3 nested-externs
2 overflow
1 pointer-sign
6 pointer-to-int-cast
31 unused-but-set-variable
14 unused-function
I really do appreciate any help in running these down.
If you want to tackle a BSP or class of warnings, just
speak up.
200 c/src/../../cpukit/libmisc/shell/hexdump-conv.c:145:4: warning: format '%lc' expects argument of type 'wint_t', but argument 4 has type 'wchar_t' [-Wformat=]
179 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:19: warning: assignment makes integer from pointer without a cast [enabled by default]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:66:7: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:66:7: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:51:5: warning: format '%x' expects argument of type 'unsigned int', but argument 9 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/shell/main_lsof.c:51:5: warning: format '%x' expects argument of type 'unsigned int', but argument 8 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libmisc/capture/capture-cli.c:1424:18: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:61:17: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer.c:55:7: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
78 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c:72:13: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long int' [-Wformat=]
56 c/src/lib/libcpu/powerpc/shared/src/cache_.h:203:2: warning: #warning Most cache functions are not implemented [-Wcpp]
34 c/src/../../cpukit/libfs/src/jffs2/src/os-rtems.h:47:3: warning: right shift count >= width of type [enabled by default]
34 c/src/../../cpukit/libfs/src/jffs2/src/nodelist.h:294:86: warning: integer overflow in expression [-Woverflow]
20 c/src/../../cpukit/libfs/src/jffs2/include/linux/kernel.h:12:23: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
8 c/src/../../cpukit/score/src/threadloadenv.c:28:8: warning: variable 'is_fp' set but not used [-Wunused-but-set-variable]
7 c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c:161:6: warning: no previous prototype for '_InitMBX8xx' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:79:5: warning: no previous prototype for 'BSP_irq_disable_at_cpm' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:66:5: warning: no previous prototype for 'BSP_irq_enable_at_cpm' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:271:1: warning: no previous prototype for 'BSP_CPM_irq_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:252:6: warning: no previous prototype for 'BSP_SIU_irq_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c:149:5: warning: no previous prototype for 'C_dispatch_irq_handler' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:42:6: warning: no previous prototype for 'mbx8xx_pcmciaide_probe' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:351:19: warning: no previous prototype for 'mbx8xx_pcmciaide_config_io_speed' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:328:5: warning: no previous prototype for 'mbx8xx_pcmciaide_control' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:270:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_block' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:213:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_block' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:175:6: warning: no previous prototype for 'mbx8xx_pcmciaide_write_reg' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:137:6: warning: no previous prototype for 'mbx8xx_pcmciaide_read_reg' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/ide/pcmcia_ide.c:111:6: warning: no previous prototype for 'mbx8xx_pcmciaide_initialize' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:714:1: warning: no previous prototype for 'serial_tstc' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:693:1: warning: no previous prototype for 'serial_getc' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:529:1: warning: no previous prototype for 'serial_init' [-Wmissing-prototypes]
7 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:1102:5: warning: no previous prototype for 'mbx8xx_console_get_configuration' [-Wmissing-prototypes]
7 c/src/../../cpukit/score/cpu/sh/context.c:171:6: warning: no previous prototype for '__CPU_Context_switch' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/zerobss.c:25:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/bspstart.c:103:8: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
6 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/motorola/motorola.c:363:15: warning: no previous prototype for 'getMotorolaBoard' [-Wmissing-prototypes]
6 c/src/../../cpukit/libfs/src/dosfs/msdos_conv_utf8.c:255:31: warning: variable 'rv' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libblock/src/media-server.c:47:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
6 c/src/../../cpukit/libblock/src/media.c:80:21: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
5 c/src/lib/libbsp/powerpc/gen83xx/startup/bsprestart.c:22:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
5 c/src/lib/libbsp/powerpc/gen83xx/../shared/startup/bspidle.c:27:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:565:5: warning: no previous prototype for 'mpc83xx_exception_handler' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:510:19: warning: no previous prototype for 'mpc83xx_ipic_initialize' [-Wmissing-prototypes]
5 c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c:497:19: warning: no previous prototype for 'mpc83xx_ipic_calc_prio2mask' [-Wmissing-prototypes]
5 c/src/../../cpukit/score/cpu/sparc/sparcv8-atomic.c:111:6: warning: conflicting types for built-in function '__atomic_compare_exchange_4' [enabled by default]
4 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/irq/irq_init.c:167:6: warning: no previous prototype for 'VIA_isa_bridge_interrupts_setup' [-Wmissing-prototypes]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 5 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 4 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:92:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 3 has type 'long unsigned int' [-Wformat=]
4 c/src/../../cpukit/libmisc/shell/main_df.c:105:9: warning: format '%llu' expects argument of type 'long long unsigned int', but argument 6 has type 'fsblkcnt_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 6 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 5 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 4 has type 'uint32_t' [-Wformat=]
4 c/src/../../cpukit/libmisc/capture/capture-cli.c:233:3: warning: format '%lu' expects argument of type 'long unsigned int', but argument 3 has type 'uint32_t' [-Wformat=]
3 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:78:3: warning: nested extern declaration of 'BSP_Convert_decrementer' [-Wnested-externs]
3 c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:78:3: warning: implicit declaration of function 'BSP_Convert_decrementer' [-Wimplicit-function-declaration]
3 c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c:220:5: warning: no previous prototype for '_BSP_poll_char' [-Wmissing-prototypes]
3 c/src/lib/libcpu/arm/at91rm9200/dbgu/dbgu.c:201:5: warning: no previous prototype for 'dbgu_poll_read' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/uboot_getenv.c:47:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/../shared/startup/bspidle.c:27:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/qoriq/clock/../../../shared/clockdrv_shell.h:154:21: warning: no previous prototype for 'Clock_initialize' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:77:1: warning: no previous prototype for '_IBMPC_scankey' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:275:1: warning: no previous prototype for '_IBMPC_inch_sleep' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:257:1: warning: no previous prototype for 'BSP_wait_polled_input' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:243:1: warning: no previous prototype for '_IBMPC_inch' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:221:1: warning: no previous prototype for '_IBMPC_chrdy' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/console/inch.c:198:6: warning: no previous prototype for '_IBMPC_keyboard_isr' [-Wmissing-prototypes]
3 c/src/lib/libbsp/powerpc/gen83xx/../shared/uboot_getenv.c:47:13: warning: no previous prototype for 'bsp_uboot_getenv' [-Wmissing-prototypes]
3 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c:43:6: warning: no previous prototype for '_Init68360' [-Wmissing-prototypes]
3 c/src/lib/libbsp/m68k/gen68360/console/console.c:200:20: warning: variable 'sc' set but not used [-Wunused-but-set-variable]
3 c/src/lib/libbsp/arm/lpc176x/misc/restart.c:28:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
3 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems.c:524:19: warning: assignment makes integer from pointer without a cast
3 c/src/../../cpukit/libcsupport/src/__assert.c:52:43: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/powerpc-virtex.log: #warning Most cache functions are not implemented
2 log/powerpc-virtex5.log: #warning Most cache functions are not implemented
2 log/powerpc-virtex4.log: #warning Most cache functions are not implemented
2 log/powerpc-t32mppc.log: #warning Most cache functions are not implemented
2 log/powerpc-ss555.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_p1020rdb.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_core_1.log: #warning Most cache functions are not implemented
2 log/powerpc-qoriq_core_0.log: #warning Most cache functions are not implemented
2 log/powerpc-qemuprep.log: #warning Most cache functions are not implemented
2 log/powerpc-qemuprep-altivec.log: #warning Most cache functions are not implemented
2 log/powerpc-phycore_mpc5554.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme5500.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme3100.log: #warning Most cache functions are not implemented
2 log/powerpc-mvme2307.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_rsm6.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674fevb_spe.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674fevb.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_ecu508_boot.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5674f_ecu508_app.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5668g.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5643l_evb.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5643l_dpu.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5566evb_spe.log: #warning Most cache functions are not implemented
2 log/powerpc-mpc5566evb.log: #warning Most cache functions are not implemented
2 log/powerpc-mcp750.log: #warning Most cache functions are not implemented
2 log/powerpc-haleakala.log: #warning Most cache functions are not implemented
2 log/powerpc-gwlcfm.log: #warning Most cache functions are not implemented
2 log/powerpc-beatnik.log: #warning Most cache functions are not implemented
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:125:5: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:51: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:123:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 log/m32c-m32csim.log:../../cpukit/../../../m32csim/lib/include/rtems/score/tls.h:120:49: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
2 c/src/lib/libbsp/sparc/leon3/startup/bspdelay.c:18:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/leon3/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/startup/bsppredriver.c:19:6: warning: no previous prototype for 'bsp_predriver_hook' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/startup/bspdelay.c:14:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:86:6: warning: no previous prototype for 'BSP_output_char_f' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:45:5: warning: no previous prototype for 'console_inbyte_nonblocking' [-Wmissing-prototypes]
2 c/src/lib/libbsp/sparc/erc32/console/debugputs.c:24:6: warning: no previous prototype for 'console_outbyte_polled' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:22:6: warning: no previous prototype for '_InitTQM8xx' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/cpuinit.c:129:6: warning: no previous prototype for 'cpu_init' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:85:13: warning: no previous prototype for 'bsp_tqm_get_cib_string' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:74:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:61:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/tqm8xx/startup/bspstart.c:115:20: warning: no previous prototype for 'bsp_tqm_get_cib_uint32' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:906:19: warning: no previous prototype for 'bsp_register_spi' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/../shared/startup/bspidle.c:27:7: warning: no previous prototype for 'bsp_idle_thread' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:59:19: warning: no previous prototype for 'bsp_irq_enable_at_CPM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:52:19: warning: no previous prototype for 'bsp_irq_disable_at_CPM' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:45:19: warning: no previous prototype for 'bsp_irq_enable_at_SIU' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:38:19: warning: no previous prototype for 'bsp_irq_disable_at_SIU' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:217:5: warning: no previous prototype for 'mpc8xx_exception_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:207:19: warning: no previous prototype for 'mpc8xx_siu_int_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/irq/irq.c:187:19: warning: no previous prototype for 'mpc8xx_cpic_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/tqm8xx/clock/p_clock.c:45:5: warning: no previous prototype for 'BSP_connect_clock_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: initialization from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/../../../powerpc/shared/bootloader/qemu_fakeres.c:146:1: warning: no previous prototype for 'res_copy' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/motorola_powerpc/qemu_fakerom/../../../powerpc/shared/bootloader/qemu_fakeres.c:123:1: warning: no previous prototype for 'nvram_rdl_be' [-Wmissing-prototypes]
2 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c:40:2: warning: #warning No SPI configuration available [-Wcpp]
2 c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c:303:12: warning: variable 'spi_busno' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c:102:7: warning: variable 'i2c_busno' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c:21:6: warning: no previous prototype for 'bsp_spurious_handler_assistant' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/m68000spurious.c:34:9: warning: variable 's' set but not used [-Wunused-but-set-variable]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/m68000spurious.c:29:11: warning: no previous prototype for 'bsp_spurious_handler' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/../../m68k/shared/bspspuriousinit.c:29:6: warning: no previous prototype for 'bsp_spurious_initialize' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/sim68000/console/debugio.c:20:6: warning: no previous prototype for 'debug_putc' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/timer/timer.c:34:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c:55:18: warning: assignment from incompatible pointer type [enabled by default]
2 c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c:26:6: warning: no previous prototype for 'bsp_return_to_monitor_trap' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:87:5: warning: implicit declaration of function 'putchar' [-Wimplicit-function-declaration]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:39:11: warning: no previous prototype for 'C_Receive_ISR' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:184:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
2 c/src/lib/libbsp/m68k/mvme162/console/console.c:171:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
2 c/src/lib/libbsp/arm/rtl22xx/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
2 c/src/../../cpukit/score/src/threadloadenv.c:29:12: warning: variable 'isr_level' set but not used [-Wunused-but-set-variable]
2 c/src/../../cpukit/score/cpu/m68k/cpu_asm.S:75:2: warning: #warning "_CPU_Context_Restart_self restoring FPU context not implemented" [-Wcpp]
2 c/src/../../cpukit/score/cpu/lm32/irq.c:32:6: warning: no previous prototype for '__ISR_Handler' [-Wmissing-prototypes]
2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:80:16: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
2 c/src/../../cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c:33:12: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
1 tools/cpu/nios2/ptf.c:92:26: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:77:9: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:166:31: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 tools/cpu/nios2/ptf.c:156:29: warning: incompatible implicit declaration of built-in function â??freeâ?? [enabled by default]
1 log/sh-gensh2.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
1 log/sh-gensh1.log:scitab.c:48:5: warning: no previous prototype for '_sci_get_brparms' [-Wmissing-prototypes]
1 log/powerpc-ss555.log: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
1 log/powerpc-mpc8309som.log: #warning No SPI configuration available
1 log/powerpc-ep1a.log: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c).
1 log/powerpc-br_uid.log: #warning No SPI configuration available
1 log/or1k-or1ksim.log:/users/joel/rtems-4.11-work/tools/lib/gcc/or1k-rtems4.11/4.8.3/../../../../or1k-rtems4.11/bin/ld: warning: cannot find entry symbol _start; defaulting to 0000000000000000
1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: (near initialization for 'Configuration.idle_task') [enabled by default]
1 log/or1k-or1ksim.log:../../cpukit/../../../or1ksim/lib/include/rtems/confdefs.h:2687:5: warning: initialization from incompatible pointer type [enabled by default]
1 log/m68k-m5484FireEngine.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
1 log/m68k-COBRA5475.log: #warning "_CPU_Context_Restart_self restoring FPU context not implemented"
1 c/src/../../testsuites/samples/paranoia/paranoia.c:195:0: warning: "POW" redefined [enabled by default]
1 c/src/../../testsuites/samples/fileio/init.c:420:7: warning: large integer implicitly truncated to unsigned type [-Woverflow]
1 c/src/../../testsuites/samples/fileio/init.c:354:9: warning: left shift count >= width of type [enabled by default]
1 c/src/lib/libcpu/sh/sh7045/sci/sci.c:304:5: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../.././gensh2/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:568:23: warning: assignment makes integer from pointer without a cast [enabled by default]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:417:1: warning: no previous prototype for 'mcfmbus_interrupt_handler' [-Wmissing-prototypes]
1 c/src/lib/libcpu/m68k/mcf5206/mbus/mcfmbus.c:190:25: warning: passing argument 1 of 'bus->done' makes pointer from integer without a cast [enabled by default]
1 c/src/lib/libcpu/m68k/mcf5206/console/mcfuart.c:524:22: warning: pointer targets in assignment differ in signedness [-Wpointer-sign]
1 c/src/lib/libcpu/arm/pxa255/ffuart/ffuart.c:207:5: warning: no previous prototype for 'ffuart_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/startup/bsp_fatal_halt.c:33:6: warning: no previous prototype for '_CPU_Fatal_halt' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/startup/bsp_fatal_exit.c:16:6: warning: no previous prototype for 'BSP_fatal_exit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:42:28: warning: no previous prototype for 'grcan_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/can/grcan_rasta.c:42:28: warning: no previous prototype for 'grcan_rasta_register_abs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/../../sparc/shared/1553/b1553brm_rasta.c:84:5: warning: no previous prototype for 'b1553brm_rasta_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c:246:5: warning: no previous prototype for 'cchip1_register' [-Wmissing-prototypes]
1 c/src/lib/libbsp/sh/gensh2/../../sh/shared/console.c:68:3: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../../.././gensh2/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libbsp/sh/gensh1/../../sh/shared/console.c:68:3: warning: 'rtems_io_lookup_name' is deprecated (declared at ../../../../../.././gensh1/lib/include/rtems/io.h:248) [-Wdeprecated-declarations]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:848:26: warning: 'bsp_dummy_spi_init' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:773:26: warning: 'bsp_pghplus_spi_init' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:743:26: warning: 'bsp_pghplus_spi_send_stop' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:694:26: warning: 'bsp_pghplus_spi_sel_addr' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:673:26: warning: 'bsp_dummy_spi_send_stop' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/tqm8xx/spi/spi.c:629:26: warning: 'bsp_dummy_spi_sel_addr' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c:51:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/t32mppc/startup/bspstart.c:38:25: warning: variable 'level' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_write.c:36:21: warning: no previous prototype for 'console_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_read.c:36:21: warning: no previous prototype for 'console_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/t32mppc/../../shared/console_control.c:37:21: warning: no previous prototype for 'console_control' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/ss555/startup/bspstart.c:22:2: warning: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c). [-Wcpp]
1 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: (near initialization for 'console_device_table[2].context') [enabled by default]
1 c/src/lib/libbsp/powerpc/qoriq/console/console-config.c:176:5: warning: (near initialization for 'console_device_table[0].context') [enabled by default]
1 c/src/lib/libbsp/powerpc/qemuppc/startup/cmain.c:41:6: warning: no previous prototype for 'cmain' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:49:19: warning: no previous prototype for 'bsp_interrupt_facility_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:43:19: warning: no previous prototype for 'bsp_interrupt_vector_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:37:19: warning: no previous prototype for 'bsp_interrupt_vector_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/qemuppc/irq/irq_init.c:28:5: warning: no previous prototype for 'qemuppc_exception_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:91:5: warning: no previous prototype for 'psim_exception_handler' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:112:19: warning: no previous prototype for 'bsp_interrupt_facility_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:106:19: warning: no previous prototype for 'bsp_interrupt_vector_disable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/psim/irq/irq_init.c:100:19: warning: no previous prototype for 'bsp_interrupt_vector_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/startup/pgtbl_activate.c:18:1: warning: no previous prototype for '__BSP_default_pgtbl_activate' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c:163:1: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/zerobss.c:25:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/probeMemEnd.c:168:1: warning: no previous prototype for 'probeMemoryEnd' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/../../powerpc/shared/startup/probeMemEnd.c:120:1: warning: no previous prototype for 'CPU_lockUnlockCaches' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci_interface.c:69:6: warning: no previous prototype for 'pci_interface' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c:22:7: warning: variable 'x' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pcifinddevice.c:19:5: warning: no previous prototype for 'BSP_pciFindDevicePrint' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c:219:18: warning: no previous prototype for 'BSP_getVMEchipType' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/pci.c:214:22: warning: no previous prototype for 'BSP_getDiscoveryChipVersion' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/pci/detect_host_bridge.c:26:15: warning: no previous prototype for '_BSP_clear_hostbridge_errors' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:482:6: warning: no previous prototype for 'BSP_printPicIsrTbl' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:357:6: warning: no previous prototype for 'BSP_disable_pic_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/irq/BSP_irq.c:322:6: warning: no previous prototype for 'BSP_enable_pic_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/GT64260/MVME5500I2C.c:31:5: warning: no previous prototype for 'I2Cread_eeprom' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme5500/GT64260/GT64260TWSI.c:61:5: warning: no previous prototype for 'GT64260TWSIintFlag' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c:125:1: warning: no previous prototype for 'BSP_eeprom_write_enable' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/misc.c:116:1: warning: no previous prototype for 'BSP_eeprom_write_protect' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c:126:8: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:691:1: warning: no previous prototype for 'am2imode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:577:1: warning: no previous prototype for 'am2omode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1238:1: warning: no previous prototype for 'vmeTsi148InboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1184:1: warning: no previous prototype for 'vmeTsi148InboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1178:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../shared/vmeUniverse/vmeTsi148.c:1114:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/startup/zerobss.c:25:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c:71:6: warning: no previous prototype for 'BSP_motload_pci_fixup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/pci/detect_host_bridge.c:109:1: warning: no previous prototype for 'BSP_pciConfigDump_early' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:430:1: warning: no previous prototype for 'i2c_write_bytes' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:424:1: warning: no previous prototype for 'i2c_read_bytes' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:381:1: warning: no previous prototype for 'i2c_send_addr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:365:1: warning: no previous prototype for 'i2c_stop' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:336:1: warning: no previous prototype for 'i2c_start' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:291:1: warning: no previous prototype for 'i2c_init' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c:205:1: warning: no previous prototype for 'i2c_xfer' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mvme3100/i2c/i2c_init.c:85:1: warning: no previous prototype for 'BSP_i2c_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/motorola_powerpc/../../powerpc/shared/startup/bspstart.c:125:14: warning: no previous prototype for 'get_eumbbar' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:411:26: warning: 'do_poll_write' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:347:26: warning: 'do_poll_read' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:219:16: warning: '_EPPCBug_pollWrite' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/mbx8xx/console/console.c:114:12: warning: '_EPPCBug_pollRead' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c:14:2: warning: #warning The interrupt disable mask is now stored in SPRG0, please verify that this is compatible to this BSP (see also bootcard.c). [-Wcpp]
1 c/src/lib/libbsp/powerpc/beatnik/startup/i2c_init.c:60:1: warning: no previous prototype for 'BSP_i2c_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:162:1: warning: no previous prototype for 'BSP_getBoardType' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/startup/bspstart.c:147:1: warning: no previous prototype for 'save_boot_params' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../shared/vme/vme_universe.c:409:5: warning: no previous prototype for 'BSP_VMEIrqMgrInstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../shared/vme/vme_universe.c:376:5: warning: no previous prototype for 'BSP_VMEInit' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:691:1: warning: no previous prototype for 'am2imode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:577:1: warning: no previous prototype for 'am2omode' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1238:1: warning: no previous prototype for 'vmeTsi148InboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1184:1: warning: no previous prototype for 'vmeTsi148InboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1178:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShow' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../shared/vmeUniverse/vmeTsi148.c:1114:1: warning: no previous prototype for 'vmeTsi148OutboundPortsShowXX' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/zerobss.c:25:6: warning: no previous prototype for 'zero_bss' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/probeMemEnd.c:168:1: warning: no previous prototype for 'probeMemoryEnd' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/probeMemEnd.c:120:1: warning: no previous prototype for 'CPU_lockUnlockCaches' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/../../powerpc/shared/startup/panic.c:31:17: warning: variable 'flags' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/powerpc/beatnik/pci/pci_io_remap.c:76:1: warning: no previous prototype for 'rtems_pci_io_remap' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/pci/motload_fixup.c:72:6: warning: no previous prototype for 'BSP_motload_pci_fixup' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/pci/gt_pci_init.c:170:1: warning: no previous prototype for 'BSP_pci_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c:258:6: warning: no previous prototype for 'BSP_timer_test_isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/marvell/gt_timer.c:212:1: warning: no previous prototype for 'BSP_timers_uninstall' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:971:1: warning: no previous prototype for 'discovery_pic_set_debug_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:924:1: warning: no previous prototype for 'discovery_pic_install_debug_irq' [-Wmissing-prototypes]
1 c/src/lib/libbsp/powerpc/beatnik/irq/discovery_pic.c:199:6: warning: no previous prototype for 'discovery_dump_picregs' [-Wmissing-prototypes]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:37:17: warning: 'uart_get_baud' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/or1k/or1ksim/console/uart.c:32:28: warning: 'uart_get_irq_number' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c:45:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type
1 c/src/lib/libbsp/nios2/nios2_iss/timer/timer.c:33:6: warning: no previous prototype for 'timerisr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/startup/bspstart.c:24:6: warning: no previous prototype for 'bsp_start' [-Wmissing-prototypes]
1 c/src/lib/libbsp/nios2/nios2_iss/console/console.c:38:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/startup/moxiebdinstallirq.c:15:6: warning: no previous prototype for 'MOXIEBD_Install_IRQ' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/startup/__main.c:10:6: warning: no previous prototype for '__main' [-Wmissing-prototypes]
1 c/src/lib/libbsp/moxie/moxiesim/../../shared/bspclean.c:14:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/startup/inittlb.c:9:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:93:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:272:6: warning: no previous prototype for 'RBTX4938_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:138:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4938/console/console-io.c:113:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/startup/inittlb.c:9:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:91:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:266:6: warning: no previous prototype for 'RBTX4925_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:134:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/rbtx4925/console/console-io.c:111:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:145:5: warning: (near initialization for 'Console_Configuration_Ports[2].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:145:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:144:5: warning: (near initialization for 'Console_Configuration_Ports[2].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:144:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:126:5: warning: (near initialization for 'Console_Configuration_Ports[1].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:126:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:125:5: warning: (near initialization for 'Console_Configuration_Ports[1].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:125:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:107:5: warning: (near initialization for 'Console_Configuration_Ports[0].setRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:107:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:106:5: warning: (near initialization for 'Console_Configuration_Ports[0].getRegister') [enabled by default]
1 c/src/lib/libbsp/mips/malta/console/conscfg.c:106:5: warning: initialization from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/mips/hurricane/startup/inittlb.c:5:6: warning: no previous prototype for 'init_tlb' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/../shared/irq/exception.S:84:0: warning: "EXTERN" redefined [enabled by default]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:80:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:254:6: warning: no previous prototype for 'hurricane_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:123:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/hurricane/console/console.c:100:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:220:1: warning: "/*" within comment [-Wcomment]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:1582:7: warning: nested extern declaration of 'rtems_interrupt_catch' [-Wnested-externs]
1 c/src/lib/libbsp/mips/genmongoosev/../../mips/shared/gdbstub/mips-stub.c:1582:7: warning: implicit declaration of function 'rtems_interrupt_catch' [-Wimplicit-function-declaration]
1 c/src/lib/libbsp/mips/csb350/console/console-io.c:76:6: warning: no previous prototype for 'csb250_output_char' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme167/timer/timer.c:78:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:585:52: warning: variable 'final_ier' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:585:39: warning: variable 'initial_ier' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:540:8: warning: variable 'buffer' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:539:42: warning: variable 'total' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:232:18: warning: variable 'ticks_per_second' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:1374:19: warning: no previous prototype for 'do_poll_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme167/console/console.c:1336:19: warning: no previous prototype for 'do_poll_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/timer/timer.c:30:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c:43:18: warning: assignment from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c:21:6: warning: no previous prototype for 'bsp_return_to_monitor_trap' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/timer/timer.c:30:3: warning: passing argument 1 of 'set_vector' from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:94:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:66:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147s/../mvme147/console/console.c:120:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:94:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:66:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mvme147/console/console.c:120:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mrm332/spurious/spinit.c:31:11: warning: no previous prototype for 'Spurious_Isr' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mrm332/console/sci.c:1150:16: warning: variable 'unused' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mrm332/console/sci.c:1041:16: warning: variable 'length' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c:40:13: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libbsp/m68k/mcf5329/startup/init5329.c:25:6: warning: no previous prototype for 'Init5329' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5235/startup/init5235.c:29:6: warning: no previous prototype for 'Init5235' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5225x/startup/init5225x.c:30:6: warning: no previous prototype for 'Init5225x' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf52235/startup/init52235.c:40:13: warning: comparison of distinct pointer types lacks a cast [enabled by default]
1 c/src/lib/libbsp/m68k/mcf52235/startup/init52235.c:25:6: warning: no previous prototype for 'Init52235' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:91:1: warning: no previous prototype for 'ds1307_get_time' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:47:1: warning: no previous prototype for 'ds1307_initialize' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/tod/ds1307.c:172:1: warning: no previous prototype for 'ds1307_set_time' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/mcf5206elite/startup/init5206e.c:66:1: warning: no previous prototype for 'Init5206e' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/idp/console/mc68ec.c:12:6: warning: no previous prototype for 'rtems_bsp_delay' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68360/startup/init68360.c:48:26: warning: variable 'RamBase_p' set but not used [-Wunused-but-set-variable]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:166:6: warning: no previous prototype for 'outbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:134:6: warning: no previous prototype for 'inbyte' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/gen68302/console/console.c:105:6: warning: no previous prototype for 'is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/csb360/startup/init5272.c:84:1: warning: no previous prototype for 'init5272' [-Wmissing-prototypes]
1 c/src/lib/libbsp/m68k/av5282/startup/init5282.c:23:6: warning: no previous prototype for 'Init5282' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/milkymist/startup/bspclean.c:48:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:61:6: warning: no previous prototype for 'BSP_uart_is_character_ready' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:54:6: warning: no previous prototype for 'BSP_uart_polled_read' [-Wmissing-prototypes]
1 c/src/lib/libbsp/lm32/lm32_evr/../../lm32/shared/console/uart.c:44:6: warning: no previous prototype for 'BSP_uart_polled_write' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../../shared/bspclean.c:14:6: warning: no previous prototype for 'bsp_fatal_extension' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:56:6: warning: no previous prototype for '_print_full_context' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/../shared/abort/simple_abort.c:108:6: warning: no previous prototype for 'do_data_abort' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/raspberrypi/console/usart.c:37:17: warning: 'usart_get_baud' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/arm/raspberrypi/console/usart.c:32:28: warning: 'usart_get_irq_number' defined but not used [-Wunused-function]
1 c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c:124:20: warning: assignment from incompatible pointer type [enabled by default]
1 c/src/lib/libbsp/arm/gba/console/conio.c:321:6: warning: no previous prototype for 'gba_initconio' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/edb7312/irq/irq.c:23:6: warning: no previous prototype for 'edb7312_interrupt_dispatch' [-Wmissing-prototypes]
1 c/src/lib/libbsp/arm/csb337/console/fbcons.c:135:5: warning: no previous prototype for 'fbcons_poll_read' [-Wmissing-prototypes]
1 c/src/../../cpukit/score/src/threadstartmultitasking.c:82:1: warning: 'noreturn' function does return [enabled by default]
1 c/src/../../cpukit/score/src/objectextendinformation.c:159:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
1 c/src/../../cpukit/score/src/objectextendinformation.c:154:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
1 c/src/../../cpukit/libmisc/utf8proc/utf8proc.c:148:5: warning: left shift count >= width of type [enabled by default]
1 c/src/../../cpukit/libfs/src/dosfs/msdos_conv.c:452:48: warning: 'c' may be used uninitialized in this function [-Wmaybe-uninitialized]
1 c/src/../../cpukit/libcsupport/src/vprintk.c:199:41: warning: 'num' may be used uninitialized in this function [-Wmaybe-uninitialized]
1 arm-altcycv_devkit (only shared)
1 arm-altcycv_devkit_smp (only shared)
1 arm-arm1136jfs (only shared)
1 arm-arm1136js (only shared)
1 arm-arm7tdmi (only shared)
1 arm-arm920 (only shared)
1 arm-armcortexa9 (only shared)
1 arm-csb336 (only shared)
1 arm-gp32 (only shared)
1 arm-lm3s3749 (only shared)
1 arm-lm3s6965 (only shared)
1 arm-lm3s6965_qemu (only shared)
1 arm-lm4f120 (only shared)
1 arm-lpc17xx_ea_ram (only shared)
1 arm-lpc17xx_ea_rom_int (only shared)
1 arm-lpc17xx_plx800_ram (only shared)
1 arm-lpc17xx_plx800_rom_int (only shared)
1 arm-lpc2362 (only shared)
1 arm-lpc23xx_tli800 (only shared)
1 arm-lpc24xx_ea (only shared)
1 arm-lpc24xx_ncs_ram (only shared)
1 arm-lpc24xx_ncs_rom_ext (only shared)
1 arm-lpc24xx_ncs_rom_int (only shared)
1 arm-lpc24xx_plx800_ram (only shared)
1 arm-lpc24xx_plx800_rom_int (only shared)
1 arm-lpc32xx_mzx (only shared)
1 arm-lpc32xx_mzx_stage_1 (only shared)
1 arm-lpc32xx_mzx_stage_2 (only shared)
1 arm-lpc32xx_phycore (only shared)
1 arm-lpc40xx_ea_ram (only shared)
1 arm-lpc40xx_ea_rom_int (only shared)
1 arm-realview_pbx_a9_qemu (only shared)
1 arm-realview_pbx_a9_qemu_smp (only shared)
1 arm-smdk2410 (only shared)
1 arm-stm32f105rc (only shared)
1 arm-stm32f4 (only shared)
1 arm-tms570ls3137_hdk_intram (only shared)
1 arm-tms570ls3137_hdk (only shared)
1 arm-tms570ls3137_hdk_sdram (only shared)
1 arm-xilinx_zynq_a9_qemu (only shared)
1 arm-xilinx_zynq_zc702 (only shared)
1 arm-xilinx_zynq_zc706 (only shared)
1 arm-xilinx_zynq_zedboard (only shared)
1 mips-jmr3904 (only shared)
2 arm-edb7312 (inBSP=1 inLibCPU=0)
2 arm-gba (inBSP=1 inLibCPU=0)
2 arm-gumstix (inBSP=0 inLibCPU=1)
2 arm-nds (inBSP=1 inLibCPU=0)
2 mips-csb350 (inBSP=1 inLibCPU=0)
3 arm-csb337 (inBSP=0 inLibCPU=2)
3 arm-kit637_v6 (inBSP=0 inLibCPU=2)
3 avr-avrtest (only shared)
3 powerpc-brs5l (only shared)
3 powerpc-brs6l (only shared)
3 powerpc-dp2 (only shared)
3 powerpc-icecube (only shared)
3 powerpc-mpc8260ads (only shared)
3 powerpc-pm520_cr825 (only shared)
3 powerpc-pm520_ze30 (only shared)
3 powerpc-score603e (only shared)
3 v850-v850e1sim (only shared)
3 v850-v850e2sim (only shared)
3 v850-v850e2v3sim (only shared)
3 v850-v850esim (only shared)
3 v850-v850essim (only shared)
3 v850-v850sim (only shared)
4 arm-csb637 (inBSP=1 inLibCPU=2)
4 mips-genmongoosev (inBSP=3 inLibCPU=0)
4 powerpc-ep1a (inBSP=1 inLibCPU=0)
4 sh-gensh4 (only shared)
4 sh-simsh1 (only shared)
4 sh-simsh2e (only shared)
4 sh-simsh2 (only shared)
4 sh-simsh4 (only shared)
5 arm-lpc1768_mbed_ahb_ram_eth (inBSP=1 inLibCPU=0)
5 arm-lpc1768_mbed_ahb_ram (inBSP=1 inLibCPU=0)
5 arm-lpc1768_mbed (inBSP=1 inLibCPU=0)
5 lm32-milkymist (inBSP=1 inLibCPU=0)
5 powerpc-gwlcfm (inBSP=0 inLibCPU=2)
5 powerpc-mpc5566evb (inBSP=0 inLibCPU=2)
5 powerpc-mpc5566evb_spe (inBSP=0 inLibCPU=2)
5 powerpc-mpc5643l_dpu (inBSP=0 inLibCPU=2)
5 powerpc-mpc5643l_evb (inBSP=0 inLibCPU=2)
5 powerpc-mpc5668g (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_ecu508_app (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_ecu508_boot (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674fevb (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674fevb_spe (inBSP=0 inLibCPU=2)
5 powerpc-mpc5674f_rsm6 (inBSP=0 inLibCPU=2)
5 powerpc-phycore_mpc5554 (inBSP=0 inLibCPU=2)
5 powerpc-virtex4 (inBSP=0 inLibCPU=2)
5 powerpc-virtex5 (inBSP=0 inLibCPU=2)
5 powerpc-virtex (inBSP=0 inLibCPU=2)
6 arm-raspberrypi (inBSP=5 inLibCPU=0)
6 arm-rtl22xx_t (inBSP=2 inLibCPU=0)
6 powerpc-haleakala (inBSP=0 inLibCPU=2)
6 powerpc-ss555 (inBSP=1 inLibCPU=2)
6 sh-gensh1 (inBSP=1 inLibCPU=0)
6 sparc-leon3 (inBSP=2 inLibCPU=0)
6 sparc-ngmp (inBSP=2 inLibCPU=0)
7 arm-rtl22xx (inBSP=2 inLibCPU=0)
7 lm32-lm32_evr (inBSP=3 inLibCPU=0)
7 mips-hurricane (inBSP=6 inLibCPU=0)
7 mips-rbtx4925 (inBSP=6 inLibCPU=0)
7 mips-rbtx4938 (inBSP=6 inLibCPU=0)
7 powerpc-psim (inBSP=4 inLibCPU=0)
7 sh-gensh2 (inBSP=1 inLibCPU=1)
8 powerpc-hsc_cm01 (inBSP=5 inLibCPU=0)
8 powerpc-qemuppc (inBSP=5 inLibCPU=0)
9 nios2-nios2_iss (inBSP=4 inLibCPU=0)
9 powerpc-mpc8349eamds (inBSP=6 inLibCPU=0)
10 powerpc-br_uid (inBSP=7 inLibCPU=0)
10 powerpc-mpc8313erdb (inBSP=7 inLibCPU=0)
10 powerpc-mvme2100 (inBSP=7 inLibCPU=0)
10 powerpc-qoriq_p1020rdb (inBSP=3 inLibCPU=4)
10 powerpc-t32mppc (inBSP=5 inLibCPU=2)
10 sparc-leon2 (inBSP=6 inLibCPU=0)
11 sparc-erc32 (inBSP=7 inLibCPU=0)
11 sparc-sis (inBSP=7 inLibCPU=0)
12 powerpc-mpc8309som (inBSP=9 inLibCPU=0)
12 powerpc-qemuprep-altivec (inBSP=7 inLibCPU=2)
12 powerpc-qemuprep (inBSP=7 inLibCPU=2)
12 powerpc-qoriq_core_0 (inBSP=5 inLibCPU=4)
12 powerpc-qoriq_core_1 (inBSP=5 inLibCPU=4)
13 mips-malta (inBSP=12 inLibCPU=0)
15 powerpc-mtx603e (inBSP=12 inLibCPU=0)
17 bfin-bf537Stamp (only shared)
17 bfin-eZKit533 (only shared)
17 bfin-TLL6527M (only shared)
17 h8300-h8sim (only shared)
17 m32r-m32rsim (only shared)
17 powerpc-mcp750 (inBSP=12 inLibCPU=2)
17 powerpc-mvme2307 (inBSP=12 inLibCPU=2)
18 i386-pc386 (only shared)
18 i386-pc486 (only shared)
18 i386-pc586 (only shared)
18 i386-pc586-sse (only shared)
18 i386-pc686 (only shared)
18 i386-pcp4 (only shared)
19 m68k-gen68340 (only shared)
19 m68k-ods68302 (only shared)
19 m68k-uC5282 (only shared)
20 m68k-av5282 (inBSP=1 inLibCPU=0)
20 m68k-COBRA5475 (only shared)
20 m68k-csb360 (inBSP=1 inLibCPU=0)
20 m68k-idp (inBSP=1 inLibCPU=0)
20 m68k-m5484FireEngine (only shared)
20 m68k-mcf5225x (inBSP=1 inLibCPU=0)
20 m68k-mcf5235 (inBSP=1 inLibCPU=0)
20 moxie-moxiesim (inBSP=3 inLibCPU=0)
21 m68k-gen68360_040 (inBSP=2 inLibCPU=0)
21 m68k-gen68360 (inBSP=2 inLibCPU=0)
21 m68k-mcf52235 (inBSP=2 inLibCPU=0)
21 m68k-mcf5329 (inBSP=2 inLibCPU=0)
21 powerpc-mbx821_001 (inBSP=18 inLibCPU=0)
21 powerpc-mbx821_002b (inBSP=18 inLibCPU=0)
21 powerpc-mbx821_002 (inBSP=18 inLibCPU=0)
21 powerpc-mbx860_001b (inBSP=18 inLibCPU=0)
21 powerpc-mbx860_002 (inBSP=18 inLibCPU=0)
21 powerpc-mbx860_1b (inBSP=18 inLibCPU=0)
21 powerpc-mvme5500 (inBSP=16 inLibCPU=2)
22 m68k-gen68302 (inBSP=3 inLibCPU=0)
22 m68k-mvme136 (only shared)
22 m68k-pgh360 (inBSP=3 inLibCPU=0)
22 powerpc-pghplus (inBSP=19 inLibCPU=0)
22 powerpc-tqm8xx_stk8xx (inBSP=19 inLibCPU=0)
23 m68k-mrm332 (inBSP=3 inLibCPU=0)
23 m68k-mvme147s (inBSP=4 inLibCPU=0)
23 or1k-or1ksim (inBSP=2 inLibCPU=0)
24 m68k-sim68000 (inBSP=5 inLibCPU=0)
24 m68k-simcpu32 (inBSP=5 inLibCPU=0)
25 m68k-mvme147 (inBSP=6 inLibCPU=0)
25 powerpc-mbx860_005b (inBSP=22 inLibCPU=0)
26 m68k-mvme162 (inBSP=7 inLibCPU=0)
26 m68k-mvme162lx (inBSP=7 inLibCPU=0)
27 m68k-mcf5206elite (inBSP=4 inLibCPU=4)
27 m68k-mvme167 (inBSP=8 inLibCPU=0)
27 powerpc-mvme3100 (inBSP=22 inLibCPU=2)
27 sparc64-niagara (only shared)
27 sparc64-usiii (only shared)
28 powerpc-beatnik (inBSP=23 inLibCPU=2)
41 h8300-h8sxsim (only shared)
52 m32c-m32csim (only shared)
