[PATCH 01/11] m68k/mvme162: Fix warnings
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Oct 16 14:28:19 UTC 2014
c/src/lib/libbsp/m68k/gen68360/console/console.c | 395 +++---
c/src/lib/libbsp/m68k/gen68360/startup/init68360.c | 1315 ++++++++++----------
c/src/lib/libbsp/m68k/mrm332/console/sci.c | 4 -
c/src/lib/libbsp/m68k/mvme162/console/console.c | 99 +-
c/src/lib/libbsp/m68k/mvme162/include/bsp.h | 16 +-
c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c | 26 +-
c/src/lib/libbsp/m68k/mvme162/timer/timer.c | 2 +-
c/src/lib/libbsp/m68k/mvme167/console/console.c | 3 +-
c/src/lib/libbsp/m68k/shared/m68000spurious.c | 6 +-
9 files changed, 919 insertions(+), 947 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/gen68360/console/console.c b/c/src/lib/libbsp/m68k/gen68360/console/console.c
index e57853d..2d23810 100644
--- a/c/src/lib/libbsp/m68k/gen68360/console/console.c
+++ b/c/src/lib/libbsp/m68k/gen68360/console/console.c
@@ -5,7 +5,9 @@
* To run with interrupt-driven I/O, ensure m360_smc1_interrupt
* is set before calling the initialization routine.
* Author:
* W. Eric Norum
* Saskatchewan Accelerator Laboratory
@@ -30,7 +32,7 @@
* Declare clock speed -- may be overwritten by downloader or debugger
-int m360_clock_rate = 25000000;
+int m360_clock_rate = 25000000;
* Interrupt-driven input buffer
@@ -40,7 +42,7 @@ int console_baud_rate = 9600;
-#define RXBUFSIZE 16
+#define RXBUFSIZE 16
* Interrupt-driven callback
@@ -64,15 +66,15 @@ static volatile m360BufferDescriptor_t *smcRxBd, *smcTxBd;
static int
smc1BRGC (int baud)
- int divisor;
- int div16 = 0;
- divisor = ((m360_clock_rate / 16) + (baud / 2)) / baud;
- if (divisor > 4096) {
- div16 = 1;
- divisor = (divisor + 8) / 16;
- return M360_BRG_EN | M360_BRG_EXTC_BRGCLK | ((divisor - 1) << 1) | div16;
+ int divisor;
+ int div16 = 0;
+ divisor = ((m360_clock_rate / 16) + (baud / 2)) / baud;
+ if (divisor > 4096) {
+ div16 = 1;
+ divisor = (divisor + 8) / 16;
+ return M360_BRG_EN | M360_BRG_EXTC_BRGCLK | ((divisor - 1) << 1) | div16;
@@ -95,165 +97,164 @@ smc1SetAttributes (int minor, const struct termios *t)
static rtems_isr
smc1InterruptHandler (rtems_vector_number v)
- * Buffer received?
- if (m360.smc1.smce & 0x1) {
- m360.smc1.smce = 0x1;
- while ((smcRxBd->status & M360_BD_EMPTY) == 0) {
- rtems_termios_enqueue_raw_characters (smc1ttyp,
- (char *)smcRxBd->buffer,
- smcRxBd->length);
- smcRxBd->status = M360_BD_EMPTY | M360_BD_WRAP | M360_BD_INTERRUPT;
- * Buffer transmitted?
- if (m360.smc1.smce & 0x2) {
- m360.smc1.smce = 0x2;
- if ((smcTxBd->status & M360_BD_READY) == 0)
- rtems_termios_dequeue_characters (smc1ttyp, smcTxBd->length);
- m360.cisr = 1UL << 4; /* Clear SMC1 interrupt-in-service bit */
+ * Buffer received?
+ if (m360.smc1.smce & 0x1) {
+ m360.smc1.smce = 0x1;
+ while ((smcRxBd->status & M360_BD_EMPTY) == 0) {
+ rtems_termios_enqueue_raw_characters (smc1ttyp,
+ (char *)smcRxBd->buffer,
+ smcRxBd->length);
+ smcRxBd->status = M360_BD_EMPTY | M360_BD_WRAP | M360_BD_INTERRUPT;
+ * Buffer transmitted?
+ if (m360.smc1.smce & 0x2) {
+ m360.smc1.smce = 0x2;
+ if ((smcTxBd->status & M360_BD_READY) == 0)
+ rtems_termios_dequeue_characters (smc1ttyp, smcTxBd->length);
+ m360.cisr = 1UL << 4; /* Clear SMC1 interrupt-in-service bit */
static int
smc1Initialize (int major, int minor, void *arg)
- * Allocate buffer descriptors
- smcRxBd = M360AllocateBufferDescriptors (1);
- smcTxBd = M360AllocateBufferDescriptors (1);
- * Configure port B pins to enable SMTXD1 and SMRXD1 pins
- m360.pbpar |= 0xC0;
- m360.pbdir &= ~0xC0;
- m360.pbodr &= ~0xC0;
- * Set up BRG1 (9,600 baud)
- m360.brgc1 = M360_BRG_RST;
- m360.brgc1 = smc1BRGC (console_baud_rate);
- * Put SMC1 in NMSI mode, connect SMC1 to BRG1
- m360.simode |= M360_SI_SMC1_BRG1;
- * Set up SMC1 parameter RAM common to all protocols
- m360.smc1p.rbase = (char *)smcRxBd - (char *)&m360;
- m360.smc1p.tbase = (char *)smcTxBd - (char *)&m360;
- m360.smc1p.rfcr = M360_RFCR_MOT | M360_RFCR_DMA_SPACE;
- m360.smc1p.tfcr = M360_TFCR_MOT | M360_TFCR_DMA_SPACE;
- if (m360_smc1_interrupt)
- m360.smc1p.mrblr = RXBUFSIZE;
- else
- m360.smc1p.mrblr = 1;
- * Set up SMC1 parameter RAM UART-specific parameters
- m360.smc1p.un.uart.max_idl = 10;
- m360.smc1p.un.uart.brklen = 0;
- m360.smc1p.un.uart.brkec = 0;
- m360.smc1p.un.uart.brkcr = 0;
- * Set up the Receive Buffer Descriptor
- smcRxBd->length = 0;
- smcRxBd->buffer = rxBuf;
- * Setup the Transmit Buffer Descriptor
- smcTxBd->status = M360_BD_WRAP;
- * Set up SMC1 general and protocol-specific mode registers
- m360.smc1.smce = ~0; /* Clear any pending events */
- m360.smc1.smcm = 0; /* Mask all interrupt/event sources */
- m360.smc1.smcmr = M360_SMCMR_CLEN(9) | M360_SMCMR_SM_UART;
- * Send "Init parameters" command
- M360ExecuteRISC (M360_CR_OP_INIT_RX_TX | M360_CR_CHAN_SMC1);
- * Enable receiver and transmitter
- m360.smc1.smcmr |= M360_SMCMR_TEN | M360_SMCMR_REN;
- if (m360_smc1_interrupt) {
- rtems_isr_entry old_handler;
- rtems_status_code sc;
- sc = rtems_interrupt_catch (smc1InterruptHandler,
- (m360.cicr & 0xE0) | 0x04,
- &old_handler);
- m360.smc1.smcm = 3; /* Enable SMC1 TX and RX interrupts */
- m360.cimr |= 1UL << 4; /* Enable SMC1 interrupts */
- return 0;
+ * Allocate buffer descriptors
+ smcRxBd = M360AllocateBufferDescriptors (1);
+ smcTxBd = M360AllocateBufferDescriptors (1);
+ * Configure port B pins to enable SMTXD1 and SMRXD1 pins
+ m360.pbpar |= 0xC0;
+ m360.pbdir &= ~0xC0;
+ m360.pbodr &= ~0xC0;
+ * Set up BRG1 (9,600 baud)
+ m360.brgc1 = M360_BRG_RST;
+ m360.brgc1 = smc1BRGC (console_baud_rate);
+ * Put SMC1 in NMSI mode, connect SMC1 to BRG1
+ m360.simode |= M360_SI_SMC1_BRG1;
+ * Set up SMC1 parameter RAM common to all protocols
+ m360.smc1p.rbase = (char *)smcRxBd - (char *)&m360;
+ m360.smc1p.tbase = (char *)smcTxBd - (char *)&m360;
+ m360.smc1p.rfcr = M360_RFCR_MOT | M360_RFCR_DMA_SPACE;
+ m360.smc1p.tfcr = M360_TFCR_MOT | M360_TFCR_DMA_SPACE;
+ if (m360_smc1_interrupt)
+ m360.smc1p.mrblr = RXBUFSIZE;
+ else
+ m360.smc1p.mrblr = 1;
+ * Set up SMC1 parameter RAM UART-specific parameters
+ m360.smc1p.un.uart.max_idl = 10;
+ m360.smc1p.un.uart.brklen = 0;
+ m360.smc1p.un.uart.brkec = 0;
+ m360.smc1p.un.uart.brkcr = 0;
+ * Set up the Receive Buffer Descriptor
+ smcRxBd->length = 0;
+ smcRxBd->buffer = rxBuf;
+ * Setup the Transmit Buffer Descriptor
+ smcTxBd->status = M360_BD_WRAP;
+ * Set up SMC1 general and protocol-specific mode registers
+ m360.smc1.smce = ~0; /* Clear any pending events */
+ m360.smc1.smcm = 0; /* Mask all interrupt/event sources */
+ m360.smc1.smcmr = M360_SMCMR_CLEN(9) | M360_SMCMR_SM_UART;
+ * Send "Init parameters" command
+ M360ExecuteRISC (M360_CR_OP_INIT_RX_TX | M360_CR_CHAN_SMC1);
+ * Enable receiver and transmitter
+ m360.smc1.smcmr |= M360_SMCMR_TEN | M360_SMCMR_REN;
+ if (m360_smc1_interrupt) {
+ rtems_isr_entry old_handler;
+ (void) rtems_interrupt_catch (smc1InterruptHandler,
+ (m360.cicr & 0xE0) | 0x04,
+ &old_handler);
+ m360.smc1.smcm = 3; /* Enable SMC1 TX and RX interrupts */
+ m360.cimr |= 1UL << 4; /* Enable SMC1 interrupts */
+ return 0;
static int
smc1PollRead (int minor)
- unsigned char c;
+ unsigned char c;
- if (smcRxBd->status & M360_BD_EMPTY)
- return -1;
- c = rxBuf[0];
- smcRxBd->status = M360_BD_EMPTY | M360_BD_WRAP;
- return c;
+ if (smcRxBd->status & M360_BD_EMPTY)
+ return -1;
+ c = rxBuf[0];
+ smcRxBd->status = M360_BD_EMPTY | M360_BD_WRAP;
+ return c;
* Device-dependent write routine
* Interrupt-driven devices:
- * Begin transmission of as many characters as possible (minimum is 1).
+ * Begin transmission of as many characters as possible (minimum is 1).
* Polling devices:
- * Transmit all characters.
+ * Transmit all characters.
static ssize_t
smc1InterruptWrite (int minor, const char *buf, size_t len)
- if (len > 0) {
- smcTxBd->buffer = (char *)buf;
- smcTxBd->length = len;
- smcTxBd->status = M360_BD_READY | M360_BD_WRAP | M360_BD_INTERRUPT;
+ if (len > 0) {
+ smcTxBd->buffer = (char *)buf;
+ smcTxBd->length = len;
+ smcTxBd->status = M360_BD_READY | M360_BD_WRAP | M360_BD_INTERRUPT;
- return 0;
+ return 0;
static ssize_t
smc1PollWrite (int minor, const char *buf, size_t len)
- size_t retval = len;
- while (len--) {
- static char txBuf;
- while (smcTxBd->status & M360_BD_READY)
- continue;
- txBuf = *buf++;
- smcTxBd->buffer = &txBuf;
- smcTxBd->length = 1;
- smcTxBd->status = M360_BD_READY | M360_BD_WRAP;
- return retval;
+ size_t retval = len;
+ while (len--) {
+ static char txBuf;
+ while (smcTxBd->status & M360_BD_READY)
+ continue;
+ txBuf = *buf++;
+ smcTxBd->buffer = &txBuf;
+ smcTxBd->length = 1;
+ smcTxBd->status = M360_BD_READY | M360_BD_WRAP;
+ return retval;
@@ -277,20 +278,20 @@ rtems_device_driver console_initialize(
void *arg
- rtems_status_code status;
- * Set up TERMIOS
- rtems_termios_initialize ();
- * Register the device
- status = rtems_io_register_name ("/dev/console", major, 0);
- if (status != RTEMS_SUCCESSFUL)
- rtems_fatal_error_occurred (status);
- return RTEMS_SUCCESSFUL;
+ rtems_status_code status;
+ * Set up TERMIOS
+ rtems_termios_initialize ();
+ * Register the device
+ status = rtems_io_register_name ("/dev/console", major, 0);
+ if (status != RTEMS_SUCCESSFUL)
+ rtems_fatal_error_occurred (status);
+ return RTEMS_SUCCESSFUL;
@@ -302,41 +303,41 @@ rtems_device_driver console_open(
void * arg
- static const rtems_termios_callbacks intrCallbacks = {
- smc1Initialize, /* firstOpen */
- NULL, /* lastClose */
- NULL, /* pollRead */
- smc1InterruptWrite, /* write */
- smc1SetAttributes, /* setAttributes */
- NULL, /* stopRemoteTx */
- NULL, /* startRemoteTx */
- 1 /* outputUsesInterrupts */
- static const rtems_termios_callbacks pollCallbacks = {
- smc1PollRead, /* pollRead */
- smc1PollWrite, /* write */
- 0 /* outputUsesInterrupts */
- * Do generic termios initialization
- rtems_libio_open_close_args_t *args = arg;
- sc = rtems_termios_open (major, minor, arg, &intrCallbacks);
- smc1ttyp = args->iop->data1;
- else {
- sc = rtems_termios_open (major, minor, arg, &pollCallbacks);
- return sc;
+ rtems_status_code sc;
+ static const rtems_termios_callbacks intrCallbacks = {
+ smc1Initialize, /* firstOpen */
+ NULL, /* lastClose */
+ NULL, /* pollRead */
+ smc1InterruptWrite, /* write */
+ smc1SetAttributes, /* setAttributes */
+ NULL, /* stopRemoteTx */
+ NULL, /* startRemoteTx */
+ 1 /* outputUsesInterrupts */
+ static const rtems_termios_callbacks pollCallbacks = {
+ smc1PollRead, /* pollRead */
+ smc1PollWrite, /* write */
+ 0 /* outputUsesInterrupts */
+ * Do generic termios initialization
+ rtems_libio_open_close_args_t *args = arg;
+ sc = rtems_termios_open (major, minor, arg, &intrCallbacks);
+ smc1ttyp = args->iop->data1;
+ else {
+ sc = rtems_termios_open (major, minor, arg, &pollCallbacks);
+ return sc;
@@ -348,7 +349,7 @@ rtems_device_driver console_close(
void * arg
- return rtems_termios_close (arg);
+ return rtems_termios_close (arg);
@@ -360,7 +361,7 @@ rtems_device_driver console_read(
void * arg
- return rtems_termios_read (arg);
+ return rtems_termios_read (arg);
@@ -372,7 +373,7 @@ rtems_device_driver console_write(
void * arg
- return rtems_termios_write (arg);
+ return rtems_termios_write (arg);
@@ -384,5 +385,5 @@ rtems_device_driver console_control(
void * arg
- return rtems_termios_ioctl (arg);
+ return rtems_termios_ioctl (arg);
diff --git a/c/src/lib/libbsp/m68k/gen68360/startup/init68360.c b/c/src/lib/libbsp/m68k/gen68360/startup/init68360.c
index 75a1793..b39a9e1 100644
--- a/c/src/lib/libbsp/m68k/gen68360/startup/init68360.c
+++ b/c/src/lib/libbsp/m68k/gen68360/startup/init68360.c
@@ -14,7 +14,7 @@
extern void _CopyDataClearBSSAndStart (unsigned long ramSize);
extern void *RamBase;
-extern void *_RomBase; /* From linkcmds */
+extern void *_RomBase; /* From linkcmds */
* Declare the m360 structure here for the benefit of the debugger
@@ -28,13 +28,13 @@ volatile m360_t m360;
void M360ExecuteRISC(uint16_t command)
- uint16_t sr;
+ uint16_t sr;
- m68k_disable_interrupts (sr);
- while (m360.cr & M360_CR_FLG)
- continue;
- m360.cr = command | M360_CR_FLG;
- m68k_enable_interrupts (sr);
+ m68k_disable_interrupts (sr);
+ while (m360.cr & M360_CR_FLG)
+ continue;
+ m360.cr = command | M360_CR_FLG;
+ m68k_enable_interrupts (sr);
@@ -42,474 +42,477 @@ void M360ExecuteRISC(uint16_t command)
void _Init68360 (void)
- int i;
- rtems_isr_entry *vbr;
- unsigned long ramSize;
- volatile unsigned long *RamBase_p;
+ int i;
+ rtems_isr_entry *vbr;
+ unsigned long ramSize;
+ volatile unsigned long *RamBase_p;
- RamBase_p = (volatile unsigned long *)&RamBase;
+ RamBase_p = (volatile unsigned long *)&RamBase;
#if (defined (__mc68040__))
- * Motorola 68040 and companion-mode 68360 *
- * Step 6: Is this a power-up reset?
- * For now we just ignore this and do *all* the steps
- * Someday we might want to:
- * if (Hard, Loss of Clock, Power-up)
- * Do all steps
- * else if (Double bus fault, watchdog or soft reset)
- * Skip to step 12
- * else (must be a reset command)
- * Skip to step 14
- * Step 7: Deal with clock synthesizer
- * HARDWARE:
- * Change if you're not using an external 25 MHz oscillator.
- m360.clkocr = 0x83; /* No more writes, full-power CLKO2 */
- m360.pllcr = 0xD000; /* PLL, no writes, no prescale,
- no LPSTOP slowdown, PLL X1 */
- m360.cdvcr = 0x8000; /* No more writes, no clock division */
- * Step 8: Initialize system protection
- * Enable watchdog
- * Watchdog causes system reset
- * Next-to-slowest watchdog timeout (21 seconds with 25 MHz oscillator)
- * Enable double bus fault monitor
- * Enable bus monitor for external cycles
- * 1024 clocks for external timeout
- m360.sypcr = 0xEC;
- * Step 9: Clear parameter RAM and reset communication processor module
- for (i = 0 ; i < 192 ; i += sizeof (long)) {
- *((long *)((char *)&m360 + 0xC00 + i)) = 0;
- *((long *)((char *)&m360 + 0xD00 + i)) = 0;
- *((long *)((char *)&m360 + 0xE00 + i)) = 0;
- *((long *)((char *)&m360 + 0xF00 + i)) = 0;
- M360ExecuteRISC (M360_CR_RST);
- * Step 10: Write PEPAR
- * SINTOUT standard M68000 family interrupt level encoding
- * CF1MODE=10 (BCLRO* output)
- * No RAS1* double drive
- * A31 - A28
- * AMUX output
- * CAS2* - CAS3*
- * CAS0* - CAS1*
- * CS7*
- * AVEC*
- m360.pepar = 0x3440;
- * Step 11: Remap Chip Select 0 (CS0*), set up GMR
- * 512 addresses per DRAM page (256K DRAM chips)
- * 70 nsec DRAM
- * 180 nsec ROM (3 wait states)
- m360.gmr = M360_GMR_RCNT(23) | M360_GMR_RFEN |
- M360_GMR_RCYC(0) | M360_GMR_PGS(1) |
- M360_GMR_DPS_32BIT | M360_GMR_NCS |
- M360_GMR_TSS40;
- m360.memc[0].br = (unsigned long)&_RomBase | M360_MEMC_BR_WP |
- M360_MEMC_BR_V;
- m360.memc[0].or = M360_MEMC_OR_WAITS(3) | M360_MEMC_OR_1MB |
- M360_MEMC_OR_32BIT;
- * Step 12: Initialize the system RAM
- * Set up option/base registers
- * 1M DRAM
- * 70 nsec DRAM
- * Enable burst mode
- * No parity checking
- * Wait for chips to power up
- * Perform 8 read cycles
- ramSize = 1 * 1024 * 1024;
- m360.memc[1].or = M360_MEMC_OR_TCYC(0) |
- M360_MEMC_OR_1MB |
- M360_MEMC_OR_DRAM;
- m360.memc[1].br = (unsigned long)&RamBase |
- M360_MEMC_BR_BACK40 |
- M360_MEMC_BR_V;
- for (i = 0; i < 50000; i++)
- continue;
- for (i = 0; i < 8; ++i)
- *RamBase_p;
- * Step 13: Copy the exception vector table to system RAM
- m68k_get_vbr (vbr);
- for (i = 0; i < 256; ++i)
- M68Kvec[i] = vbr[i];
- m68k_set_vbr (M68Kvec);
- * Step 14: More system initialization
- * SDCR (Serial DMA configuration register)
- * Enable SDMA during FREEZE
- * Give SDMA priority over all interrupt handlers
- * Set DMA arbiration level to 4
- * CICR (CPM interrupt configuration register):
- * SCC1 requests at SCCa position
- * SCC2 requests at SCCb position
- * SCC3 requests at SCCc position
- * SCC4 requests at SCCd position
- * Interrupt request level 4
- * Maintain original priority order
- * Vector base 128
- * SCCs priority grouped at top of table
- m360.sdcr = M360_SDMA_SISM_7 | M360_SDMA_SAID_4;
- m360.cicr = (3 << 22) | (2 << 20) | (1 << 18) | (0 << 16) |
- (4 << 13) | (0x1F << 8) | (128);
- * Step 15: Set module configuration register
- * Bus request MC68040 Arbitration ID 3
- * Bus asynchronous timing mode (work around bug in Rev. B)
- * Arbitration asynchronous timing mode
- * Disable timers during FREEZE
- * Disable bus monitor during FREEZE
- * BCLRO* arbitration level 3
- * No show cycles
- * User/supervisor access
- * Bus clear in arbitration ID level 3
- * SIM60 interrupt sources higher priority than CPM
- m360.mcr = 0x6000EC3F;
+ * Motorola 68040 and companion-mode 68360 *
+ * Step 6: Is this a power-up reset?
+ * For now we just ignore this and do *all* the steps
+ * Someday we might want to:
+ * if (Hard, Loss of Clock, Power-up)
+ * Do all steps
+ * else if (Double bus fault, watchdog or soft reset)
+ * Skip to step 12
+ * else (must be a reset command)
+ * Skip to step 14
+ * Step 7: Deal with clock synthesizer
+ * HARDWARE:
+ * Change if you're not using an external 25 MHz oscillator.
+ m360.clkocr = 0x83; /* No more writes, full-power CLKO2 */
+ m360.pllcr = 0xD000; /* PLL, no writes, no prescale,
+ no LPSTOP slowdown, PLL X1 */
+ m360.cdvcr = 0x8000; /* No more writes, no clock division */
+ * Step 8: Initialize system protection
+ * Enable watchdog
+ * Watchdog causes system reset
+ * Next-to-slowest watchdog timeout (21 seconds with 25 MHz oscillator)
+ * Enable double bus fault monitor
+ * Enable bus monitor for external cycles
+ * 1024 clocks for external timeout
+ m360.sypcr = 0xEC;
+ * Step 9: Clear parameter RAM and reset communication processor module
+ for (i = 0 ; i < 192 ; i += sizeof (long)) {
+ *((long *)((char *)&m360 + 0xC00 + i)) = 0;
+ *((long *)((char *)&m360 + 0xD00 + i)) = 0;
+ *((long *)((char *)&m360 + 0xE00 + i)) = 0;
+ *((long *)((char *)&m360 + 0xF00 + i)) = 0;
+ M360ExecuteRISC (M360_CR_RST);
+ * Step 10: Write PEPAR
+ * SINTOUT standard M68000 family interrupt level encoding
+ * CF1MODE=10 (BCLRO* output)
+ * No RAS1* double drive
+ * A31 - A28
+ * AMUX output
+ * CAS2* - CAS3*
+ * CAS0* - CAS1*
+ * CS7*
+ * AVEC*
+ m360.pepar = 0x3440;
+ * Step 11: Remap Chip Select 0 (CS0*), set up GMR
+ * 512 addresses per DRAM page (256K DRAM chips)
+ * 70 nsec DRAM
+ * 180 nsec ROM (3 wait states)
+ m360.gmr = M360_GMR_RCNT(23) | M360_GMR_RFEN |
+ M360_GMR_RCYC(0) | M360_GMR_PGS(1) |
+ M360_GMR_DPS_32BIT | M360_GMR_NCS |
+ M360_GMR_TSS40;
+ m360.memc[0].br = (unsigned long)&_RomBase | M360_MEMC_BR_WP |
+ M360_MEMC_BR_V;
+ m360.memc[0].or = M360_MEMC_OR_WAITS(3) | M360_MEMC_OR_1MB |
+ M360_MEMC_OR_32BIT;
+ * Step 12: Initialize the system RAM
+ * Set up option/base registers
+ * 1M DRAM
+ * 70 nsec DRAM
+ * Enable burst mode
+ * No parity checking
+ * Wait for chips to power up
+ * Perform 8 read cycles
+ ramSize = 1 * 1024 * 1024;
+ m360.memc[1].or = M360_MEMC_OR_TCYC(0) |
+ M360_MEMC_OR_1MB |
+ M360_MEMC_OR_DRAM;
+ m360.memc[1].br = (unsigned long)&RamBase |
+ M360_MEMC_BR_BACK40 |
+ M360_MEMC_BR_V;
+ for (i = 0; i < 50000; i++)
+ continue;
+ for (i = 0; i < 8; ++i) {
+ unsigned long rambase_value;
+ rambase_value = *RamBase_p;
+ (void) rambase_value; /* avoid set but not used warning */
+ * Step 13: Copy the exception vector table to system RAM
+ m68k_get_vbr (vbr);
+ for (i = 0; i < 256; ++i)
+ M68Kvec[i] = vbr[i];
+ m68k_set_vbr (M68Kvec);
+ * Step 14: More system initialization
+ * SDCR (Serial DMA configuration register)
+ * Enable SDMA during FREEZE
+ * Give SDMA priority over all interrupt handlers
+ * Set DMA arbiration level to 4
+ * CICR (CPM interrupt configuration register):
+ * SCC1 requests at SCCa position
+ * SCC2 requests at SCCb position
+ * SCC3 requests at SCCc position
+ * SCC4 requests at SCCd position
+ * Interrupt request level 4
+ * Maintain original priority order
+ * Vector base 128
+ * SCCs priority grouped at top of table
+ m360.sdcr = M360_SDMA_SISM_7 | M360_SDMA_SAID_4;
+ m360.cicr = (3 << 22) | (2 << 20) | (1 << 18) | (0 << 16) |
+ (4 << 13) | (0x1F << 8) | (128);
+ * Step 15: Set module configuration register
+ * Bus request MC68040 Arbitration ID 3
+ * Bus asynchronous timing mode (work around bug in Rev. B)
+ * Arbitration asynchronous timing mode
+ * Disable timers during FREEZE
+ * Disable bus monitor during FREEZE
+ * BCLRO* arbitration level 3
+ * No show cycles
+ * User/supervisor access
+ * Bus clear in arbitration ID level 3
+ * SIM60 interrupt sources higher priority than CPM
+ m360.mcr = 0x6000EC3F;
#elif (defined (M68360_ATLAS_HSB))
- * Standalone Motorola 68360 -- ATLAS HSB *
- * Do all steps
- * Skip to step 12
- * else (must be a CPU32+ reset command)
- * Skip to step 14
- * HARDWARE:
- m360.clkocr = 0x8F; /* No more writes, no clock outputs */
- * Enable watchdog
- * SINTOUT not used (CPU32+ mode)
- * CF1MODE=00 (CONFIG1 input)
- * RAS1* double drive
- * WE0* - WE3*
- * OE* output
- * CAS2* - CAS3*
- * CAS0* - CAS1*
- * CS7*
- * AVEC*
- * HARDWARE:
- * Change if you are using a different memory configuration
- * (static RAM, external address multiplexing, etc).
- m360.pepar = 0x0180;
- m360.gmr = M360_GMR_RCNT(12) | M360_GMR_RFEN |
- M360_GMR_DPS_32BIT | M360_GMR_DWQ |
- M360_GMR_GAMX;
- M360_MEMC_BR_V;
- M360_MEMC_OR_8BIT;
- ramSize = 2 * 1024 * 1024;
- /* first bank 1MByte DRAM */
- m360.memc[1].or = M360_MEMC_OR_TCYC(2) | M360_MEMC_OR_1MB |
- M360_MEMC_OR_PGME | M360_MEMC_OR_DRAM;
- m360.memc[1].br = (unsigned long)&RamBase | M360_MEMC_BR_V;
- /* second bank 1MByte DRAM */
- m360.memc[2].or = M360_MEMC_OR_TCYC(2) | M360_MEMC_OR_1MB |
- m360.memc[2].br = ((unsigned long)&RamBase + 0x100000) |
- M360_MEMC_BR_V;
- /* flash rom socket U6 on CS5 */
- m360.memc[5].br = (unsigned long)ATLASHSB_ROM_U6 | M360_MEMC_BR_WP |
- M360_MEMC_BR_V;
- m360.memc[5].or = M360_MEMC_OR_WAITS(2) | M360_MEMC_OR_512KB |
- /* CSRs on CS7 */
- m360.memc[7].or = M360_MEMC_OR_TCYC(4) | M360_MEMC_OR_64KB |
- m360.memc[7].br = ATLASHSB_ESR | 0x01;
- continue;
- *((volatile unsigned long *)(unsigned long)&RamBase);
- * Vector base 128
- * Enable bus monitor during FREEZE
+ * Standalone Motorola 68360 -- ATLAS HSB *
+ * Do all steps
+ * Skip to step 12
+ * else (must be a CPU32+ reset command)
+ * Skip to step 14
+ * HARDWARE:
+ m360.clkocr = 0x8F; /* No more writes, no clock outputs */
+ * Enable watchdog
+ * SINTOUT not used (CPU32+ mode)
+ * CF1MODE=00 (CONFIG1 input)
+ * RAS1* double drive
+ * WE0* - WE3*
+ * OE* output
+ * CAS2* - CAS3*
+ * CAS0* - CAS1*
+ * CS7*
+ * AVEC*
+ * HARDWARE:
+ * Change if you are using a different memory configuration
+ * (static RAM, external address multiplexing, etc).
+ m360.pepar = 0x0180;
+ m360.gmr = M360_GMR_RCNT(12) | M360_GMR_RFEN |
+ M360_GMR_DPS_32BIT | M360_GMR_DWQ |
+ M360_GMR_GAMX;
+ M360_MEMC_BR_V;
+ M360_MEMC_OR_8BIT;
+ ramSize = 2 * 1024 * 1024;
+ /* first bank 1MByte DRAM */
+ m360.memc[1].or = M360_MEMC_OR_TCYC(2) | M360_MEMC_OR_1MB |
+ M360_MEMC_OR_PGME | M360_MEMC_OR_DRAM;
+ m360.memc[1].br = (unsigned long)&RamBase | M360_MEMC_BR_V;
+ /* second bank 1MByte DRAM */
+ m360.memc[2].or = M360_MEMC_OR_TCYC(2) | M360_MEMC_OR_1MB |
+ m360.memc[2].br = ((unsigned long)&RamBase + 0x100000) |
+ M360_MEMC_BR_V;
+ /* flash rom socket U6 on CS5 */
+ m360.memc[5].br = (unsigned long)ATLASHSB_ROM_U6 | M360_MEMC_BR_WP |
+ M360_MEMC_BR_V;
+ m360.memc[5].or = M360_MEMC_OR_WAITS(2) | M360_MEMC_OR_512KB |
+ /* CSRs on CS7 */
+ m360.memc[7].or = M360_MEMC_OR_TCYC(4) | M360_MEMC_OR_64KB |
+ m360.memc[7].br = ATLASHSB_ESR | 0x01;
+ continue;
+ *((volatile unsigned long *)(unsigned long)&RamBase);
+ * Vector base 128
+ * Enable bus monitor during FREEZE
#elif defined(PGH360)
- * Do all steps
- * Skip to step 12
- * Skip to step 14
- * HARDWARE:
- m360.clkocr = 0x8e; /* No more writes, CLKO1=1/3, CLKO2=off */
- * adjust crystal to average between 4.19 MHz and 4.00 MHz
- * reprogram pll
- m360.pllcr = 0xA000+(24576000/((4000000+4194304)/2/128))-1;
- /* LPSTOP slowdown, PLL /128*??? */
- * Enable watchdog
- * 128 sec. watchdog timeout
- * Enable bus monitor external
- * 128 clocks for external timeout
- m360.sypcr = 0xEF;
- * also initialize the SWP bit in PITR to 1
- m360.pitr |= 0x0200;
- * and trigger SWSR twice to ensure, that interval starts right now
- m360.swsr = 0x55;
- m360.swsr = 0xAA;
- m360.swsr = 0x55;
- m360.swsr = 0xAA;
- * IPIPE1
- * WE0-3
- * OE* output
- * CAS2* / CAS3*
- * CAS0* / CAS1*
- * CS7*
- * AVEC*
- * HARDWARE:
- m360.pepar = 0x0080;
- * no DRAM support
- * HARDWARE:
- m360.gmr = M360_GMR_RCNT(23) | M360_GMR_RFEN | M360_GMR_RCYC(0) |
- M360_GMR_PGS(6) | M360_GMR_DPS_32BIT | M360_GMR_DWQ |
- M360_GMR_GAMX;
- M360_MEMC_BR_V;
- m360.memc[0].or = M360_MEMC_OR_WAITS(3) | M360_MEMC_OR_512KB |
- * 16 MB DRAM
- * 1 wait state
- * HARDWARE:
- * NOTE: no Page mode possible for EDO RAMs (?)
- ramSize = 16 * 1024 * 1024;
- m360.memc[7].or = M360_MEMC_OR_TCYC(1) | M360_MEMC_OR_16MB |
- M360_MEMC_OR_FCMC(0) | /* M360_MEMC_OR_PGME | */
+ * Do all steps
+ * Skip to step 12
+ * Skip to step 14
+ * HARDWARE:
+ m360.clkocr = 0x8e; /* No more writes, CLKO1=1/3, CLKO2=off */
+ * adjust crystal to average between 4.19 MHz and 4.00 MHz
+ * reprogram pll
+ m360.pllcr = 0xA000+(24576000/((4000000+4194304)/2/128))-1;
+ /* LPSTOP slowdown, PLL /128*??? */
+ * Enable watchdog
+ * 128 sec. watchdog timeout
+ * Enable bus monitor external
+ * 128 clocks for external timeout
+ m360.sypcr = 0xEF;
+ * also initialize the SWP bit in PITR to 1
+ m360.pitr |= 0x0200;
+ * and trigger SWSR twice to ensure, that interval starts right now
+ m360.swsr = 0x55;
+ m360.swsr = 0xAA;
+ m360.swsr = 0x55;
+ m360.swsr = 0xAA;
+ * IPIPE1
+ * WE0-3
+ * OE* output
+ * CAS2* / CAS3*
+ * CAS0* / CAS1*
+ * CS7*
+ * AVEC*
+ * HARDWARE:
+ m360.pepar = 0x0080;
+ * no DRAM support
+ * HARDWARE:
+ m360.gmr = M360_GMR_RCNT(23) | M360_GMR_RFEN | M360_GMR_RCYC(0) |
+ M360_GMR_PGS(6) | M360_GMR_DPS_32BIT | M360_GMR_DWQ |
+ M360_GMR_GAMX;
+ M360_MEMC_BR_V;
+ m360.memc[0].or = M360_MEMC_OR_WAITS(3) | M360_MEMC_OR_512KB |
+ * 16 MB DRAM
+ * 1 wait state
+ * HARDWARE:
+ * NOTE: no Page mode possible for EDO RAMs (?)
+ ramSize = 16 * 1024 * 1024;
+ m360.memc[7].or = M360_MEMC_OR_TCYC(1) | M360_MEMC_OR_16MB |
+ M360_MEMC_OR_FCMC(0) | /* M360_MEMC_OR_PGME | */
M360_MEMC_OR_32BIT | M360_MEMC_OR_DRAM;
- m360.memc[7].br = (unsigned long)&RamBase | M360_MEMC_BR_V;
- * FIXME: here we should wait for 8 refresh cycles...
- * Step 12a: test the ram, if wanted
- * FIXME: when do we call this?
- * -> only during firmware execution
- * -> perform intesive test only on request
- * -> ensure, that results are stored properly
+ m360.memc[7].br = (unsigned long)&RamBase | M360_MEMC_BR_V;
+ * FIXME: here we should wait for 8 refresh cycles...
+ * Step 12a: test the ram, if wanted
+ * FIXME: when do we call this?
+ * -> only during firmware execution
+ * -> perform intesive test only on request
+ * -> ensure, that results are stored properly
#if 0 /* FIXME: activate RAM tests again */
- void *ram_base, *ram_end, *code_loc;
- extern char ramtest_start,ramtest_end;
- ram_base = &ramtest_start;
- ram_end = &ramtest_end;
- code_loc = (void *)ramtest_exec;
- if ((ram_base < ram_end) &&
- !((ram_base <= code_loc) && (code_loc < ram_end))) {
- ramtest_exec(ram_base,ram_end);
+ void *ram_base, *ram_end, *code_loc;
+ extern char ramtest_start,ramtest_end;
+ ram_base = &ramtest_start;
+ ram_end = &ramtest_end;
+ code_loc = (void *)ramtest_exec;
+ if ((ram_base < ram_end) &&
+ !((ram_base <= code_loc) && (code_loc < ram_end))) {
+ ramtest_exec(ram_base,ram_end);
#endif
- * Disable SDMA during FREEZE
- * Vector base 128
- * No show cycles
- * Bus clear interupt service level 7
- m360.mcr = 0x4C7F;
+ * Disable SDMA during FREEZE
+ * Vector base 128
+ * No show cycles
+ * Bus clear interupt service level 7
+ m360.mcr = 0x4C7F;
#elif (defined (GEN68360_WITH_SRAM))
@@ -642,197 +645,197 @@ void _Init68360 (void)
m360.mcr = 0x4C7F;
#else
- * Generic Standalone Motorola 68360 *
- * As described in MC68360 User's Manual *
- * Atlas ACE360 *
- * Do all steps
- * Skip to step 12
- * Skip to step 14
- * HARDWARE:
- * Enable watchdog
- * WE0* - WE3*
- * OE* output
- * CAS2* - CAS3*
- * CAS0* - CAS1*
- * CS7*
- * AVEC*
- * HARDWARE:
- * 32-bit DRAM
- * Internal DRAM address multiplexing
- * 60 nsec DRAM
- * 15.36 usec DRAM refresh interval
- * The DRAM page size selection is not modified since this
- * startup code may be running in a bootstrap PROM or in
- * a program downloaded by the bootstrap PROM.
- m360.gmr = (m360.gmr & 0x001C0000) | M360_GMR_RCNT(23) |
- M360_GMR_RFEN | M360_GMR_RCYC(0) |
- M360_GMR_GAMX;
- M360_MEMC_BR_V;
- * Do this only if the DRAM has not already been set up
- if ((m360.memc[1].br & M360_MEMC_BR_V) == 0) {
- * Set up GMR DRAM page size, option and base registers
- * Assume 16Mbytes of DRAM
- * 60 nsec DRAM
- m360.gmr = (m360.gmr & ~0x001C0000) | M360_GMR_PGS(5);
- M360_MEMC_OR_16MB |
- continue;
- *RamBase_p;
- * Determine memory size (1, 4, or 16 Mbytes)
- * Set GMR DRAM page size appropriately.
- * The OR is left at 16 Mbytes. The bootstrap PROM places its
- * .data and .bss segments at the top of the 16 Mbyte space.
- * A 1 Mbyte or 4 Mbyte DRAM will show up several times in
- * the memory map, but will work with the same bootstrap PROM.
- *(volatile char *)&RamBase = 0;
- *((volatile char *)&RamBase+0x00C01800) = 1;
- if (*(volatile char *)&RamBase) {
- m360.gmr = (m360.gmr & ~0x001C0000) | M360_GMR_PGS(1);
- else {
- *((volatile char *)&RamBase+0x00801000) = 1;
- m360.gmr = (m360.gmr & ~0x001C0000) | M360_GMR_PGS(3);
- * Enable parity checking
- m360.memc[1].br |= M360_MEMC_BR_PAREN;
- switch (m360.gmr & 0x001C0000) {
- default: ramSize = 4 * 1024 * 1024; break;
- case M360_GMR_PGS(1): ramSize = 1 * 1024 * 1024; break;
- case M360_GMR_PGS(3): ramSize = 4 * 1024 * 1024; break;
- case M360_GMR_PGS(5): ramSize = 16 * 1024 * 1024; break;
- * Vector base 128
- * No show cycles
- * Bus clear interrupt service level 7
+ * Generic Standalone Motorola 68360 *
+ * As described in MC68360 User's Manual *
+ * Atlas ACE360 *
+ * Do all steps
+ * Skip to step 12
+ * Skip to step 14
+ * HARDWARE:
+ * Enable watchdog
+ * WE0* - WE3*
+ * OE* output
+ * CAS2* - CAS3*
+ * CAS0* - CAS1*
+ * CS7*
+ * AVEC*
+ * HARDWARE:
+ * 32-bit DRAM
+ * Internal DRAM address multiplexing
+ * 60 nsec DRAM
+ * 15.36 usec DRAM refresh interval
+ * The DRAM page size selection is not modified since this
+ * startup code may be running in a bootstrap PROM or in
+ * a program downloaded by the bootstrap PROM.
+ m360.gmr = (m360.gmr & 0x001C0000) | M360_GMR_RCNT(23) |
+ M360_GMR_RFEN | M360_GMR_RCYC(0) |
+ M360_GMR_GAMX;
+ M360_MEMC_BR_V;
+ * Do this only if the DRAM has not already been set up
+ if ((m360.memc[1].br & M360_MEMC_BR_V) == 0) {
+ * Set up GMR DRAM page size, option and base registers
+ * Assume 16Mbytes of DRAM
+ * 60 nsec DRAM
+ m360.gmr = (m360.gmr & ~0x001C0000) | M360_GMR_PGS(5);
+ M360_MEMC_OR_16MB |
+ continue;
+ *RamBase_p;
+ * Determine memory size (1, 4, or 16 Mbytes)
+ * Set GMR DRAM page size appropriately.
+ * The OR is left at 16 Mbytes. The bootstrap PROM places its
+ * .data and .bss segments at the top of the 16 Mbyte space.
+ * A 1 Mbyte or 4 Mbyte DRAM will show up several times in
+ * the memory map, but will work with the same bootstrap PROM.
+ *(volatile char *)&RamBase = 0;
+ *((volatile char *)&RamBase+0x00C01800) = 1;
+ if (*(volatile char *)&RamBase) {
+ m360.gmr = (m360.gmr & ~0x001C0000) | M360_GMR_PGS(1);
+ else {
+ *((volatile char *)&RamBase+0x00801000) = 1;
+ m360.gmr = (m360.gmr & ~0x001C0000) | M360_GMR_PGS(3);
+ * Enable parity checking
+ m360.memc[1].br |= M360_MEMC_BR_PAREN;
+ switch (m360.gmr & 0x001C0000) {
+ default: ramSize = 4 * 1024 * 1024; break;
+ case M360_GMR_PGS(1): ramSize = 1 * 1024 * 1024; break;
+ case M360_GMR_PGS(3): ramSize = 4 * 1024 * 1024; break;
+ case M360_GMR_PGS(5): ramSize = 16 * 1024 * 1024; break;
+ * Vector base 128
+ * No show cycles
+ * Bus clear interrupt service level 7
#endif
- * Copy data, clear BSS, switch stacks and call main()
- * Must pass ramSize as argument since the data/bss segment
- * may be overwritten.
- _CopyDataClearBSSAndStart (ramSize);
+ * Copy data, clear BSS, switch stacks and call main()
+ * Must pass ramSize as argument since the data/bss segment
+ * may be overwritten.
+ _CopyDataClearBSSAndStart (ramSize);
diff --git a/c/src/lib/libbsp/m68k/mrm332/console/sci.c b/c/src/lib/libbsp/m68k/mrm332/console/sci.c
index 63f9e65..299f218 100644
--- a/c/src/lib/libbsp/m68k/mrm332/console/sci.c
+++ b/c/src/lib/libbsp/m68k/mrm332/console/sci.c
@@ -1038,7 +1038,6 @@ rtems_device_driver SciRead (
rtems_libio_rw_args_t *rw_args; /* ptr to argument struct */
char *buffer;
- uint16_t length;
rw_args = (rtems_libio_rw_args_t *) arg; /* arguments to read() */
@@ -1054,8 +1053,6 @@ rtems_device_driver SciRead (
buffer = rw_args->buffer; /* points to user's buffer */
- length = rw_args->count; /* how many bytes they want */
/* *buffer = SciReadCharWait(); wait for a character */
/* if there isn't a character available, wait until one shows up */
@@ -1147,7 +1144,6 @@ rtems_device_driver SciControl (
rtems_libio_ioctl_args_t *args = arg; /* rtems arg struct */
uint16_t command; /* the cmd to execute */
- uint16_t unused; /* maybe later */
uint16_t *ptr; /* ptr to user data */
/*printk("%s major=%d minor=%d\r\n", __FUNCTION__,major,minor); */
diff --git a/c/src/lib/libbsp/m68k/mvme162/console/console.c b/c/src/lib/libbsp/m68k/mvme162/console/console.c
index 281fe4c..639dfee 100644
--- a/c/src/lib/libbsp/m68k/mvme162/console/console.c
+++ b/c/src/lib/libbsp/m68k/mvme162/console/console.c
@@ -1,7 +1,9 @@
* This file contains the MVME162 console IO package.
- * COPYRIGHT (c) 1989-1999.
+ * COPYRIGHT (c) 1989-2013.
* On-Line Applications Research Corporation (OAR).
* The license and distribution terms for this file may be
@@ -24,19 +26,10 @@
Ring_buffer_t Console_Buffer[2];
-static bool Console_Is_Initialized = false;
-/* Printk function */
-static void _162Bug_output_char( char c );
-static void _BSP_output_char( char c );
-BSP_output_char_function_type BSP_output_char = _BSP_output_char;
* Interrupt handler for receiver interrupts
-rtems_isr C_Receive_ISR(rtems_vector_number vector)
+static rtems_isr C_Receive_ISR(rtems_vector_number vector)
register int ipend, port;
@@ -55,44 +48,6 @@ rtems_isr C_Receive_ISR(rtems_vector_number vector)
- * _162Bug_output_char
- * Output a single character using the 162Bug functions. The character
- * will be written to the default output port.
-void _162Bug_output_char( char c )
- asm volatile( "moveb %0, -(%%sp)\n\t" /* char to output */
- "trap #15\n\t" /* Trap to 162Bug */
- ".short 0x20" /* Code for .OUTCHR */
- :: "d" (c) );
- * _BSP_output_char
- * printk() function prototyped in bspIo.h. Does not use termios.
- * If we have initialized the console device then use it, otherwise
- * use the 162Bug routines to send it to the default output port.
-void _BSP_output_char(char c)
- if (Console_Is_Initialized)
- putchar(c);
- else
- _162Bug_output_char(c);
- if ('\n' == c)
- _BSP_output_char('\r');
rtems_device_major_number major,
rtems_device_minor_number minor,
@@ -105,7 +60,6 @@ rtems_device_driver console_initialize(
* Initialise receiver interrupts on both ports
for (i = 0; i <= 1; i++) {
Ring_buffer_Initialize( &Console_Buffer[i] );
ZWRITE(i, 2, SCC_VECTOR);
@@ -153,7 +107,6 @@ rtems_device_driver console_initialize(
* Non-blocking char input
bool char_ready(int port, char *ch)
if ( Ring_buffer_Is_empty( &Console_Buffer[port] ) )
@@ -167,8 +120,7 @@ bool char_ready(int port, char *ch)
* Block on char input
-char inbyte(int port)
+static char inbyte(int port)
char tmp_char;
@@ -180,8 +132,7 @@ char inbyte(int port)
* This routine transmits a character out the SCC. It no longer supports
* XON/XOFF flow control.
-void outbyte(char ch, int port)
+static void outbyte(char ch, int port)
while (1) {
if (ZREAD0(port) & TX_BUFFER_EMPTY) break;
@@ -192,7 +143,6 @@ void outbyte(char ch, int port)
* Open entry point
@@ -205,7 +155,6 @@ rtems_device_driver console_open(
* Close entry point
@@ -218,7 +167,6 @@ rtems_device_driver console_close(
* read bytes from the serial port. We only have stdin.
@@ -253,7 +201,6 @@ rtems_device_driver console_read(
* write bytes to the serial port. Stdout and stderr are the same.
@@ -287,7 +234,6 @@ rtems_device_driver console_write(
* IO Control entry point
@@ -296,3 +242,34 @@ rtems_device_driver console_control(
+ * _162Bug_output_char
+ * Output a single character using the 162Bug functions. The character
+ * will be written to the default output port.
+static void _162Bug_output_char( char c )
+ asm volatile( "moveb %0, -(%%sp)\n\t" /* char to output */
+ "trap #15\n\t" /* Trap to 162Bug */
+ ".short 0x20" /* Code for .OUTCHR */
+ :: "d" (c) );
+ * _BSP_output_char
+ * printk() function prototyped in bspIo.h. Does not use termios.
+ * If we have initialized the console device then use it, otherwise
+ * use the 162Bug routines to send it to the default output port.
+static void _BSP_output_char(char c)
+ _162Bug_output_char(c);
+/* Printk function */
+BSP_output_char_function_type BSP_output_char = _BSP_output_char;
diff --git a/c/src/lib/libbsp/m68k/mvme162/include/bsp.h b/c/src/lib/libbsp/m68k/mvme162/include/bsp.h
index 9954bfc..056cb1a 100644
--- a/c/src/lib/libbsp/m68k/mvme162/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/mvme162/include/bsp.h
@@ -1,8 +1,9 @@
-/* bsp.h
* This include file contains all MVME162fx board IO definitions.
+ * COPYRIGHT (c) 1989-2014.
@@ -162,7 +163,6 @@ typedef volatile struct {
#define EXTERN extern
#endif
* This value is the default address location of the 162Bug vector table
* and is also the default start address of the boards DRAM. This value
@@ -194,6 +194,12 @@ rtems_isr_entry set_vector(
int type
+ * Prototypes for methods in the BSP that cross file boundaries.
+bool char_ready(int port, char *ch);
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c b/c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c
index 86402dd..085f346 100644
--- a/c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c
+++ b/c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c
@@ -1,7 +1,9 @@
* This routine returns control to 162Bug.
- * COPYRIGHT (c) 1989-2010.
@@ -21,9 +23,9 @@
#include <rtems/zilog/z8036.h>
#include <page_table.h>
-extern void start( void );
-void bsp_return_to_monitor_trap(void)
+static rtems_isr bsp_return_to_monitor_trap(
+ rtems_vector_number vector
page_table_teardown();
@@ -32,18 +34,6 @@ void bsp_return_to_monitor_trap(void)
__asm__ volatile( "trap #15" ); /* trap to 162Bug */
__asm__ volatile( ".short 0x63" ); /* return to 162Bug (.RETURN) */
- /* restart program */
- * This does not work on the 162....
-#if 0
- { register volatile void *start_addr;
- start_addr = start;
- __asm__ volatile ( "jmp %0@" : "=a" (start_addr) : "0" (start_addr) );
-#endif
void bsp_fatal_extension(
@@ -53,5 +43,5 @@ void bsp_fatal_extension(
M68Kvec[ 45 ] = bsp_return_to_monitor_trap; /* install handler */
- __asm__ volatile( "trap #13" ); /* insures SUPV mode */
+ __asm__ volatile( "trap #13" ); /* ensures SUPV mode */
diff --git a/c/src/lib/libbsp/m68k/mvme162/timer/timer.c b/c/src/lib/libbsp/m68k/mvme162/timer/timer.c
index 579685c..c7dce04 100644
--- a/c/src/lib/libbsp/m68k/mvme162/timer/timer.c
+++ b/c/src/lib/libbsp/m68k/mvme162/timer/timer.c
@@ -27,7 +27,7 @@
uint32_t Ttimer_val;
bool benchmark_timer_find_average_overhead;
-rtems_isr timerisr(void);
+rtems_isr timerisr(rtems_vector_number vector);
void benchmark_timer_initialize(void)
diff --git a/c/src/lib/libbsp/m68k/mvme167/console/console.c b/c/src/lib/libbsp/m68k/mvme167/console/console.c
index 1fcf106..7ec174e 100644
--- a/c/src/lib/libbsp/m68k/mvme167/console/console.c
+++ b/c/src/lib/libbsp/m68k/mvme167/console/console.c
@@ -229,9 +229,8 @@ rtems_isr_entry Prev_modem_isr; /* Previous modem/timer isr */
unsigned long i = 20000; /* In case clock is off */
- rtems_interval ticks_per_second, start_ticks, end_ticks, current_ticks;
+ rtems_interval start_ticks, end_ticks, current_ticks;
- ticks_per_second = rtems_clock_get_ticks_per_second();
start_ticks = rtems_clock_get_ticks_since_boot();
end_ticks = start_ticks + delay;
diff --git a/c/src/lib/libbsp/m68k/shared/m68000spurious.c b/c/src/lib/libbsp/m68k/shared/m68000spurious.c
index 95e174a..e511ebb 100644
--- a/c/src/lib/libbsp/m68k/shared/m68000spurious.c
+++ b/c/src/lib/libbsp/m68k/shared/m68000spurious.c
@@ -31,9 +31,11 @@ rtems_isr bsp_spurious_handler(
CPU_Interrupt_frame *isf */
+#if 0
+ printk( "Unexpected interrupt (0x%x)\n", vector );
+#else
char *s;
- printk( "Unexpected interrupt (0x%x)\n", vector );
printk( "It looks like we got the interrupt at 0x%x\n", isf->interrupted );
@@ -41,9 +43,7 @@ rtems_isr bsp_spurious_handler(
* Can we print a name?
s = 0;
-#if 0
if ( vector <= 0x1f ) {
switch ( vector ) {
case 1: s = "INT0"; break;
1.9.3
