[PATCH 17/42] powerpc/mvme3100: Fix warnings
Fri Oct 17 15:23:33 UTC 2014
 .../lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c  |  2 +-
 c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h    | 46 ++++++++++++++--------
 .../lib/libbsp/powerpc/mvme3100/startup/bspstart.c | 14 +++----
 c/src/lib/libbsp/powerpc/mvme3100/vme/VMEConfig.h  |  4 +-
 4 files changed, 41 insertions(+), 25 deletions(-)
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c b/c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c
index 94dfcd9..5682091 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c
+++ b/c/src/lib/libbsp/powerpc/mvme3100/i2c/mpc8540_i2c.c
@@ -65,7 +65,7 @@
 #include "mpc8540_i2c_busdrv.h"
-#define STATIC
+#define STATIC static
 /* I2C controller register definitions */
 #define	I2CADR				0x3000
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h b/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
index a5ab776..6299239 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
@@ -7,7 +7,6 @@
  *  Copyright (C) 1999 Eric Valette. valette at crf.canon.fr
  *  The license and distribution terms for this file may be
@@ -19,6 +18,8 @@
 #ifndef _BSP_H
 #define _BSP_H
+#ifndef ASM
 #include <bspopts.h>
 #include <bsp/default-initial-extension.h>
@@ -176,8 +177,7 @@ extern "C" {
  *   /dev/i2c0.ds1375-raw   (read-write; transfer bytes to/from the ds1375)
-int
-BSP_i2c_initialize();
+int BSP_i2c_initialize(void);
 /* System Control Register */
 #define BSP_MVME3100_SYS_CR				((volatile uint8_t *)0xe2000001)
@@ -213,8 +213,7 @@ BSP_i2c_initialize();
  *          any changes this call may be used
  *          to read the current status w/o modifying it.
-uint8_t
-BSP_setSysReg(volatile uint8_t *r, uint8_t mask);
+uint8_t BSP_setSysReg(volatile uint8_t *r, uint8_t mask);
 /* Atomically clear bits in a sys-register; The bits set in 'mask'
  * are cleared in the register; others are left unmodified.
@@ -226,22 +225,19 @@ BSP_setSysReg(volatile uint8_t *r, uint8_t mask);
-uint8_t
-BSP_clrSysReg(volatile uint8_t *r, uint8_t mask);
+uint8_t BSP_clrSysReg(volatile uint8_t *r, uint8_t mask);
 /* Convenience wrappers around BSP_setSysReg()/BSP_clrSysReg() */
 /* Set write-protection for all EEPROM devices
  * RETURNS: old status
-uint8_t
-BSP_eeprom_write_protect();
+uint8_t BSP_eeprom_write_protect(void);
 /* Disengage write-protection for all EEPROM devices
-uint8_t
-BSP_eeprom_write_enable();
+uint8_t BSP_eeprom_write_enable(void);
 /* Set LEDs that have their bit set in the mask
@@ -251,8 +247,7 @@ BSP_eeprom_write_enable();
-uint8_t
-BSP_setLEDs(uint8_t mask);
+uint8_t BSP_setLEDs(uint8_t mask);
 /* Clear LEDs that have their bit set in the mask
@@ -260,8 +255,7 @@ BSP_setLEDs(uint8_t mask);
  * NOTE:  : see above (BSP_setLEDs)
-uint8_t
-BSP_clrLEDs(uint8_t mask);
+uint8_t BSP_clrLEDs(uint8_t mask);
 #if 0
 #define outport_byte(port,value) outb(value,port)
@@ -314,7 +308,7 @@ extern int BSP_connect_clock_handler (void);
  *            on PCI config space access to empty slots.
 extern unsigned long _BSP_clear_hostbridge_errors(int enableMCP, int quiet);
-extern void BSP_motload_pci_fixup();
+extern void BSP_motload_pci_fixup(void);
 struct rtems_bsdnet_ifconfig;
@@ -324,8 +318,28 @@ rtems_tsec_attach(struct rtems_bsdnet_ifconfig *ifcfg, int attaching);
 #define RTEMS_BSP_NETWORK_DRIVER_NAME   "tse1"
 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_tsec_attach
+ * Prototypes for methods called only from .S for dependency tracking
+char *save_boot_params(
+  void *r3,
+  void *r4,
+  void *r5,
+  char *cmdline_start,
+  char *cmdline_end
+void zero_bss(void);
+ * Prototypes for methods in the BSP that cross file boundaries
+extern void BSP_vme_config(void);
+extern void BSP_pciConfigDump_early( void );
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
index 5a14349..86b9ec0 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
@@ -47,8 +47,6 @@
 #endif
 extern unsigned long __rtems_end[];
-extern void          BSP_vme_config(void);
-extern void          BSP_pciConfigDump_early( void );
 extern unsigned      ppc_exc_lock_std, ppc_exc_gpr3_std;
@@ -123,14 +121,16 @@ char *rtems_progname;
  *  Use the shared implementations of the following routines
-char * save_boot_params(
-  void* r3,
+  void *r3,
   void *r4,
-  void* r5,
-  char *additional_boot_options)
+  void *r5,
+  char *cmdline_end
-  strncpy(cmdline_buf, additional_boot_options, CMDLINE_BUF_SIZE);
+  strncpy(cmdline_buf, cmdline_start, CMDLINE_BUF_SIZE);
   cmdline_buf[CMDLINE_BUF_SIZE - 1] ='\0';
   return cmdline_buf;
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/vme/VMEConfig.h b/c/src/lib/libbsp/powerpc/mvme3100/vme/VMEConfig.h
index 5692ac5..10b424c 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/vme/VMEConfig.h
+++ b/c/src/lib/libbsp/powerpc/mvme3100/vme/VMEConfig.h
@@ -104,6 +104,9 @@
  * sharing.
+extern int BSP_VMEInit(void);
+extern int BSP_VMEIrqMgrInstall(void);
  *  @defgroup powerpc_vme BSP_VME_INSTALL_IRQ_MGR Support
@@ -111,7 +114,6 @@
  *  @brief BSP_VME_INSTALL_IRQ_MGR Support Package
 #define BSP_VME_INSTALL_IRQ_MGR(err)    \
 	do {                                \
 		err = vmeTsi148InstallIrqMgrAlt(\
1.9.3
