[PATCH 05/34] m68k/av5282: Fix warning
Mon Oct 20 20:34:07 UTC 2014
 c/src/lib/libbsp/m68k/av5282/include/bsp.h      | 24 +++++---
 c/src/lib/libbsp/m68k/av5282/start/start.S      |  7 ++-
 c/src/lib/libbsp/m68k/av5282/startup/init5282.c | 76 ++++++++++++-------------
 3 files changed, 58 insertions(+), 49 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/av5282/include/bsp.h b/c/src/lib/libbsp/m68k/av5282/include/bsp.h
index 2068bb1..6741fda 100644
--- a/c/src/lib/libbsp/m68k/av5282/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/av5282/include/bsp.h
@@ -10,9 +10,19 @@
  *  av5282 BSP header file
+ * @defgroup m68k_av5282 AV5282 Support
+ * @ingroup bsp_m68k
+ * @brief AV5282 support.
 #ifndef __SBav5282_BSP_H
 #define __SBav5282_BSP_H
+#ifndef ASM
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -78,16 +88,14 @@ rtems_isr_entry set_vector(
 #define UART2_IRQ_LEVEL     3
 #define UART2_IRQ_PRIORITY  5
+ * Prototypes for methods called from .S to alow dependency tracking
+void Init5282(void);
 #ifdef __cplusplus
 #endif
+#endif /* !ASM */
 #endif
- * @defgroup m68k_av5282 AV5282 Support
- * @ingroup bsp_m68k
- * @brief AV5282 support.
diff --git a/c/src/lib/libbsp/m68k/av5282/start/start.S b/c/src/lib/libbsp/m68k/av5282/start/start.S
index d9b255a..5075851 100644
--- a/c/src/lib/libbsp/m68k/av5282/start/start.S
+++ b/c/src/lib/libbsp/m68k/av5282/start/start.S
@@ -5,8 +5,10 @@
  *  The name of this entry point is compiler dependent.
  *  It jumps to the BSP which is responsible for performing
  *  all initialization.
- *  COPYRIGHT (c) 1989-1998.
+ *  COPYRIGHT (c) 1989-2014.
  *  On-Line Applications Research Corporation (OAR).
  *  The license and distribution terms for this file may be
@@ -14,6 +16,7 @@
  *  http://www.rtems.org/license/LICENSE.
+#include <bsp.h>
 #include <rtems/asm.h>
 #define SRAM_SIZE (64*1024)
diff --git a/c/src/lib/libbsp/m68k/av5282/startup/init5282.c b/c/src/lib/libbsp/m68k/av5282/startup/init5282.c
index 2898295..df5eedb 100644
--- a/c/src/lib/libbsp/m68k/av5282/startup/init5282.c
+++ b/c/src/lib/libbsp/m68k/av5282/startup/init5282.c
@@ -7,12 +7,15 @@
  * work has been done by the bootstrap dBUG code.
-#include <rtems.h>
 #include <bsp.h>
-#define m68k_set_cacr(_cacr) __asm__ volatile ("movec %0,%%cacr" : : "d" (_cacr))
-#define m68k_set_acr0(_acr0) __asm__ volatile ("movec %0,%%acr0" : : "d" (_acr0))
-#define m68k_set_acr1(_acr1) __asm__ volatile ("movec %0,%%acr1" : : "d" (_acr1))
-#define MM_SDRAM_BASE		(0x00000000)
+#define m68k_set_cacr(_cacr) \
+    __asm__ volatile ("movec %0,%%cacr" : : "d" (_cacr))
+#define m68k_set_acr0(_acr0) \
+    __asm__ volatile ("movec %0,%%acr0" : : "d" (_acr0))
+#define m68k_set_acr1(_acr1) \
+    __asm__ volatile ("movec %0,%%acr1" : : "d" (_acr1))
+#define MM_SDRAM_BASE    (0x00000000)
  * External methods used by this file
@@ -41,49 +44,44 @@ void Init5282 (void)
     MCF5282_CS0_CSMR = 0x007f0001;
     MCF5282_CS0_CSCR =(((0xf)&0x0F)<<10)|(1<<8)|(0x80);
-	/*Setup the SDRAM  */
-	for(x=0; x<20000; x++)
-		temp +=1;
-	MCF5282_SDRAMC_DCR  = 0x00000239;
-	MCF5282_SDRAMC_DACR0 = 0x00001320;
-	MCF5282_SDRAMC_DMR0 = (0x00FC0000) | (0x00000001);
-		temp +=1;
-	/* set ip ( bit 3 ) in dacr */
-	MCF5282_SDRAMC_DACR0 |= (0x00000008) ;
-	/* init precharge */
-	*((short *)MM_SDRAM_BASE) = 0;
-	/* set RE in dacr */
-	MCF5282_SDRAMC_DACR0 |= (0x00008000);
-	/* wait */
-		temp +=1;
-	/* issue IMRS */
-	MCF5282_SDRAMC_DACR0 |= (0x00000040);
-	*((short *)MM_SDRAM_BASE) = 0x0000;
-	for(x=0; x<60000; x++)
-		temp +=1;
-	*((unsigned long*)MM_SDRAM_BASE)=0x12345678;
+  /*Setup the SDRAM  */
+  for(x=0; x<20000; x++) {
+    temp +=1;
+  MCF5282_SDRAMC_DCR  = 0x00000239;
+  MCF5282_SDRAMC_DACR0 = 0x00001320;
+  MCF5282_SDRAMC_DMR0 = (0x00FC0000) | (0x00000001);
+    temp +=1;
+  /* set ip ( bit 3 ) in dacr */
+  MCF5282_SDRAMC_DACR0 |= (0x00000008) ;
+  /* init precharge */
+  *((short *)MM_SDRAM_BASE) = 0;
+  /* set RE in dacr */
+  MCF5282_SDRAMC_DACR0 |= (0x00008000);
+  /* wait */
+    temp +=1;
+  /* issue IMRS */
+  MCF5282_SDRAMC_DACR0 |= (0x00000040);
+  *((short *)MM_SDRAM_BASE) = 0x0000;
+  for(x=0; x<60000; x++) {
+    temp +=1;
+  *((unsigned long*)MM_SDRAM_BASE)=0x12345678;
     /* Copy the interrupt vector table to address 0x0 in SDRAM */
         uint32_t *inttab = (uint32_t *)&INTERRUPT_VECTOR;
         uint32_t *intvec = (uint32_t *)0x0;
         register int i;
-        for (i = 0; i < 256; i++)
+        for (i = 0; i < 256; i++) {
             *(intvec++) = *(inttab++);
      * Copy data, clear BSS and call boot_card()
     CopyDataClearBSSAndStart ();
1.9.3
