[PATCH 06/34] m68k/csb360: Fix warnings
Mon Oct 20 20:34:08 UTC 2014
 c/src/lib/libbsp/m68k/csb360/include/bsp.h      |   5 +
 c/src/lib/libbsp/m68k/csb360/start/start.S      |   4 +-
 c/src/lib/libbsp/m68k/csb360/startup/init5272.c | 130 +++++++++++-------------
 3 files changed, 69 insertions(+), 70 deletions(-)
diff --git a/c/src/lib/libbsp/m68k/csb360/include/bsp.h b/c/src/lib/libbsp/m68k/csb360/include/bsp.h
index 073295c..7a18974 100644
--- a/c/src/lib/libbsp/m68k/csb360/include/bsp.h
+++ b/c/src/lib/libbsp/m68k/csb360/include/bsp.h
@@ -178,6 +178,11 @@ rtems_isr_entry set_vector(
   int                 type
+ * Prototypes for BSP methods which cross file boundaries
+void init5272(void);
 #ifdef __cplusplus
 #endif
diff --git a/c/src/lib/libbsp/m68k/csb360/start/start.S b/c/src/lib/libbsp/m68k/csb360/start/start.S
index 82a834b..299c8da 100644
--- a/c/src/lib/libbsp/m68k/csb360/start/start.S
+++ b/c/src/lib/libbsp/m68k/csb360/start/start.S
@@ -5,7 +5,9 @@
  *  The name of this entry point is compiler dependent.
  *  It jumps to the BSP which is responsible for performing
  *  all initialization.
  *  Copyright (C) 2004 Cogent Computer Systems
  *  Author: Jay Monkman <jtm at lopingdog.com>
diff --git a/c/src/lib/libbsp/m68k/csb360/startup/init5272.c b/c/src/lib/libbsp/m68k/csb360/startup/init5272.c
index 0e7617c..267fd55 100644
--- a/c/src/lib/libbsp/m68k/csb360/startup/init5272.c
+++ b/c/src/lib/libbsp/m68k/csb360/startup/init5272.c
@@ -8,7 +8,9 @@
  *  This initialization code based on hardware settings of dBUG
  *  monitor. This must be changed if you like to run it immediately
  *  after reset.
  *  Copyright (C) 2000 OKTET Ltd., St.-Petersburg, Russia
  *  Author: Victor V. Vengerov <vvv at oktet.ru>
@@ -25,7 +27,6 @@
  *  http://www.rtems.org/license/LICENSE.
-#include <rtems.h>
 #include <bsp.h>
 #include <mcf5272/mcf5272.h>
@@ -71,84 +72,75 @@ usb_regs_t *g_usb_regs            = (void *) MCF5272_USB_BASE(BSP_MBAR);
                   "nop\n\t" \
                   : : "d" (MCF5272_CACR_CINV) )
-/* init5272 --
- *     Initialize MCF5272 on-chip modules
- * PARAMETERS:
- *     none
- * RETURNS:
- *     none
+ * Initialize MCF5272 on-chip modules
-void
-init5272(void)
-    /* Invalidate the cache - WARNING: It won't complete for 64 clocks */
-    m68k_set_cacr(MCF5272_CACR_CINV);
-    /* Set Module Base Address register */
-    m68k_set_mbar((BSP_MBAR & MCF5272_MBAR_BA) | MCF5272_MBAR_V);
-    /* Set RAM Base Address register */
-    m68k_set_srambar((BSP_RAMBAR & MCF5272_RAMBAR_BA) | MCF5272_RAMBAR_V);
-    /* Set System Control Register:
-     * Enet has highest priority, 16384 bus cycles before timeout
-    g_sim_regs->scr = (MCF5272_SCR_HWR_16384);
-    /* System Protection Register:
-     * Enable Hardware watchdog timer.
-    g_sim_regs->spr = MCF5272_SPR_HWTEN;
-    /* Clear and mask all interrupts */
-    g_intctrl_regs->icr1 = 0x88888888;
-    g_intctrl_regs->icr2 = 0x88888888;
-    g_intctrl_regs->icr3 = 0x88888888;
-    g_intctrl_regs->icr4 = 0x88880000;
-    /* Copy the interrupt vector table to SRAM */
-        uint32_t *inttab = (uint32_t *)&INTERRUPT_VECTOR;
-        uint32_t *intvec = (uint32_t *)BSP_RAMBAR;
-        register int i;
-        for (i = 0; i < 256; i++)
-            *(intvec++) = *(inttab++);
-    m68k_set_vbr(BSP_RAMBAR);
+  /* Invalidate the cache - WARNING: It won't complete for 64 clocks */
+  m68k_set_cacr(MCF5272_CACR_CINV);
+  /* Set Module Base Address register */
+  m68k_set_mbar((BSP_MBAR & MCF5272_MBAR_BA) | MCF5272_MBAR_V);
-     * Setup ACRs so that if cache turned on, periphal accesses
-     * are not messed up.  (Non-cacheable, serialized)
+  /* Set RAM Base Address register */
+  m68k_set_srambar((BSP_RAMBAR & MCF5272_RAMBAR_BA) | MCF5272_RAMBAR_V);
-    m68k_set_acr0(MCF5272_ACR_BASE(BSP_MEM_ADDR_SDRAM)    |
-                  MCF5272_ACR_MASK(BSP_MEM_MASK_SDRAM)    |
-                  MCF5272_ACR_EN                          |
-                  MCF5272_ACR_SM_ANY);
+  /* Set System Control Register:
+   * Enet has highest priority, 16384 bus cycles before timeout
+  g_sim_regs->scr = (MCF5272_SCR_HWR_16384);
-    m68k_set_acr1 (MCF5206E_ACR_BASE(BSP_MEM_ADDR_FLASH) |
-                   MCF5206E_ACR_MASK(BSP_MEM_MASK_FLASH) |
-                   MCF5206E_ACR_EN                       |
-                   MCF5206E_ACR_SM_ANY);
+  /* System Protection Register:
+   * Enable Hardware watchdog timer.
+  g_sim_regs->spr = MCF5272_SPR_HWTEN;
+  /* Clear and mask all interrupts */
+  g_intctrl_regs->icr1 = 0x88888888;
+  g_intctrl_regs->icr2 = 0x88888888;
+  g_intctrl_regs->icr3 = 0x88888888;
+  g_intctrl_regs->icr4 = 0x88880000;
+  /* Copy the interrupt vector table to SRAM */
+    uint32_t *inttab = (uint32_t *)&INTERRUPT_VECTOR;
+    uint32_t *intvec = (uint32_t *)BSP_RAMBAR;
+    register int i;
+    for (i = 0; i < 256; i++) {
+	*(intvec++) = *(inttab++);
+  m68k_set_vbr(BSP_RAMBAR);
-    /* Enable the caches */
-    m68k_set_cacr(MCF5272_CACR_CENB |
-                  MCF5272_CACR_DCM);       /* Default is not cached */
-   * Copy data, clear BSS, switch stacks and call boot_card()
+   * Setup ACRs so that if cache turned on, periphal accesses
+   * are not messed up.  (Non-cacheable, serialized)
+  m68k_set_acr0(MCF5272_ACR_BASE(BSP_MEM_ADDR_SDRAM)    |
+		MCF5272_ACR_MASK(BSP_MEM_MASK_SDRAM)    |
+		MCF5272_ACR_EN                          |
+		MCF5272_ACR_SM_ANY);
+  m68k_set_acr1 (MCF5206E_ACR_BASE(BSP_MEM_ADDR_FLASH) |
+		 MCF5206E_ACR_MASK(BSP_MEM_MASK_FLASH) |
+		 MCF5206E_ACR_EN                       |
+		 MCF5206E_ACR_SM_ANY);
+  /* Enable the caches */
+  m68k_set_cacr(MCF5272_CACR_CENB |
+		MCF5272_CACR_DCM);       /* Default is not cached */
+ * Copy data, clear BSS, switch stacks and call boot_card()
-  CopyDataClearBSSAndStart(BSP_MEM_SIZE_ESRAM - 0x400);
+CopyDataClearBSSAndStart(BSP_MEM_SIZE_ESRAM - 0x400);
-    clear_bss();
-    start_csb360();
+  clear_bss();
+  start_csb360();
1.9.3
