Redundant Logging on User Extensions
Wed Oct 29 21:01:59 UTC 2014
On Wed, Oct 29, 2014 at 2:42 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> As Jennifer has reviewed the output from an SMP capture
> test, it is clear that something which was no big deal in
> the old fixed record uniprocessor version is now an issue.
> Most extensions have an "actor" and "acted upon" thread.
> For example, when a task is created, the calling task and
> new task are important. The actor and acted upon threads
> were logged in separate records.
> In an SMP system sorted by time, these two records can
> become disconnected. Since we now have variable length
> records, it makes sense to consolidate these into a single
> capture record.
> Any complaints?
You probably want to support multiple ways to view the capture log,
including sorting by core, or by some notion of "system call" e.g. the
entire chain of events for a single thread creation.
-Gedare
> Hi
> capture record.
> Any complaints?
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
