[rtems commit] libmisc: Add top to cpuusage.
Thu Oct 30 14:24:59 UTC 2014
On 10/30/2014 8:39 AM, Sebastian Huber wrote:
> On 28/10/14 16:17, Jennifer Averett wrote:
>> +            /* Count the number of tasks and sort this load value */
>> +            task_count++;
>> +            for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++) {
>> +              if (load_tasks[i]) {
>> +                if ((l == 0) || (l < load[i]))
>> +                  continue;
>> +                for (j = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); j >= i; j--){
>> +                  load_tasks[j + 1] = load_tasks[j];
>> +                  load[j + 1]  = load[j];
>> +              load_tasks[i] = the_thread;
>> +              load[i]  = l;
>> +              break;
> This breaks all ports using CPU_TIMESTAMP_USE_STRUCT_TIMESPEC:
> /home/sh/rtems-4.11/c/src/../../cpukit/libmisc/cpuuse/cpuusagetop.c: In
> function 'rtems_cpuusage_top_thread':
> /home/sh/rtems-4.11/c/src/../../cpukit/libmisc/cpuuse/cpuusagetop.c:117:24:
> error: invalid operands to binary == (have 'Thread_CPU_usage_t' and 'int')
> /home/sh/rtems-4.11/c/src/../../cpukit/libmisc/cpuuse/cpuusagetop.c:117:36:
> error: invalid operands to binary < (have 'Thread_CPU_usage_t' and 'long long
> unsigned int')
> /home/sh/rtems-4.11/c/src/../../cpukit/libmisc/cpuuse/cpuusagetop.c:125:24:
> error: incompatible types when assigning to type 'long long unsigned int' from
> type 'Thread_CPU_usage_t'
>                 load[i]  = l;
> /home/sh/rtems-4.11/c/src/../../cpukit/libmisc/cpuuse/cpuusagetop.c:192:13:
> error: incompatible types when assigning to type 'Timestamp_Control' from type
>           ran = load[i];
Jennifer and I just looked through my build logs from overnight
and didn't see this.
Which BSP and configure command?
We understand the issue but want to confirm it in the right
configuration.
