[rtems commit] libmisc: Add top to cpuusage.
Thu Oct 30 14:53:34 UTC 2014
I missed reviewing this patch earlier, but there are some style
problems with it, please fix them on the head.
On Tue, Oct 28, 2014 at 11:17 AM, Jennifer Averett <jennifer at rtems.org> wrote:
> Module:    rtems
> Branch:    master
> Commit:    6031da438d219c6ec5d9d48f1df2aef91710cce3
> Changeset: http://git.rtems.org/rtems/commit/?id=6031da438d219c6ec5d9d48f1df2aef91710cce3
> Author:    Jennifer Averett <jennifer.averett at oarcorp.com>
> Date:      Mon Sep 29 10:20:27 2014 -0500
>  cpukit/libmisc/Makefile.am          |    2 +-
>  cpukit/libmisc/cpuuse/cpuusagetop.c |  337 +++++++++++++++++++++++++++++++++++
>  cpukit/libmisc/cpuuse/cpuuse.h      |   19 ++
>  3 files changed, 357 insertions(+), 1 deletions(-)
> diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
> index 2f41ffa..d26c484 100644
> --- a/cpukit/libmisc/Makefile.am
> +++ b/cpukit/libmisc/Makefile.am
> @@ -27,7 +27,7 @@ EXTRA_DIST += cpuuse/README
>  noinst_LIBRARIES += libcpuuse.a
>  libcpuuse_a_SOURCES = cpuuse/cpuusagereport.c cpuuse/cpuusagereset.c \
> -    cpuuse/cpuuse.h cpuuse/cpuusagedata.c
> +     cpuuse/cpuuse.h cpuuse/cpuusagedata.c cpuuse/cpuusagetop.c
>  ## devnull
>  noinst_LIBRARIES += libdevnull.a
> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
> new file mode 100644
> index 0000000..7e7348a
> --- /dev/null
> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
> @@ -0,0 +1,337 @@
> + * @file
> + * @brief CPU Usage Top
> + * @ingroup libmisc_cpuuse CPU Usage
> + *  COPYRIGHT (c) 2014.
> + *  On-Line Applications Research Corporation (OAR).
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.org/license/LICENSE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <string.h>
> +#include <stdlib.h>
> +#include <stdio.h>
> +#include <ctype.h>
> +#include <inttypes.h>
> +#include <rtems/cpuuse.h>
> +#include <rtems/score/objectimpl.h>
> +#include <rtems/score/threadimpl.h>
> +#include <rtems/score/todimpl.h>
> +#include <rtems/score/watchdogimpl.h>
> + * Common variable to sync the load monitor task.
> +static volatile int rtems_cpuusage_top_thread_active;
remove multiple blank lines
> +typedef struct {
> +  void                  *context;
> +  rtems_printk_plugin_t  print;
> +}rtems_cpu_usage_plugin_t;
> +#define RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS (20)
> + * rtems_cpuusage_top_thread
> + *  DESCRIPTION:
> + * This function displays the load of the tasks on an ANSI terminal.
Get rid of "DESCRIPTION", prefer to use minimalist comment style on
static functions.
> +static void
> +rtems_cpuusage_top_thread (rtems_task_argument arg)
> +  uint32_t                  api_index;
> +  Thread_Control*           the_thread;
> +  int                       i;
> +  int                       j;
> +  int                       k;
> +  Objects_Information*      information;
> +    char                    name[13];
> +  int                       task_count = 0;
> +  uint32_t                  seconds, nanoseconds;
> +  rtems_cpu_usage_plugin_t* plugin = (rtems_cpu_usage_plugin_t*)arg;
> +  Thread_Control*           load_tasks[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
> +  unsigned long long        load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
> +  while (true)
Opening brace should go on whille() line.
> +    #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
> +      Timestamp_Control  uptime, total, ran, uptime_at_last_reset;
> +    #else
> +      uint32_t           total_units = 0;
> +    #endif
> +    rtems_cpuusage_top_thread_active = 1;
> +    memset (load_tasks, 0, sizeof (load_tasks));
> +    memset (load, 0, sizeof (load));
> +     * Iterate over the tasks and sort the highest load tasks
> +     * into our local arrays. We only handle a limited number of
> +     * tasks.
> +    for ( api_index = 1 ; api_index <= OBJECTS_APIS_LAST ; api_index++ ) {
> +      #if !defined(RTEMS_POSIX_API) || defined(RTEMS_DEBUG)
> +        if ( !_Objects_Information_table[ api_index ] )
> +          continue;
> +      #endif
> +      information = _Objects_Information_table[ api_index ][ 1 ];
> +      if ( information ) {
> +        for ( k=1 ; k <= information->maximum ; k++ ) {
I prefer that nested iterators should be used in increasing order, e.g. i first.
> +          the_thread = (Thread_Control *)information->local_table[ k ];
> +          if ( the_thread ) {
No blank space after the opening brace.
> +            Thread_CPU_usage_t l = the_thread->cpu_time_used;
Avoid using l and I as variable names.They're hard to differentiate
from each other and from the digit 1. This should be a more useful
variable name anyway. A one-letter variable should really only be used
for iterators. We ought to have a rule about this if we don't.
> +             *  When not using nanosecond CPU usage resolution, we have to count
> +             *  the number of "ticks" we gave credit for to give the user a rough
> +             *  guideline as to what each number means proportionally.
> +            #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
> +              total_units += l;
> +            #endif
> +            /* Count the number of tasks and sort this load value */
> +            task_count++;
> +            for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++) {
> +              if (load_tasks[i]) {
> +                if ((l == 0) || (l < load[i]))
> +                  continue;
> +                for (j = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); j >= i; j--){
> +                  load_tasks[j + 1] = load_tasks[j];
> +                  load[j + 1]  = load[j];
> +              load_tasks[i] = the_thread;
> +              load[i]  = l;
> +              break;
> +      _Timestamp_Set_to_zero( &total );
> +      uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
> +    #endif
> +    _TOD_Get_uptime( &uptime );
> +    seconds = _Timestamp_Get_seconds( &uptime );
> +    nanoseconds = _Timestamp_Get_nanoseconds( &uptime ) /
> +                  TOD_NANOSECONDS_PER_MICROSECOND;
> +    (*plugin->print)(plugin->context, "\x1b[H\x1b[J Press ENTER to exit.\n\n");
> +    (*plugin->print)(plugin->context, "uptime: ");
> +      "%7" PRIu32 ".%06" PRIu32 "\n",  seconds, nanoseconds
> +    (*plugin->print)(
> +       plugin->context,
> +       "-------------------------------------------------------------------------------\n"
> +       "                              CPU USAGE BY THREAD\n"
> +       "------------+---------------------+---------------+---------------+------------\n"
> +        " ID         | NAME                | RPRI | CPRI   | SECONDS       | PERCENT\n"
> +       #else
> +         " ID        | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
> +       #endif
Fix style here.
> +      if (!load_tasks[i])
> +        break;
> +       * If this is the currently executing thread, account for time
> +       * since the last context switch.
> +      the_thread = load_tasks[i];
> +      rtems_object_get_name( the_thread->Object.id, sizeof(name), name );
> +      (*plugin->print)(
> +        plugin->context,
> +        " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   |",
> +        the_thread->Object.id,
> +        name,
> +        the_thread->real_priority,
> +        the_thread->current_priority
I don't know how to feel about artifically adding scoped blocks.
Anyone else weigh in?
> +        Timestamp_Control last;
> +        uint32_t          ival, fval;
> +        ran = load[i];
> +        if ( _Thread_Get_time_of_last_context_switch( the_thread, &last ) ) {
> +          Timestamp_Control used;
> +          _Timestamp_Subtract( &last, &uptime, &used );
> +          _Timestamp_Add_to( &ran, &used );
> +        } else {
> +        _Timestamp_Subtract( &uptime_at_last_reset, &uptime, &total );
> +        _Timestamp_Divide( &ran, &total, &ival, &fval );
> +         * Print the information
> +        seconds = _Timestamp_Get_seconds( &ran );
> +        nanoseconds = _Timestamp_Get_nanoseconds( &ran ) /
> +       (*plugin->print)( plugin->context,
> +          "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
> +          seconds, nanoseconds,
> +            ival, fval
> +      #else
> +        if (total_units) {
> +          uint64_t ival_64;
> +          ival_64 = load[i];
> +          ival_64 *= 100000;
> +          ival = ival_64 / total_units;
> +        } else {
> +          ival = 0;
> +        fval = ival % 1000;
> +        ival /= 1000;
> +          "%14" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
> +          load[i],
> +          ival,
> +          fval
> +      #endif
> +    if (task_count < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS)
> +      j = RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - task_count;
> +      while (j > 0)
> +       (*plugin->print)( plugin->context, "\x1b[K\n");
> +        j--;
> +    rtems_cpuusage_top_thread_active = 0;
> +    rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (5000000));
> +void rtems_cpu_usage_top_with_plugin(
> +  void                  *context,
> +  rtems_status_code   sc;
> +  rtems_task_priority priority;
> +  rtems_name          name;
> +  rtems_id            id;
> +  rtems_cpu_usage_plugin_t  plugin;
> +  if ( !print )
> +    return;
> +  plugin.context = context;
> +  plugin.print   = print;
> +  sc = rtems_task_set_priority (RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &priority);
> +  if (sc != RTEMS_SUCCESSFUL)
> +    (*print)(
> +       context,
> +       "error: cannot obtain the current priority: %s\n",
> +       rtems_status_text (sc)
> +    return;
> +  name = rtems_build_name('C', 'P', 'l', 't');
> +  sc = rtems_task_create (name, priority, 4 * 1024,
> +                          RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
> +                          RTEMS_PREEMPT | RTEMS_TIMESLICE | RTEMS_NO_ASR,
> +                          &id);
> +    (*print)(
> +       context,
> +       "error: cannot create helper thread: %s\n",
> +    return;
> +  sc = rtems_task_start (
> +    id, rtems_cpuusage_top_thread, (rtems_task_argument)&plugin
> +    (*print)(
> +       context,
> +       "error: cannot start helper thread: %s\n",
> +    rtems_task_delete (id);
> +    return;
> +  for (;;)
> +    int c = getchar ();
> +    if ((c == '\r') || (c == '\n'))
> +      int loops = 20;
> +      while (loops && rtems_cpuusage_top_thread_active)
> +        rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (100000));
> +      (*print)(context, "load monitoring stopped.\n");
> +      return;
> +void rtems_cpu_usage_top( void )
> +  rtems_cpu_usage_top_with_plugin( NULL, printk_plugin );
> diff --git a/cpukit/libmisc/cpuuse/cpuuse.h b/cpukit/libmisc/cpuuse/cpuuse.h
> index 1aee275..662d905 100644
> --- a/cpukit/libmisc/cpuuse/cpuuse.h
> +++ b/cpukit/libmisc/cpuuse/cpuuse.h
> @@ -63,6 +63,25 @@ void rtems_cpu_usage_report_with_plugin(
>  void rtems_cpu_usage_report( void );
> + *   @brief CPU usage Top plugin
> + *   Report CPU Usage in top format to
> + *   to a print plugin.
> +  void                  *context,
> + *  @brief CPU usage top.
> + *  CPU Usage top
> +void rtems_cpu_usage_top( void );
>   *  @brief Reset CPU usage.
>   *  CPU Usage Reporter
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
