[rtems commit] libmisc: Add top to cpuusage.
Thu Oct 30 14:55:03 UTC 2014
FWIW she is jennifer.averett at rtems.org not jennifer at .
--joel
On 10/30/2014 9:53 AM, Gedare Bloom wrote:
> I missed reviewing this patch earlier, but there are some style
> problems with it, please fix them on the head.
> On Tue, Oct 28, 2014 at 11:17 AM, Jennifer Averett <jennifer at rtems.org> wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    6031da438d219c6ec5d9d48f1df2aef91710cce3
>> Changeset: http://git.rtems.org/rtems/commit/?id=6031da438d219c6ec5d9d48f1df2aef91710cce3
>> Author:    Jennifer Averett <jennifer.averett at oarcorp.com>
>> Date:      Mon Sep 29 10:20:27 2014 -0500
>>  cpukit/libmisc/Makefile.am          |    2 +-
>>  cpukit/libmisc/cpuuse/cpuusagetop.c |  337 +++++++++++++++++++++++++++++++++++
>>  cpukit/libmisc/cpuuse/cpuuse.h      |   19 ++
>>  3 files changed, 357 insertions(+), 1 deletions(-)
>> diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
>> index 2f41ffa..d26c484 100644
>> --- a/cpukit/libmisc/Makefile.am
>> +++ b/cpukit/libmisc/Makefile.am
>> @@ -27,7 +27,7 @@ EXTRA_DIST += cpuuse/README
>>  noinst_LIBRARIES += libcpuuse.a
>>  libcpuuse_a_SOURCES = cpuuse/cpuusagereport.c cpuuse/cpuusagereset.c \
>> -    cpuuse/cpuuse.h cpuuse/cpuusagedata.c
>> +     cpuuse/cpuuse.h cpuuse/cpuusagedata.c cpuuse/cpuusagetop.c
>>  ## devnull
>>  noinst_LIBRARIES += libdevnull.a
>> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
>> new file mode 100644
>> index 0000000..7e7348a
>> --- /dev/null
>> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
>> @@ -0,0 +1,337 @@
>> + * @file
>> + * @brief CPU Usage Top
>> + * @ingroup libmisc_cpuuse CPU Usage
>> + *  COPYRIGHT (c) 2014.
>> + *  On-Line Applications Research Corporation (OAR).
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.org/license/LICENSE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <string.h>
>> +#include <stdlib.h>
>> +#include <stdio.h>
>> +#include <ctype.h>
>> +#include <inttypes.h>
>> +#include <rtems/cpuuse.h>
>> +#include <rtems/score/objectimpl.h>
>> +#include <rtems/score/threadimpl.h>
>> +#include <rtems/score/todimpl.h>
>> +#include <rtems/score/watchdogimpl.h>
>> + * Common variable to sync the load monitor task.
>> +static volatile int rtems_cpuusage_top_thread_active;
> remove multiple blank lines
>> +typedef struct {
>> +  void                  *context;
>> +  rtems_printk_plugin_t  print;
>> +}rtems_cpu_usage_plugin_t;
>> +#define RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS (20)
>> + * rtems_cpuusage_top_thread
>> + *  DESCRIPTION:
>> + * This function displays the load of the tasks on an ANSI terminal.
> Get rid of "DESCRIPTION", prefer to use minimalist comment style on
> static functions.
>> +static void
>> +rtems_cpuusage_top_thread (rtems_task_argument arg)
>> +  uint32_t                  api_index;
>> +  Thread_Control*           the_thread;
>> +  int                       i;
>> +  int                       j;
>> +  int                       k;
>> +  Objects_Information*      information;
>> +    char                    name[13];
>> +  int                       task_count = 0;
>> +  uint32_t                  seconds, nanoseconds;
>> +  rtems_cpu_usage_plugin_t* plugin = (rtems_cpu_usage_plugin_t*)arg;
>> +  Thread_Control*           load_tasks[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
>> +  unsigned long long        load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
>> +  while (true)
> Opening brace should go on whille() line.
>> +    #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
>> +      Timestamp_Control  uptime, total, ran, uptime_at_last_reset;
>> +    #else
>> +      uint32_t           total_units = 0;
>> +    #endif
>> +    rtems_cpuusage_top_thread_active = 1;
>> +    memset (load_tasks, 0, sizeof (load_tasks));
>> +    memset (load, 0, sizeof (load));
>> +     * Iterate over the tasks and sort the highest load tasks
>> +     * into our local arrays. We only handle a limited number of
>> +     * tasks.
>> +    for ( api_index = 1 ; api_index <= OBJECTS_APIS_LAST ; api_index++ ) {
>> +      #if !defined(RTEMS_POSIX_API) || defined(RTEMS_DEBUG)
>> +        if ( !_Objects_Information_table[ api_index ] )
>> +          continue;
>> +      #endif
>> +      information = _Objects_Information_table[ api_index ][ 1 ];
>> +      if ( information ) {
>> +        for ( k=1 ; k <= information->maximum ; k++ ) {
> I prefer that nested iterators should be used in increasing order, e.g. i first.
>> +          the_thread = (Thread_Control *)information->local_table[ k ];
>> +          if ( the_thread ) {
> No blank space after the opening brace.
>> +            Thread_CPU_usage_t l = the_thread->cpu_time_used;
> Avoid using l and I as variable names.They're hard to differentiate
> from each other and from the digit 1. This should be a more useful
> variable name anyway. A one-letter variable should really only be used
> for iterators. We ought to have a rule about this if we don't.
>> +             *  When not using nanosecond CPU usage resolution, we have to count
>> +             *  the number of "ticks" we gave credit for to give the user a rough
>> +             *  guideline as to what each number means proportionally.
>> +            #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
>> +              total_units += l;
>> +            #endif
>> +            /* Count the number of tasks and sort this load value */
>> +            task_count++;
>> +            for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++) {
>> +              if (load_tasks[i]) {
>> +                if ((l == 0) || (l < load[i]))
>> +                  continue;
>> +                for (j = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); j >= i; j--){
>> +                  load_tasks[j + 1] = load_tasks[j];
>> +                  load[j + 1]  = load[j];
>> +              load_tasks[i] = the_thread;
>> +              load[i]  = l;
>> +              break;
>> +      _Timestamp_Set_to_zero( &total );
>> +      uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
>> +    #endif
>> +    _TOD_Get_uptime( &uptime );
>> +    seconds = _Timestamp_Get_seconds( &uptime );
>> +    nanoseconds = _Timestamp_Get_nanoseconds( &uptime ) /
>> +                  TOD_NANOSECONDS_PER_MICROSECOND;
>> +    (*plugin->print)(plugin->context, "\x1b[H\x1b[J Press ENTER to exit.\n\n");
>> +    (*plugin->print)(plugin->context, "uptime: ");
>> +      "%7" PRIu32 ".%06" PRIu32 "\n",  seconds, nanoseconds
>> +    (*plugin->print)(
>> +       plugin->context,
>> +       "-------------------------------------------------------------------------------\n"
>> +       "                              CPU USAGE BY THREAD\n"
>> +       "------------+---------------------+---------------+---------------+------------\n"
>> +        " ID         | NAME                | RPRI | CPRI   | SECONDS       | PERCENT\n"
>> +       #else
>> +         " ID        | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
>> +       #endif
> Fix style here.
>> +      if (!load_tasks[i])
>> +        break;
>> +       * If this is the currently executing thread, account for time
>> +       * since the last context switch.
>> +      the_thread = load_tasks[i];
>> +      rtems_object_get_name( the_thread->Object.id, sizeof(name), name );
>> +      (*plugin->print)(
>> +        plugin->context,
>> +        " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   |",
>> +        the_thread->Object.id,
>> +        name,
>> +        the_thread->real_priority,
>> +        the_thread->current_priority
> I don't know how to feel about artifically adding scoped blocks.
> Anyone else weigh in?
>> +        Timestamp_Control last;
>> +        uint32_t          ival, fval;
>> +        ran = load[i];
>> +        if ( _Thread_Get_time_of_last_context_switch( the_thread, &last ) ) {
>> +          Timestamp_Control used;
>> +          _Timestamp_Subtract( &last, &uptime, &used );
>> +          _Timestamp_Add_to( &ran, &used );
>> +        } else {
>> +        _Timestamp_Subtract( &uptime_at_last_reset, &uptime, &total );
>> +        _Timestamp_Divide( &ran, &total, &ival, &fval );
>> +         * Print the information
>> +        seconds = _Timestamp_Get_seconds( &ran );
>> +        nanoseconds = _Timestamp_Get_nanoseconds( &ran ) /
>> +       (*plugin->print)( plugin->context,
>> +          "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>> +          seconds, nanoseconds,
>> +            ival, fval
>> +      #else
>> +        if (total_units) {
>> +          uint64_t ival_64;
>> +          ival_64 = load[i];
>> +          ival_64 *= 100000;
>> +          ival = ival_64 / total_units;
>> +        } else {
>> +          ival = 0;
>> +        fval = ival % 1000;
>> +        ival /= 1000;
>> +          "%14" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>> +          load[i],
>> +          ival,
>> +          fval
>> +      #endif
>> +    if (task_count < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS)
>> +      j = RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - task_count;
>> +      while (j > 0)
>> +       (*plugin->print)( plugin->context, "\x1b[K\n");
>> +        j--;
>> +    rtems_cpuusage_top_thread_active = 0;
>> +    rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (5000000));
>> +void rtems_cpu_usage_top_with_plugin(
>> +  void                  *context,
>> +  rtems_status_code   sc;
>> +  rtems_task_priority priority;
>> +  rtems_name          name;
>> +  rtems_id            id;
>> +  rtems_cpu_usage_plugin_t  plugin;
>> +  if ( !print )
>> +    return;
>> +  plugin.context = context;
>> +  plugin.print   = print;
>> +  sc = rtems_task_set_priority (RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &priority);
>> +  if (sc != RTEMS_SUCCESSFUL)
>> +    (*print)(
>> +       context,
>> +       "error: cannot obtain the current priority: %s\n",
>> +       rtems_status_text (sc)
>> +    return;
>> +  name = rtems_build_name('C', 'P', 'l', 't');
>> +  sc = rtems_task_create (name, priority, 4 * 1024,
>> +                          RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
>> +                          RTEMS_PREEMPT | RTEMS_TIMESLICE | RTEMS_NO_ASR,
>> +                          &id);
>> +    (*print)(
>> +       context,
>> +       "error: cannot create helper thread: %s\n",
>> +    return;
>> +  sc = rtems_task_start (
>> +    id, rtems_cpuusage_top_thread, (rtems_task_argument)&plugin
>> +    (*print)(
>> +       context,
>> +       "error: cannot start helper thread: %s\n",
>> +    rtems_task_delete (id);
>> +    return;
>> +  for (;;)
>> +    int c = getchar ();
>> +    if ((c == '\r') || (c == '\n'))
>> +      int loops = 20;
>> +      while (loops && rtems_cpuusage_top_thread_active)
>> +        rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (100000));
>> +      (*print)(context, "load monitoring stopped.\n");
>> +      return;
>> +void rtems_cpu_usage_top( void )
>> +  rtems_cpu_usage_top_with_plugin( NULL, printk_plugin );
>> diff --git a/cpukit/libmisc/cpuuse/cpuuse.h b/cpukit/libmisc/cpuuse/cpuuse.h
>> index 1aee275..662d905 100644
>> --- a/cpukit/libmisc/cpuuse/cpuuse.h
>> +++ b/cpukit/libmisc/cpuuse/cpuuse.h
>> @@ -63,6 +63,25 @@ void rtems_cpu_usage_report_with_plugin(
>>  void rtems_cpu_usage_report( void );
>> + *   @brief CPU usage Top plugin
>> + *   Report CPU Usage in top format to
>> + *   to a print plugin.
>> +  void                  *context,
>> + *  @brief CPU usage top.
>> + *  CPU Usage top
>> +void rtems_cpu_usage_top( void );
>>   *  @brief Reset CPU usage.
>>   *  CPU Usage Reporter
>> vc mailing list
>> vc at rtems.org
>> http://lists.rtems.org/mailman/listinfo/vc
> devel mailing list
> devel at rtems.org
