[rtems commit] libmisc: Add top to cpuusage.
Thu Oct 30 15:07:53 UTC 2014
The problem may be a setup issue on git.rtems.org, where it converts
from user login to email, I think it might be doing something dumb
like just taking login-name @rtems.org
On Thu, Oct 30, 2014 at 11:03 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 10/30/2014 9:55 AM, Gedare Bloom wrote:
>> The email address came from VC, so it is a problem in the commit setup I guess.
> OK. I will help her double check.  Working on multiple machines,
> I periodically find one that is wrong for myself. :(
> --joel
>> On Thu, Oct 30, 2014 at 10:55 AM, Joel Sherrill
>>> FWIW she is jennifer.averett at rtems.org not jennifer at .
>>> --joel
>>> On 10/30/2014 9:53 AM, Gedare Bloom wrote:
>>>> I missed reviewing this patch earlier, but there are some style
>>>> problems with it, please fix them on the head.
>>>> On Tue, Oct 28, 2014 at 11:17 AM, Jennifer Averett <jennifer at rtems.org> wrote:
>>>>> Module:    rtems
>>>>> Branch:    master
>>>>> Commit:    6031da438d219c6ec5d9d48f1df2aef91710cce3
>>>>> Changeset: http://git.rtems.org/rtems/commit/?id=6031da438d219c6ec5d9d48f1df2aef91710cce3
>>>>> Author:    Jennifer Averett <jennifer.averett at oarcorp.com>
>>>>> Date:      Mon Sep 29 10:20:27 2014 -0500
>>>>>  cpukit/libmisc/Makefile.am          |    2 +-
>>>>>  cpukit/libmisc/cpuuse/cpuusagetop.c |  337 +++++++++++++++++++++++++++++++++++
>>>>>  cpukit/libmisc/cpuuse/cpuuse.h      |   19 ++
>>>>>  3 files changed, 357 insertions(+), 1 deletions(-)
>>>>> diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
>>>>> index 2f41ffa..d26c484 100644
>>>>> --- a/cpukit/libmisc/Makefile.am
>>>>> +++ b/cpukit/libmisc/Makefile.am
>>>>> @@ -27,7 +27,7 @@ EXTRA_DIST += cpuuse/README
>>>>>  noinst_LIBRARIES += libcpuuse.a
>>>>>  libcpuuse_a_SOURCES = cpuuse/cpuusagereport.c cpuuse/cpuusagereset.c \
>>>>> -    cpuuse/cpuuse.h cpuuse/cpuusagedata.c
>>>>> +     cpuuse/cpuuse.h cpuuse/cpuusagedata.c cpuuse/cpuusagetop.c
>>>>>  ## devnull
>>>>>  noinst_LIBRARIES += libdevnull.a
>>>>> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
>>>>> new file mode 100644
>>>>> index 0000000..7e7348a
>>>>> --- /dev/null
>>>>> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
>>>>> @@ -0,0 +1,337 @@
>>>>> + * @file
>>>>> + * @brief CPU Usage Top
>>>>> + * @ingroup libmisc_cpuuse CPU Usage
>>>>> + *  COPYRIGHT (c) 2014.
>>>>> + *  On-Line Applications Research Corporation (OAR).
>>>>> + *  The license and distribution terms for this file may be
>>>>> + *  found in the file LICENSE in this distribution or at
>>>>> + *  http://www.rtems.org/license/LICENSE.
>>>>> +#ifdef HAVE_CONFIG_H
>>>>> +#include "config.h"
>>>>> +#endif
>>>>> +#include <string.h>
>>>>> +#include <stdlib.h>
>>>>> +#include <stdio.h>
>>>>> +#include <ctype.h>
>>>>> +#include <inttypes.h>
>>>>> +#include <rtems/cpuuse.h>
>>>>> +#include <rtems/score/objectimpl.h>
>>>>> +#include <rtems/score/threadimpl.h>
>>>>> +#include <rtems/score/todimpl.h>
>>>>> +#include <rtems/score/watchdogimpl.h>
>>>>> + * Common variable to sync the load monitor task.
>>>>> +static volatile int rtems_cpuusage_top_thread_active;
>>>> remove multiple blank lines
>>>>> +typedef struct {
>>>>> +  void                  *context;
>>>>> +  rtems_printk_plugin_t  print;
>>>>> +}rtems_cpu_usage_plugin_t;
>>>>> +#define RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS (20)
>>>>> + * rtems_cpuusage_top_thread
>>>>> + *  DESCRIPTION:
>>>>> + * This function displays the load of the tasks on an ANSI terminal.
>>>> Get rid of "DESCRIPTION", prefer to use minimalist comment style on
>>>> static functions.
>>>>> +static void
>>>>> +rtems_cpuusage_top_thread (rtems_task_argument arg)
>>>>> +  uint32_t                  api_index;
>>>>> +  Thread_Control*           the_thread;
>>>>> +  int                       i;
>>>>> +  int                       j;
>>>>> +  int                       k;
>>>>> +  Objects_Information*      information;
>>>>> +    char                    name[13];
>>>>> +  int                       task_count = 0;
>>>>> +  uint32_t                  seconds, nanoseconds;
>>>>> +  rtems_cpu_usage_plugin_t* plugin = (rtems_cpu_usage_plugin_t*)arg;
>>>>> +  Thread_Control*           load_tasks[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
>>>>> +  unsigned long long        load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
>>>>> +  while (true)
>>>> Opening brace should go on whille() line.
>>>>> +    #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
>>>>> +      Timestamp_Control  uptime, total, ran, uptime_at_last_reset;
>>>>> +    #else
>>>>> +      uint32_t           total_units = 0;
>>>>> +    #endif
>>>>> +    rtems_cpuusage_top_thread_active = 1;
>>>>> +    memset (load_tasks, 0, sizeof (load_tasks));
>>>>> +    memset (load, 0, sizeof (load));
>>>>> +     * Iterate over the tasks and sort the highest load tasks
>>>>> +     * into our local arrays. We only handle a limited number of
>>>>> +     * tasks.
>>>>> +    for ( api_index = 1 ; api_index <= OBJECTS_APIS_LAST ; api_index++ ) {
>>>>> +      #if !defined(RTEMS_POSIX_API) || defined(RTEMS_DEBUG)
>>>>> +        if ( !_Objects_Information_table[ api_index ] )
>>>>> +          continue;
>>>>> +      #endif
>>>>> +      information = _Objects_Information_table[ api_index ][ 1 ];
>>>>> +      if ( information ) {
>>>>> +        for ( k=1 ; k <= information->maximum ; k++ ) {
>>>> I prefer that nested iterators should be used in increasing order, e.g. i first.
>>>>> +          the_thread = (Thread_Control *)information->local_table[ k ];
>>>>> +          if ( the_thread ) {
>>>> No blank space after the opening brace.
>>>>> +            Thread_CPU_usage_t l = the_thread->cpu_time_used;
>>>> Avoid using l and I as variable names.They're hard to differentiate
>>>> from each other and from the digit 1. This should be a more useful
>>>> variable name anyway. A one-letter variable should really only be used
>>>> for iterators. We ought to have a rule about this if we don't.
>>>>> +             *  When not using nanosecond CPU usage resolution, we have to count
>>>>> +             *  the number of "ticks" we gave credit for to give the user a rough
>>>>> +             *  guideline as to what each number means proportionally.
>>>>> +            #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
>>>>> +              total_units += l;
>>>>> +            #endif
>>>>> +            /* Count the number of tasks and sort this load value */
>>>>> +            task_count++;
>>>>> +            for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++) {
>>>>> +              if (load_tasks[i]) {
>>>>> +                if ((l == 0) || (l < load[i]))
>>>>> +                  continue;
>>>>> +                for (j = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); j >= i; j--){
>>>>> +                  load_tasks[j + 1] = load_tasks[j];
>>>>> +                  load[j + 1]  = load[j];
>>>>> +              load_tasks[i] = the_thread;
>>>>> +              load[i]  = l;
>>>>> +              break;
>>>>> +      _Timestamp_Set_to_zero( &total );
>>>>> +      uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
>>>>> +    #endif
>>>>> +    _TOD_Get_uptime( &uptime );
>>>>> +    seconds = _Timestamp_Get_seconds( &uptime );
>>>>> +    nanoseconds = _Timestamp_Get_nanoseconds( &uptime ) /
>>>>> +                  TOD_NANOSECONDS_PER_MICROSECOND;
>>>>> +    (*plugin->print)(plugin->context, "\x1b[H\x1b[J Press ENTER to exit.\n\n");
>>>>> +    (*plugin->print)(plugin->context, "uptime: ");
>>>>> +      "%7" PRIu32 ".%06" PRIu32 "\n",  seconds, nanoseconds
>>>>> +    (*plugin->print)(
>>>>> +       plugin->context,
>>>>> +       "-------------------------------------------------------------------------------\n"
>>>>> +       "                              CPU USAGE BY THREAD\n"
>>>>> +       "------------+---------------------+---------------+---------------+------------\n"
>>>>> +        " ID         | NAME                | RPRI | CPRI   | SECONDS       | PERCENT\n"
>>>>> +       #else
>>>>> +         " ID        | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
>>>>> +       #endif
>>>> Fix style here.
>>>>> +      if (!load_tasks[i])
>>>>> +        break;
>>>>> +       * If this is the currently executing thread, account for time
>>>>> +       * since the last context switch.
>>>>> +      the_thread = load_tasks[i];
>>>>> +      rtems_object_get_name( the_thread->Object.id, sizeof(name), name );
>>>>> +      (*plugin->print)(
>>>>> +        plugin->context,
>>>>> +        " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   |",
>>>>> +        the_thread->Object.id,
>>>>> +        name,
>>>>> +        the_thread->real_priority,
>>>>> +        the_thread->current_priority
>>>> I don't know how to feel about artifically adding scoped blocks.
>>>> Anyone else weigh in?
>>>>> +        Timestamp_Control last;
>>>>> +        uint32_t          ival, fval;
>>>>> +        ran = load[i];
>>>>> +        if ( _Thread_Get_time_of_last_context_switch( the_thread, &last ) ) {
>>>>> +          Timestamp_Control used;
>>>>> +          _Timestamp_Subtract( &last, &uptime, &used );
>>>>> +          _Timestamp_Add_to( &ran, &used );
>>>>> +        } else {
>>>>> +        _Timestamp_Subtract( &uptime_at_last_reset, &uptime, &total );
>>>>> +        _Timestamp_Divide( &ran, &total, &ival, &fval );
>>>>> +         * Print the information
>>>>> +        seconds = _Timestamp_Get_seconds( &ran );
>>>>> +        nanoseconds = _Timestamp_Get_nanoseconds( &ran ) /
>>>>> +       (*plugin->print)( plugin->context,
>>>>> +          "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>>>>> +          seconds, nanoseconds,
>>>>> +            ival, fval
>>>>> +      #else
>>>>> +        if (total_units) {
>>>>> +          uint64_t ival_64;
>>>>> +          ival_64 = load[i];
>>>>> +          ival_64 *= 100000;
>>>>> +          ival = ival_64 / total_units;
>>>>> +        } else {
>>>>> +          ival = 0;
>>>>> +        fval = ival % 1000;
>>>>> +        ival /= 1000;
>>>>> +          "%14" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>>>>> +          load[i],
>>>>> +          ival,
>>>>> +          fval
>>>>> +      #endif
>>>>> +    if (task_count < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS)
>>>>> +      j = RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - task_count;
>>>>> +      while (j > 0)
>>>>> +       (*plugin->print)( plugin->context, "\x1b[K\n");
>>>>> +        j--;
>>>>> +    rtems_cpuusage_top_thread_active = 0;
>>>>> +    rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (5000000));
>>>>> +void rtems_cpu_usage_top_with_plugin(
>>>>> +  void                  *context,
>>>>> +  rtems_status_code   sc;
>>>>> +  rtems_task_priority priority;
>>>>> +  rtems_name          name;
>>>>> +  rtems_id            id;
>>>>> +  rtems_cpu_usage_plugin_t  plugin;
>>>>> +  if ( !print )
>>>>> +    return;
>>>>> +  plugin.context = context;
>>>>> +  plugin.print   = print;
>>>>> +  sc = rtems_task_set_priority (RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &priority);
>>>>> +  if (sc != RTEMS_SUCCESSFUL)
>>>>> +    (*print)(
>>>>> +       context,
>>>>> +       "error: cannot obtain the current priority: %s\n",
>>>>> +       rtems_status_text (sc)
>>>>> +    return;
>>>>> +  name = rtems_build_name('C', 'P', 'l', 't');
>>>>> +  sc = rtems_task_create (name, priority, 4 * 1024,
>>>>> +                          RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
>>>>> +                          RTEMS_PREEMPT | RTEMS_TIMESLICE | RTEMS_NO_ASR,
>>>>> +                          &id);
>>>>> +    (*print)(
>>>>> +       context,
>>>>> +       "error: cannot create helper thread: %s\n",
>>>>> +    return;
>>>>> +  sc = rtems_task_start (
>>>>> +    id, rtems_cpuusage_top_thread, (rtems_task_argument)&plugin
>>>>> +    (*print)(
>>>>> +       context,
>>>>> +       "error: cannot start helper thread: %s\n",
>>>>> +    rtems_task_delete (id);
>>>>> +    return;
>>>>> +  for (;;)
>>>>> +    int c = getchar ();
>>>>> +    if ((c == '\r') || (c == '\n'))
>>>>> +      int loops = 20;
>>>>> +      while (loops && rtems_cpuusage_top_thread_active)
>>>>> +        rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (100000));
>>>>> +      (*print)(context, "load monitoring stopped.\n");
>>>>> +      return;
>>>>> +void rtems_cpu_usage_top( void )
>>>>> +  rtems_cpu_usage_top_with_plugin( NULL, printk_plugin );
>>>>> diff --git a/cpukit/libmisc/cpuuse/cpuuse.h b/cpukit/libmisc/cpuuse/cpuuse.h
>>>>> index 1aee275..662d905 100644
>>>>> --- a/cpukit/libmisc/cpuuse/cpuuse.h
>>>>> +++ b/cpukit/libmisc/cpuuse/cpuuse.h
>>>>> @@ -63,6 +63,25 @@ void rtems_cpu_usage_report_with_plugin(
>>>>>  void rtems_cpu_usage_report( void );
>>>>> + *   @brief CPU usage Top plugin
>>>>> + *   Report CPU Usage in top format to
>>>>> + *   to a print plugin.
>>>>> +  void                  *context,
>>>>> + *  @brief CPU usage top.
>>>>> + *  CPU Usage top
>>>>> +void rtems_cpu_usage_top( void );
>>>>>   *  @brief Reset CPU usage.
>>>>>   *  CPU Usage Reporter
>>>>> _______________________________________________
>>>>> vc mailing list
>>>>> vc at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/vc
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
