[rtems commit] libmisc: Add top to cpuusage.
    Jennifer Averett
    Jennifer.Averett at OARcorp.com
    Thu Oct 30 15:11:02 UTC 2014
My name and email are correct in git config.
> -----Original Message-----
> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Gedare Bloom
> Sent: Thursday, October 30, 2014 10:08 AM
> To: Joel Sherrill
> Cc: Jennifer Averett; rtems-devel at rtems.org
> Subject: Re: [rtems commit] libmisc: Add top to cpuusage.
> The problem may be a setup issue on git.rtems.org, where it converts from
> user login to email, I think it might be doing something dumb like just taking
> login-name @rtems.org
> On Thu, Oct 30, 2014 at 11:03 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
> > On 10/30/2014 9:55 AM, Gedare Bloom wrote:
> >> The email address came from VC, so it is a problem in the commit setup I
> guess.
> > OK. I will help her double check.  Working on multiple machines, I
> > periodically find one that is wrong for myself. :(
> > --joel
> >> On Thu, Oct 30, 2014 at 10:55 AM, Joel Sherrill
> >> <joel.sherrill at oarcorp.com> wrote:
> >>> FWIW she is jennifer.averett at rtems.org not jennifer at .
> >>> --joel
> >>> On 10/30/2014 9:53 AM, Gedare Bloom wrote:
> >>>> I missed reviewing this patch earlier, but there are some style
> >>>> problems with it, please fix them on the head.
> >>>> On Tue, Oct 28, 2014 at 11:17 AM, Jennifer Averett
> <jennifer at rtems.org> wrote:
> >>>>> Module:    rtems
> >>>>> Branch:    master
> >>>>> Commit:    6031da438d219c6ec5d9d48f1df2aef91710cce3
> >>>>> Changeset:
> http://git.rtems.org/rtems/commit/?id=6031da438d219c6ec5d9d48f1df2
> >>>>> aef91710cce3
> >>>>> Author:    Jennifer Averett <jennifer.averett at oarcorp.com>
> >>>>> Date:      Mon Sep 29 10:20:27 2014 -0500
> >>>>>  cpukit/libmisc/Makefile.am          |    2 +-
> >>>>>  cpukit/libmisc/cpuuse/cpuusagetop.c |  337
> >>>>>  cpukit/libmisc/cpuuse/cpuuse.h      |   19 ++
> >>>>>  3 files changed, 357 insertions(+), 1 deletions(-)
> >>>>> diff --git a/cpukit/libmisc/Makefile.am
> >>>>> b/cpukit/libmisc/Makefile.am index 2f41ffa..d26c484 100644
> >>>>> --- a/cpukit/libmisc/Makefile.am
> >>>>> +++ b/cpukit/libmisc/Makefile.am
> >>>>> @@ -27,7 +27,7 @@ EXTRA_DIST += cpuuse/README
> >>>>>  noinst_LIBRARIES += libcpuuse.a
> >>>>>  libcpuuse_a_SOURCES = cpuuse/cpuusagereport.c
> cpuuse/cpuusagereset.c \
> >>>>> -    cpuuse/cpuuse.h cpuuse/cpuusagedata.c
> >>>>> +     cpuuse/cpuuse.h cpuuse/cpuusagedata.c cpuuse/cpuusagetop.c
> >>>>>  ## devnull
> >>>>>  noinst_LIBRARIES += libdevnull.a
> >>>>> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c
> >>>>> b/cpukit/libmisc/cpuuse/cpuusagetop.c
> >>>>> new file mode 100644
> >>>>> index 0000000..7e7348a
> >>>>> --- /dev/null
> >>>>> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
> >>>>> @@ -0,0 +1,337 @@
> >>>>> + * @file
> >>>>> + * @brief CPU Usage Top
> >>>>> + * @ingroup libmisc_cpuuse CPU Usage  */
> >>>>> + *  COPYRIGHT (c) 2014.
> >>>>> + *  On-Line Applications Research Corporation (OAR).
> >>>>> + *  The license and distribution terms for this file may be
> >>>>> + *  found in the file LICENSE in this distribution or at
> >>>>> + *  http://www.rtems.org/license/LICENSE.
> >>>>> +#ifdef HAVE_CONFIG_H
> >>>>> +#include "config.h"
> >>>>> +#endif
> >>>>> +#include <string.h>
> >>>>> +#include <stdlib.h>
> >>>>> +#include <stdio.h>
> >>>>> +#include <ctype.h>
> >>>>> +#include <inttypes.h>
> >>>>> +#include <rtems/cpuuse.h>
> >>>>> +#include <rtems/score/objectimpl.h> #include
> >>>>> +<rtems/score/threadimpl.h> #include <rtems/score/todimpl.h>
> >>>>> +#include <rtems/score/watchdogimpl.h>
> >>>>> + * Common variable to sync the load monitor task.
> >>>>> +static volatile int rtems_cpuusage_top_thread_active;
> >>>> remove multiple blank lines
> >>>>> +typedef struct {
> >>>>> +  void                  *context;
> >>>>> +  rtems_printk_plugin_t  print;
> >>>>> +}rtems_cpu_usage_plugin_t;
> >>>>> +#define RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS (20)
> >>>>> + * rtems_cpuusage_top_thread
> >>>>> + *  DESCRIPTION:
> >>>>> + * This function displays the load of the tasks on an ANSI terminal.
> >>>> Get rid of "DESCRIPTION", prefer to use minimalist comment style on
> >>>> static functions.
> >>>>> +static void
> >>>>> +rtems_cpuusage_top_thread (rtems_task_argument arg) {
> >>>>> +  uint32_t                  api_index;
> >>>>> +  Thread_Control*           the_thread;
> >>>>> +  int                       i;
> >>>>> +  int                       j;
> >>>>> +  int                       k;
> >>>>> +  Objects_Information*      information;
> >>>>> +    char                    name[13];
> >>>>> +  int                       task_count = 0;
> >>>>> +  uint32_t                  seconds, nanoseconds;
> >>>>> +  rtems_cpu_usage_plugin_t* plugin =
> (rtems_cpu_usage_plugin_t*)arg;
> >>>>> +  Thread_Control*
> load_tasks[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
> >>>>> +  unsigned long long
> load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
> >>>>> +  while (true)
> >>>> Opening brace should go on whille() line.
> >>>>> +    #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
> >>>>> +      Timestamp_Control  uptime, total, ran, uptime_at_last_reset;
> >>>>> +    #else
> >>>>> +      uint32_t           total_units = 0;
> >>>>> +    #endif
> >>>>> +    rtems_cpuusage_top_thread_active = 1;
> >>>>> +    memset (load_tasks, 0, sizeof (load_tasks));
> >>>>> +    memset (load, 0, sizeof (load));
> >>>>> +     * Iterate over the tasks and sort the highest load tasks
> >>>>> +     * into our local arrays. We only handle a limited number of
> >>>>> +     * tasks.
> >>>>> +    for ( api_index = 1 ; api_index <= OBJECTS_APIS_LAST ;
> api_index++ ) {
> >>>>> +      #if !defined(RTEMS_POSIX_API) || defined(RTEMS_DEBUG)
> >>>>> +        if ( !_Objects_Information_table[ api_index ] )
> >>>>> +          continue;
> >>>>> +      #endif
> >>>>> +      information = _Objects_Information_table[ api_index ][ 1 ];
> >>>>> +      if ( information ) {
> >>>>> +        for ( k=1 ; k <= information->maximum ; k++ ) {
> >>>> I prefer that nested iterators should be used in increasing order, e.g. i
> first.
> >>>>> +          the_thread = (Thread_Control *)information->local_table[ k ];
> >>>>> +          if ( the_thread ) {
> >>>> No blank space after the opening brace.
> >>>>> +            Thread_CPU_usage_t l = the_thread->cpu_time_used;
> >>>> Avoid using l and I as variable names.They're hard to differentiate
> >>>> from each other and from the digit 1. This should be a more useful
> >>>> variable name anyway. A one-letter variable should really only be
> >>>> used for iterators. We ought to have a rule about this if we don't.
> >>>>> +             *  When not using nanosecond CPU usage resolution, we have
> to count
> >>>>> +             *  the number of "ticks" we gave credit for to give the user a
> rough
> >>>>> +             *  guideline as to what each number means proportionally.
> >>>>> +            #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
> >>>>> +              total_units += l;
> >>>>> +            #endif
> >>>>> +            /* Count the number of tasks and sort this load value */
> >>>>> +            task_count++;
> >>>>> +            for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++)
> >>>>> +              if (load_tasks[i]) {
> >>>>> +                if ((l == 0) || (l < load[i]))
> >>>>> +                  continue;
> >>>>> +                for (j = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); j
> >= i; j--){
> >>>>> +                  load_tasks[j + 1] = load_tasks[j];
> >>>>> +                  load[j + 1]  = load[j];
> >>>>> +              load_tasks[i] = the_thread;
> >>>>> +              load[i]  = l;
> >>>>> +              break;
> >>>>> +      _Timestamp_Set_to_zero( &total );
> >>>>> +      uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
> >>>>> +    #endif
> >>>>> +    _TOD_Get_uptime( &uptime );
> >>>>> +    seconds = _Timestamp_Get_seconds( &uptime );
> >>>>> +    nanoseconds = _Timestamp_Get_nanoseconds( &uptime ) /
> >>>>> +                  TOD_NANOSECONDS_PER_MICROSECOND;
> >>>>> +    (*plugin->print)(plugin->context, "\x1b[H\x1b[J Press ENTER to
> exit.\n\n");
> >>>>> +    (*plugin->print)(plugin->context, "uptime: ");
> >>>>> +      "%7" PRIu32 ".%06" PRIu32 "\n",  seconds, nanoseconds
> >>>>> +    (*plugin->print)(
> >>>>> +       plugin->context,
> -\n"
> >>>>> +       "                              CPU USAGE BY THREAD\n"
> ---\n"
> >>>>> +        " ID         | NAME                | RPRI | CPRI   | SECONDS       |
> PERCENT\n"
> >>>>> +       #else
> >>>>> +         " ID        | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
> >>>>> +       #endif
> ---\n"
> >>>> Fix style here.
> >>>>> +      if (!load_tasks[i])
> >>>>> +        break;
> >>>>> +       * If this is the currently executing thread, account for time
> >>>>> +       * since the last context switch.
> >>>>> +      the_thread = load_tasks[i];
> >>>>> +      rtems_object_get_name( the_thread->Object.id, sizeof(name),
> name );
> >>>>> +      (*plugin->print)(
> >>>>> +        plugin->context,
> >>>>> +        " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   |",
> >>>>> +        the_thread->Object.id,
> >>>>> +        name,
> >>>>> +        the_thread->real_priority,
> >>>>> +        the_thread->current_priority
> >>>> I don't know how to feel about artifically adding scoped blocks.
> >>>> Anyone else weigh in?
> >>>>> +        Timestamp_Control last;
> >>>>> +        uint32_t          ival, fval;
> >>>>> +        ran = load[i];
> >>>>> +        if ( _Thread_Get_time_of_last_context_switch( the_thread,
> &last ) ) {
> >>>>> +          Timestamp_Control used;
> >>>>> +          _Timestamp_Subtract( &last, &uptime, &used );
> >>>>> +          _Timestamp_Add_to( &ran, &used );
> >>>>> +        } else {
> >>>>> +        _Timestamp_Subtract( &uptime_at_last_reset, &uptime, &total
> >>>>> +        _Timestamp_Divide( &ran, &total, &ival, &fval );
> >>>>> +         * Print the information
> >>>>> +        seconds = _Timestamp_Get_seconds( &ran );
> >>>>> +        nanoseconds = _Timestamp_Get_nanoseconds( &ran ) /
> >>>>> +       (*plugin->print)( plugin->context,
> >>>>> +          "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
> >>>>> +          seconds, nanoseconds,
> >>>>> +            ival, fval
> >>>>> +      #else
> >>>>> +        if (total_units) {
> >>>>> +          uint64_t ival_64;
> >>>>> +          ival_64 = load[i];
> >>>>> +          ival_64 *= 100000;
> >>>>> +          ival = ival_64 / total_units;
> >>>>> +        } else {
> >>>>> +          ival = 0;
> >>>>> +        fval = ival % 1000;
> >>>>> +        ival /= 1000;
> >>>>> +          "%14" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
> >>>>> +          load[i],
> >>>>> +          ival,
> >>>>> +          fval
> >>>>> +      #endif
> >>>>> +    if (task_count < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS)
> >>>>> +      j = RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - task_count;
> >>>>> +      while (j > 0)
> >>>>> +       (*plugin->print)( plugin->context, "\x1b[K\n");
> >>>>> +        j--;
> >>>>> +    rtems_cpuusage_top_thread_active = 0;
> >>>>> +    rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS
> >>>>> +(5000000));
> >>>>> +void rtems_cpu_usage_top_with_plugin(
> >>>>> +  void                  *context,
> >>>>> +  rtems_status_code   sc;
> >>>>> +  rtems_task_priority priority;
> >>>>> +  rtems_name          name;
> >>>>> +  rtems_id            id;
> >>>>> +  rtems_cpu_usage_plugin_t  plugin;
> >>>>> +  if ( !print )
> >>>>> +    return;
> >>>>> +  plugin.context = context;
> >>>>> +  plugin.print   = print;
> >>>>> +  sc = rtems_task_set_priority (RTEMS_SELF,
> >>>>> + RTEMS_CURRENT_PRIORITY, &priority);
> >>>>> +  if (sc != RTEMS_SUCCESSFUL)
> >>>>> +    (*print)(
> >>>>> +       context,
> >>>>> +       "error: cannot obtain the current priority: %s\n",
> >>>>> +       rtems_status_text (sc)
> >>>>> +    return;
> >>>>> +  name = rtems_build_name('C', 'P', 'l', 't');
> >>>>> +  sc = rtems_task_create (name, priority, 4 * 1024,
> >>>>> +                          RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
> >>>>> +                          RTEMS_PREEMPT | RTEMS_TIMESLICE |
> RTEMS_NO_ASR,
> >>>>> +                          &id);
> >>>>> +    (*print)(
> >>>>> +       context,
> >>>>> +       "error: cannot create helper thread: %s\n",
> >>>>> +    return;
> >>>>> +  sc = rtems_task_start (
> >>>>> +    id, rtems_cpuusage_top_thread, (rtems_task_argument)&plugin
> >>>>> + );  if (sc != RTEMS_SUCCESSFUL)  {
> >>>>> +    (*print)(
> >>>>> +       context,
> >>>>> +       "error: cannot start helper thread: %s\n",
> >>>>> +    rtems_task_delete (id);
> >>>>> +    return;
> >>>>> +  for (;;)
> >>>>> +    int c = getchar ();
> >>>>> +    if ((c == '\r') || (c == '\n'))
> >>>>> +      int loops = 20;
> >>>>> +      while (loops && rtems_cpuusage_top_thread_active)
> >>>>> + (100000));
> >>>>> +      (*print)(context, "load monitoring stopped.\n");
> >>>>> +      return;
> >>>>> +void rtems_cpu_usage_top( void )
> >>>>> +  rtems_cpu_usage_top_with_plugin( NULL, printk_plugin ); }
> >>>>> diff --git a/cpukit/libmisc/cpuuse/cpuuse.h
> >>>>> b/cpukit/libmisc/cpuuse/cpuuse.h index 1aee275..662d905 100644
> >>>>> --- a/cpukit/libmisc/cpuuse/cpuuse.h
> >>>>> +++ b/cpukit/libmisc/cpuuse/cpuuse.h
> >>>>> @@ -63,6 +63,25 @@ void rtems_cpu_usage_report_with_plugin(
> >>>>>  void rtems_cpu_usage_report( void );
> >>>>> + *   @brief CPU usage Top plugin
> >>>>> + *   Report CPU Usage in top format to
> >>>>> + *   to a print plugin.
> >>>>> +  void                  *context,
> >>>>> + *  @brief CPU usage top.
> >>>>> + *  CPU Usage top
> >>>>> +void rtems_cpu_usage_top( void );
> >>>>>   *  @brief Reset CPU usage.
> >>>>>   *  CPU Usage Reporter
> >>>>> _______________________________________________
> >>>>> vc mailing list
> >>>>> vc at rtems.org
> >>>>> http://lists.rtems.org/mailman/listinfo/vc
> >>>> devel mailing list
> >>>> devel at rtems.org
> >>>> http://lists.rtems.org/mailman/listinfo/devel
> >>> Joel Sherrill, Ph.D.             Director of Research & Development
> >>> joel.sherrill at OARcorp.com        On-Line Applications Research
> >>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >>> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
