[rtems commit] libmisc: Add top to cpuusage.
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Thu Oct 30 15:12:27 UTC 2014
On 10/30/2014 10:11 AM, Jennifer Averett wrote:
> My name and email are correct in git config.
And if it was converting git accounts into email addresses,
I would just be joel@ which would likely bounce as well.
-joel
>> -----Original Message-----
>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Gedare Bloom
>> Sent: Thursday, October 30, 2014 10:08 AM
>> To: Joel Sherrill
>> Cc: Jennifer Averett; rtems-devel at rtems.org
>> Subject: Re: [rtems commit] libmisc: Add top to cpuusage.
>> The problem may be a setup issue on git.rtems.org, where it converts from
>> user login to email, I think it might be doing something dumb like just taking
>> login-name @rtems.org
>> On Thu, Oct 30, 2014 at 11:03 AM, Joel Sherrill <joel.sherrill at oarcorp.com>
>> wrote:
>>> On 10/30/2014 9:55 AM, Gedare Bloom wrote:
>>>> The email address came from VC, so it is a problem in the commit setup I
>> guess.
>>> OK. I will help her double check.  Working on multiple machines, I
>>> periodically find one that is wrong for myself. :(
>>> --joel
>>>> On Thu, Oct 30, 2014 at 10:55 AM, Joel Sherrill
>>>> <joel.sherrill at oarcorp.com> wrote:
>>>>> FWIW she is jennifer.averett at rtems.org not jennifer at .
>>>>> --joel
>>>>> On 10/30/2014 9:53 AM, Gedare Bloom wrote:
>>>>>> I missed reviewing this patch earlier, but there are some style
>>>>>> problems with it, please fix them on the head.
>>>>>> On Tue, Oct 28, 2014 at 11:17 AM, Jennifer Averett
>> <jennifer at rtems.org> wrote:
>>>>>>> Module:    rtems
>>>>>>> Branch:    master
>>>>>>> Commit:    6031da438d219c6ec5d9d48f1df2aef91710cce3
>>>>>>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=6031da438d219c6ec5d9d48f1df2
>>>>>>> aef91710cce3
>>>>>>> Author:    Jennifer Averett <jennifer.averett at oarcorp.com>
>>>>>>> Date:      Mon Sep 29 10:20:27 2014 -0500
>>>>>>>  cpukit/libmisc/Makefile.am          |    2 +-
>>>>>>>  cpukit/libmisc/cpuuse/cpuusagetop.c |  337
>>>>>>>  cpukit/libmisc/cpuuse/cpuuse.h      |   19 ++
>>>>>>>  3 files changed, 357 insertions(+), 1 deletions(-)
>>>>>>> diff --git a/cpukit/libmisc/Makefile.am
>>>>>>> b/cpukit/libmisc/Makefile.am index 2f41ffa..d26c484 100644
>>>>>>> --- a/cpukit/libmisc/Makefile.am
>>>>>>> +++ b/cpukit/libmisc/Makefile.am
>>>>>>> @@ -27,7 +27,7 @@ EXTRA_DIST += cpuuse/README
>>>>>>>  noinst_LIBRARIES += libcpuuse.a
>>>>>>>  libcpuuse_a_SOURCES = cpuuse/cpuusagereport.c
>> cpuuse/cpuusagereset.c \
>>>>>>> -    cpuuse/cpuuse.h cpuuse/cpuusagedata.c
>>>>>>> +     cpuuse/cpuuse.h cpuuse/cpuusagedata.c cpuuse/cpuusagetop.c
>>>>>>>  ## devnull
>>>>>>>  noinst_LIBRARIES += libdevnull.a
>>>>>>> diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c
>>>>>>> b/cpukit/libmisc/cpuuse/cpuusagetop.c
>>>>>>> new file mode 100644
>>>>>>> index 0000000..7e7348a
>>>>>>> --- /dev/null
>>>>>>> +++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
>>>>>>> @@ -0,0 +1,337 @@
>>>>>>> + * @file
>>>>>>> + * @brief CPU Usage Top
>>>>>>> + * @ingroup libmisc_cpuuse CPU Usage  */
>>>>>>> + *  COPYRIGHT (c) 2014.
>>>>>>> + *  On-Line Applications Research Corporation (OAR).
>>>>>>> + *  The license and distribution terms for this file may be
>>>>>>> + *  found in the file LICENSE in this distribution or at
>>>>>>> + *  http://www.rtems.org/license/LICENSE.
>>>>>>> +#ifdef HAVE_CONFIG_H
>>>>>>> +#include "config.h"
>>>>>>> +#endif
>>>>>>> +#include <string.h>
>>>>>>> +#include <stdlib.h>
>>>>>>> +#include <stdio.h>
>>>>>>> +#include <ctype.h>
>>>>>>> +#include <inttypes.h>
>>>>>>> +#include <rtems/cpuuse.h>
>>>>>>> +#include <rtems/score/objectimpl.h> #include
>>>>>>> +<rtems/score/threadimpl.h> #include <rtems/score/todimpl.h>
>>>>>>> +#include <rtems/score/watchdogimpl.h>
>>>>>>> + * Common variable to sync the load monitor task.
>>>>>>> +static volatile int rtems_cpuusage_top_thread_active;
>>>>>> remove multiple blank lines
>>>>>>> +typedef struct {
>>>>>>> +  void                  *context;
>>>>>>> +  rtems_printk_plugin_t  print;
>>>>>>> +}rtems_cpu_usage_plugin_t;
>>>>>>> +#define RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS (20)
>>>>>>> + * rtems_cpuusage_top_thread
>>>>>>> + *  DESCRIPTION:
>>>>>>> + * This function displays the load of the tasks on an ANSI terminal.
>>>>>> Get rid of "DESCRIPTION", prefer to use minimalist comment style on
>>>>>> static functions.
>>>>>>> +static void
>>>>>>> +rtems_cpuusage_top_thread (rtems_task_argument arg) {
>>>>>>> +  uint32_t                  api_index;
>>>>>>> +  Thread_Control*           the_thread;
>>>>>>> +  int                       i;
>>>>>>> +  int                       j;
>>>>>>> +  int                       k;
>>>>>>> +  Objects_Information*      information;
>>>>>>> +    char                    name[13];
>>>>>>> +  int                       task_count = 0;
>>>>>>> +  uint32_t                  seconds, nanoseconds;
>>>>>>> +  rtems_cpu_usage_plugin_t* plugin =
>> (rtems_cpu_usage_plugin_t*)arg;
>>>>>>> +  Thread_Control*
>> load_tasks[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
>>>>>>> +  unsigned long long
>> load[RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS + 1];
>>>>>>> +  while (true)
>>>>>> Opening brace should go on whille() line.
>>>>>>> +    #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
>>>>>>> +      Timestamp_Control  uptime, total, ran, uptime_at_last_reset;
>>>>>>> +    #else
>>>>>>> +      uint32_t           total_units = 0;
>>>>>>> +    #endif
>>>>>>> +    rtems_cpuusage_top_thread_active = 1;
>>>>>>> +    memset (load_tasks, 0, sizeof (load_tasks));
>>>>>>> +    memset (load, 0, sizeof (load));
>>>>>>> +     * Iterate over the tasks and sort the highest load tasks
>>>>>>> +     * into our local arrays. We only handle a limited number of
>>>>>>> +     * tasks.
>>>>>>> +    for ( api_index = 1 ; api_index <= OBJECTS_APIS_LAST ;
>> api_index++ ) {
>>>>>>> +      #if !defined(RTEMS_POSIX_API) || defined(RTEMS_DEBUG)
>>>>>>> +        if ( !_Objects_Information_table[ api_index ] )
>>>>>>> +          continue;
>>>>>>> +      #endif
>>>>>>> +      information = _Objects_Information_table[ api_index ][ 1 ];
>>>>>>> +      if ( information ) {
>>>>>>> +        for ( k=1 ; k <= information->maximum ; k++ ) {
>>>>>> I prefer that nested iterators should be used in increasing order, e.g. i
>> first.
>>>>>>> +          the_thread = (Thread_Control *)information->local_table[ k ];
>>>>>>> +          if ( the_thread ) {
>>>>>> No blank space after the opening brace.
>>>>>>> +            Thread_CPU_usage_t l = the_thread->cpu_time_used;
>>>>>> Avoid using l and I as variable names.They're hard to differentiate
>>>>>> from each other and from the digit 1. This should be a more useful
>>>>>> variable name anyway. A one-letter variable should really only be
>>>>>> used for iterators. We ought to have a rule about this if we don't.
>>>>>>> +             *  When not using nanosecond CPU usage resolution, we have
>> to count
>>>>>>> +             *  the number of "ticks" we gave credit for to give the user a
>> rough
>>>>>>> +             *  guideline as to what each number means proportionally.
>>>>>>> +            #ifdef __RTEMS_USE_TICKS_FOR_STATISTICS__
>>>>>>> +              total_units += l;
>>>>>>> +            #endif
>>>>>>> +            /* Count the number of tasks and sort this load value */
>>>>>>> +            task_count++;
>>>>>>> +            for (i = 0; i < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS; i++)
>>>>>>> +              if (load_tasks[i]) {
>>>>>>> +                if ((l == 0) || (l < load[i]))
>>>>>>> +                  continue;
>>>>>>> +                for (j = (RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - 1); j
>>> = i; j--){
>>>>>>> +                  load_tasks[j + 1] = load_tasks[j];
>>>>>>> +                  load[j + 1]  = load[j];
>>>>>>> +              load_tasks[i] = the_thread;
>>>>>>> +              load[i]  = l;
>>>>>>> +              break;
>>>>>>> +      _Timestamp_Set_to_zero( &total );
>>>>>>> +      uptime_at_last_reset = CPU_usage_Uptime_at_last_reset;
>>>>>>> +    #endif
>>>>>>> +    _TOD_Get_uptime( &uptime );
>>>>>>> +    seconds = _Timestamp_Get_seconds( &uptime );
>>>>>>> +    nanoseconds = _Timestamp_Get_nanoseconds( &uptime ) /
>>>>>>> +                  TOD_NANOSECONDS_PER_MICROSECOND;
>>>>>>> +    (*plugin->print)(plugin->context, "\x1b[H\x1b[J Press ENTER to
>> exit.\n\n");
>>>>>>> +    (*plugin->print)(plugin->context, "uptime: ");
>>>>>>> +      "%7" PRIu32 ".%06" PRIu32 "\n",  seconds, nanoseconds
>>>>>>> +    (*plugin->print)(
>>>>>>> +       plugin->context,
>> -\n"
>>>>>>> +       "                              CPU USAGE BY THREAD\n"
>> ---\n"
>>>>>>> +        " ID         | NAME                | RPRI | CPRI   | SECONDS       |
>> PERCENT\n"
>>>>>>> +       #else
>>>>>>> +         " ID        | NAME                | RPRI | CPRI   | TICKS         | PERCENT\n"
>>>>>>> +       #endif
>> ---\n"
>>>>>> Fix style here.
>>>>>>> +      if (!load_tasks[i])
>>>>>>> +        break;
>>>>>>> +       * If this is the currently executing thread, account for time
>>>>>>> +       * since the last context switch.
>>>>>>> +      the_thread = load_tasks[i];
>>>>>>> +      rtems_object_get_name( the_thread->Object.id, sizeof(name),
>> name );
>>>>>>> +      (*plugin->print)(
>>>>>>> +        plugin->context,
>>>>>>> +        " 0x%08" PRIx32 " | %-19s |  %3" PRId32 " |  %3" PRId32 "   |",
>>>>>>> +        the_thread->Object.id,
>>>>>>> +        name,
>>>>>>> +        the_thread->real_priority,
>>>>>>> +        the_thread->current_priority
>>>>>> I don't know how to feel about artifically adding scoped blocks.
>>>>>> Anyone else weigh in?
>>>>>>> +        Timestamp_Control last;
>>>>>>> +        uint32_t          ival, fval;
>>>>>>> +        ran = load[i];
>>>>>>> +        if ( _Thread_Get_time_of_last_context_switch( the_thread,
>> &last ) ) {
>>>>>>> +          Timestamp_Control used;
>>>>>>> +          _Timestamp_Subtract( &last, &uptime, &used );
>>>>>>> +          _Timestamp_Add_to( &ran, &used );
>>>>>>> +        } else {
>>>>>>> +        _Timestamp_Subtract( &uptime_at_last_reset, &uptime, &total
>>>>>>> +        _Timestamp_Divide( &ran, &total, &ival, &fval );
>>>>>>> +         * Print the information
>>>>>>> +        seconds = _Timestamp_Get_seconds( &ran );
>>>>>>> +        nanoseconds = _Timestamp_Get_nanoseconds( &ran ) /
>>>>>>> +       (*plugin->print)( plugin->context,
>>>>>>> +          "%7" PRIu32 ".%06" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>>>>>>> +          seconds, nanoseconds,
>>>>>>> +            ival, fval
>>>>>>> +      #else
>>>>>>> +        if (total_units) {
>>>>>>> +          uint64_t ival_64;
>>>>>>> +          ival_64 = load[i];
>>>>>>> +          ival_64 *= 100000;
>>>>>>> +          ival = ival_64 / total_units;
>>>>>>> +        } else {
>>>>>>> +          ival = 0;
>>>>>>> +        fval = ival % 1000;
>>>>>>> +        ival /= 1000;
>>>>>>> +          "%14" PRIu32 " |%4" PRIu32 ".%03" PRIu32 "\n",
>>>>>>> +          load[i],
>>>>>>> +          ival,
>>>>>>> +          fval
>>>>>>> +      #endif
>>>>>>> +    if (task_count < RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS)
>>>>>>> +      j = RTEMS_CPUUSAGE_TOP_MAX_LOAD_TASKS - task_count;
>>>>>>> +      while (j > 0)
>>>>>>> +       (*plugin->print)( plugin->context, "\x1b[K\n");
>>>>>>> +        j--;
>>>>>>> +    rtems_cpuusage_top_thread_active = 0;
>>>>>>> +    rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS
>>>>>>> +(5000000));
>>>>>>> +void rtems_cpu_usage_top_with_plugin(
>>>>>>> +  void                  *context,
>>>>>>> +  rtems_status_code   sc;
>>>>>>> +  rtems_task_priority priority;
>>>>>>> +  rtems_name          name;
>>>>>>> +  rtems_id            id;
>>>>>>> +  rtems_cpu_usage_plugin_t  plugin;
>>>>>>> +  if ( !print )
>>>>>>> +    return;
>>>>>>> +  plugin.context = context;
>>>>>>> +  plugin.print   = print;
>>>>>>> +  sc = rtems_task_set_priority (RTEMS_SELF,
>>>>>>> + RTEMS_CURRENT_PRIORITY, &priority);
>>>>>>> +  if (sc != RTEMS_SUCCESSFUL)
>>>>>>> +    (*print)(
>>>>>>> +       context,
>>>>>>> +       "error: cannot obtain the current priority: %s\n",
>>>>>>> +       rtems_status_text (sc)
>>>>>>> +    return;
>>>>>>> +  name = rtems_build_name('C', 'P', 'l', 't');
>>>>>>> +  sc = rtems_task_create (name, priority, 4 * 1024,
>>>>>>> +                          RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
>>>>>>> +                          RTEMS_PREEMPT | RTEMS_TIMESLICE |
>> RTEMS_NO_ASR,
>>>>>>> +                          &id);
>>>>>>> +    (*print)(
>>>>>>> +       context,
>>>>>>> +       "error: cannot create helper thread: %s\n",
>>>>>>> +    return;
>>>>>>> +  sc = rtems_task_start (
>>>>>>> +    id, rtems_cpuusage_top_thread, (rtems_task_argument)&plugin
>>>>>>> + );  if (sc != RTEMS_SUCCESSFUL)  {
>>>>>>> +    (*print)(
>>>>>>> +       context,
>>>>>>> +       "error: cannot start helper thread: %s\n",
>>>>>>> +    rtems_task_delete (id);
>>>>>>> +    return;
>>>>>>> +  for (;;)
>>>>>>> +    int c = getchar ();
>>>>>>> +    if ((c == '\r') || (c == '\n'))
>>>>>>> +      int loops = 20;
>>>>>>> +      while (loops && rtems_cpuusage_top_thread_active)
>>>>>>> + (100000));
>>>>>>> +      (*print)(context, "load monitoring stopped.\n");
>>>>>>> +      return;
>>>>>>> +void rtems_cpu_usage_top( void )
>>>>>>> +  rtems_cpu_usage_top_with_plugin( NULL, printk_plugin ); }
>>>>>>> diff --git a/cpukit/libmisc/cpuuse/cpuuse.h
>>>>>>> b/cpukit/libmisc/cpuuse/cpuuse.h index 1aee275..662d905 100644
>>>>>>> --- a/cpukit/libmisc/cpuuse/cpuuse.h
>>>>>>> +++ b/cpukit/libmisc/cpuuse/cpuuse.h
>>>>>>> @@ -63,6 +63,25 @@ void rtems_cpu_usage_report_with_plugin(
>>>>>>>  void rtems_cpu_usage_report( void );
>>>>>>> + *   @brief CPU usage Top plugin
>>>>>>> + *   Report CPU Usage in top format to
>>>>>>> + *   to a print plugin.
>>>>>>> +  void                  *context,
>>>>>>> + *  @brief CPU usage top.
>>>>>>> + *  CPU Usage top
>>>>>>> +void rtems_cpu_usage_top( void );
>>>>>>>   *  @brief Reset CPU usage.
>>>>>>>   *  CPU Usage Reporter
>>>>>>> _______________________________________________
>>>>>>> vc mailing list
>>>>>>> vc at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/vc
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
