rtems-tester coverage patches break or1k/sis runs
Krzysztof Mięsowicz krzysztof.miesowicz at gmail.com
Sat Oct 4 19:08:50 UTC 2014
Hi,
First, sorry for so late response. I've finally make a fix - it should help
with this error. Macro _coverage is defined if --coverage option has been
passed to rtems-test. I've encountered and fixed this problem in qemu.cfg
before and forgot about gdb.cfg...
Please, let me know if it solve the problem.
2014-10-02 8:37 GMT+02:00 Krzysztof Mięsowicz <krzysztof.miesowicz at gmail.com
> Hi,
> I will check this in the evening and prepare a fix - it should not be
> difficult.
> 2014-10-02 1:57 GMT+02:00 Chris Johns <chrisj at rtems.org>:
>> On 2/10/2014 3:44 am, Joel Sherrill wrote:
>>> Krzysztof/Hesham,
>>> And devel@ since this needs to be public now.
>>> I am trying to test or1ksim and sis using rtems-tester.
>>> We need to get Krzysztof's patches merged and I am
>>> just trying to run down all the issues I can.
>>> You both have made some changes to the repository
>>> and I am having issues. Krzysztof's are on a branch
>>> for me and I have attached them.  Except for the note
>>> before the remains of the old email, all issues are
>>> with Krzysztof's changes.
>>> Hesham's are all committed.
>>> $ ~/rtems-4.11-work/rtems-tools/tester/rtems-test --log=or1ksim.log
>>> --rtems-bsp=sis --rtems-tools=/users/joel/rtems-4.11-work/tools
>>> sparc-rtems4.11/c/sis/testsuites/samples/hello/
>>> RTEMS Testing - Tester, v0.2.0
>>> error: gdb.cfg:59: macro '%{_coverage}' not found
>>> warning: switched to dry run due to errors
>>> error: gdb.cfg:59: invalid if bool value:  %if %{_coverage}
>>> [1/1] p:0 f:0 t:0 i:0 | sparc/sis: hello.exe
>> There is something missing in the default configuration. The pattern
>> often used in this case is to define a default if the macro is not defined
>> before any logic that uses it.
>>  When I use Krzysztof's branch with the or1ksim as shown below,
>>> it adds a 1 to the end of the qemu-system-or32 invocation.
>>> On 10/1/2014 11:19 AM, Hesham Moustafa wrote:
>>>> I cloned a vanilla RTEMS tester, and it works fine with me with the
>>>> following command
>>>> "~/development/rtems/test/rtems-tester/tester/rtems-test
>>>> --log=or1ksim.log --rtems-bsp=or1ksim
>>>> /home/hesham/build/or1k-rtems4.11/c/or1ksim/testsuites/"
>>>>  But it seemed to run a long time and then I killed it when
>>> I used your command.
>>> And when I try to run it on sis, you do need the --rtems-tools
>>> argument to find the simulator. I don't know what the difference
>>> for this is when doing the or1ksim. I think it should be required
>>> for consistency.
>> Yes, dependence on environment variables should not occur.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141004/fa6d17e3/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141004/fa6d17e3/attachment-0002.bin>
