[PATCH 1/2] libcpu/or1k: Fix warnings.
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Oct 13 17:03:59 UTC 2014
On 10/13/2014 11:45 AM, Hesham Moustafa wrote:
> Missed patch?
Yep. Committed now. This should address a bunch of the or1ksim
build warnings. I fixed another in console/uart.c for an unused
variable.
Starting another build of all BSPs to see if I fixed all
"-Wunused-variables"
cases.
Thanks.
> On Fri, Oct 10, 2014 at 7:23 PM, Hesham ALMatary
> <heshamelmatary at gmail.com <mailto:heshamelmatary at gmail.com>> wrote:
> c/src/lib/libcpu/or1k/shared/cache/cache.c | 16 ++++++++--------
> c/src/lib/libcpu/or1k/shared/cache/cache_.h | 1 +
> 2 files changed, 9 insertions(+), 8 deletions(-)
> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache.c
> b/c/src/lib/libcpu/or1k/shared/cache/cache.c
> index 039be36..afc8859 100644
> --- a/c/src/lib/libcpu/or1k/shared/cache/cache.c
> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache.c
> @@ -71,7 +71,7 @@ static inline void
> _CPU_OR1K_Cache_data_block_prefetch(const void *d_addr)
> _ISR_Disable (level);
> - _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, d_addr);
> + _OR1K_mtspr(CPU_OR1K_SPR_DCBPR, (uintptr_t) d_addr);
> _ISR_Enable(level);
> @@ -81,7 +81,7 @@ static inline void
> _CPU_OR1K_Cache_data_block_flush(const void *d_addr)
> ISR_Level level;
> - _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, d_addr);
> + _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, (uintptr_t) d_addr);
> _ISR_Enable(level);
> @@ -91,7 +91,7 @@ static inline void
> _CPU_OR1K_Cache_data_block_invalidate(const void *d_addr)
> ISR_Level level;
> - _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, d_addr);
> + _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, (uintptr_t) d_addr);
> _ISR_Enable(level);
> @@ -101,7 +101,7 @@ static inline void
> _CPU_OR1K_Cache_data_block_writeback(const void *d_addr)
> ISR_Level level;
> - _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, d_addr);
> + _OR1K_mtspr(CPU_OR1K_SPR_DCBWR, (uintptr_t) d_addr);
> _ISR_Enable(level);
> @@ -111,7 +111,7 @@ static inline void
> _CPU_OR1K_Cache_data_block_lock(const void *d_addr)
> ISR_Level level;
> - _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, d_addr);
> + _OR1K_mtspr(CPU_OR1K_SPR_DCBLR, (uintptr_t) d_addr);
> _ISR_Enable(level);
> @@ -122,7 +122,7 @@ static inline void
> _CPU_OR1K_Cache_instruction_block_prefetch
> ISR_Level level;
> - _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, d_addr);
> + _OR1K_mtspr(CPU_OR1K_SPR_ICBPR, (uintptr_t) d_addr);
> _ISR_Enable(level);
> @@ -133,7 +133,7 @@ static inline void
> _CPU_OR1K_Cache_instruction_block_invalidate
> ISR_Level level;
> - _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, d_addr);
> + _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, (uintptr_t) d_addr);
> _ISR_Enable(level);
> @@ -144,7 +144,7 @@ static inline void
> _CPU_OR1K_Cache_instruction_block_lock
> ISR_Level level;
> - _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, d_addr);
> + _OR1K_mtspr(CPU_OR1K_SPR_ICBLR, (uintptr_t) d_addr);
> _ISR_Enable(level);
> diff --git a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
> b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
> index 5f08410..0ea939f 100644
> --- a/c/src/lib/libcpu/or1k/shared/cache/cache_.h
> +++ b/c/src/lib/libcpu/or1k/shared/cache/cache_.h
> @@ -6,6 +6,7 @@
> #define __OR1K_CACHE_H
> #include <bsp/cache_.h>
> +#include <libcpu/cache.h>
> #endif
> /* end of include file */
> 1.9.3
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141013/8419b2c5/attachment-0002.html>
