threadglobalconstruction.c compile error when POSIX is disabled
Wed Oct 29 18:37:38 UTC 2014
On 10/25/2014 8:57 AM, Hesham Moustafa wrote:
> Hi,
> The exact error occurs with or1k port, even with --enable-posix and
> after Sebastian's fix commit. Any idea how to fix this?
Can you give me your configure command?
I tried with POSIX enabled and disabled and built all tests in both
cases. I don't see it on sparc/sis and this should be a generic issue.
--joel
> Regards,
> Hesham
> On Thu, Oct 16, 2014 at 2:04 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On October 16, 2014 1:05:54 AM CDT, Sebastian Huber
>     <sebastian.huber at embedded-brains.de
>     <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     >Hello Joel,
>     >sorry, I didn't test this with POSIX disabled.  I fixed it like this:
>     >http://git.rtems.org/rtems/commit/?id=cf51c3bfa0bbc50af6e162f22da385c7da113143
>     >Why is there a
>     >  *  This is kind of kludgy but it allows targets to totally
>     ignore the
>     >  *  optional APIs like POSIX safely.
>     >#ifdef RTEMS_POSIX_API
>     >#include <rtems/posix/config.h>
>     >#else
>     >typedef void *posix_api_configuration_table;
>     >#endif
>     >in <rtems/config.h>?
>     I honestly have no idea. Must have been referenced at point.
>     Thanks for fixing this. My tree has enough going on.
>     --joel
>     >On 15/10/14 18:13, Joel Sherrill wrote:
>     >> Hi
>     >> Tripped across this when POSIX is disabled
>     >> sparc-rtems4.11-gcc --pipe -DHAVE_CONFIG_H   -I..
>     >> -I../../cpukit/../../../sis/lib/include   -mcpu=cypress -O2 -g
>     >> -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes
>     >> -Wimplicit-function-declaration -Wstrict-prototypes
>     -Wnested-externs
>     >-MT
>     >> src/libscore_a-threadglobalconstruction.o -MD -MP -MF
>     >> src/.deps/libscore_a-threadglobalconstruction.Tpo -c -o
>     >> src/libscore_a-threadglobalconstruction.o `test -f
>     >> 'src/threadglobalconstruction.c' || echo
>     >'../../../../../../rtems/c/src/../../cpukit/score/'`src/threadglobalconstruction.c
>     >> In file included from
>     >../../../../../../rtems/c/src/../../cpukit/score/src/threadglobalconstruction.c:25:0:
>     >> ../../cpukit/../../../sis/lib/include/rtems/posix/config.h:140:3:
>     >error:
>     >> conflicting types for 'posix_api_configuration_table'
>     >>   } posix_api_configuration_table;
>     ../../cpukit/../../../sis/lib/include/rtems/score/threadimpl.h:33:0,
>     >>                   from
>     >../../../../../../rtems/c/src/../../cpukit/score/src/threadglobalconstruction.c:22:
>     >> ../../cpukit/../../../sis/lib/include/rtems/config.h:54:15: note:
>     >> previous declaration of 'posix_api_configuration_table' was here
>     >> gmake[6]: *** [src/libscore_a-threadglobalconstruction.o] Error 1
>     >> gmake[6]: Leaving directory
>     `/home/joel/rtems-4.11-work/b-sis/sparc-rtems4.11/c/sis/cpukit/score'
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141029/e1e30297/attachment-0002.html>
