threadglobalconstruction.c compile error when POSIX is disabled
Hesham Moustafa heshamelmatary at gmail.com
Wed Oct 29 20:49:43 UTC 2014
Hi,
Sorry for the false alarm, it seems to be due to some rebasing issues.
I forked a vanilla repo and it builds fine with/without POSIX enabled.
Regards,
Hesham
On Wed, Oct 29, 2014 at 8:37 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 10/25/2014 8:57 AM, Hesham Moustafa wrote:
> Hi,
>  The exact error occurs with or1k port, even with --enable-posix and
> after Sebastian's fix commit. Any idea how to fix this?
>   Can you give me your configure command?
> I tried with POSIX enabled and disabled and built all tests in both
> cases. I don't see it on sparc/sis and this should be a generic issue.
> --joel
>  Regards,
> Hesham
> On Thu, Oct 16, 2014 at 2:04 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
> wrote:
>> On October 16, 2014 1:05:54 AM CDT, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>> >Hello Joel,
>> >sorry, I didn't test this with POSIX disabled.  I fixed it like this:
>> http://git.rtems.org/rtems/commit/?id=cf51c3bfa0bbc50af6e162f22da385c7da113143
>> >Why is there a
>> >  *  This is kind of kludgy but it allows targets to totally ignore the
>> >  *  optional APIs like POSIX safely.
>> >#ifdef RTEMS_POSIX_API
>> >#include <rtems/posix/config.h>
>> >#else
>> >typedef void *posix_api_configuration_table;
>> >#endif
>> >in <rtems/config.h>?
>> I honestly have no idea. Must have been referenced at point.
>> Thanks for fixing this. My tree has enough going on.
>> --joel
>> >On 15/10/14 18:13, Joel Sherrill wrote:
>> >> Hi
>> >> Tripped across this when POSIX is disabled
>> >> sparc-rtems4.11-gcc --pipe -DHAVE_CONFIG_H   -I..
>> >> -I../../cpukit/../../../sis/lib/include   -mcpu=cypress -O2 -g
>> >> -ffunction-sections -fdata-sections -Wall -Wmissing-prototypes
>> >> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
>> >-MT
>> >> src/libscore_a-threadglobalconstruction.o -MD -MP -MF
>> >> src/.deps/libscore_a-threadglobalconstruction.Tpo -c -o
>> >> src/libscore_a-threadglobalconstruction.o `test -f
>> >> 'src/threadglobalconstruction.c' || echo
>> >'../../../../../../rtems/c/src/../../cpukit/score/'`src/threadglobalconstruction.c
>> >> In file included from
>> >../../../../../../rtems/c/src/../../cpukit/score/src/threadglobalconstruction.c:25:0:
>> >> ../../cpukit/../../../sis/lib/include/rtems/posix/config.h:140:3:
>> >error:
>> >> conflicting types for 'posix_api_configuration_table'
>> >>   } posix_api_configuration_table;
>> >> ../../cpukit/../../../sis/lib/include/rtems/score/threadimpl.h:33:0,
>> >>                   from
>> >../../../../../../rtems/c/src/../../cpukit/score/src/threadglobalconstruction.c:22:
>> >> ../../cpukit/../../../sis/lib/include/rtems/config.h:54:15: note:
>> >> previous declaration of 'posix_api_configuration_table' was here
>> >> gmake[6]: *** [src/libscore_a-threadglobalconstruction.o] Error 1
>> >> gmake[6]: Leaving directory
>> >> `/home/joel/rtems-4.11-work/b-sis/sparc-rtems4.11/c/sis/cpukit/score'
>>   _______________________________________________
>> devel mailing list
>> devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141029/ba2b38f6/attachment-0002.html>
