4.11 Branching To Do
    Chris Johns
    chrisj at rtems.org
    Wed Oct 29 23:35:54 UTC 2014
On 30/10/2014 8:49 am, Joel Sherrill wrote:
> Mandatory
> + Tool version selection
>     - Likely gcc 4.9 on almost all targets.
All but m32c and h8300 ?
>     - binutils last release
>     - newlib TBD
What happened about the snapshots ?
>     - GDB could be new release
Patches need updating. They are in the rtems-tools repo. Anyone on the
list able to help ? The change is simple. GDB remove the old P()
wrappers around decls and that broke the patches I created.
> + BeagleBoard BSP added
Yes this is important.
> + Run-Time Loader merged and tested
A patch has been posted but it needs at least a v2 before being merged.
I need to add tests and this needs a tool to generate a suitable kernel
symbol table. I am working on adding this to the rtems-syms tool in the
rtems-tools repo. That part is ok but it has uncovered an issue with the
RTL code living in librtemscpu.a. It seems the symbol table's object
file and the RTL in a library results in some strange dependency dance
where unresolved externals happen. It is proving difficult to track down.
