[PATCH 01/23] raspberrypi: Use shared bspreset.c
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Sep 3 15:25:55 UTC 2014
c/src/lib/libbsp/arm/csb337/startup/bspreset.c | 1 +
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 2 +-
.../lib/libbsp/arm/raspberrypi/startup/bspreset.c | 35 ------------
testsuites/sptests/spintr_err01/init.c | 65 +++++++++++-----------
4 files changed, 34 insertions(+), 69 deletions(-)
delete mode 100644 c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
diff --git a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
index 1167d92..940ff7f 100644
--- a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
+++ b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
@@ -17,6 +17,7 @@ void bsp_reset(void)
rtems_interrupt_level level;
+ (void) level;
rtems_interrupt_disable(level);
/* Enable the watchdog timer, then wait for the world to end. */
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index a8d98b4..cda8510 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -92,7 +92,7 @@ libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
# Startup
-libbsp_a_SOURCES += startup/bspreset.c
+libbsp_a_SOURCES += ../../shared/bspreset_loop.c
libbsp_a_SOURCES += startup/bspstart.c
# IRQ
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
deleted file mode 100644
index 4b3c732..0000000
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c
+++ /dev/null
@@ -1,35 +0,0 @@
- * @file
- * @ingroup arm_start
- * @brief Raspberry Pi reset code.
- * Copyright (c) 2013 by Alan Cudmore
- * Based on work by:
- * Copyright (c) 2009
- * embedded brains GmbH
- * Obere Lagerstr. 30
- * D-82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE
-#include <rtems.h>
-#include <bsp/bootcard.h>
-void bsp_reset( void)
- while (true) {
- /* Do nothing */
diff --git a/testsuites/sptests/spintr_err01/init.c b/testsuites/sptests/spintr_err01/init.c
index 84ebfdb..490a0e6 100644
--- a/testsuites/sptests/spintr_err01/init.c
+++ b/testsuites/sptests/spintr_err01/init.c
@@ -20,11 +20,8 @@ rtems_task Init(
rtems_task_argument argument
- rtems_status_code status;
TEST_BEGIN();
- #if ((CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE) || \
- defined(_C3x) || defined(_C4x))
+ #if (CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE)
puts(
"TA1 - rtems_interrupt_catch - "
"bad handler RTEMS_INVALID_ADDRESS -- SKIPPED"
@@ -32,36 +29,38 @@ rtems_task Init(
puts(
"old isr RTEMS_INVALID_ADDRESS - SKIPPED" );
-#else
- rtems_isr_entry old_service_routine;
- status = rtems_interrupt_catch(
- Service_routine,
- CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER + 1,
- &old_service_routine
- fatal_directive_status(
- status,
- RTEMS_INVALID_NUMBER,
- "rtems_interrupt_catch with invalid vector"
- puts( "TA1 - rtems_interrupt_catch - RTEMS_INVALID_NUMBER" );
+ #else
+ rtems_status_code status;
- status = rtems_interrupt_catch( NULL, 3, &old_service_routine );
- status,
- RTEMS_INVALID_ADDRESS,
- "rtems_interrupt_catch with invalid handler"
- puts( "TA1 - rtems_interrupt_catch - bad handler RTEMS_INVALID_ADDRESS" );
+ rtems_isr_entry old_service_routine;
+ status = rtems_interrupt_catch(
+ Service_routine,
+ CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER + 1,
+ &old_service_routine
+ fatal_directive_status(
+ status,
+ RTEMS_INVALID_NUMBER,
+ "rtems_interrupt_catch with invalid vector"
+ puts( "TA1 - rtems_interrupt_catch - RTEMS_INVALID_NUMBER" );
+ status = rtems_interrupt_catch( NULL, 3, &old_service_routine );
+ status,
+ RTEMS_INVALID_ADDRESS,
+ "rtems_interrupt_catch with invalid handler"
+ puts( "TA1 - rtems_interrupt_catch - bad handler RTEMS_INVALID_ADDRESS" );
+ status = rtems_interrupt_catch( Service_routine, 3, NULL );
+ status,
+ "rtems_interrupt_catch with invalid old isr pointer"
+ puts( "TA1 - rtems_interrupt_catch - old isr RTEMS_INVALID_ADDRESS" );
+ #endif
- status = rtems_interrupt_catch( Service_routine, 3, NULL );
- status,
- "rtems_interrupt_catch with invalid old isr pointer"
- puts( "TA1 - rtems_interrupt_catch - old isr RTEMS_INVALID_ADDRESS" );
-#endif
TEST_END();
1.9.3
