[PATCH 03/23] gp32/.../bspreset.c: Eliminate warning for set not used variable
Wed Sep 3 15:25:57 UTC 2014
 c/src/lib/libbsp/arm/gp32/startup/bspreset.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/c/src/lib/libbsp/arm/gp32/startup/bspreset.c b/c/src/lib/libbsp/arm/gp32/startup/bspreset.c
index e98fb72..f88e848 100644
--- a/c/src/lib/libbsp/arm/gp32/startup/bspreset.c
+++ b/c/src/lib/libbsp/arm/gp32/startup/bspreset.c
@@ -9,6 +9,8 @@
 void bsp_reset(void)
   rtems_interrupt_level level;
+  (void) level;
   rtems_interrupt_disable(level);
   /* disable mmu, invalide i-cache and call swi #4 */
   __asm__ volatile(""
1.9.3
