[PATCH 02/23] csb337/.../bspreset.c: Eliminate warning for set not used variable
Wed Sep 3 15:25:56 UTC 2014
 c/src/lib/libbsp/arm/csb337/startup/bspreset.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
index 940ff7f..1167d92 100644
--- a/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
+++ b/c/src/lib/libbsp/arm/csb337/startup/bspreset.c
@@ -17,7 +17,6 @@ void bsp_reset(void)
   rtems_interrupt_level level;
-  (void) level;
   rtems_interrupt_disable(level);
   /* Enable the watchdog timer, then wait for the world to end. */
1.9.3
